[PATCH v3 1/5] fdtdec: Fix the types of addr and size in fdtdec_add_reserved_memory()
fdtdec_get_addr_size() expects size is of type 'fdt_size_t', and return value is of type 'fdt_addr_t'. Adjust their types accordingly.
Signed-off-by: Bin Meng bin.meng@windriver.com Reviewed-by: Simon Glass sjg@chromium.org ---
(no changes since v1)
lib/fdtdec.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 1f2b763..42f7a25 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1294,7 +1294,8 @@ int fdtdec_add_reserved_memory(void *blob, const char *basename, /* find a matching node and return the phandle to that */ fdt_for_each_subnode(node, blob, parent) { const char *name = fdt_get_name(blob, node, NULL); - phys_addr_t addr, size; + fdt_addr_t addr; + fdt_size_t size;
addr = fdtdec_get_addr_size(blob, node, "reg", &size); if (addr == FDT_ADDR_T_NONE) {
At present fdtdec_add_reserved_memory() calls fdtdec_get_addr_size() to get address and size for the subnodes of /reserved-memory node.
We should honor #address-cells and #size-cells properties in the parent node.
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 42f7a25..0dd7ff1 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1297,7 +1297,8 @@ int fdtdec_add_reserved_memory(void *blob, const char *basename, fdt_addr_t addr; fdt_size_t size;
- addr = fdtdec_get_addr_size(blob, node, "reg", &size); + addr = fdtdec_get_addr_size_fixed(blob, node, "reg", 0, na, ns, + &size, false); if (addr == FDT_ADDR_T_NONE) { debug("failed to read address/size for %s\n", name); continue;
Add DECLARE_GLOBAL_DATA_PTR since it is referenced in the test codes.
Signed-off-by: Bin Meng bin.meng@windriver.com ---
test/dm/fdtdec.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/test/dm/fdtdec.c b/test/dm/fdtdec.c index b2f75b5..c2f7b94 100644 --- a/test/dm/fdtdec.c +++ b/test/dm/fdtdec.c @@ -9,6 +9,8 @@ #include <dm/test.h> #include <test/ut.h>
+DECLARE_GLOBAL_DATA_PTR; + static int dm_test_fdtdec_set_carveout(struct unit_test_state *uts) { struct fdt_memory resv;
You may need to rebase this series on u-boot-dm/next
It should be "writable".
test/dm/fdtdec.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/dm/fdtdec.c b/test/dm/fdtdec.c index c2f7b94..999d712 100644 --- a/test/dm/fdtdec.c +++ b/test/dm/fdtdec.c @@ -22,7 +22,7 @@ static int dm_test_fdtdec_set_carveout(struct unit_test_state *uts) blob = malloc(blob_sz); ut_assertnonnull(blob);
- /* Make a writtable copy of the fdt blob */ + /* Make a writable copy of the fdt blob */ ut_assertok(fdt_open_into(gd->fdt_blob, blob, blob_sz));
resv.start = 0x1000;
This adds a test case to test the functionality of the fdtdec API fdtdec_add_reserved_memory().
Changes in v3: - correct typo in the comments, and some minor rewording
test/dm/fdtdec.c | 69 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 69 insertions(+)
diff --git a/test/dm/fdtdec.c b/test/dm/fdtdec.c index 999d712..56f6f4f 100644 --- a/test/dm/fdtdec.c +++ b/test/dm/fdtdec.c @@ -59,3 +59,72 @@ static int dm_test_fdtdec_set_carveout(struct unit_test_state *uts) } DM_TEST(dm_test_fdtdec_set_carveout, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT | DM_TESTF_FLAT_TREE); + +static int dm_test_fdtdec_add_reserved_memory(struct unit_test_state *uts) +{ + struct fdt_memory resv; + fdt_addr_t addr; + fdt_size_t size; + void *blob; + int blob_sz, parent, subnode; + uint32_t phandle, phandle1; + + blob_sz = fdt_totalsize(gd->fdt_blob) + 128; + blob = malloc(blob_sz); + ut_assertnonnull(blob); + + /* Make a writable copy of the fdt blob */ + ut_assertok(fdt_open_into(gd->fdt_blob, blob, blob_sz)); + + /* Insert a memory region in /reserved-memory node */ + resv.start = 0x1000; + resv.end = 0x1fff; + ut_assertok(fdtdec_add_reserved_memory(blob, "rsvd_region", + &resv, &phandle)); + + /* Test /reserve-memory and its subnode should exist */ + parent = fdt_path_offset(blob, "/reserved-memory"); + ut_assert(parent > 0); + subnode = fdt_path_offset(blob, "/reserved-memory/rsvd_region"); + ut_assert(subnode > 0); + + /* Test reg property of /reserved-memory/rsvd_region node */ + addr = fdtdec_get_addr_size_auto_parent(blob, parent, subnode, + "reg", 0, &size, false); + ut_assert(addr == resv.start); + ut_assert(size == resv.end - resv.start + 1); + + /* Insert another memory region in /reserved-memory node */ + subnode = fdt_path_offset(blob, "/reserved-memory/rsvd_region1"); + ut_assert(subnode < 0); + + resv.start = 0x2000; + resv.end = 0x2fff; + ut_assertok(fdtdec_add_reserved_memory(blob, "rsvd_region1", + &resv, &phandle1)); + subnode = fdt_path_offset(blob, "/reserved-memory/rsvd_region1"); + ut_assert(subnode > 0); + + /* phandles must be different */ + ut_assert(phandle != phandle1); + + /* + * Insert a 3rd memory region with the same addr/size as the 1st one, + * but a new node should not be inserted due to the same addr/size. + */ + resv.start = 0x1000; + resv.end = 0x1fff; + ut_assertok(fdtdec_add_reserved_memory(blob, "rsvd_region2", + &resv, &phandle1)); + subnode = fdt_path_offset(blob, "/reserved-memory/rsvd_region2"); + ut_assert(subnode < 0); + + /* phandle must be same as the 1st one */ + ut_assert(phandle == phandle1); + + free(blob); + + return 0; +} +DM_TEST(dm_test_fdtdec_add_reserved_memory, + DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT | DM_TESTF_FLAT_TREE);
Changes in v3:
I think this is useful. But do note that upstream libfdt has some tess also.
Bin Meng
