[PATCH 0/8 v7] TPM cleanups and MMIO driver
Hi! This is the update for [1].
Changes since v6: - added a few missing @return in function documentation - switched TPM1_ defines to TPM_INFINEON_ Changes since v5: - Fixed 2 tpmv1.2 drivers. Some of the internal driver functions were conflicting with the new API Changes since v4: - renamed struct udevice *udev -> struct udevice *dev - added comments on struct tpm_tis_phy_ops - removed duplicate defines from tpm2_tis_spi driver (now in tpm_tis.h) - moved API function description for the .c to the .h file - added Reviewed-by tags from Simon and Heinrich Changes since v3: - Coverted SPI TPM to use the API as well - moved some log_info to log_debug - Added documentation on how to run QEMU and enabled TPM by default o arm qemu builds Changes since v2: - Add myself as a maintainer on TPM drivers Changes since v1: - split off the tis core code into a different file
Ilias Apalodimas (6): tpm2: Introduce TIS tpm core tpm2: Add a TPMv2 MMIO TIS driver tpm: Use the new API on tpm2 spi driver configs: Enable tpmv2 mmio on qemu for arm/arm64 doc: qemu: Add instructions for swtpm usage MAINTAINERS: Add entry for TPM drivers
[1] https://lore.kernel.org/u-boot/20211107213312.263357-1-ilias.apalodimas@lina...
Ilias Apalodimas (8): tpm: refactor function names and macros for infineon v1.2 TPM tpm: refactor function names for LPC based TPMs tpm2: Introduce TIS tpm core tpm2: Add a TPMv2 MMIO TIS driver tpm: Use the new API on tpm2 spi driver configs: Enable tpmv2 mmio on qemu for arm/arm64 doc: qemu: Add instructions for swtpm usage MAINTAINERS: Add entry for TPM drivers
MAINTAINERS | 5 + configs/qemu_arm64_defconfig | 2 + configs/qemu_arm_defconfig | 2 + doc/board/emulation/qemu-arm.rst | 25 ++ drivers/tpm/Kconfig | 9 + drivers/tpm/Makefile | 3 +- drivers/tpm/tpm2_tis_core.c | 463 +++++++++++++++++++++++++++++++ drivers/tpm/tpm2_tis_mmio.c | 157 +++++++++++ drivers/tpm/tpm2_tis_spi.c | 447 +++-------------------------- drivers/tpm/tpm_tis.h | 136 +++++++++ drivers/tpm/tpm_tis_infineon.c | 34 +-- drivers/tpm/tpm_tis_lpc.c | 4 +- include/tpm-v2.h | 1 + 13 files changed, 852 insertions(+), 436 deletions(-) create mode 100644 drivers/tpm/tpm2_tis_core.c create mode 100644 drivers/tpm/tpm2_tis_mmio.c
With the upcoming TPM2 API, some of the functions name are part of the new header file. So switch conflicting internal function names and defines.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/tpm/tpm_tis_infineon.c | 34 +++++++++++++++++----------------- 1 file changed, 17 insertions(+), 17 deletions(-)
diff --git a/drivers/tpm/tpm_tis_infineon.c b/drivers/tpm/tpm_tis_infineon.c index f414e5657db9..525ad72f4c92 100644 --- a/drivers/tpm/tpm_tis_infineon.c +++ b/drivers/tpm/tpm_tis_infineon.c @@ -50,10 +50,10 @@ static const char * const chip_name[] = { [UNKNOWN] = "unknown/fallback to slb9635", };
-#define TPM_ACCESS(l) (0x0000 | ((l) << 4)) -#define TPM_STS(l) (0x0001 | ((l) << 4)) -#define TPM_DATA_FIFO(l) (0x0005 | ((l) << 4)) -#define TPM_DID_VID(l) (0x0006 | ((l) << 4)) +#define TPM_INFINEON_ACCESS(l) (0x0000 | ((l) << 4)) +#define TPM_INFINEON_STS(l) (0x0001 | ((l) << 4)) +#define TPM_INFINEON_DATA_FIFO(l) (0x0005 | ((l) << 4)) +#define TPM_INFINEON_DID_VID(l) (0x0006 | ((l) << 4))
/* * tpm_tis_i2c_read() - read from TPM register @@ -197,7 +197,7 @@ static int tpm_tis_i2c_check_locality(struct udevice *dev, int loc) u8 buf; int rc;
- rc = tpm_tis_i2c_read(dev, TPM_ACCESS(loc), &buf, 1); + rc = tpm_tis_i2c_read(dev, TPM_INFINEON_ACCESS(loc), &buf, 1); if (rc < 0) return rc;
@@ -215,12 +215,12 @@ static void tpm_tis_i2c_release_locality(struct udevice *dev, int loc, const u8 mask = TPM_ACCESS_REQUEST_PENDING | TPM_ACCESS_VALID; u8 buf;
- if (tpm_tis_i2c_read(dev, TPM_ACCESS(loc), &buf, 1) < 0) + if (tpm_tis_i2c_read(dev, TPM_INFINEON_ACCESS(loc), &buf, 1) < 0) return;
if (force || (buf & mask) == mask) { buf = TPM_ACCESS_ACTIVE_LOCALITY; - tpm_tis_i2c_write(dev, TPM_ACCESS(loc), &buf, 1); + tpm_tis_i2c_write(dev, TPM_INFINEON_ACCESS(loc), &buf, 1); } }
@@ -240,7 +240,7 @@ static int tpm_tis_i2c_request_locality(struct udevice *dev, int loc) return rc; }
- rc = tpm_tis_i2c_write(dev, TPM_ACCESS(loc), &buf, 1); + rc = tpm_tis_i2c_write(dev, TPM_INFINEON_ACCESS(loc), &buf, 1); if (rc) { debug("%s: Failed to write to TPM: %d\n", __func__, rc); return rc; @@ -271,7 +271,7 @@ static u8 tpm_tis_i2c_status(struct udevice *dev) /* NOTE: Since i2c read may fail, return 0 in this case --> time-out */ u8 buf;
- if (tpm_tis_i2c_read(dev, TPM_STS(chip->locality), &buf, 1) < 0) + if (tpm_tis_i2c_read(dev, TPM_INFINEON_STS(chip->locality), &buf, 1) < 0) return 0; else return buf; @@ -286,7 +286,7 @@ static int tpm_tis_i2c_ready(struct udevice *dev) u8 buf = TPM_STS_COMMAND_READY;
debug("%s\n", __func__); - rc = tpm_tis_i2c_write_long(dev, TPM_STS(chip->locality), &buf, 1); + rc = tpm_tis_i2c_write_long(dev, TPM_INFINEON_STS(chip->locality), &buf, 1); if (rc) debug("%s: rc=%d\n", __func__, rc);
@@ -306,7 +306,7 @@ static ssize_t tpm_tis_i2c_get_burstcount(struct udevice *dev) stop = chip->timeout_d; do { /* Note: STS is little endian */ - addr = TPM_STS(chip->locality) + 1; + addr = TPM_INFINEON_STS(chip->locality) + 1; if (tpm_tis_i2c_read(dev, addr, buf, 3) < 0) burstcnt = 0; else @@ -360,7 +360,7 @@ static int tpm_tis_i2c_recv_data(struct udevice *dev, u8 *buf, size_t count) if (burstcnt > (count - size)) burstcnt = count - size;
- rc = tpm_tis_i2c_read(dev, TPM_DATA_FIFO(chip->locality), + rc = tpm_tis_i2c_read(dev, TPM_INFINEON_DATA_FIFO(chip->locality), &(buf[size]), burstcnt); if (rc == 0) size += burstcnt; @@ -462,7 +462,7 @@ static int tpm_tis_i2c_send(struct udevice *dev, const u8 *buf, size_t len) burstcnt = CONFIG_TPM_TIS_I2C_BURST_LIMITATION_LEN; #endif /* CONFIG_TPM_TIS_I2C_BURST_LIMITATION */
- rc = tpm_tis_i2c_write(dev, TPM_DATA_FIFO(chip->locality), + rc = tpm_tis_i2c_write(dev, TPM_INFINEON_DATA_FIFO(chip->locality), &(buf[count]), burstcnt); if (rc == 0) count += burstcnt; @@ -482,7 +482,7 @@ static int tpm_tis_i2c_send(struct udevice *dev, const u8 *buf, size_t len) }
/* Go and do it */ - rc = tpm_tis_i2c_write(dev, TPM_STS(chip->locality), &sts, 1); + rc = tpm_tis_i2c_write(dev, TPM_INFINEON_STS(chip->locality), &sts, 1); if (rc < 0) return rc; debug("%s: done, rc=%d\n", __func__, rc); @@ -525,7 +525,7 @@ static int tpm_tis_i2c_init(struct udevice *dev) return rc;
/* Read four bytes from DID_VID register */ - if (tpm_tis_i2c_read(dev, TPM_DID_VID(0), (uchar *)&vendor, 4) < 0) { + if (tpm_tis_i2c_read(dev, TPM_INFINEON_DID_VID(0), (uchar *)&vendor, 4) < 0) { tpm_tis_i2c_release_locality(dev, 0, 1); return -EIO; } @@ -583,7 +583,7 @@ static int tpm_tis_i2c_close(struct udevice *dev) return 0; }
-static int tpm_tis_get_desc(struct udevice *dev, char *buf, int size) +static int tpm_tis_i2c_get_desc(struct udevice *dev, char *buf, int size) { struct tpm_chip *chip = dev_get_priv(dev);
@@ -615,7 +615,7 @@ static int tpm_tis_i2c_probe(struct udevice *dev) static const struct tpm_ops tpm_tis_i2c_ops = { .open = tpm_tis_i2c_open, .close = tpm_tis_i2c_close, - .get_desc = tpm_tis_get_desc, + .get_desc = tpm_tis_i2c_get_desc, .send = tpm_tis_i2c_send, .recv = tpm_tis_i2c_recv, .cleanup = tpm_tis_i2c_cleanup,
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Heinrich Schuchardt heinrich.schuchardt@canaonical.com Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/tpm/tpm_tis_lpc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/tpm/tpm_tis_lpc.c b/drivers/tpm/tpm_tis_lpc.c index 003c0d8816d0..13a133d58ebd 100644 --- a/drivers/tpm/tpm_tis_lpc.c +++ b/drivers/tpm/tpm_tis_lpc.c @@ -443,7 +443,7 @@ static int tpm_tis_lpc_open(struct udevice *dev) return 0; }
-static int tpm_tis_get_desc(struct udevice *dev, char *buf, int size) +static int tpm_tis_lpc_get_desc(struct udevice *dev, char *buf, int size) { ulong chip_type = dev_get_driver_data(dev);
@@ -458,7 +458,7 @@ static int tpm_tis_get_desc(struct udevice *dev, char *buf, int size) static const struct tpm_ops tpm_tis_lpc_ops = { .open = tpm_tis_lpc_open, .close = tpm_tis_lpc_close, - .get_desc = tpm_tis_get_desc, + .get_desc = tpm_tis_lpc_get_desc, .send = tis_senddata, .recv = tis_readresponse, };
There's a lot of code duplication in U-Boot right now. All the TPM TIS compatible drivers we have at the moment have their own copy of a TIS implementation.
So let's create a common layer which implements the core TIS functions. Any driver added from now own, which is compatible with the TIS spec, will only have to provide the underlying bus communication mechanisms.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/tpm/tpm2_tis_core.c | 463 ++++++++++++++++++++++++++++++++++++ drivers/tpm/tpm_tis.h | 136 +++++++++++ include/tpm-v2.h | 1 + 3 files changed, 600 insertions(+) create mode 100644 drivers/tpm/tpm2_tis_core.c
diff --git a/drivers/tpm/tpm2_tis_core.c b/drivers/tpm/tpm2_tis_core.c new file mode 100644 index 000000000000..ec8c730fe906 --- /dev/null +++ b/drivers/tpm/tpm2_tis_core.c @@ -0,0 +1,463 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2020, Linaro Limited + * + * Based on the Linux TIS core interface and U-Boot original SPI TPM driver + */ + +#include <common.h> +#include <dm.h> +#include <tpm-v2.h> +#include <linux/delay.h> +#include <linux/unaligned/be_byteshift.h> +#include "tpm_tis.h" + +int tpm_tis_get_desc(struct udevice *dev, char *buf, int size) +{ + struct tpm_chip *chip = dev_get_priv(dev); + + if (size < 80) + return -ENOSPC; + + return snprintf(buf, size, + "%s v2.0: VendorID 0x%04x, DeviceID 0x%04x, RevisionID 0x%02x [%s]", + dev->name, chip->vend_dev & 0xFFFF, + chip->vend_dev >> 16, chip->rid, + (chip->is_open ? "open" : "closed")); +} + +/** + * tpm_tis_check_locality - Check the current TPM locality + * + * @dev: TPM device + * @loc: locality + * + * Return: True if the tested locality matches + */ +static bool tpm_tis_check_locality(struct udevice *dev, int loc) +{ + struct tpm_chip *chip = dev_get_priv(dev); + struct tpm_tis_phy_ops *phy_ops = chip->phy_ops; + u8 locality; + + phy_ops->read_bytes(dev, TPM_ACCESS(loc), 1, &locality); + if ((locality & (TPM_ACCESS_ACTIVE_LOCALITY | TPM_ACCESS_VALID | + TPM_ACCESS_REQUEST_USE)) == + (TPM_ACCESS_ACTIVE_LOCALITY | TPM_ACCESS_VALID)) { + chip->locality = loc; + return true; + } + + return false; +} + +/** + * tpm_tis_request_locality - Request a locality from the TPM + * + * @dev: TPM device + * @loc: requested locality + * + * Return: 0 on success -1 on failure + */ +int tpm_tis_request_locality(struct udevice *dev, int loc) +{ + struct tpm_chip *chip = dev_get_priv(dev); + struct tpm_tis_phy_ops *phy_ops = chip->phy_ops; + u8 buf = TPM_ACCESS_REQUEST_USE; + unsigned long start, stop; + + if (tpm_tis_check_locality(dev, loc)) + return 0; + + phy_ops->write_bytes(dev, TPM_ACCESS(loc), 1, &buf); + start = get_timer(0); + stop = chip->timeout_a; + do { + if (tpm_tis_check_locality(dev, loc)) + return 0; + mdelay(TPM_TIMEOUT_MS); + } while (get_timer(start) < stop); + + return -1; +} + +/** + * tpm_tis_status - Check the current device status + * + * @dev: TPM device + * @status: return value of status + * + * Return: 0 on success, negative on failure + */ +static int tpm_tis_status(struct udevice *dev, u8 *status) +{ + struct tpm_chip *chip = dev_get_priv(dev); + struct tpm_tis_phy_ops *phy_ops = chip->phy_ops; + + if (chip->locality < 0) + return -EINVAL; + + phy_ops->read_bytes(dev, TPM_STS(chip->locality), 1, status); + + if ((*status & TPM_STS_READ_ZERO)) { + log_err("TPM returned invalid status\n"); + return -EINVAL; + } + + return 0; +} + +/** + * tpm_tis_release_locality - Release the requested locality + * + * @dev: TPM device + * @loc: requested locality + * + * Return: 0 on success, negative on failure + */ +int tpm_tis_release_locality(struct udevice *dev, int loc) +{ + struct tpm_chip *chip = dev_get_priv(dev); + struct tpm_tis_phy_ops *phy_ops = chip->phy_ops; + u8 buf = TPM_ACCESS_ACTIVE_LOCALITY; + int ret; + + if (chip->locality < 0) + return 0; + + ret = phy_ops->write_bytes(dev, TPM_ACCESS(loc), 1, &buf); + chip->locality = -1; + + return ret; +} + +/** + * tpm_tis_wait_for_stat - Wait for TPM to become ready + * + * @dev: TPM device + * @mask: mask to match + * @timeout: timeout for retries + * @status: current status + * + * Return: 0 on success, negative on failure + */ +static int tpm_tis_wait_for_stat(struct udevice *dev, u8 mask, + unsigned long timeout, u8 *status) +{ + unsigned long start = get_timer(0); + unsigned long stop = timeout; + int ret; + + do { + mdelay(TPM_TIMEOUT_MS); + ret = tpm_tis_status(dev, status); + if (ret) + return ret; + + if ((*status & mask) == mask) + return 0; + } while (get_timer(start) < stop); + + return -ETIMEDOUT; +} + +/** + * tpm_tis_get_burstcount - Get the burstcount for the data FIFO + * + * @dev: TPM device + * @burstcount: current burstcount + * + * Return: 0 on success, negative on failure + */ +static int tpm_tis_get_burstcount(struct udevice *dev, size_t *burstcount) +{ + struct tpm_chip *chip = dev_get_priv(dev); + struct tpm_tis_phy_ops *phy_ops = chip->phy_ops; + unsigned long start, stop; + u32 burst; + + if (chip->locality < 0) + return -EINVAL; + + /* wait for burstcount */ + start = get_timer(0); + /* + * This is the TPMv2 defined timeout. Change this in case you want to + * make the driver compatile to TPMv1 + */ + stop = chip->timeout_a; + do { + phy_ops->read32(dev, TPM_STS(chip->locality), &burst); + *burstcount = (burst >> 8) & 0xFFFF; + if (*burstcount) + return 0; + + mdelay(TPM_TIMEOUT_MS); + } while (get_timer(start) < stop); + + return -ETIMEDOUT; +} + +/** + * tpm_tis_ready - Cancel pending comands and get the device on a ready state + * + * @dev: TPM device + * + * Return: 0 on success, negative on failure + */ +static int tpm_tis_ready(struct udevice *dev) +{ + struct tpm_chip *chip = dev_get_priv(dev); + struct tpm_tis_phy_ops *phy_ops = chip->phy_ops; + u8 data = TPM_STS_COMMAND_READY; + + /* This will cancel any pending commands */ + return phy_ops->write_bytes(dev, TPM_STS(chip->locality), 1, &data); +} + +int tpm_tis_send(struct udevice *dev, const u8 *buf, size_t len) +{ + struct tpm_chip *chip = dev_get_priv(dev); + struct tpm_tis_phy_ops *phy_ops = chip->phy_ops; + size_t burstcnt, wr_size, sent = 0; + u8 data = TPM_STS_GO; + u8 status; + int ret; + + if (!chip) + return -ENODEV; + + ret = tpm_tis_request_locality(dev, 0); + if (ret < 0) + return -EBUSY; + + ret = tpm_tis_status(dev, &status); + if (ret) + goto release_locality; + + if (!(status & TPM_STS_COMMAND_READY)) { + ret = tpm_tis_ready(dev); + if (ret) { + log_err("Can't cancel previous TPM operation\n"); + goto release_locality; + } + ret = tpm_tis_wait_for_stat(dev, TPM_STS_COMMAND_READY, + chip->timeout_b, &status); + if (ret) { + log_err("TPM not ready\n"); + goto release_locality; + } + } + + while (len > 0) { + ret = tpm_tis_get_burstcount(dev, &burstcnt); + if (ret) + goto release_locality; + + wr_size = min(len, burstcnt); + ret = phy_ops->write_bytes(dev, TPM_DATA_FIFO(chip->locality), + wr_size, buf + sent); + if (ret < 0) + goto release_locality; + + ret = tpm_tis_wait_for_stat(dev, TPM_STS_VALID, + chip->timeout_c, &status); + if (ret) + goto release_locality; + + sent += wr_size; + len -= wr_size; + /* make sure the TPM expects more data */ + if (len && !(status & TPM_STS_DATA_EXPECT)) { + ret = -EIO; + goto release_locality; + } + } + + /* + * Make a final check ensuring everything is ok and the TPM expects no + * more data + */ + ret = tpm_tis_wait_for_stat(dev, TPM_STS_VALID, chip->timeout_c, + &status); + if (ret) + goto release_locality; + + if (status & TPM_STS_DATA_EXPECT) { + ret = -EIO; + goto release_locality; + } + + ret = phy_ops->write_bytes(dev, TPM_STS(chip->locality), 1, &data); + if (ret) + goto release_locality; + + return sent; + +release_locality: + tpm_tis_ready(dev); + tpm_tis_release_locality(dev, chip->locality); + + return ret; +} + +static int tpm_tis_recv_data(struct udevice *dev, u8 *buf, size_t count) +{ + struct tpm_chip *chip = dev_get_priv(dev); + struct tpm_tis_phy_ops *phy_ops = chip->phy_ops; + int size = 0, len, ret; + size_t burstcnt; + u8 status; + + while (size < count && + tpm_tis_wait_for_stat(dev, TPM_STS_DATA_AVAIL | TPM_STS_VALID, + chip->timeout_c, &status) == 0) { + ret = tpm_tis_get_burstcount(dev, &burstcnt); + if (ret) + return ret; + + len = min_t(int, burstcnt, count - size); + ret = phy_ops->read_bytes(dev, TPM_DATA_FIFO(chip->locality), + len, buf + size); + if (ret < 0) + return ret; + + size += len; + } + + return size; +} + +/** + * tpm_tis_recv - Receive data from a device + * + * @dev: TPM device + * @buf: buffer to copy data + * @size: buffer size + * + * Return: bytes read or negative on failure + */ +int tpm_tis_recv(struct udevice *dev, u8 *buf, size_t count) +{ + struct tpm_chip *chip = dev_get_priv(dev); + int size, expected; + + if (count < TPM_HEADER_SIZE) + return -E2BIG; + + size = tpm_tis_recv_data(dev, buf, TPM_HEADER_SIZE); + if (size < TPM_HEADER_SIZE) { + log_err("TPM error, unable to read header\n"); + goto out; + } + + expected = get_unaligned_be32(buf + TPM_CMD_COUNT_OFFSET); + if (expected > count) { + size = -EIO; + log_warning("Too much data: %d > %zu\n", expected, count); + goto out; + } + + size += tpm_tis_recv_data(dev, &buf[TPM_HEADER_SIZE], + expected - TPM_HEADER_SIZE); + if (size < expected) { + log(LOGC_NONE, LOGL_ERR, + "TPM error, unable to read remaining bytes of result\n"); + size = -EIO; + goto out; + } + +out: + tpm_tis_ready(dev); + /* acquired in tpm_tis_send */ + tpm_tis_release_locality(dev, chip->locality); + + return size; +} + +int tpm_tis_cleanup(struct udevice *dev) +{ + struct tpm_chip *chip = dev_get_priv(dev); + + tpm_tis_ready(dev); + tpm_tis_release_locality(dev, chip->locality); + + return 0; +} + +int tpm_tis_open(struct udevice *dev) +{ + struct tpm_chip *chip = dev_get_priv(dev); + int ret; + + if (chip->is_open) + return -EBUSY; + + ret = tpm_tis_request_locality(dev, 0); + if (!ret) + chip->is_open = 1; + + return ret; +} + +void tpm_tis_ops_register(struct udevice *dev, struct tpm_tis_phy_ops *ops) +{ + struct tpm_chip *chip = dev_get_priv(dev); + + chip->phy_ops = ops; +} + +static bool tis_check_ops(struct tpm_tis_phy_ops *phy_ops) +{ + if (!phy_ops || !phy_ops->read_bytes || !phy_ops->write_bytes || + !phy_ops->read32 || !phy_ops->write32) + return false; + + return true; +} + +int tpm_tis_init(struct udevice *dev) +{ + struct tpm_chip *chip = dev_get_priv(dev); + struct tpm_tis_phy_ops *phy_ops = chip->phy_ops; + int ret; + u32 tmp; + + if (!tis_check_ops(phy_ops)) { + log_err("Driver bug. No bus ops defined\n"); + return -1; + } + ret = tpm_tis_request_locality(dev, 0); + if (ret) + return ret; + + chip->timeout_a = TIS_SHORT_TIMEOUT_MS; + chip->timeout_b = TIS_LONG_TIMEOUT_MS; + chip->timeout_c = TIS_SHORT_TIMEOUT_MS; + chip->timeout_d = TIS_SHORT_TIMEOUT_MS; + + /* Disable interrupts */ + phy_ops->read32(dev, TPM_INT_ENABLE(chip->locality), &tmp); + tmp |= TPM_INTF_CMD_READY_INT | TPM_INTF_LOCALITY_CHANGE_INT | + TPM_INTF_DATA_AVAIL_INT | TPM_INTF_STS_VALID_INT; + tmp &= ~TPM_GLOBAL_INT_ENABLE; + phy_ops->write32(dev, TPM_INT_ENABLE(chip->locality), tmp); + + phy_ops->read_bytes(dev, TPM_RID(chip->locality), 1, &chip->rid); + phy_ops->read32(dev, TPM_DID_VID(chip->locality), &chip->vend_dev); + + return tpm_tis_release_locality(dev, chip->locality); +} + +int tpm_tis_close(struct udevice *dev) +{ + struct tpm_chip *chip = dev_get_priv(dev); + int ret = 0; + + if (chip->is_open) { + ret = tpm_tis_release_locality(dev, chip->locality); + chip->is_open = 0; + } + + return ret; +} diff --git a/drivers/tpm/tpm_tis.h b/drivers/tpm/tpm_tis.h index 2a160fe05c9a..93f622f29104 100644 --- a/drivers/tpm/tpm_tis.h +++ b/drivers/tpm/tpm_tis.h @@ -21,6 +21,73 @@ #include <linux/compiler.h> #include <linux/types.h>
+/** + * struct tpm_tis_phy_ops - low-level TPM bus operations + */ +struct tpm_tis_phy_ops { + /* read_bytes() - Read a number of bytes from the device + * + * @udev: TPM device + * @addr: offset from device base + * @len: len to read + * @result: data read + * + * @return: 0 on success, negative on failure + */ + int (*read_bytes)(struct udevice *udev, u32 addr, u16 len, + u8 *result); + /* write_bytes() - Read a number of bytes from the device + * + * @udev: TPM device + * @addr: offset from device base + * @len: len to read + * @value: data to write + * + * @return: 0 on success, negative on failure + */ + int (*write_bytes)(struct udevice *udev, u32 addr, u16 len, + const u8 *value); + /* read32() - Read a 32bit value of the device + * + * @udev: TPM device + * @addr: offset from device base + * @result: data read + * + * @return: 0 on success, negative on failure + */ + int (*read32)(struct udevice *udev, u32 addr, u32 *result); + /* write32() - write a 32bit value to the device + * + * @udev: TPM device + * @addr: offset from device base + * @src: data to write + * + * @return: 0 on success, negative on failure + */ + int (*write32)(struct udevice *udev, u32 addr, u32 src); +}; + +enum tis_int_flags { + TPM_GLOBAL_INT_ENABLE = 0x80000000, + TPM_INTF_BURST_COUNT_STATIC = 0x100, + TPM_INTF_CMD_READY_INT = 0x080, + TPM_INTF_INT_EDGE_FALLING = 0x040, + TPM_INTF_INT_EDGE_RISING = 0x020, + TPM_INTF_INT_LEVEL_LOW = 0x010, + TPM_INTF_INT_LEVEL_HIGH = 0x008, + TPM_INTF_LOCALITY_CHANGE_INT = 0x004, + TPM_INTF_STS_VALID_INT = 0x002, + TPM_INTF_DATA_AVAIL_INT = 0x001, +}; + +#define TPM_ACCESS(l) (0x0000 | ((l) << 12)) +#define TPM_INT_ENABLE(l) (0x0008 | ((l) << 12)) +#define TPM_STS(l) (0x0018 | ((l) << 12)) +#define TPM_DATA_FIFO(l) (0x0024 | ((l) << 12)) +#define TPM_DID_VID(l) (0x0f00 | ((l) << 12)) +#define TPM_RID(l) (0x0f04 | ((l) << 12)) +#define TPM_INTF_CAPS(l) (0x0014 | ((l) << 12)) + enum tpm_timeout { TPM_TIMEOUT_MS = 5, TIS_SHORT_TIMEOUT_MS = 750, @@ -43,6 +110,7 @@ struct tpm_chip { u8 rid; unsigned long timeout_a, timeout_b, timeout_c, timeout_d; /* msec */ ulong chip_type; + struct tpm_tis_phy_ops *phy_ops; };
struct tpm_input_header { @@ -130,4 +198,72 @@ enum tis_status { }; #endif
+/** + * tpm_tis_open - Open the device and request locality 0 + * + * @dev: TPM device + * + * @return: 0 on success, negative on failure + */ +int tpm_tis_open(struct udevice *udev); +/** + * tpm_tis_close - Close the device and release locality + * + * @dev: TPM device + * + * @return: 0 on success, negative on failure + */ +int tpm_tis_close(struct udevice *udev); +/** tpm_tis_cleanup - Get the device in ready state and release locality + * + * @dev: TPM device + * + * @return: always 0 + */ +int tpm_tis_cleanup(struct udevice *udev); +/** + * tpm_tis_send - send data to the device + * + * @dev: TPM device + * @buf: buffer to send + * @len: size of the buffer + * + * @return: number of bytes sent or negative on failure + */ +int tpm_tis_send(struct udevice *udev, const u8 *buf, size_t len); +/** + * tpm_tis_recv_data - Receive data from a device. Wrapper for tpm_tis_recv + * + * @dev: TPM device + * @buf: buffer to copy data + * @size: buffer size + * + * @return: bytes read or negative on failure + */ +int tpm_tis_recv(struct udevice *udev, u8 *buf, size_t count); +/** + * tpm_tis_get_desc - Get the TPM description + * + * @dev: TPM device + * @buf: buffer to fill data + * @size: buffer size + * + * @return: Number of characters written (or would have been written) in buffer + */ +int tpm_tis_get_desc(struct udevice *udev, char *buf, int size); +/** + * tpm_tis_init - inititalize the device + * + * @dev: TPM device + * + * @return: 0 on success, negative on failure + */ +int tpm_tis_init(struct udevice *udev); +/** + * tpm_tis_ops_register - register the PHY ops for the device + * + * @dev: TPM device + * @ops: tpm_tis_phy_ops ops for the device + */ +void tpm_tis_ops_register(struct udevice *udev, struct tpm_tis_phy_ops *ops); #endif diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 947458b0bdfd..ceff7d245ed2 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -396,6 +396,7 @@ enum { TPM_STS_DATA_EXPECT = 1 << 3, TPM_STS_SELF_TEST_DONE = 1 << 2, TPM_STS_RESPONSE_RETRY = 1 << 1, + TPM_STS_READ_ZERO = 0x23 };
enum {
On Tue, 9 Nov 2021 at 00:02, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
- Copyright (c) 2020, Linaro Limited
- Based on the Linux TIS core interface and U-Boot original SPI TPM driver
if (size < 80)
return -ENOSPC;
- tpm_tis_check_locality - Check the current TPM locality
- @dev: TPM device
- @loc: locality
- Return: True if the tested locality matches
u8 locality;
return true;
return false;
- tpm_tis_request_locality - Request a locality from the TPM
- @dev: TPM device
- @loc: requested locality
- Return: 0 on success -1 on failure
do {
return -1;
- tpm_tis_status - Check the current device status
- @dev: TPM device
- @status: return value of status
- Return: 0 on success, negative on failure
return -EINVAL;
return -EINVAL;
- tpm_tis_release_locality - Release the requested locality
- @dev: TPM device
int ret;
return ret;
- tpm_tis_wait_for_stat - Wait for TPM to become ready
- @dev: TPM device
- @mask: mask to match
- @timeout: timeout for retries
- @status: current status
int ret;
do {
if (ret)
return ret;
return -ETIMEDOUT;
- tpm_tis_get_burstcount - Get the burstcount for the data FIFO
- @dev: TPM device
- @burstcount: current burstcount
u32 burst;
return -EINVAL;
do {
if (*burstcount)
return -ETIMEDOUT;
- tpm_tis_ready - Cancel pending comands and get the device on a ready state
- @dev: TPM device
u8 status;
int ret;
if (!chip)
return -ENODEV;
if (ret < 0)
return -EBUSY;
if (ret)
if (ret) {
if (ret) {
while (len > 0) {
if (ret)
if (ret < 0)
if (ret)
sent += wr_size;
len -= wr_size;
ret = -EIO;
* more data
&status);
if (ret)
ret = -EIO;
if (ret)
return sent;
+release_locality:
tpm_tis_ready(dev);
return ret;
size_t burstcnt;
u8 status;
if (ret)
return ret;
len, buf + size);
if (ret < 0)
return ret;
size += len;
return size;
- tpm_tis_recv - Receive data from a device
- @dev: TPM device
- @buf: buffer to copy data
- @size: buffer size
- Return: bytes read or negative on failure
int size, expected;
return -E2BIG;
goto out;
size = -EIO;
goto out;
size = -EIO;
goto out;
+out:
tpm_tis_ready(dev);
return size;
tpm_tis_ready(dev);
int ret;
if (chip->is_open)
return -EBUSY;
if (!ret)
chip->is_open = 1;
return ret;
return false;
return true;
int ret;
u32 tmp;
return -1;
if (ret)
return ret;
int ret = 0;
chip->is_open = 0;
return ret;
- struct tpm_tis_phy_ops - low-level TPM bus operations
* @udev: TPM device
* @len: len to read
u8 *result);
* @udev: TPM device
* @len: len to read
const u8 *value);
* @udev: TPM device
* @udev: TPM device
- tpm_tis_open - Open the device and request locality 0
- @dev: TPM device
- @return: 0 on success, negative on failure
- tpm_tis_close - Close the device and release locality
- @dev: TPM device
- @dev: TPM device
- @return: always 0
- tpm_tis_send - send data to the device
- @dev: TPM device
- @buf: buffer to send
- @len: size of the buffer
- @return: number of bytes sent or negative on failure
- tpm_tis_recv_data - Receive data from a device. Wrapper for tpm_tis_recv
- @dev: TPM device
- @return: bytes read or negative on failure
- tpm_tis_get_desc - Get the TPM description
- @dev: TPM device
- @buf: buffer to fill data
- @return: Number of characters written (or would have been written) in buffer
- tpm_tis_init - inititalize the device
- @dev: TPM device
- tpm_tis_ops_register - register the PHY ops for the device
- @dev: TPM device
- @ops: tpm_tis_phy_ops ops for the device
enum {
2.33.1
Please can you add a change log to each patch? You have a vague one in the cover letter but I am left to guess how each patch has changed.
Will do. On this one specifically I fixed the @return missing info on the documentation
Thanks /Ilias
Add support for devices that expose a TPMv2 though MMIO. Apart from those devices, we can use the driver in our QEMU setups and test TPM related code which is difficult to achieve using the sandbox driver (e.g test the EFI TCG2 protocol).
It's worth noting that a previous patch added TPMv2 TIS core functions, which the current driver is consuming.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/tpm/Kconfig | 9 +++ drivers/tpm/Makefile | 1 + drivers/tpm/tpm2_tis_mmio.c | 157 ++++++++++++++++++++++++++++++++++++ 3 files changed, 167 insertions(+) create mode 100644 drivers/tpm/tpm2_tis_mmio.c
diff --git a/drivers/tpm/Kconfig b/drivers/tpm/Kconfig index 9eebab5cfd90..406ee8716e1e 100644 --- a/drivers/tpm/Kconfig +++ b/drivers/tpm/Kconfig @@ -161,6 +161,15 @@ config TPM2_FTPM_TEE help This driver supports firmware TPM running in TEE.
+config TPM2_MMIO + bool "MMIO based TPM2 Interface" + depends on TPM_V2 + help + This driver supports firmware TPM2.0 MMIO interface. + The usual TPM operations and the 'tpm' command can be used to talk + to the device using the standard TPM Interface Specification (TIS) + protocol. + endif # TPM_V2
endmenu diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index c65be5267002..494aa5a46d30 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -14,3 +14,4 @@ obj-$(CONFIG_$(SPL_TPL_)TPM2_CR50_I2C) += cr50_i2c.o obj-$(CONFIG_TPM2_TIS_SANDBOX) += tpm2_tis_sandbox.o sandbox_common.o obj-$(CONFIG_TPM2_TIS_SPI) += tpm2_tis_spi.o obj-$(CONFIG_TPM2_FTPM_TEE) += tpm2_ftpm_tee.o +obj-$(CONFIG_TPM2_MMIO) += tpm2_tis_core.o tpm2_tis_mmio.o diff --git a/drivers/tpm/tpm2_tis_mmio.c b/drivers/tpm/tpm2_tis_mmio.c new file mode 100644 index 000000000000..9cedff222503 --- /dev/null +++ b/drivers/tpm/tpm2_tis_mmio.c @@ -0,0 +1,157 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * driver for mmio TCG/TIS TPM (trusted platform module). + * + * Specifications at www.trustedcomputinggroup.org + */ + +#include <common.h> +#include <dm.h> +#include <log.h> +#include <tpm-v2.h> +#include <linux/bitops.h> +#include <linux/compiler.h> +#include <linux/delay.h> +#include <linux/errno.h> +#include <linux/types.h> +#include <linux/io.h> +#include <linux/unaligned/be_byteshift.h> +#include "tpm_tis.h" +#include "tpm_internal.h" + +/** + * struct tpm_tis_chip_data - Information about an MMIO TPM + * @pcr_count: Number of PCR per bank + * @pcr_select_min: Minimum size in bytes of the pcrSelect array + * @iobase: Base address + */ +struct tpm_tis_chip_data { + unsigned int pcr_count; + unsigned int pcr_select_min; + void __iomem *iobase; +}; + +static int mmio_read_bytes(struct udevice *dev, u32 addr, u16 len, + u8 *result) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(dev); + + while (len--) + *result++ = ioread8(drv_data->iobase + addr); + + return 0; +} + +static int mmio_write_bytes(struct udevice *dev, u32 addr, u16 len, + const u8 *value) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(dev); + + while (len--) + iowrite8(*value++, drv_data->iobase + addr); + + return 0; +} + +static int mmio_read32(struct udevice *dev, u32 addr, u32 *result) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(dev); + + *result = ioread32(drv_data->iobase + addr); + + return 0; +} + +static int mmio_write32(struct udevice *dev, u32 addr, u32 value) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(dev); + + iowrite32(value, drv_data->iobase + addr); + + return 0; +} + +static struct tpm_tis_phy_ops phy_ops = { + .read_bytes = mmio_read_bytes, + .write_bytes = mmio_write_bytes, + .read32 = mmio_read32, + .write32 = mmio_write32, +}; + +static int tpm_tis_probe(struct udevice *dev) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(dev); + struct tpm_chip_priv *priv = dev_get_uclass_priv(dev); + int ret = 0; + fdt_addr_t ioaddr; + u64 sz; + + ioaddr = dev_read_addr(dev); + if (ioaddr == FDT_ADDR_T_NONE) + return log_msg_ret("ioaddr", -EINVAL); + + ret = dev_read_u64(dev, "reg", &sz); + if (ret) + return -EINVAL; + + drv_data->iobase = ioremap(ioaddr, sz); + tpm_tis_ops_register(dev, &phy_ops); + ret = tpm_tis_init(dev); + if (ret) + goto iounmap; + + priv->pcr_count = drv_data->pcr_count; + priv->pcr_select_min = drv_data->pcr_select_min; + /* + * Although the driver probably works with a TPMv1 our Kconfig + * limits the driver to TPMv2 only + */ + priv->version = TPM_V2; + + return ret; +iounmap: + iounmap(drv_data->iobase); + + return -EINVAL; +} + +static int tpm_tis_remove(struct udevice *dev) +{ + struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(dev); + + iounmap(drv_data->iobase); + + return tpm_tis_cleanup(dev); +} + +static const struct tpm_ops tpm_tis_ops = { + .open = tpm_tis_open, + .close = tpm_tis_close, + .get_desc = tpm_tis_get_desc, + .send = tpm_tis_send, + .recv = tpm_tis_recv, + .cleanup = tpm_tis_cleanup, +}; + +static const struct tpm_tis_chip_data tpm_tis_std_chip_data = { + .pcr_count = 24, + .pcr_select_min = 3, +}; + +static const struct udevice_id tpm_tis_ids[] = { + { + .compatible = "tcg,tpm-tis-mmio", + .data = (ulong)&tpm_tis_std_chip_data, + }, + { } +}; + +U_BOOT_DRIVER(tpm_tis_mmio) = { + .name = "tpm_tis_mmio", + .id = UCLASS_TPM, + .of_match = tpm_tis_ids, + .ops = &tpm_tis_ops, + .probe = tpm_tis_probe, + .remove = tpm_tis_remove, + .priv_auto = sizeof(struct tpm_chip), +};
Convert our SPI TPM driver and use the newly added API
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/tpm/Makefile | 2 +- drivers/tpm/tpm2_tis_spi.c | 447 +++---------------------------------- 2 files changed, 32 insertions(+), 417 deletions(-)
diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index 494aa5a46d30..51725230c780 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -12,6 +12,6 @@ obj-$(CONFIG_TPM_ST33ZP24_SPI) += tpm_tis_st33zp24_spi.o
obj-$(CONFIG_$(SPL_TPL_)TPM2_CR50_I2C) += cr50_i2c.o obj-$(CONFIG_TPM2_TIS_SANDBOX) += tpm2_tis_sandbox.o sandbox_common.o -obj-$(CONFIG_TPM2_TIS_SPI) += tpm2_tis_spi.o +obj-$(CONFIG_TPM2_TIS_SPI) += tpm2_tis_core.o tpm2_tis_spi.o obj-$(CONFIG_TPM2_FTPM_TEE) += tpm2_ftpm_tee.o obj-$(CONFIG_TPM2_MMIO) += tpm2_tis_core.o tpm2_tis_mmio.o diff --git a/drivers/tpm/tpm2_tis_spi.c b/drivers/tpm/tpm2_tis_spi.c index 1d24d32d867e..58b6f3351057 100644 --- a/drivers/tpm/tpm2_tis_spi.c +++ b/drivers/tpm/tpm2_tis_spi.c @@ -30,13 +30,6 @@ #include "tpm_tis.h" #include "tpm_internal.h"
-#define TPM_ACCESS(l) (0x0000 | ((l) << 12)) -#define TPM_INT_ENABLE(l) (0x0008 | ((l) << 12)) -#define TPM_STS(l) (0x0018 | ((l) << 12)) -#define TPM_DATA_FIFO(l) (0x0024 | ((l) << 12)) -#define TPM_DID_VID(l) (0x0F00 | ((l) << 12)) -#define TPM_RID(l) (0x0F04 | ((l) << 12)) - #define MAX_SPI_FRAMESIZE 64
/* Number of wait states to wait for */ @@ -165,7 +158,7 @@ release_bus: return ret; }
-static int tpm_tis_spi_read(struct udevice *dev, u16 addr, u8 *in, u16 len) +static int tpm_tis_spi_read(struct udevice *dev, u32 addr, u16 len, u8 *in) { return tpm_tis_spi_xfer(dev, addr, NULL, in, len); } @@ -175,382 +168,24 @@ static int tpm_tis_spi_read32(struct udevice *dev, u32 addr, u32 *result) __le32 result_le; int ret;
- ret = tpm_tis_spi_read(dev, addr, (u8 *)&result_le, sizeof(u32)); + ret = tpm_tis_spi_read(dev, addr, sizeof(u32), (u8 *)&result_le); if (!ret) *result = le32_to_cpu(result_le);
return ret; }
-static int tpm_tis_spi_write(struct udevice *dev, u16 addr, const u8 *out, - u16 len) -{ - return tpm_tis_spi_xfer(dev, addr, out, NULL, len); -} - -static int tpm_tis_spi_check_locality(struct udevice *dev, int loc) -{ - const u8 mask = TPM_ACCESS_ACTIVE_LOCALITY | TPM_ACCESS_VALID; - struct tpm_chip *chip = dev_get_priv(dev); - u8 buf; - int ret; - - ret = tpm_tis_spi_read(dev, TPM_ACCESS(loc), &buf, 1); - if (ret) - return ret; - - if ((buf & mask) == mask) { - chip->locality = loc; - return 0; - } - - return -ENOENT; -} - -static void tpm_tis_spi_release_locality(struct udevice *dev, int loc, - bool force) -{ - const u8 mask = TPM_ACCESS_REQUEST_PENDING | TPM_ACCESS_VALID; - u8 buf;
- if (tpm_tis_spi_read(dev, TPM_ACCESS(loc), &buf, 1) < 0) - return; - - if (force || (buf & mask) == mask) { - buf = TPM_ACCESS_ACTIVE_LOCALITY; - tpm_tis_spi_write(dev, TPM_ACCESS(loc), &buf, 1); - } -} - -static int tpm_tis_spi_request_locality(struct udevice *dev, int loc) +static int tpm_tis_spi_write(struct udevice *dev, u32 addr, u16 len, const u8 *out) { - struct tpm_chip *chip = dev_get_priv(dev); - unsigned long start, stop; - u8 buf = TPM_ACCESS_REQUEST_USE; - int ret; - - ret = tpm_tis_spi_check_locality(dev, loc); - if (!ret) - return 0; - - if (ret != -ENOENT) { - log(LOGC_NONE, LOGL_ERR, "%s: Failed to get locality: %d\n", - __func__, ret); - return ret; - } - - ret = tpm_tis_spi_write(dev, TPM_ACCESS(loc), &buf, 1); - if (ret) { - log(LOGC_NONE, LOGL_ERR, "%s: Failed to write to TPM: %d\n", - __func__, ret); - return ret; - } - - start = get_timer(0); - stop = chip->timeout_a; - do { - ret = tpm_tis_spi_check_locality(dev, loc); - if (!ret) - return 0; - - if (ret != -ENOENT) { - log(LOGC_NONE, LOGL_ERR, - "%s: Failed to get locality: %d\n", __func__, ret); - return ret; - } - - mdelay(TPM_TIMEOUT_MS); - } while (get_timer(start) < stop); - - log(LOGC_NONE, LOGL_ERR, "%s: Timeout getting locality: %d\n", __func__, - ret); - - return ret; -} - -static u8 tpm_tis_spi_status(struct udevice *dev, u8 *status) -{ - struct tpm_chip *chip = dev_get_priv(dev); - - return tpm_tis_spi_read(dev, TPM_STS(chip->locality), status, 1); -} - -static int tpm_tis_spi_wait_for_stat(struct udevice *dev, u8 mask, - unsigned long timeout, u8 *status) -{ - unsigned long start = get_timer(0); - unsigned long stop = timeout; - int ret; - - do { - mdelay(TPM_TIMEOUT_MS); - ret = tpm_tis_spi_status(dev, status); - if (ret) - return ret; - - if ((*status & mask) == mask) - return 0; - } while (get_timer(start) < stop); - - return -ETIMEDOUT; -} - -static u8 tpm_tis_spi_valid_status(struct udevice *dev, u8 *status) -{ - struct tpm_chip *chip = dev_get_priv(dev); - - return tpm_tis_spi_wait_for_stat(dev, TPM_STS_VALID, - chip->timeout_c, status); -} - -static int tpm_tis_spi_get_burstcount(struct udevice *dev) -{ - struct tpm_chip *chip = dev_get_priv(dev); - unsigned long start, stop; - u32 burstcount, ret; - - /* wait for burstcount */ - start = get_timer(0); - stop = chip->timeout_d; - do { - ret = tpm_tis_spi_read32(dev, TPM_STS(chip->locality), - &burstcount); - if (ret) - return -EBUSY; - - burstcount = (burstcount >> 8) & 0xFFFF; - if (burstcount) - return burstcount; - - mdelay(TPM_TIMEOUT_MS); - } while (get_timer(start) < stop); - - return -EBUSY; -} - -static int tpm_tis_spi_cancel(struct udevice *dev) -{ - struct tpm_chip *chip = dev_get_priv(dev); - u8 data = TPM_STS_COMMAND_READY; - - return tpm_tis_spi_write(dev, TPM_STS(chip->locality), &data, 1); -} - -static int tpm_tis_spi_recv_data(struct udevice *dev, u8 *buf, size_t count) -{ - struct tpm_chip *chip = dev_get_priv(dev); - int size = 0, burstcnt, len, ret; - u8 status; - - while (size < count && - tpm_tis_spi_wait_for_stat(dev, - TPM_STS_DATA_AVAIL | TPM_STS_VALID, - chip->timeout_c, &status) == 0) { - burstcnt = tpm_tis_spi_get_burstcount(dev); - if (burstcnt < 0) - return burstcnt; - - len = min_t(int, burstcnt, count - size); - ret = tpm_tis_spi_read(dev, TPM_DATA_FIFO(chip->locality), - buf + size, len); - if (ret < 0) - return ret; - - size += len; - } - - return size; -} - -static int tpm_tis_spi_recv(struct udevice *dev, u8 *buf, size_t count) -{ - struct tpm_chip *chip = dev_get_priv(dev); - int size, expected; - - if (!chip) - return -ENODEV; - - if (count < TPM_HEADER_SIZE) { - size = -EIO; - goto out; - } - - size = tpm_tis_spi_recv_data(dev, buf, TPM_HEADER_SIZE); - if (size < TPM_HEADER_SIZE) { - log(LOGC_NONE, LOGL_ERR, "TPM error, unable to read header\n"); - goto out; - } - - expected = get_unaligned_be32(buf + 2); - if (expected > count) { - size = -EIO; - goto out; - } - - size += tpm_tis_spi_recv_data(dev, &buf[TPM_HEADER_SIZE], - expected - TPM_HEADER_SIZE); - if (size < expected) { - log(LOGC_NONE, LOGL_ERR, - "TPM error, unable to read remaining bytes of result\n"); - size = -EIO; - goto out; - } - -out: - tpm_tis_spi_cancel(dev); - tpm_tis_spi_release_locality(dev, chip->locality, false); - - return size; -} - -static int tpm_tis_spi_send(struct udevice *dev, const u8 *buf, size_t len) -{ - struct tpm_chip *chip = dev_get_priv(dev); - u32 i, size; - u8 status; - int burstcnt, ret; - u8 data; - - if (!chip) - return -ENODEV; - - if (len > TPM_DEV_BUFSIZE) - return -E2BIG; /* Command is too long for our tpm, sorry */ - - ret = tpm_tis_spi_request_locality(dev, 0); - if (ret < 0) - return -EBUSY; - - /* - * Check if the TPM is ready. If not, if not, cancel the pending command - * and poll on the status to be finally ready. - */ - ret = tpm_tis_spi_status(dev, &status); - if (ret) - return ret; - - if (!(status & TPM_STS_COMMAND_READY)) { - /* Force the transition, usually this will be done at startup */ - ret = tpm_tis_spi_cancel(dev); - if (ret) { - log(LOGC_NONE, LOGL_ERR, - "%s: Could not cancel previous operation\n", - __func__); - goto out_err; - } - - ret = tpm_tis_spi_wait_for_stat(dev, TPM_STS_COMMAND_READY, - chip->timeout_b, &status); - if (ret < 0 || !(status & TPM_STS_COMMAND_READY)) { - log(LOGC_NONE, LOGL_ERR, - "status %d after wait for stat returned %d\n", - status, ret); - goto out_err; - } - } - - for (i = 0; i < len - 1;) { - burstcnt = tpm_tis_spi_get_burstcount(dev); - if (burstcnt < 0) - return burstcnt; - - size = min_t(int, len - i - 1, burstcnt); - ret = tpm_tis_spi_write(dev, TPM_DATA_FIFO(chip->locality), - buf + i, size); - if (ret < 0) - goto out_err; - - i += size; - } - - ret = tpm_tis_spi_valid_status(dev, &status); - if (ret) - goto out_err; - - if ((status & TPM_STS_DATA_EXPECT) == 0) { - ret = -EIO; - goto out_err; - } - - ret = tpm_tis_spi_write(dev, TPM_DATA_FIFO(chip->locality), - buf + len - 1, 1); - if (ret) - goto out_err; - - ret = tpm_tis_spi_valid_status(dev, &status); - if (ret) - goto out_err; - - if ((status & TPM_STS_DATA_EXPECT) != 0) { - ret = -EIO; - goto out_err; - } - - data = TPM_STS_GO; - ret = tpm_tis_spi_write(dev, TPM_STS(chip->locality), &data, 1); - if (ret) - goto out_err; - - return len; - -out_err: - tpm_tis_spi_cancel(dev); - tpm_tis_spi_release_locality(dev, chip->locality, false); - - return ret; -} - -static int tpm_tis_spi_cleanup(struct udevice *dev) -{ - struct tpm_chip *chip = dev_get_priv(dev); - - tpm_tis_spi_cancel(dev); - /* - * The TPM needs some time to clean up here, - * so we sleep rather than keeping the bus busy - */ - mdelay(2); - tpm_tis_spi_release_locality(dev, chip->locality, false); - - return 0; -} - -static int tpm_tis_spi_open(struct udevice *dev) -{ - struct tpm_chip *chip = dev_get_priv(dev); - - if (chip->is_open) - return -EBUSY; - - chip->is_open = 1; - - return 0; -} - -static int tpm_tis_spi_close(struct udevice *dev) -{ - struct tpm_chip *chip = dev_get_priv(dev); - - if (chip->is_open) { - tpm_tis_spi_release_locality(dev, chip->locality, true); - chip->is_open = 0; - } - - return 0; + return tpm_tis_spi_xfer(dev, addr, out, NULL, len); }
-static int tpm_tis_get_desc(struct udevice *dev, char *buf, int size) +static int tpm_tis_spi_write32(struct udevice *dev, u32 addr, u32 value) { - struct tpm_chip *chip = dev_get_priv(dev); - - if (size < 80) - return -ENOSPC; + __le32 value_le = cpu_to_le32(value);
- return snprintf(buf, size, - "%s v2.0: VendorID 0x%04x, DeviceID 0x%04x, RevisionID 0x%02x [%s]", - dev->name, chip->vend_dev & 0xFFFF, - chip->vend_dev >> 16, chip->rid, - (chip->is_open ? "open" : "closed")); + return tpm_tis_spi_write(dev, addr, sizeof(value), (u8 *)&value_le); }
static int tpm_tis_wait_init(struct udevice *dev, int loc) @@ -565,7 +200,7 @@ static int tpm_tis_wait_init(struct udevice *dev, int loc) do { mdelay(TPM_TIMEOUT_MS);
- ret = tpm_tis_spi_read(dev, TPM_ACCESS(loc), &status, 1); + ret = tpm_tis_spi_read(dev, TPM_ACCESS(loc), 1, &status); if (ret) break;
@@ -576,6 +211,13 @@ static int tpm_tis_wait_init(struct udevice *dev, int loc) return -EIO; }
+static struct tpm_tis_phy_ops phy_ops = { + .read_bytes = tpm_tis_spi_read, + .write_bytes = tpm_tis_spi_write, + .read32 = tpm_tis_spi_read32, + .write32 = tpm_tis_spi_write32, +}; + static int tpm_tis_spi_probe(struct udevice *dev) { struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(dev); @@ -611,65 +253,38 @@ init: /* Ensure a minimum amount of time elapsed since reset of the TPM */ mdelay(drv_data->time_before_first_cmd_ms);
- chip->locality = 0; - chip->timeout_a = TIS_SHORT_TIMEOUT_MS; - chip->timeout_b = TIS_LONG_TIMEOUT_MS; - chip->timeout_c = TIS_SHORT_TIMEOUT_MS; - chip->timeout_d = TIS_SHORT_TIMEOUT_MS; - priv->pcr_count = drv_data->pcr_count; - priv->pcr_select_min = drv_data->pcr_select_min; - ret = tpm_tis_wait_init(dev, chip->locality); if (ret) { log(LOGC_DM, LOGL_ERR, "%s: no device found\n", __func__); return ret; }
- ret = tpm_tis_spi_request_locality(dev, chip->locality); - if (ret) { - log(LOGC_NONE, LOGL_ERR, "%s: could not request locality %d\n", - __func__, chip->locality); - return ret; - } - - ret = tpm_tis_spi_read32(dev, TPM_DID_VID(chip->locality), - &chip->vend_dev); - if (ret) { - log(LOGC_NONE, LOGL_ERR, - "%s: could not retrieve VendorID/DeviceID\n", __func__); - return ret; - } - - ret = tpm_tis_spi_read(dev, TPM_RID(chip->locality), &chip->rid, 1); - if (ret) { - log(LOGC_NONE, LOGL_ERR, "%s: could not retrieve RevisionID\n", - __func__); - return ret; - } + tpm_tis_ops_register(dev, &phy_ops); + ret = tpm_tis_init(dev); + if (ret) + goto err;
- log(LOGC_NONE, LOGL_ERR, - "SPI TPMv2.0 found (vid:%04x, did:%04x, rid:%02x)\n", - chip->vend_dev & 0xFFFF, chip->vend_dev >> 16, chip->rid); + priv->pcr_count = drv_data->pcr_count; + priv->pcr_select_min = drv_data->pcr_select_min; + priv->version = TPM_V2;
return 0; +err: + return -EINVAL; }
-static int tpm_tis_spi_remove(struct udevice *dev) +static int tpm_tis_spi_remove(struct udevice *udev) { - struct tpm_chip *chip = dev_get_priv(dev); - - tpm_tis_spi_release_locality(dev, chip->locality, true); - - return 0; + return tpm_tis_cleanup(udev); }
static const struct tpm_ops tpm_tis_spi_ops = { - .open = tpm_tis_spi_open, - .close = tpm_tis_spi_close, + .open = tpm_tis_open, + .close = tpm_tis_close, .get_desc = tpm_tis_get_desc, - .send = tpm_tis_spi_send, - .recv = tpm_tis_spi_recv, - .cleanup = tpm_tis_spi_cleanup, + .send = tpm_tis_send, + .recv = tpm_tis_recv, + .cleanup = tpm_tis_cleanup, };
A previous commit is adding an MMIO TPMv2 driver. Include in the default qemu arm configs, since we plan on using them on EFI testing
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- configs/qemu_arm64_defconfig | 2 ++ configs/qemu_arm_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index 003717efde28..83d7ae54de4d 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -49,6 +49,8 @@ CONFIG_SCSI=y CONFIG_DM_SCSI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y +CONFIG_TPM2_MMIO=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y +CONFIG_TPM=y diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index 27b0e49f6f89..ab5574847e89 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -51,6 +51,8 @@ CONFIG_SCSI=y CONFIG_DM_SCSI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y +CONFIG_TPM2_MMIO=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y +CONFIG_TPM=y
A previous patch added support for an mmio based TPM. Add an example in QEMU on it's usage
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- doc/board/emulation/qemu-arm.rst | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/doc/board/emulation/qemu-arm.rst b/doc/board/emulation/qemu-arm.rst index 8d7fda10f15e..584ef0a7e150 100644 --- a/doc/board/emulation/qemu-arm.rst +++ b/doc/board/emulation/qemu-arm.rst @@ -81,6 +81,31 @@ can be enabled with the following command line parameters:
These have been tested in QEMU 2.9.0 but should work in at least 2.5.0 as well.
+Enabling TPMv2 support +---------------------- + +To emulate a TPM the swtpm package may be used. It can be built from the +following repositories: + + https://github.com/stefanberger/swtpm.git + +Swtpm provides a socket for the TPM emulation which can be consumed by QEMU. + +In a first console invoke swtpm with:: + + swtpm socket --tpmstate dir=/tmp/mytpm1 \ + --ctrl type=unixio,path=/tmp/mytpm1/swtpm-sock --log level=20 + +In a second console invoke qemu-system-aarch64 with:: + + -chardev socket,id=chrtpm,path=/tmp/mytpm1/swtpm-sock \ + -tpmdev emulator,id=tpm0,chardev=chrtpm \ + -device tpm-tis-device,tpmdev=tpm0 + +Enable the TPM on U-Boot's command line with:: + + tpm2 startup TPM2_SU_CLEAR + Debug UART ----------
Hi Ilias,
How would I run the test that need this TPM emulator? Remember I was going to look at what is involved to enhance U-Boot's emulator.
Hi Simon,
On Sat, Nov 13, 2021 at 11:14:27AM -0700, Simon Glass wrote:
Hi Ilias,
Heinrich has already sent patches adding this to the docker CI [1]. Is that clear enough ?
[1] https://lore.kernel.org/u-boot/20211115101106.36479-1-heinrich.schuchardt@ca...
Thanks /Ilias
Hi Ilias,
On Mon, 15 Nov 2021 at 04:11, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon,
Hi Ilias,
Yes thanks.
- Simon
Thanks /Ilias
Am 27. Januar 2022 16:06:03 MEZ schrieb Simon Glass sjg@chromium.org:
Hi Ilias,
Hi Simon,
Hi Ilias,
Yes thanks.
The sandbox could communicate to swtpm via a socket like QEMU does or call libtpm directly. You may want to look at the QEMU code first.
Best regards
Heinrich
- Simon
Thanks /Ilias
TPM drivers have currently no maintainers. Add myself since I contributed the TIS implementation.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- MAINTAINERS | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 00ff572d4d23..6db5354322fe 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1187,6 +1187,11 @@ F: configs/am65x_hs_evm_a53_defconfig F: configs/j721e_hs_evm_r5_defconfig F: configs/j721e_hs_evm_a72_defconfig
+TPM DRIVERS +M: Ilias Apalodimas ilias.apalodimas@linaro.org +S: Maintained +F: drivers/tpm/ + TQ GROUP #M: Martin Krause martin.krause@tq-systems.de S: Orphaned (Since 2016-02)
Ilias Apalodimas
