[U-Boot-Users] U-Boot and MPC857T?
Hi there,
has someone patched U-Boot to "support" the MPC857T?
AFAIK it's basicly a MPC855T. So the only change would be to avoid a boot message like:
CPU: unknown MPC855 (0x07000003) at 80 MHz: 4 kB I-Cache 4 kB D-Cache FEC present
*** Warning: CPU Core has Silicon Bugs -- Check the Errata ***
Thanks,
Steven
All you need to do is extend the list of types defined in "cpu/mpc8xx/cpu.c" - a patch is welcome.
I'd love to present a patch. Could you please give me a pointer where to find information about the values of
k = (immr << 16) | *((ushort *) & immap->im_cpm.cp_dparam[0xB0]);
? I couldn't find some.
Is it possible to find out if it's a 855, 857 or 860 at runtime? So that we don't have to rely on DEFINES?
FAIK MPC855T and MPC857T are basicly the same. So could put both on my board without actually changing the firmware. Would be nice if u-boot could figure out which one is actually present.
Thanks,
Steven
Hello!
Sorry, I am still using PPCBoot V1.6 and made a quick hack for some performance tests.
Hope, this helps for a good patch.
I couldn't neither. I patched the orginal check_CPU function for MPC855 and inserted a call like this: + case 0x07000003: + return (check_CPU_MPC857_HACK(clock, pvr, immr)); + break;
so function check_CPU_MPC857_HACK is almost a copy of check_CPU. the main differences in compare to check_CPU was this: + char pre = 'X'; + char *mid = "xx"; + char *suf; ... + switch(k) { + case 0x07000003: mid = "T"; suf = "B"; m = 1; break; + default: suf = NULL; break; + } ... + if (suf) + printf ("%cPC857%sZPnn%s", pre, mid, suf); + else + printf ("unknown MPC857 (0x%08x)", k); + + printf(" at %s MHz:", strmhz(buf, clock));
This would be really nice, that is the reason why I first tried the hack like above, but we would have to modify some part of the macro concept.
I also thought to that, but it is not so easy, because of at least the following Macros showed below.
We have our board with a MPC855T 50 MHz and two prototypes with a MPC857T 100 MHz. The CPU-Clock cannot be detected automatically. We need at least the following differences:
#elif defined(CONFIG_100MHz) /* for 100 MHz = "50 MHz" |= SCCR_EBDF01 */ #define CFG_SCCR (SCCR_TBS | SCCR_EBDF01 | \ SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ SCCR_RTSEL | SCCR_DFALCD00) #define CFG_PLPRCR ( (4-1)<<PLPRCR_MF_SHIFT | PLPRCR_TEXPS | PLPRCR_TMIST ) #define CONFIG_8xx_GCLK_FREQ 100000000 #else /* up to 50 MHz we use a 1:1 clock (CLKOUT=GCLK2) */ #define CFG_SCCR (SCCR_TBS | \ SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ SCCR_RTSEL | SCCR_DFALCD00) #define CFG_PLPRCR ( (2-1)<<PLPRCR_MF_SHIFT | PLPRCR_TEXPS | PLPRCR_TMIST ) #define CONFIG_8xx_GCLK_FREQ 50000000 #endif /* CONFIG_...MHz */
also CFG_MAMR_PTA should be modified.
Gunnar Larisch
Hi Gunnar,
... I also thought to that, but it is not so easy, because of at least the following Macros showed below.
Ehm... I don't understand. The code above only depends on CONFIG_100MHz and not some CONFIG_MPC855T! Of course you have to compile for a specific clock frequency. But it shouldn't matter if it's a 855T or a 857T!
That's why I thought the FW (compiled for one specific clock) should be able to detect the processor typ...
Steven
On Wed, Jul 02, 2003 at 01:36:07PM +0200, Steven Scholz wrote:
Hi Gunnar,
Yes, I would like to have more, like this: Identify processor and set Clock for that processor right.
I hoped not.
We only used a 857T instead of 855T because the 857T works with 100 MHz internal (both with 50 MHz extern). 855T are only avaible up to 80 MHz. Do you use another feature of the 857T?
You are right, that is working except with the warning and our 857T behaves the same (as slow) like a 855T.
Best regards, Gunnar Larisch
motorola has sever pvr/immr/dparam references on the site.
the only chips you can't distinguish from each other are the new 866 family.
i also have a large 8xx patch i am working on to support that and the new ADS board.
Thanks,
Steven
This SF.Net email sponsored by: Free pre-built ASP.NET sites including Data Reports, E-commerce, Portals, and Forums are available now. Download today and enter to win an XBOX or Visual Studio .NET. http://aspnet.click-url.com/go/psa00100006ave/direct;at.asp_061203_01/01 _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
On Wed, Jul 02, 2003 at 01:37:59PM +0200, Steven Scholz wrote:
Any chance you can provide a URL?
I can't find it offhand, i got most of our docs via the FAE.
I'm off for the long weekend, i'll try to have URLS for you when i get back.
Do you mind to show us some lines in advance?
The patch is still a huge mess, i dont think you want to see it yet ;)
I'll try to cc you my next submission to wolfgang, but im pretty sure he wont accept it, so you may be stuck on a fork if you depend on it; it just touches too much existing code right now.
participants (5)
Gunnar Larisch
Nye Liu
nyet@mrv.com
Steven Scholz
