[U-Boot] [PATCH] iMX6: Disable the L2 before chaning the PL310 latency
The Latency parameters of PL310 Tag RAM latency control register and Data RAM Latency control register are set in L2 cache enable. And setting these registers must have PL310 NOT enabled.
But when using Plugin mode boot, the PL310 is enabled by bootrom. The patch disables the PL310 before applying this setting.
Signed-off-by: Ye.Li Ye.Li@freescale.com --- arch/arm/cpu/armv7/mx6/soc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index f20bdeb..cc2231a 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -394,6 +394,9 @@ void v7_outer_cache_enable(void) } #endif
+ /* Must disable the L2 before changing the latency parameters */ + clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); + writel(0x132, &pl310->pl310_tag_latency_ctrl); writel(0x132, &pl310->pl310_data_latency_ctrl);
Hi Ye,
- /* Must disable the L2 before changing the latency parameters */
- clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN);
- writel(0x132, &pl310->pl310_tag_latency_ctrl); writel(0x132, &pl310->pl310_data_latency_ctrl);
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Stefano Babic
Ye.Li
