[U-Boot] [PATCH v4 0/2] ARM: add support for Bananapi BPI-R1
* changes from lamobo-r1 required include: - unset ahci power pin - usbvbus gpio pin change - mmc cd gpio pin change - enable uart2, set default LED trigger - CONFIG_GMAC_TX_DELAY change
Changes for v2: - incorprated feedback for config options (remove 3, add 1) Changes for v3/v4: - re-submit (no change to patch payload) with cover
Steve Arnold (2): ARM: sun7i: config: add config for Sinovoip/Bananapi BPI-R1 ARM: sun7i: dts: add support for Sinovoip/Bananapi BPI-R1
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun7i-a20-bananapi-r1.dts | 376 +++++++++++++++++++++++++++++++++ configs/Bananapi_R1_defconfig | 16 ++ 3 files changed, 393 insertions(+) create mode 100644 arch/arm/dts/sun7i-a20-bananapi-r1.dts create mode 100644 configs/Bananapi_R1_defconfig
Signed-off-by: Steve Arnold stephen.arnold42@gmail.com Cc: Ian Campbell ijc@hellion.org.uk Cc: Hans De Goede hdegoede@redhat.com
Changes for v2: - incorprated feedback for config options (remove 3, add 1) Changes for v3/v4: - re-submit (no change to patch payload) with cover Changes for v5: - re-submit as one patch (no change to patch payload)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8458f6b..8aa8646 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -217,6 +217,7 @@ dtb-$(CONFIG_MACH_SUN7I) += \ sun7i-a20-ainol-aw1.dtb \ sun7i-a20-bananapi.dtb \ sun7i-a20-bananapi-m1-plus.dtb \ + sun7i-a20-bananapi-r1.dtb \ sun7i-a20-bananapro.dtb \ sun7i-a20-cubieboard2.dtb \ sun7i-a20-cubietruck.dtb \ diff --git a/arch/arm/dts/sun7i-a20-bananapi-r1.dts b/arch/arm/dts/sun7i-a20-bananapi-r1.dts new file mode 100644 index 0000000..1a550f9 --- /dev/null +++ b/arch/arm/dts/sun7i-a20-bananapi-r1.dts @@ -0,0 +1,376 @@ +/* + * Copyright 2015 Hans de Goede hdegoede@redhat.com + * Changes copyright 2016 Stephen Arnold nerdboy@gentoo.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun7i-a20.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "Banana Pi BPI-R1"; + compatible = "sinovoip,bpi-r1", "allwinner,sun7i-a20"; + + aliases { + serial0 = &uart0; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart7; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins_bpi_r1>; + + green { + label = "bpi-r1:green:usr"; + gpios = <&pio 7 24 GPIO_ACTIVE_HIGH>; /* PH24 */ + linux,default-trigger = "heartbeat"; + }; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&gmac_power_pin_bpi_r1>; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 7 23 GPIO_ACTIVE_HIGH>; /* PH23 */ + }; + +}; + +&ahci { + target-supply = <®_ahci_5v>; + status = "okay"; +}; + +&cpu0 { + cpu-supply = <®_dcdc2>; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&gmac { + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_rgmii_a>; + phy = <&phy1>; + phy-mode = "rgmii"; + phy-supply = <®_gmac_3v3>; + status = "okay"; + + fixed-link { + speed = <1000>; + full-duplex; + }; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + switch: ethernet-switch@1e { + compatible = "brcm,bcm53125"; + reg = <30>; + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port0: port@0 { + reg = <0>; + label = "lan2"; + }; + + port1: port@1 { + reg = <1>; + label = "lan3"; + }; + + port2: port@2 { + reg = <2>; + label = "lan4"; + }; + + port3: port@3 { + reg = <3>; + label = "wan"; + }; + + port4: port@4 { + reg = <4>; + label = "lan1"; + }; + + port8: port@8 { + reg = <8>; + label = "cpu"; + ethernet = <&gmac>; + phy-mode = "rgmii"; + fixed-link { + speed = <1000>; + full-duplex; + }; + }; + }; + }; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; + + axp209: pmic@34 { + compatible = "x-powers,axp209"; + reg = <0x34>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + + interrupt-controller; + #interrupt-cells = <1>; + }; +}; + +#include "axp209.dtsi" + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_a>; + status = "okay"; +}; + +&ir0 { + pinctrl-names = "default"; + pinctrl-0 = <&ir0_rx_pins_a>; + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_bpi_r1>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ + cd-inverted; + status = "okay"; +}; + +&otg_sram { + status = "okay"; +}; + +&pio { + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PH5"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb0_vbus_pin_bpi_r1: usb0_vbus_pin@0 { + allwinner,pins = "PB9"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb2_vbus_pin_bpi_r1: usb2_vbus_pin@0 { + allwinner,pins = "PH3"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + mmc0_cd_pin_bpi_r1: mmc0_cd_pin@0 { + allwinner,pins = "PH1"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + gmac_power_pin_bpi_r1: gmac_power_pin@0 { + allwinner,pins = "PH23"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + led_pins_bpi_r1: led_pins@0 { + allwinner,pins = "PH24"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +®_ahci_5v { + status = "okay"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-int-dll"; +}; + +®_ldo1 { + regulator-name = "vdd-rtc"; +}; + +®_ldo2 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; + +®_usb0_vbus { + pinctrl-0 = <&usb0_vbus_pin_bpi_r1>; + gpio = <&pio 1 9 GPIO_ACTIVE_HIGH>; /* PB9 */ + status = "okay"; +}; + +®_usb1_vbus { + status = "okay"; +}; + +®_usb2_vbus { + pinctrl-0 = <&usb2_vbus_pin_bpi_r1>; + gpio = <&pio 7 3 GPIO_ACTIVE_HIGH>; /* PH3 */ + status = "okay"; +}; + +&spi0 { + pinctrl-names = "default"; + pinctrl-0 = <&spi0_pins_a>, + <&spi0_cs0_pins_a>, + <&spi0_cs1_pins_a>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins_a>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins_b>; + status = "okay"; +}; + +&uart7 { + pinctrl-names = "default"; + pinctrl-0 = <&uart7_pins_a>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usb_power_supply { + status = "okay"; +}; + +&usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>; + usb0_id_det-gpio = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ + usb0_vbus_power-supply = <&usb_power_supply>; + usb0_vbus-supply = <®_usb0_vbus>; + usb1_vbus-supply = <®_usb1_vbus>; + usb2_vbus-supply = <®_usb2_vbus>; + status = "okay"; +}; diff --git a/configs/Bananapi_R1_defconfig b/configs/Bananapi_R1_defconfig new file mode 100644 index 0000000..3743d5c --- /dev/null +++ b/configs/Bananapi_R1_defconfig @@ -0,0 +1,16 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN7I=y +CONFIG_DRAM_CLK=432 +CONFIG_GMAC_TX_DELAY=3 +CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi-r1" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,USB_EHCI" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_USB_EHCI_HCD=y +CONFIG_DM_ETH=y +CONFIG_PHYLIB=y +# CONFIG_RTL8211X_PHY_FORCE_MASTER=y
On Mon, Oct 10, 2016 at 2:34 AM, Stephen Arnold stephen.arnold42@gmail.com wrote:
- changes from lamobo-r1 required include:
Changes for v2:
Changes for v3/v4:
Changes for v5:
- Copyright 2015 Hans de Goede hdegoede@redhat.com
- Changes copyright 2016 Stephen Arnold nerdboy@gentoo.org
Remove "Changes" text and add your copy on top, it some how look take reference from Hans.
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
aliases {
serial0 = &uart0;
serial1 = &uart2;
serial2 = &uart3;
serial3 = &uart7;
chosen {
leds {
green {
This property not needed, skip this.
enable-active-high;
+&ahci {
status = "okay";
+&cpu0 {
+&ehci0 {
status = "okay";
+&ehci1 {
status = "okay";
+&ohci0 {
status = "okay";
+&ohci1 {
status = "okay";
+&gmac {
phy = <&phy1>;
phy-mode = "rgmii";
status = "okay";
fixed-link {
speed = <1000>;
full-duplex;
mdio {
#size-cells = <0>;
We don't have this compatible in drivers/net yet, better to skip this gmac node once added/tested.
reg = <30>;
#size-cells = <0>;
ports {
#size-cells = <0>;
port0: port@0 {
reg = <0>;
label = "lan2";
port1: port@1 {
reg = <1>;
label = "lan3";
port2: port@2 {
reg = <2>;
label = "lan4";
port3: port@3 {
reg = <3>;
label = "wan";
port4: port@4 {
reg = <4>;
label = "lan1";
port8: port@8 {
reg = <8>;
label = "cpu";
ethernet = <&gmac>;
phy-mode = "rgmii";
fixed-link {
speed = <1000>;
full-duplex;
+&i2c0 {
status = "okay";
axp209: pmic@34 {
I think same as gmac
So instead of copy the entire dts, please add the nodes which are tested. maintenance becomes difficult for long run for unnecessary/untested nodes atleast for dts files(!dtsi)
thanks!
Okay, but I could use a little clarity; do you want the u-boot dts to look just like my (proposed) kernel dts? Or do I start with kernel dts and remove the gmac/axp209 stuff?
If we can merge all of this feedback into a single list of changes, then I can take a whack at it later this week (after a few work things). Back to the test mtg...
Thanks in advance, Steve
Changes for v2:
Changes for v3/v4:
Changes for v5:
- whole.
conditions:
aliases {
serial0 = &uart0;
serial1 = &uart2;
serial2 = &uart3;
serial3 = &uart7;
chosen {
leds {
green {
enable-active-high;
+&ahci {
status = "okay";
+&cpu0 {
+&ehci0 {
status = "okay";
+&ehci1 {
status = "okay";
+&ohci0 {
status = "okay";
+&ohci1 {
status = "okay";
+&gmac {
phy = <&phy1>;
phy-mode = "rgmii";
status = "okay";
fixed-link {
speed = <1000>;
full-duplex;
mdio {
#size-cells = <0>;
reg = <30>;
#size-cells = <0>;
ports {
#size-cells = <0>;
port0: port@0 {
reg = <0>;
label = "lan2";
port1: port@1 {
reg = <1>;
label = "lan3";
port2: port@2 {
reg = <2>;
label = "lan4";
port3: port@3 {
reg = <3>;
label = "wan";
port4: port@4 {
reg = <4>;
label = "lan1";
port8: port@8 {
reg = <8>;
label = "cpu";
ethernet = <&gmac>;
phy-mode = "rgmii";
fixed-link {
speed = <1000>;
full-duplex;
+&i2c0 {
status = "okay";
axp209: pmic@34 {
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
On Wed, Oct 12, 2016 at 12:18 AM, Stephen Arnold stephen.arnold42@gmail.com wrote:
Please take a reference of Linux dts and add tested nodes/properties, this would be certainly gives a better understanding and maintenance easy.
thanks!
Okay, rebased on u-boot master again and updated the config for i2c/spl. I have an RFC patch for u-boot and an updated kernel dts to test; I also brought in the (small) sun7i-a20.dtsi patch to add the standard A20 i2c4 pins_a which is the only i2c brought out on the Pi header (goes with pin fix for uart3).
Since this is not quite what I'm running now, and I had to go back and trace some wiring on the schematic for USB, I think I've got it dialed in now, so I'll test it when my kernel is finished.
If that looks good, I'll make a kernel patch and try that list for a change...
Thanks, Steve
thanks!
On Fri, Oct 14, 2016 at 4:58 AM, Stephen Arnold stephen.arnold42@gmail.com wrote:
OK, please send.
thanks!
Please ignore the crufty v4 cover; the following v5 is correct (a single patch) as requested by Jagan.
Thanks, Steve
On Sun, Oct 9, 2016 at 2:04 PM, Stephen Arnold stephen.arnold42@gmail.com wrote:
Changes for v2:
Changes for v3/v4:
-- 2.9.3
Jagan Teki
Jagan Teki
Jagan Teki
Stephen Arnold
