[U-Boot] [PATCH v2 3/9] ARMv8/fsl-lsch3: Refactor spin-table code
This creates the function cpu_update_dt for ARMv8 which currently patches the cpu node in the device table and sets enable-method to spin-table.
Signed-off-by: Arnab Basu arnab_basu@rocketmail.com Cc: Bhupesh Sharma bhupesh.sharma@freescale.com Cc: York Sun yorksun@freescale.com --- arch/arm/cpu/armv8/Makefile | 1 + arch/arm/cpu/armv8/{fsl-lsch3/fdt.c => cpu-dt.c} | 32 +++++++++------- arch/arm/cpu/armv8/fsl-lsch3/fdt.c | 48 ++++++++---------------- 3 files changed, 36 insertions(+), 45 deletions(-) copy arch/arm/cpu/armv8/{fsl-lsch3/fdt.c => cpu-dt.c} (68%)
diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index 0c10223..74c32b2 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -14,5 +14,6 @@ obj-y += exceptions.o obj-y += cache.o obj-y += tlb.o obj-y += transition.o +obj-y += cpu-dt.o
obj-$(CONFIG_FSL_LSCH3) += fsl-lsch3/ diff --git a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c b/arch/arm/cpu/armv8/cpu-dt.c similarity index 68% copy from arch/arm/cpu/armv8/fsl-lsch3/fdt.c copy to arch/arm/cpu/armv8/cpu-dt.c index e392eb9..8833e6a 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c +++ b/arch/arm/cpu/armv8/cpu-dt.c @@ -7,17 +7,24 @@ #include <common.h> #include <libfdt.h> #include <fdt_support.h> -#include "mp.h"
#ifdef CONFIG_MP -void ft_fixup_cpu(void *blob) + +__weak u64 arch_get_release_addr(u64 cpu_id) +{ + return 0; +} + +__weak void arch_spin_table_reserve_mem(void *fdt) +{ +} + +static void cpu_update_dt_spin_table(void *blob) { int off; - __maybe_unused u64 spin_tbl_addr = (u64)get_spin_tbl_addr(); - fdt32_t *reg; + __maybe_unused u64 val; int addr_cells; - u64 val; - size_t *boot_code_size = &(__secondary_boot_code_size); + __maybe_unused fdt32_t *reg;
off = fdt_path_offset(blob, "/cpus"); if (off < 0) { @@ -30,9 +37,8 @@ void ft_fixup_cpu(void *blob) while (off != -FDT_ERR_NOTFOUND) { reg = (fdt32_t *)fdt_getprop(blob, off, "reg", 0); if (reg) { - val = spin_tbl_addr; - val += id_to_core(of_read_number(reg, addr_cells)) - * SPIN_TABLE_ELEM_SIZE; + val = arch_get_release_addr( + of_read_number(reg, addr_cells)); val = cpu_to_fdt64(val); fdt_setprop_string(blob, off, "enable-method", "spin-table"); @@ -45,14 +51,14 @@ void ft_fixup_cpu(void *blob) "cpu", 4); }
- fdt_add_mem_rsv(blob, (uintptr_t)&secondary_boot_code, - *boot_code_size); + arch_spin_table_reserve_mem(blob); } #endif
-void ft_cpu_setup(void *blob, bd_t *bd) +int cpu_update_dt(void *fdt) { #ifdef CONFIG_MP - ft_fixup_cpu(blob); + cpu_update_dt_spin_table(fdt); #endif + return 0; } diff --git a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c b/arch/arm/cpu/armv8/fsl-lsch3/fdt.c index e392eb9..bb35393 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c +++ b/arch/arm/cpu/armv8/fsl-lsch3/fdt.c @@ -10,44 +10,28 @@ #include "mp.h"
#ifdef CONFIG_MP -void ft_fixup_cpu(void *blob) +u64 arch_get_release_addr(u64 cpu_id) { - int off; - __maybe_unused u64 spin_tbl_addr = (u64)get_spin_tbl_addr(); - fdt32_t *reg; - int addr_cells; u64 val; + + val = (u64)get_spin_tbl_addr(); + val += id_to_core(cpu_id) * SPIN_TABLE_ELEM_SIZE; + + return val; +} + +void arch_spin_table_reserve_mem(void *fdt) +{ size_t *boot_code_size = &(__secondary_boot_code_size);
- off = fdt_path_offset(blob, "/cpus"); - if (off < 0) { - puts("couldn't find /cpus node\n"); - return; - } - of_bus_default_count_cells(blob, off, &addr_cells, NULL); - - off = fdt_node_offset_by_prop_value(blob, -1, "device_type", "cpu", 4); - while (off != -FDT_ERR_NOTFOUND) { - reg = (fdt32_t *)fdt_getprop(blob, off, "reg", 0); - if (reg) { - val = spin_tbl_addr; - val += id_to_core(of_read_number(reg, addr_cells)) - * SPIN_TABLE_ELEM_SIZE; - val = cpu_to_fdt64(val); - fdt_setprop_string(blob, off, "enable-method", - "spin-table"); - fdt_setprop(blob, off, "cpu-release-addr", - &val, sizeof(val)); - } else { - puts("Warning: found cpu node without reg property\n"); - } - off = fdt_node_offset_by_prop_value(blob, off, "device_type", - "cpu", 4); - } - - fdt_add_mem_rsv(blob, (uintptr_t)&secondary_boot_code, + fdt_add_mem_rsv(fdt, (uintptr_t)&secondary_boot_code, *boot_code_size); } + +static void ft_fixup_cpu(void *blob) +{ +} + #endif
Arnab Basu
