[PATCH v3 20/25] arm: rockchip: rv1126: Set dram area unsecure for SPL
Unsecure the dram area so that MMC, USB, and SFC controllers can able to read data from dram.
Signed-off-by: Jason Zhu jason.zhu@rock-chips.com Signed-off-by: Jagan Teki jagan@edgeble.ai Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Changes for v3: - collect Kever r-b Changes for v2: - none
arch/arm/mach-rockchip/rv1126/rv1126.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/mach-rockchip/rv1126/rv1126.c b/arch/arm/mach-rockchip/rv1126/rv1126.c index 91554c98b6..b9b898756f 100644 --- a/arch/arm/mach-rockchip/rv1126/rv1126.c +++ b/arch/arm/mach-rockchip/rv1126/rv1126.c @@ -10,6 +10,8 @@ #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/grf_rv1126.h>
+#define FIREWALL_APB_BASE 0xffa60000 +#define FW_DDR_CON_REG 0x80 #define GRF_BASE 0xFE000000
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { @@ -58,6 +60,16 @@ void board_debug_uart_init(void) #ifndef CONFIG_TPL_BUILD int arch_cpu_init(void) { + /** + * Set dram area unsecure in spl + * + * usb & mmc & sfc controllers can read data to dram + * since they are unsecure. + * (Note: only secure-world can access this register) + */ + if (IS_ENABLED(CONFIG_SPL_BUILD)) + writel(0, FIREWALL_APB_BASE + FW_DDR_CON_REG); + return 0; } #endif
Add support for rv1126 package header in mkimage tool.
tools/rkcommon.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 0db45c2d41..9c5e1a29e5 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -133,6 +133,7 @@ static struct spl_info spl_infos[] = { { "rk3368", "RK33", 0x8000 - 0x1000, false, RK_HEADER_V1 }, { "rk3399", "RK33", 0x30000 - 0x2000, false, RK_HEADER_V1 }, { "rv1108", "RK11", 0x1800, false, RK_HEADER_V1 }, + { "rv1126", "110B", 0x10000 - 0x1000, false, RK_HEADER_V1 }, { "rk3568", "RK35", 0x14000 - 0x1000, false, RK_HEADER_V2 }, };
Neural Compute Module 2(Neu2) is a 96boards SoM-CB compute module based on Rockchip RV1126 from Edgeble AI.
General features: - Rockchip RV1126 - 2/4GB LPDDR4 - 8/16/32GB eMMC - 2x MIPI CSI2 FPC connector - Fn-link 8223A-SR WiFi/BT
Industrial grade (-40 °C to +85 °C) version of the same class of module called Neu2k powered with Rockchip RV1126K.
Neu2 needs to mount on top of Edgeble IO boards for creating complete platform solutions.
Add support for it.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v3: - rebase on linux Changes for v2: - none
arch/arm/dts/rv1126-edgeble-neu2.dtsi | 353 ++++++++++++++++++++++++++ 1 file changed, 353 insertions(+) create mode 100644 arch/arm/dts/rv1126-edgeble-neu2.dtsi
diff --git a/arch/arm/dts/rv1126-edgeble-neu2.dtsi b/arch/arm/dts/rv1126-edgeble-neu2.dtsi new file mode 100644 index 0000000000..e4bdc25475 --- /dev/null +++ b/arch/arm/dts/rv1126-edgeble-neu2.dtsi @@ -0,0 +1,353 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Rockchip Electronics Co., Ltd. + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +/ { + compatible = "edgeble,neural-compute-module-2", "rockchip,rv1126"; + + aliases { + mmc0 = &emmc; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vccio_flash: vccio-flash-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&flash_vol_sel>; + regulator-name = "vccio_flash"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk809 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + reset-gpios = <&gpio1 RK_PD0 GPIO_ACTIVE_LOW>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_arm>; +}; + +&emmc { + bus-width = <8>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_bus8 &emmc_cmd &emmc_clk &emmc_rstnout>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&vccio_flash>; + rockchip,default-sample-phase = <90>; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB1 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "rk808-clkout1", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc5-supply = <&vcc_buck5>; + vcc6-supply = <&vcc_buck5>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc5v0_sys>; + + regulators { + vdd_npu_vepu: DCDC_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <6001>; + regulator-initial-mode = <0x2>; + regulator-name = "vdd_npu_vepu"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <725000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-initial-mode = <0x2>; + regulator-name = "vdd_arm"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-name = "vcc_ddr"; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc3v3_sys: DCDC_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-initial-mode = <0x2>; + regulator-name = "vcc3v3_sys"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_buck5: DCDC_REG5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2200000>; + regulator-max-microvolt = <2200000>; + regulator-name = "vcc_buck5"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2200000>; + }; + }; + + vcc_0v8: LDO_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-name = "vcc_0v8"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmu: LDO_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8_pmu"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd0v8_pmu: LDO_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-name = "vcc0v8_pmu"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <800000>; + }; + }; + + vcc_1v8: LDO_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_dovdd: LDO_REG5 { + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_dovdd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_dvdd: LDO_REG6 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc_dvdd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_avdd: LDO_REG7 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vcc_avdd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vccio_sd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_sd: LDO_REG9 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc3v3_sd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_5v0: SWITCH_REG1 { + regulator-name = "vcc_5v0"; + }; + + vcc_3v3: SWITCH_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_3v3"; + }; + }; + }; +}; + +&pinctrl { + bt { + bt_enable: bt-enable { + rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + flash { + flash_vol_sel: flash-vol-sel { + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + wifi { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmuio0-supply = <&vcc1v8_pmu>; + pmuio1-supply = <&vcc3v3_sys>; + vccio1-supply = <&vccio_flash>; + vccio2-supply = <&vccio_sd>; + vccio3-supply = <&vcc_1v8>; + vccio4-supply = <&vcc_dovdd>; + vccio5-supply = <&vcc_1v8>; + vccio6-supply = <&vcc_1v8>; + vccio7-supply = <&vcc_dovdd>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcc_1v8>; + status = "okay"; +}; + +&sdio { + #address-cells = <1>; + #size-cells = <0>; + max-frequency = <100000000>; + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc1_clk &sdmmc1_cmd &sdmmc1_bus4>; + vmmc-supply = <&vcc3v3_sys>; + vqmmc-supply = <&vcc_1v8>; + rockchip,default-sample-phase = <90>; + sd-uhs-sdr104; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_ctsn &uart0_rtsn>; + status = "okay"; + + bluetooth { + compatible = "qcom,qca9377-bt"; + clocks = <&rk809 1>; + clock-names = "lpo"; + enable-gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_HIGH>; /* BT_RST */ + max-speed = <2000000>; + pinctrl-names = "default"; + pinctrl-0 = <&bt_enable>; + vddxo-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_1v8>; + }; +};
Neural Compute Module 2(Neu2) IO board is an industrial form factor evaluation board from Edgeble AI.
General features: - microSD slot - MIPI DSI connector - 2x USB Host - 1x USB OTG - Ethernet - mini PCIe - Onboard PoE - RS485, RS232, CAN - Micro Phone array - Speaker - RTC battery slot - 40-pin expansion
Neu2 needs to mount on top of this IO board in order to create complete Edgeble Neural Compute Module 2(Neu2) IO platform.
Add support for it.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v3: - rebased on linux Changes for v2: - none
arch/arm/dts/Makefile | 3 ++ arch/arm/dts/rv1126-edgeble-neu2-io.dts | 38 +++++++++++++++++++++++++ 2 files changed, 41 insertions(+) create mode 100644 arch/arm/dts/rv1126-edgeble-neu2-io.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 791838733c..422580be6e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -170,6 +170,9 @@ dtb-$(CONFIG_ROCKCHIP_RV1108) += \ rv1108-elgin-r1.dtb \ rv1108-evb.dtb
+dtb-$(CONFIG_ROCKCHIP_RV1126) += \ + rv1126-edgeble-neu2-io.dtb + dtb-$(CONFIG_ARCH_S5P4418) += \ s5p4418-nanopi2.dtb
diff --git a/arch/arm/dts/rv1126-edgeble-neu2-io.dts b/arch/arm/dts/rv1126-edgeble-neu2-io.dts new file mode 100644 index 0000000000..ae1cf34423 --- /dev/null +++ b/arch/arm/dts/rv1126-edgeble-neu2-io.dts @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Rockchip Electronics Co., Ltd. + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +/dts-v1/; +#include "rv1126.dtsi" +#include "rv1126-edgeble-neu2.dtsi" + +/ { + model = "Edgeble Neu2 IO Board"; + compatible = "edgeble,neural-compute-module-2-io", + "edgeble,neural-compute-module-2", "rockchip,rv1126"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_bus4 &sdmmc0_det>; + rockchip,default-sample-phase = <90>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +};
Add u-boot,dm-spl and u-boot,dm-pre-reloc related properties for Rockchip RV1126 SoC.
Both eMMC and SD boot are tested in Edgeble Neu2 SoM.
arch/arm/dts/rv1126-u-boot.dtsi | 63 +++++++++++++++++++++++++++++++++ 1 file changed, 63 insertions(+) create mode 100644 arch/arm/dts/rv1126-u-boot.dtsi
diff --git a/arch/arm/dts/rv1126-u-boot.dtsi b/arch/arm/dts/rv1126-u-boot.dtsi new file mode 100644 index 0000000000..8f635f382b --- /dev/null +++ b/arch/arm/dts/rv1126-u-boot.dtsi @@ -0,0 +1,63 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include "rockchip-u-boot.dtsi" +#include "rockchip-binman.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = \ + "same-as-spl", &emmc, &sdmmc; + }; + + dmc { + compatible = "rockchip,rv1126-dmc"; + u-boot,dm-pre-reloc; + }; +}; + +&gpio0 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&grf { + u-boot,dm-spl; +}; + +&pmu { + u-boot,dm-spl; +}; + +&pmugrf { + u-boot,dm-spl; +}; + +&xin24m { + u-boot,dm-spl; +}; + +&cru { + u-boot,dm-spl; +}; + +&pmucru { + u-boot,dm-spl; +}; + +&sdmmc { + u-boot,dm-spl; +}; + +&emmc { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +};
Neural Compute Module 2(Neu2) IO board is an industrial form factor IO board from Edgeble AI.
Add support for it.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v3: - updated the board names Changes for v2: - none
.../dts/rv1126-edgeble-neu2-io-u-boot.dtsi | 10 ++++ arch/arm/mach-rockchip/rv1126/Kconfig | 16 ++++++ board/edgeble/neural-compute-module-2/Kconfig | 16 ++++++ .../neural-compute-module-2/MAINTAINERS | 6 ++ .../edgeble/neural-compute-module-2/Makefile | 7 +++ board/edgeble/neural-compute-module-2/neu2.c | 4 ++ configs/neu2-io-rv1126_defconfig | 56 +++++++++++++++++++ doc/board/rockchip/rockchip.rst | 3 + include/configs/neural-compute-module-2.h | 21 +++++++ 9 files changed, 139 insertions(+) create mode 100644 arch/arm/dts/rv1126-edgeble-neu2-io-u-boot.dtsi create mode 100644 board/edgeble/neural-compute-module-2/Kconfig create mode 100644 board/edgeble/neural-compute-module-2/MAINTAINERS create mode 100644 board/edgeble/neural-compute-module-2/Makefile create mode 100644 board/edgeble/neural-compute-module-2/neu2.c create mode 100644 configs/neu2-io-rv1126_defconfig create mode 100644 include/configs/neural-compute-module-2.h
diff --git a/arch/arm/dts/rv1126-edgeble-neu2-io-u-boot.dtsi b/arch/arm/dts/rv1126-edgeble-neu2-io-u-boot.dtsi new file mode 100644 index 0000000000..51a1617708 --- /dev/null +++ b/arch/arm/dts/rv1126-edgeble-neu2-io-u-boot.dtsi @@ -0,0 +1,10 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include "rv1126-u-boot.dtsi" + +&sdio { + status = "disabled"; +}; diff --git a/arch/arm/mach-rockchip/rv1126/Kconfig b/arch/arm/mach-rockchip/rv1126/Kconfig index 4f5021b083..7382c55996 100644 --- a/arch/arm/mach-rockchip/rv1126/Kconfig +++ b/arch/arm/mach-rockchip/rv1126/Kconfig @@ -1,5 +1,19 @@ if ROCKCHIP_RV1126
+config TARGET_RV1126_NEU2 + bool "Edgeble Neural Compute Module 2(Neu2) SoM" + help + Neu2: + Neural Compute Module 2(Neu2) is a 96boards SoM-CB compute module + based on Rockchip RV1126 from Edgeble AI. + Neu2 powered with Consumer grade (0 to +80 °C) RV1126 SoC. + Neu2k powered with Industrial grade (-40 °C to +85 °C) RV1126K SoC. + + Neu2-IO: + Neural Compute Module 2(Neu2) IO board is an industrial form factor + IO board and Neu2 needs to mount on top of this IO board in order to + create complete Edgeble Neural Compute Module 2(Neu2) IO platform. + config SOC_SPECIFIC_OPTIONS # dummy def_bool y select HAS_CUSTOM_SYS_INIT_SP_ADDR @@ -40,4 +54,6 @@ config SYS_MALLOC_F_LEN config TEXT_BASE default 0x600000
+source board/edgeble/neural-compute-module-2/Kconfig + endif diff --git a/board/edgeble/neural-compute-module-2/Kconfig b/board/edgeble/neural-compute-module-2/Kconfig new file mode 100644 index 0000000000..21faf4ad26 --- /dev/null +++ b/board/edgeble/neural-compute-module-2/Kconfig @@ -0,0 +1,16 @@ +if TARGET_RV1126_NEU2 + +config SYS_BOARD + default "neural-compute-module-2" + +config SYS_VENDOR + default "edgeble" + +config SYS_CONFIG_NAME + default "neural-compute-module-2" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select RAM_ROCKCHIP_LPDDR4 + +endif diff --git a/board/edgeble/neural-compute-module-2/MAINTAINERS b/board/edgeble/neural-compute-module-2/MAINTAINERS new file mode 100644 index 0000000000..38edb3a360 --- /dev/null +++ b/board/edgeble/neural-compute-module-2/MAINTAINERS @@ -0,0 +1,6 @@ +RV1126-ECM0 +M: Jagan Teki jagan@edgeble.ai +S: Maintained +F: board/edgeble/neural-compute-module-2 +F: include/configs/neural-compute-module-2.h +F: configs/neu2-io-rv1126_defconfig diff --git a/board/edgeble/neural-compute-module-2/Makefile b/board/edgeble/neural-compute-module-2/Makefile new file mode 100644 index 0000000000..3bfc89fa15 --- /dev/null +++ b/board/edgeble/neural-compute-module-2/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += neu2.o diff --git a/board/edgeble/neural-compute-module-2/neu2.c b/board/edgeble/neural-compute-module-2/neu2.c new file mode 100644 index 0000000000..3d2262ce97 --- /dev/null +++ b/board/edgeble/neural-compute-module-2/neu2.c @@ -0,0 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ diff --git a/configs/neu2-io-rv1126_defconfig b/configs/neu2-io-rv1126_defconfig new file mode 100644 index 0000000000..b1814fb102 --- /dev/null +++ b/configs/neu2-io-rv1126_defconfig @@ -0,0 +1,56 @@ +CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_TPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_SYS_ARCH_TIMER=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_DEVICE_TREE="rv1126-edgeble-neu2-io" +CONFIG_ROCKCHIP_RV1126=y +CONFIG_TARGET_RV1126_NEU2=y +CONFIG_DEBUG_UART_BASE=0xff570000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xe00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT_VERBOSE=y +CONFIG_DEFAULT_FDT_FILE="rv1126-edgeble-neu2-io.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_NO_BSS_LIMIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +# CONFIG_CMD_BOOTD is not set +CONFIG_SYS_BOOTM_LEN=0x4000000 +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_GPT=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_REGULATOR_PWM=y +CONFIG_PWM_ROCKCHIP=y +# CONFIG_RAM_ROCKCHIP_DEBUG is not set +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set +CONFIG_DM_THERMAL=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_LZO=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 4ca7b00b1f..8b332c2e77 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -89,6 +89,9 @@ List of mainline supported Rockchip boards: - Rockchip Evb-rv1108 (evb-rv1108) - Elgin-R1 (elgin-rv1108)
+* rv1126 + - Edgeble Neural Compute Module 2 SoM - Neu2/Neu2k (neu2-io-r1126) + Building --------
diff --git a/include/configs/neural-compute-module-2.h b/include/configs/neural-compute-module-2.h new file mode 100644 index 0000000000..f0934ae00c --- /dev/null +++ b/include/configs/neural-compute-module-2.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#ifndef __NEURAL_COMPUTE_MODULE_2_H +#define __NEURAL_COMPUTE_MODULE_2_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rv1126_common.h> + +#undef BOOT_TARGET_DEVICES + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) + +#endif /* __NEURAL_COMPUTE_MODULE_2_H */
Jagan Teki
