[U-Boot] [PATCH] imximage: header v2: Remove overwriting of flash_offset
The flash header v2 supports different flash offsets for different boot devices. E.g. parallel NOR or OneNAND use a different offset than FLASH_OFFSET_STANDARD (== 0x400).
The flash offset is correctly read from the configuration in parse_cfg_cmd(). But is then overwritten wrongly in set_imx_hdr_v2().
Fix this by removing this overwriting. Use the flash offset correclty read from the configuration, instead.
Signed-off-by: Dirk Behme dirk.behme@de.bosch.com CC: Jason Liu liu.h.jason@gmail.com CC: Stefano Babic sbabic@denx.de --- tools/imximage.c | 3 --- 1 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/tools/imximage.c b/tools/imximage.c index 1e0f5d4..e9947f1 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -253,9 +253,6 @@ static void set_imx_hdr_v2(struct imx_header *imxhdr, uint32_t dcd_len, imx_header_v2_t *hdr_v2 = &imxhdr->header.hdr_v2; flash_header_v2_t *fhdr_v2 = &hdr_v2->fhdr;
- /* Set default offset */ - imxhdr->flash_offset = FLASH_OFFSET_STANDARD; - /* Set magic number */ fhdr_v2->header.tag = IVT_HEADER_TAG; /* 0xD1 */ fhdr_v2->header.length = cpu_to_be16(sizeof(flash_header_v2_t));
Hi Dirk,
I think we have then a problem when there is not a BOOT_FROM statement in the configuration file, that let imxhdr->flash_offset unset.
We need to set it with the default value at the beginning of the processing or to raise an error if we want to make this statement mandatory in the configuration file.
Best regards, Stefano Babic
Signed-off-by: Dirk Behmedirk.behme@de.bosch.com CC: Jason Liuliu.h.jason@gmail.com CC: Stefano Babicsbabic@denx.de
Hi Dirk,
diff --git a/tools/imximage.c b/tools/imximage.c index 1e0f5d4..e9947f1 100644 --- a/tools/imximage.c +++ b/tools/imximage.c @@ -253,9 +253,6 @@ static void set_imx_hdr_v2(struct imx_header *imxhdr, uint32_t dcd_len, imx_header_v2_t *hdr_v2 =&imxhdr->header.hdr_v2; flash_header_v2_t *fhdr_v2 =&hdr_v2->fhdr;
Hmm, my understanding is that there can't be any default value? What do you think would be a default value? The one for SD boot? The one for NAND? Or? Who will decide what the default should be?
If there can't be a default value, I think to raise an error if no BOOT_FROM statement is there is the only option.
Best regards
Dirk
Am 21/02/2012 20:18, schrieb Dirk Behme:
This is desirable, but it does not correspond to the code.
Whatever we choose, it is wrong. We can select SD, and one board has not a SD interface. The same with NAND, ...
The best one is we have not a default value.
Agree - BOOT_FROM must be mandatory.
Yes, agree.
What do you think about anything like below then [1]?
I looked through the imximage.c code and, well, due to the mixture to support the v1 and v2 header format, the execution path isn't the cleanest one. So, while it doesn't seem to be the cleanest way to exit directly in set_imx_hdr_v2, it seems to be the easiest and best place to add this check. Some other functions have some exit() calls, too, so it seems to be common practice in this code.
If this is ok, I will send a v2 of the patch.
Best regards
Dirk
[1]
--- a/tools/imximage.c +++ b/tools/imximage.c @@ -253,8 +253,12 @@ static void set_imx_hdr_v2(struct imx_header *imxhdr, uint32_t dcd_len, imx_header_v2_t *hdr_v2 = &imxhdr->header.hdr_v2; flash_header_v2_t *fhdr_v2 = &hdr_v2->fhdr;
- /* Set default offset */ - imxhdr->flash_offset = FLASH_OFFSET_STANDARD; + /* Exit if there is no BOOT_FROM field specifying the flash_offset */ + if(imxhdr->flash_offset == 0) { + fprintf(stderr, "Error: Header v2: No BOOT_FROM tag in %s\n", + params->imagename); + exit(EXIT_FAILURE); + }
Hi Dirk,
It is common in all mkimage - when there is an error, it makes no sense to go on.
You must also fix this issue for V1 in set_imx_hdr_v1() as well, because we do not want default value at all. I suggest also you do not check with if(imxhdr->flash_offset == 0), in case Freescale will put a SOC without an offset in the future. But it is easy to add a value that is not allowed. If we add something like
FLASH_OFFSET_UNDEFINED = 0xFF
or whatever you want that is not 32-bit aligned, we are on the safest side.
Ok, thanks.
Hi Dirk,
Ok, the V1 topic is new.
I can't touch V1 because I don't know anything about it. And I don't have any hardware to test anything V1 related.
Even though the V1 code might have a similar issue, it's my understanding that it doesn't hurt there as in V1 there are no flash_offsets != FLASH_OFFSET_STANDARD. Therefore in V1 the existing code works fine (?). Same as the V2 code before Freescale introduced flash offsets which are not FLASH_OFFSET_STANDARD (== 0x400).
I will look where the correct location might be to add this.
I will try to update the V2 header with something like FLASH_OFFSET_UNDEFINED as proposed above and then send a v2 of the patch.
Best regards
Dirk
It is enough if you add the same check in set_imx_hdr_v1() you want to put in set_imx_hdr_v2().
This is not correct. For the MX51, there is a different offset for the onenand device. But there is not a board booting from onenand in mainline.
However, we want that BOOT_FROM is mandatory to avoid confusion. All V1 boards in mainline have BOOT_FROM in their imximage file, so it is enough to test if we can build the boards.
It is the same with both versions - also with V1 there are different offset, but SD / NAND / SPI share the same offset.
Add it into imximage.h
Dirk Behme
Dirk Behme
Stefano Babic
stefano babic
