Re: [U-Boot-Users] PROBLEM ABOUT PORTING U-BOOT-1.1.4 TO INTELPXA255 BOARD
hi,Markus_Klotzbucher
======= 2006-06-19 22:24:58 You write in the letter:=======
Dear Scut Paradise,
Please reply to the list too.
OK,i got it.
"$A3B:i1&(B" scut.paradise@gmail.com writes:
$ATZ(B 06-6-19$A#,(BMarkus Klotzb$A(9(Bchermk@denx.de $AP45@#:(B
The fact that the "DECLARE_GLOBAL_DATA_PTR" is defined inside board_init indicates that you are not using top of the tree U-Boot. Please switch to current sourcen first of all. The DECLARE_GLOBAL_DATA_PTR statement needs to be defined globally due to gcc misbehaviour.
I don't quite understand the meaning of this paragraph, what should i do?
Use the newest version of U-Boot from the git repository. The version you are using is old.
You're right, I download the u-boot-1.1.4 from http,instead of using the git repository. I will try now, Thanks very much.
Regards
Markus Klotzbucher
THANKS
Paradise scut.paradise@gmail.com 2006-06-20
Paradise
