[U-Boot] [PATCH] sata: fix sata command can not being executed bug
Commit d97dc8a0 separated the non-command code into its own file which caused variable sata_curr_device can not be set to a correct value.
Before commit d97dc8a0, variable sata_curr_device can be set correctly in sata_initialize(). After commit d97dc8a0, sata_initialize() is moved out to its own file. Accordingly, variable sata_curr_device is removed from sata_initialize() too. This caused sata_curr_device never gets a chance to be set properly which prevent other commands from being executed.
This patch sets variable sata_curr_device properly.
Fixes: d97dc8a0 (dm: sata: Separate the non-command code into its own file)
Signed-off-by: Tang Yuantian yuantian.tang@nxp.com --- v3: - refine the commit message v2: - refined this patch and updated the commit title and message
cmd/sata.c | 9 ++++++--- common/sata.c | 8 +++++--- 2 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/cmd/sata.c b/cmd/sata.c index d18b523..f56622a 100644 --- a/cmd/sata.c +++ b/cmd/sata.c @@ -32,9 +32,12 @@ static int do_sata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
/* If the user has not yet run `sata init`, do it now */ - if (sata_curr_device == -1) - if (sata_initialize()) - return 1; + if (sata_curr_device == -1) { + rc = sata_initialize(); + if (rc == -1) + return rc; + sata_curr_device = rc; + }
switch (argc) { case 0: diff --git a/common/sata.c b/common/sata.c index 88f08c9..42ff5c7 100644 --- a/common/sata.c +++ b/common/sata.c @@ -51,7 +51,7 @@ static unsigned long sata_bwrite(struct blk_desc *block_dev, lbaint_t start,
int __sata_initialize(void) { - int rc; + int rc, ret = -1; int i;
for (i = 0; i < CONFIG_SYS_SATA_MAX_DEVICE; i++) { @@ -71,12 +71,14 @@ int __sata_initialize(void) if (!rc) { rc = scan_sata(i); if (!rc && sata_dev_desc[i].lba > 0 && - sata_dev_desc[i].blksz > 0) + sata_dev_desc[i].blksz > 0) { part_init(&sata_dev_desc[i]); + ret = i; + } } }
- return rc; + return ret; } int sata_initialize(void) __attribute__((weak, alias("__sata_initialize")));
v3:
v2:
Signed-off-by: Tang Yuantian yuantian.tang@nxp.com Reviewed-by: Simon Glass sjg@chromium.org
