[PATCH] qspi: versal-net: Add condition for tapdelay register
Add CONFIG_ARCH_VERSAL_NET to select tapdelay register for versal-net.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
drivers/spi/zynqmp_gqspi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/zynqmp_gqspi.c b/drivers/spi/zynqmp_gqspi.c index 49facc46d3c1..48eff777dfb3 100644 --- a/drivers/spi/zynqmp_gqspi.c +++ b/drivers/spi/zynqmp_gqspi.c @@ -104,7 +104,8 @@ #define TAP_DLY_BYPASS_LQSPI_RX_VALUE 0x1 #define TAP_DLY_BYPASS_LQSPI_RX_SHIFT 2 #define GQSPI_DATA_DLY_ADJ_OFST 0x000001F8 -#define IOU_TAPDLY_BYPASS_OFST !IS_ENABLED(CONFIG_ARCH_VERSAL) ? \ +#define IOU_TAPDLY_BYPASS_OFST !(IS_ENABLED(CONFIG_ARCH_VERSAL) || \ + IS_ENABLED(CONFIG_ARCH_VERSAL_NET)) ? \ 0xFF180390 : 0xF103003C #define GQSPI_LPBK_DLY_ADJ_LPBK_MASK 0x00000020 #define GQSPI_FREQ_37_5MHZ 37500000
st 16. 11. 2022 v 16:40 odesÃlatel Michal Simek michal.simek@amd.com napsal:
2.36.1
Applied. M
Michal Simek
Michal Simek
