[U-Boot] [ARM]: File type for u-boot elf file
I have OMAP L138 Hawkboard which is loaded with some other program. I am new to this hawkboard and tried to boot as per instructions from user guide in http://www.hawkboard.org/ , system is not coming to hawkboard.org > to access command. It is coming as follows.
Please help me to make it ready.
Switch positions made as follows
Pin1 = ON Pin2 = OFF Pin3 = OFF Pin4 = OFF
Terminal data as follows:
U-Boot 2009.01-dirty (Nov 26 2009 - 02:15:00)
DRAM: 128 MB NAND: NAND device: Manufacturer ID: 0x2c, Chip ID: 0xa1 (Micron NAND 128MiB 1,8 V 8-bit) Bad block table found at page 65472, version 0x01 Bad block table found at page 65408, version 0x01 nand_read_bbt: Bad block at 0x03500000 nand_read_bbt: Bad block at 0x049a0000 128 MiB In: serial Out: serial Err: serial ARM Clock : 300000000 Hz DDR Clock : 150000000 Hz Ethernet PHY: GENERIC @ 0x07 Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x200000, size 0x300000 ..
Regards, Rojan Joy
During this countdown you need to 'hit any key' to stop the boot from happening and give you the U-Boot prompt.
rojan
