[U-Boot] Please pull u-boot-ti/master
Wolfgang,
Please pull u-boot-ti/master. I ran MAKEALL and saw no issues. The patch modifying the I2c driver has an ACK from Heiko. The patch restructuring the USB driver actually was a simple patch adding some more #defines so i went ahead and added it.
Thanks, Sandeep
The following changes since commit e9aecdec153ae166739858e6a570432449b979f7: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-ti
git://git.denx.de/u-boot-ti.git master
Steve Sakoman (8): ARMV7: Add pad mux support for OMAP4 ARMV7: Fix udelay for OMAP4 ARMV7: Modify i2c driver for more reliable operation on OMAP4 ARMV7: Add support for the TWL6030 I2C power chip used in OMAP4 systems ARMV7: Restructure omap3 musb driver to allow code sharing between OMAP3 and OMAP4 ARMV7: Enable musb driver and usbtty on OMAP4430 SDP ARMV7: Enable musb driver and usbtty on OMAP4 Panda ARMV7: Update default environment for OMAP4 boards
arch/arm/cpu/armv7/omap-common/timer.c | 9 - arch/arm/cpu/armv7/omap4/board.c | 11 + arch/arm/include/asm/arch-omap3/cpu.h | 3 + arch/arm/include/asm/arch-omap3/i2c.h | 4 +- arch/arm/include/asm/arch-omap4/cpu.h | 3 + arch/arm/include/asm/arch-omap4/mux_omap4.h | 344 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 2 + arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + board/ti/panda/panda.c | 26 ++ board/ti/panda/panda.h | 265 +++++++++++++++++++++ board/ti/sdp4430/sdp.c | 26 ++ board/ti/sdp4430/sdp.h | 265 +++++++++++++++++++++ drivers/i2c/omap24xx_i2c.c | 31 ++- drivers/i2c/omap24xx_i2c.h | 4 + drivers/power/Makefile | 1 + drivers/power/twl6030.c | 77 ++++++ drivers/usb/musb/omap3.c | 16 ++ drivers/usb/musb/omap3.h | 3 +- include/configs/omap4_panda.h | 26 ++- include/configs/omap4_sdp4430.h | 26 ++- include/twl6030.h | 90 +++++++ 21 files changed, 1208 insertions(+), 25 deletions(-) create mode 100644 arch/arm/include/asm/arch-omap4/mux_omap4.h create mode 100644 board/ti/panda/panda.h create mode 100644 board/ti/sdp4430/sdp.h create mode 100644 drivers/power/twl6030.c create mode 100644 include/twl6030.h
Dear Sandeep,
Sorry, I cannot.
There is a license conflivt with that patch:
Steve Sakoman (8): ARMV7: Add support for the TWL6030 I2C power chip used in OMAP4 systems
On Tue, Aug 3, 2010 at 2:37 PM, Wolfgang Denk wd@denx.de wrote:
Dear Sandeep,
Sorry, I cannot.
I just sent a revised version of the patch with that change incorporated.
Steve
Dear Steve Sakoman,
In message AANLkTimyVY=-eippjPncN144Qte6Oq1h5HzLkVS_rPz+@mail.gmail.com you wrote:
Thanks. I'll wait for Sandeep to rebase his tree and resend the pull rq, then.
On Tue, Aug 3, 2010 at 3:21 PM, Wolfgang Denk wd@denx.de wrote:
Dear Steve Sakoman,
OK. Sorry for the inconvenience.
I also have the updated series in the following branch if that will make it easier for Sandeep:
http://www.sakoman.com/cgi-bin/gitweb.cgi?p=u-boot.git;a=shortlog;h=refs/hea...
Steve
s-paulraj@ti.com
Steve Sakoman
