[U-Boot] [PATCH] buildman: Add GCC 8.1.0 version to tools from kernel.org
Since May 22th toolchains built from GCC 8.1.0 are available at https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/8.1.0/
Unfortunately that pretty trivial bump disclosed a few build issues, see CI job [1] for all the details.
That's a brief analysis if of any interest: 1) Wrong use of ARRAY_SIZE in drivers/mtd/nand/atmel_nand.c, see [2].
| arm: + wb45n |+In file included from include/linux/delay.h:6, |+ from include/common.h:26, |+ from drivers/mtd/nand/atmel_nand.c:13: |+drivers/mtd/nand/atmel_nand.c: In function 'pmecc_get_sigma': |+include/linux/kernel.h:46:34: error: division 'sizeof (int16_t * {aka short int *}) / sizeof (int16_t {aka short int})' does not compute the number of array elements [-Werror=sizeof-pointer-div] |+ #define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) |+ ^ |+drivers/mtd/nand/atmel_nand.c:252:35: note: in expansion of macro 'ARRAY_SIZE' |+ memset(smu, 0, sizeof(int16_t) * ARRAY_SIZE(smu)); |+ ^~~~~~~~~~ |+drivers/mtd/nand/atmel_nand.c:244:11: note: first 'sizeof' operand was declared here |+ int16_t *smu = host->pmecc_smu; |+ ^~~
I guess that's because of 'smu' variable not being an array or a pointer to array. Should be trivial to fix.
2) Issues with .dts on some ARM boards, see [3]: | arm: + vinco |+arch/arm/dts/at91-vinco.dtb: Warning (reg_format): "reg" property in /ahb/apb/timer@fc024000/timer@0 has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) ...and a couple of more of the similar type.
3) Assembler issues on efi-x86, see [4]: | x86: + efi-x86 |+{standard input}: Assembler messages: |+{standard input}:21624: Error: junk at end of line, first unrecognized character is `@' |+{standard input}:21669: Error: junk at end of line, first unrecognized character is `@' |+{standard input}:21624: Error: can't resolve `end.6766' {.u_boot_list_2_fit_loadable_3 section} - `start.6763' {.u_boot_list_2_fit_loadable_1 section} |+{standard input}:21669: Error: can't resolve `end.6766' {.u_boot_list_2_fit_loadable_3 section} - `start.6763' {.u_boot_list_2_fit_loadable_1 section}
4) -Werror=tautological-compare on some PowerPC boards, see [5]: | powerpc: + T1040D4RDB_SPIFLASH |+drivers/net/fm/t1040.c: In function 'fman_port_enet_if': |+drivers/net/fm/t1040.c:19:53: error: bitwise comparison always evaluates to false [-Werror=tautological-compare] |+ ((rcwsr13 & FSL_CORENET_RCWSR13_MAC2_GMII_SEL) == |+ ^~ |+drivers/net/fm/t1040.c:44:48: error: bitwise comparison always evaluates to false [-Werror=tautological-compare] |+ else if ((rcwsr13 & FSL_CORENET_RCWSR13_EC2) == |+
5) Missing property '#phy-cells' in node in arch/arm/dts/am335x-boneblack.dts, see [6]: | arm: + rastaban pxm2 smartweb etamin thuban draco rut |+arch/arm/dts/am335x-boneblack.dtb: Warning (phys_property): Missing property '#phy-cells' in node /ocp/usb@47400000/usb-phy@47401300 or bad phandle (referred from /ocp/usb@47400000/usb@47401000:phys[0])
[1] https://travis-ci.org/abrodkin/u-boot/builds/383423675 [2] https://travis-ci.org/abrodkin/u-boot/jobs/383423678 [3] https://travis-ci.org/abrodkin/u-boot/jobs/383423695 [4] https://travis-ci.org/abrodkin/u-boot/jobs/383423696 [5] https://travis-ci.org/abrodkin/u-boot/jobs/383423714 [6] https://travis-ci.org/abrodkin/u-boot/jobs/383423717
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Cc: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Patrice Chotard patrice.chotard@st.com Cc: Jagan Teki jagan@amarulasolutions.com Cc: Dmitry Korunov dessel.k@gmail.com Cc: Alexander Graf agraf@suse.de Cc: Simon Glass sjg@chromium.org Cc: Jason Rush jarush@gmail.com Cc: Scott Wood oss@buserror.net Cc: Marek Vasut marex@denx.de --- .travis.yml | 2 +- tools/buildman/toolchain.py | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/.travis.yml b/.travis.yml index 589ca8982443..d5e517574bf3 100644 --- a/.travis.yml +++ b/.travis.yml @@ -68,7 +68,7 @@ before_script: - if [[ "${TOOLCHAIN}" == *sh* ]]; then ./tools/buildman/buildman --fetch-arch sh2 ; fi - if [[ "${TOOLCHAIN}" == *x86_64* ]]; then ./tools/buildman/buildman --fetch-arch x86_64; - echo -e "\n[toolchain-prefix]\nx86 = ${HOME}/.buildman-toolchains/gcc-7.3.0-nolibc/x86_64-linux/bin/x86_64-linux-" >> ~/.buildman; + echo -e "\n[toolchain-prefix]\nx86 = ${HOME}/.buildman-toolchains/gcc-8.1.0-nolibc/x86_64-linux/bin/x86_64-linux-" >> ~/.buildman; fi - if [[ "${TOOLCHAIN}" == *arc* ]]; then ./tools/buildman/buildman --fetch-arch arc ; fi - if [[ "${TOOLCHAIN}" == *xtensa* ]]; then diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 4b35f400e97d..0e9f43fd3fcc 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -430,7 +430,7 @@ class Toolchains: """ arch = command.OutputOneLine('uname', '-m') base = 'https://www.kernel.org/pub/tools/crosstool/files/bin' - versions = ['7.3.0', '6.4.0', '4.9.4'] + versions = ['8.1.0', '7.3.0', '6.4.0', '4.9.4'] links = [] for version in versions: url = '%s/%s/%s/' % (base, arch, version)
Alexey Brodkin
