[U-Boot] [PATCH 1/2] [for v2018.03] ARM: dts: imx6qdl-icore-rqs: Sync usdhc4 node from Linux
usdhc4 node need to update pinctrl, bus-width and non-removable properties, sync the same from Linux.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6qdl-icore-rqs.dtsi | 37 ++++++++++++++++++++++++++++++++++++- 1 file changed, 36 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/imx6qdl-icore-rqs.dtsi b/arch/arm/dts/imx6qdl-icore-rqs.dtsi index 1623838490..4f7f10203d 100644 --- a/arch/arm/dts/imx6qdl-icore-rqs.dtsi +++ b/arch/arm/dts/imx6qdl-icore-rqs.dtsi @@ -115,9 +115,13 @@
&usdhc4 { u-boot,dm-spl; - pinctrl-names = "default"; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; pinctrl-0 = <&pinctrl_usdhc4>; + pinctrl-1 = <&pinctrl_usdhc4_100mhz>; + pinctrl-2 = <&pinctrl_usdhc4_200mhz>; + bus-witdh = <8>; no-1-8-v; + non-removable; status = "okay"; };
@@ -198,4 +202,35 @@ MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x17070 >; }; + + pinctrl_usdhc4_100mhz: usdhc4grp_100mhz { + fsl,pins = < + MX6QDL_PAD_SD4_CMD__SD4_CMD 0x170B1 + MX6QDL_PAD_SD4_CLK__SD4_CLK 0x100B1 + MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x170B1 + MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x170B1 + MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x170B1 + MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x170B1 + MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x170B1 + MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x170B1 + MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x170B1 + MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x170B1 + >; + }; + + pinctrl_usdhc4_200mhz: usdhc4grp_200mhz { + fsl,pins = < + MX6QDL_PAD_SD4_CMD__SD4_CMD 0x170F9 + MX6QDL_PAD_SD4_CLK__SD4_CLK 0x100F9 + MX6QDL_PAD_SD4_DAT0__SD4_DATA0 0x170F9 + MX6QDL_PAD_SD4_DAT1__SD4_DATA1 0x170F9 + MX6QDL_PAD_SD4_DAT2__SD4_DATA2 0x170F9 + MX6QDL_PAD_SD4_DAT3__SD4_DATA3 0x170F9 + MX6QDL_PAD_SD4_DAT4__SD4_DATA4 0x170F9 + MX6QDL_PAD_SD4_DAT5__SD4_DATA5 0x170F9 + MX6QDL_PAD_SD4_DAT6__SD4_DATA6 0x170F9 + MX6QDL_PAD_SD4_DAT7__SD4_DATA7 0x170F9 + >; + }; + };
This patch fixes the wrongly included dtsi file which was breaking mainline support for Engicam i.CoreM6 DualLite/Solo RQS.
Linux commit details for the same change as "ARM: dts: imx6dl: Include correct dtsi file for Engicam i.CoreM6 DualLite/Solo RQS" (sha1: c0c6bb2322964bd264b4ddedaa5776f40c709f0c)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6dl-icore-rqs.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/imx6dl-icore-rqs.dts b/arch/arm/dts/imx6dl-icore-rqs.dts index 0f1de3f18c..820e66c724 100644 --- a/arch/arm/dts/imx6dl-icore-rqs.dts +++ b/arch/arm/dts/imx6dl-icore-rqs.dts @@ -41,7 +41,7 @@
/dts-v1/;
-#include "imx6q.dtsi" +#include "imx6dl.dtsi" #include "imx6qdl-icore-rqs.dtsi"
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Hi Stefano,
Can you pick these two for the release?
On 09/03/2018 13:13, Jagan Teki wrote:
Hi Stefano,
Applied to -um-boot-imx, master, and I will send my PR to Tom with these fixes.
Regards, Stefano
Fabio Estevam
Jagan Teki
Stefano Babic
