[PATCH 1/2] imx8mp_evk: Convert to DM_PMIC
Currently, the imx8mp_evk uses the non-DM code to initialize the PMIC.
Convert to DM_PMIC, which is the recommended way to access the PMIC.
While at it, fix multi-line comments style.
Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/imx8mp-evk-u-boot.dtsi | 18 ++++++++++- board/freescale/imx8mp_evk/spl.c | 50 +++++++++++++++-------------- configs/imx8mp_evk_defconfig | 12 +++---- 3 files changed, 47 insertions(+), 33 deletions(-)
diff --git a/arch/arm/dts/imx8mp-evk-u-boot.dtsi b/arch/arm/dts/imx8mp-evk-u-boot.dtsi index 9ed62f1bb02d..0bf489b46248 100644 --- a/arch/arm/dts/imx8mp-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-evk-u-boot.dtsi @@ -13,6 +13,22 @@ }; };
+&pinctrl_i2c1 { + bootph-all; +}; + +&pinctrl_pmic { + bootph-all; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@25} { + bootph-all; +}; + +&{/soc@0/bus@30800000/i2c@30a20000/pmic@25/regulators} { + bootph-all; +}; + ®_usdhc2_vmmc { u-boot,off-on-delay-us = <20000>; }; @@ -66,7 +82,7 @@ };
&i2c1 { - bootph-pre-ram; + bootph-all; };
&i2c2 { diff --git a/board/freescale/imx8mp_evk/spl.c b/board/freescale/imx8mp_evk/spl.c index 246826a0d482..9dd2cbc799c3 100644 --- a/board/freescale/imx8mp_evk/spl.c +++ b/board/freescale/imx8mp_evk/spl.c @@ -67,40 +67,44 @@ struct i2c_pads_info i2c_pad_info1 = { }, };
-#if CONFIG_IS_ENABLED(POWER_LEGACY) -#define I2C_PMIC 0 +#if CONFIG_IS_ENABLED(DM_PMIC_PCA9450) int power_init_board(void) { - struct pmic *p; + struct udevice *dev; int ret;
- ret = power_pca9450_init(I2C_PMIC, 0x25); - if (ret) - printf("power init failed"); - p = pmic_get("PCA9450"); - pmic_probe(p); + ret = pmic_get("pmic@25", &dev); + if (ret == -ENODEV) { + puts("No pmic@25\n"); + return 0; + } + if (ret < 0) + return ret;
/* BUCKxOUT_DVS0/1 control BUCK123 output */ - pmic_reg_write(p, PCA9450_BUCK123_DVS, 0x29); + pmic_reg_write(dev, PCA9450_BUCK123_DVS, 0x29);
/* - * increase VDD_SOC to typical value 0.95V before first - * DRAM access, set DVS1 to 0.85v for suspend. + * Increase VDD_SOC to typical value 0.95V before first + * DRAM access, set DVS1 to 0.85V for suspend. * Enable DVS control through PMIC_STBY_REQ and * set B1_ENMODE=1 (ON by PMIC_ON_REQ=H) */ -#ifdef CONFIG_IMX8M_VDD_SOC_850MV - /* set DVS0 to 0.85v for special case*/ - pmic_reg_write(p, PCA9450_BUCK1OUT_DVS0, 0x14); -#else - pmic_reg_write(p, PCA9450_BUCK1OUT_DVS0, 0x1C); -#endif - pmic_reg_write(p, PCA9450_BUCK1OUT_DVS1, 0x14); - pmic_reg_write(p, PCA9450_BUCK1CTRL, 0x59); + if (CONFIG_IS_ENABLED(IMX8M_VDD_SOC_850MV)) + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, 0x14); + else + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS0, 0x1C);
- /* Kernel uses OD/OD freq for SOC */ - /* To avoid timing risk from SOC to ARM,increase VDD_ARM to OD voltage 0.95v */ - pmic_reg_write(p, PCA9450_BUCK2OUT_DVS0, 0x1C); + pmic_reg_write(dev, PCA9450_BUCK1OUT_DVS1, 0x14); + pmic_reg_write(dev, PCA9450_BUCK1CTRL, 0x59); + + /* + * Kernel uses OD/OD freq for SOC. + * To avoid timing risk from SOC to ARM,increase VDD_ARM to OD + * voltage 0.95V. + */ + + pmic_reg_write(dev, PCA9450_BUCK2OUT_DVS0, 0x1C);
return 0; } @@ -135,8 +139,6 @@ void board_init_f(ulong dummy)
enable_tzc380();
- setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); - power_init_board();
/* DDR initialization */ diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index 820dc36e9cdd..0675f0f4f41b 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -7,9 +7,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 -CONFIG_SYS_I2C_MXC_I2C1=y -CONFIG_SYS_I2C_MXC_I2C2=y -CONFIG_SYS_I2C_MXC_I2C3=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx8mp-evk" CONFIG_SPL_TEXT_BASE=0x920000 @@ -88,8 +85,6 @@ CONFIG_FASTBOOT_MMC_USER_SUPPORT=y CONFIG_MXC_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y -# CONFIG_SPL_DM_I2C is not set -CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_SUPPORT_EMMC_BOOT=y @@ -110,15 +105,16 @@ CONFIG_PHY_IMX8MQ_USB=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y -CONFIG_SPL_POWER_LEGACY=y CONFIG_POWER_DOMAIN=y CONFIG_IMX8M_POWER_DOMAIN=y CONFIG_IMX8MP_HSIOMIX_BLKCTRL=y -CONFIG_POWER_PCA9450=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_PMIC_PCA9450=y CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PCA9450=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SPL_POWER_I2C=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y
I would like to help maintaining the imx8mp_evk board.
Add myself to MAINTAINERS.
Signed-off-by: Fabio Estevam festevam@denx.de --- board/freescale/imx8mp_evk/MAINTAINERS | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/freescale/imx8mp_evk/MAINTAINERS b/board/freescale/imx8mp_evk/MAINTAINERS index 2759652cc425..c2c7c830b5d2 100644 --- a/board/freescale/imx8mp_evk/MAINTAINERS +++ b/board/freescale/imx8mp_evk/MAINTAINERS @@ -1,4 +1,5 @@ i.MX8MP EVK BOARD +M: Fabio Estevm festevam@gmail.com M: Peng Fan peng.fan@nxp.com S: Maintained F: board/freescale/imx8mp_evk/
Acked-by: Peng Fan peng.fan@nxp.com
Applied to u-boot-imx next, thanks.
Reviewed-by: Peng Fan peng.fan@nxp.com
+&pinctrl_i2c1 {
- bootph-all;
+&pinctrl_pmic {
- bootph-all;
- bootph-all;
- bootph-all;
- ®_usdhc2_vmmc { u-boot,off-on-delay-us = <20000>; };
&i2c1 {
- bootph-pre-ram;
bootph-all; };
&i2c2 {
- struct pmic *p;
- struct udevice *dev; int ret;
- if (ret)
- pmic_probe(p);
if (ret < 0)
return ret;
- Enable DVS control through PMIC_STBY_REQ and
- set B1_ENMODE=1 (ON by PMIC_ON_REQ=H)
-#else
-#endif
- if (CONFIG_IS_ENABLED(IMX8M_VDD_SOC_850MV))
- else
* voltage 0.95V.
return 0; }
enable_tzc380();
power_init_board();
Fabio Estevam
Peng Fan
