[U-Boot] [PATCH] powerpc/mpc85xx: Remove P1023 RDS support
Since P1023RDS is no longer supported/manufactured by Freescale, we clean up P1023RDS related code. Since P1023RDB is still supported by Freescale, we keep P1023RDB releated code.
Signed-off-by: Lijun Pan Lijun.Pan@freescale.com --- board/freescale/p1023rds/Makefile | 9 - board/freescale/p1023rds/README | 101 ----- board/freescale/p1023rds/bcsr.h | 49 --- board/freescale/p1023rds/law.c | 19 - board/freescale/p1023rds/p1023rds.c | 196 ---------- board/freescale/p1023rds/tlb.c | 102 ----- boards.cfg | 2 - include/configs/P1023RDS.h | 523 -------------------------- nand_spl/board/freescale/p1023rds/Makefile | 87 ----- nand_spl/board/freescale/p1023rds/nand_boot.c | 96 ----- 10 files changed, 1184 deletions(-) delete mode 100644 board/freescale/p1023rds/Makefile delete mode 100644 board/freescale/p1023rds/README delete mode 100644 board/freescale/p1023rds/bcsr.h delete mode 100644 board/freescale/p1023rds/law.c delete mode 100644 board/freescale/p1023rds/p1023rds.c delete mode 100644 board/freescale/p1023rds/tlb.c delete mode 100644 include/configs/P1023RDS.h delete mode 100644 nand_spl/board/freescale/p1023rds/Makefile delete mode 100644 nand_spl/board/freescale/p1023rds/nand_boot.c
diff --git a/board/freescale/p1023rds/Makefile b/board/freescale/p1023rds/Makefile deleted file mode 100644 index fdbf365..0000000 --- a/board/freescale/p1023rds/Makefile +++ /dev/null @@ -1,9 +0,0 @@ -# -# Copyright 2010-2011 Freescale Semiconductor, Inc. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y += p1023rds.o -obj-y += law.o -obj-y += tlb.o diff --git a/board/freescale/p1023rds/README b/board/freescale/p1023rds/README deleted file mode 100644 index d382551..0000000 --- a/board/freescale/p1023rds/README +++ /dev/null @@ -1,101 +0,0 @@ -Overview --------- -The P1023 process includes a performance optimized implementation of the -QorIQ data Path Acceleration Architecture (DPAA). This architecture -provides the infrastructure to support simplified sharing of networking -interfaces and accelerators by multiple CPU cores. P1023 is an e500 based -dual core SOC. - -P1023RDS board is a Low End Dual core platform supporting the P1023 -processor of QorIQ series. - -Building U-boot ---------------- -To build the u-boot for P1023RDS: -Configure to NOR boot: - make P1023RDS_config -Configure to NAND boot: - make P1023RDS_NAND_config -Build: - make - -Board Switches --------------- -Most switches on the board should not be changed. The most frequent -user-settable switches on the board are used to configure -the flash banks. - -J4: all open - -Default NOR flash boot switch setting: - Sw3[1:8]: off on on off on on off off - Sw4[1:8]: off off off on off off off off - Sw6[1:8]: off on off on off on on off - Sw7[1:8]: off on off off on off off off - Sw8[1:8]: on off off off off off off off - -For NAND flash boot,set -Sw4[1:4]: off on on on - -The default native ethernet setting is for RGMII mode. -To use SGMII mode, set -SW8[1:2]: OFF OFF -SW7[6:7]: ON ON - -Memory Map ----------- -0x0000_0000 0x7fff_ffff DDR 2G Cacheable -0x8000_0000 0xbfff_ffff PCI Express Mem 1G non-cacheable -0xc000_0000 0xdfff_ffff PCI 512M non-cacheable -0xe100_0000 0xe3ff_ffff PCI IO range 4M non-cacheable - -0xe000_0000 0xe003_ffff BCSR 256K BCSR -0xee00_0000 0xefff_ffff NOR flash 32M NOR flash -0xff00_0000 0xff3f_ffff DPAA_QBMAN 4M -0xff60_0000 0xff7f_ffff CCSR 2M non-cacheable -0xffa0_0000 0xffaf_ffff NAND FLASH 1M non-cacheable -0xffd0_0000 0xffd0_3fff L1 for stack 16K Cacheable TLB0 - -Flashing u-boot Images ---------------- -To program the image in the boot flash bank: -NOR flash boot: - => tftp 1000000 u-boot.bin - => protect off all - => erase eff40000 efffffff - => cp.b 1000000 eff40000 c0000 - -NAND flash boot: - => tftp 1000000 u-boot-nand.bin - => nand erase 0 80000 - => nand write 1000000 0 80000 - -Firmware ucode location ---------------------------------- -Microcode(ucode) to FMAN's IRAM is needed to make FMAN Ethernet work. -u-boot loads ucode FLASH. The location for ucode: -NOR Flash: 0xfe000000 -NAND Flash: 0x1f00000 - -Using the Device Tree Source File ---------------------------------- -To create the DTB (Device Tree Binary) image file, -use a command similar to this: - - dtc -b 0 -f -I dts -O dtb p1023rds.dts > p1023rds.dtb - -Likely, that .dts file will come from here; - - linux-2.6/arch/powerpc/boot/dts/p1023rds.dts -or - make p1023rds.dtb ARCH=powerpc -in linux-2.6 directory. - -Booting Linux -------------- -Place a linux uImage in the TFTP disk area. - - tftp 1000000 uImage - tftp 2000000 rootfs.ext2.gz.uboot - tftp c00000 p1023rds.dtb - bootm 1000000 2000000 c00000 diff --git a/board/freescale/p1023rds/bcsr.h b/board/freescale/p1023rds/bcsr.h deleted file mode 100644 index a9deb72..0000000 --- a/board/freescale/p1023rds/bcsr.h +++ /dev/null @@ -1,49 +0,0 @@ -/* - * Copyright (C) 2011 Freescale Semiconductor, Inc. - * - * Authors: Chunhe Lan b25806@freescale.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __BCSR_H_ -#define __BCSR_H_ - -#include <common.h> - -/* - * BCSR Bit definitions - * BCSR 15 * - 0 device insertion oriention - 1 stack processor present - 2 power supply shut down/normal operation - 3 I2C bus0 drive enable - 4 reserved - 5:7 I2C bus0 select - 5 - I2C_BUS_0_SS0 - 6 - I2C_BUS_0_SS1 - 7 - I2C_BUS_0_SS2 -*/ - -/* BCSR register base address is 0xFX000020 */ -#define BCSR_BASE_REG_OFFSET 0x20 -#define BCSR_ACCESS_REG_ADDR (CONFIG_SYS_BCSR_BASE + BCSR_BASE_REG_OFFSET) - -#define BCSR15_DEV_INS_ORI 0x80 -#define BCSR15_STACK_PRO_PRE 0x40 -#define BCSR15_POWER_SUPPLY 0x20 -#define BCSR15_I2C_BUS0_EN 0x10 -#define BCSR15_I2C_BUS0_SEG0 0x00 -#define BCSR15_I2C_BUS0_SEG1 0x04 -#define BCSR15_I2C_BUS0_SEG2 0x02 -#define BCSR15_I2C_BUS0_SEG3 0x06 -#define BCSR15_I2C_BUS0_SEG4 0x01 -#define BCSR15_I2C_BUS0_SEG5 0x05 -#define BCSR15_I2C_BUS0_SEG6 0x03 -#define BCSR15_I2C_BUS0_SEG7 0x07 -#define BCSR15_I2C_BUS0_SEG_CLR 0x07 -#define BCSR19_SGMII_SEL_L 0x01 - -/*BCSR Utils functions*/ -void fixup_i2c_bus0_sel_seg0(void); -#endif /* __BCSR_H_ */ diff --git a/board/freescale/p1023rds/law.c b/board/freescale/p1023rds/law.c deleted file mode 100644 index 92f5a3f..0000000 --- a/board/freescale/p1023rds/law.c +++ /dev/null @@ -1,19 +0,0 @@ -/* - * Copyright 2010-2011 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/fsl_law.h> -#include <asm/mmu.h> - -struct law_entry law_table[] = { - SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_4M, - LAW_TRGT_IF_DPAA_SWP_SRAM), - /* The LAW 0xe0000000 ~ 0xefffffff for BCSR and NOR flash */ - SET_LAW(CONFIG_SYS_BCSR_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), -}; - -int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/p1023rds/p1023rds.c b/board/freescale/p1023rds/p1023rds.c deleted file mode 100644 index d8c8745..0000000 --- a/board/freescale/p1023rds/p1023rds.c +++ /dev/null @@ -1,196 +0,0 @@ -/* - * Copyright 2010-2012 Freescale Semiconductor, Inc. - * - * Authors: Roy Zang tie-fei.zang@freescale.com - * Chunhe Lan b25806@freescale.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <pci.h> -#include <asm/io.h> -#include <asm/cache.h> -#include <asm/processor.h> -#include <asm/mmu.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_pci.h> -#include <fsl_ddr_sdram.h> -#include <asm/fsl_portals.h> -#include <libfdt.h> -#include <fdt_support.h> -#include <netdev.h> -#include <malloc.h> -#include <fm_eth.h> -#include <fsl_mdio.h> -#include <miiphy.h> -#include <phy.h> -#include <asm/fsl_dtsec.h> - -#include "bcsr.h" - -DECLARE_GLOBAL_DATA_PTR; - -int board_early_init_f(void) -{ - fsl_lbc_t *lbc = LBC_BASE_ADDR; - - /* Set ABSWP to implement conversion of addresses in the LBC */ - setbits_be32(&lbc->lbcr, CONFIG_SYS_LBC_LBCR); - - return 0; -} - -int checkboard(void) -{ - u8 *bcsr = (u8 *)BCSR_ACCESS_REG_ADDR; - - printf("Board: P1023 RDS\n"); - - clrbits_8(&bcsr[15], BCSR15_I2C_BUS0_SEG_CLR); - setbits_8(&bcsr[15], BCSR15_I2C_BUS0_SEG0); - - return 0; -} - -/* Fixed sdram init -- doesn't use serial presence detect. */ -phys_size_t fixed_sdram(void) -{ -#ifndef CONFIG_SYS_RAMBOOT - struct ccsr_ddr __iomem *ddr = - (struct ccsr_ddr __iomem *)CONFIG_SYS_FSL_DDR_ADDR; - - set_next_law(0, LAW_SIZE_2G, LAW_TRGT_IF_DDR_1); - - out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); - out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); - out_be32(&ddr->cs1_bnds, CONFIG_SYS_DDR_CS1_BNDS); - out_be32(&ddr->cs1_config, CONFIG_SYS_DDR_CS1_CONFIG); - out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); - out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); - out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); - out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); - out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); - out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); - out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); - out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); - out_be32(&ddr->sdram_data_init, CONFIG_SYS_DDR_DATA_INIT); - out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); - out_be32(&ddr->timing_cfg_4, CONFIG_SYS_DDR_TIMING_4); - out_be32(&ddr->timing_cfg_5, CONFIG_SYS_DDR_TIMING_5); - out_be32(&ddr->ddr_zq_cntl, CONFIG_SYS_DDR_ZQ_CNTL); - out_be32(&ddr->ddr_wrlvl_cntl, CONFIG_SYS_DDR_WRLVL_CNTL); - out_be32(&ddr->ddr_cdr1, CONFIG_SYS_DDR_CDR_1); - out_be32(&ddr->ddr_cdr2, CONFIG_SYS_DDR_CDR_2); - out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); -#endif - return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024ul; -} - -#ifdef CONFIG_PCI -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} -#endif - -int board_early_init_r(void) -{ - const unsigned int flashbase = CONFIG_SYS_BCSR_BASE; - const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); - - /* - * Remap Boot flash + BCSR region to caching-inhibited - * so that flash can be erased properly. - */ - - /* Flush d-cache and invalidate i-cache of any FLASH data */ - flush_dcache(); - invalidate_icache(); - - /* invalidate existing TLB entry for flash + bcsr */ - disable_tlb(flash_esel); - - set_tlb(1, flashbase, CONFIG_SYS_BCSR_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, flash_esel, BOOKE_PAGESZ_256M, 1); - - setup_portals(); - - return 0; -} - -unsigned long get_board_sys_clk(ulong dummy) -{ - return gd->bus_clk; -} - -unsigned long get_board_ddr_clk(ulong dummy) -{ - return gd->mem_clk; -} - -int board_eth_init(bd_t *bis) -{ - u8 *bcsr = (u8 *)BCSR_ACCESS_REG_ADDR; - ccsr_gur_t *gur = (ccsr_gur_t *)CONFIG_SYS_MPC85xx_GUTS_ADDR; - struct fsl_pq_mdio_info dtsec_mdio_info; - - /* - * Need to set dTSEC 1 pin multiplexing to TSEC. The default setting - * is not correct. - */ - setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_TSEC1_1); - - dtsec_mdio_info.regs = - (struct tsec_mii_mng *)CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR; - dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; - - /* Register the 1G MDIO bus */ - fsl_pq_mdio_init(bis, &dtsec_mdio_info); - - fm_info_set_phy_address(FM1_DTSEC1, CONFIG_SYS_FM1_DTSEC1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, CONFIG_SYS_FM1_DTSEC2_PHY_ADDR); - - fm_info_set_mdio(FM1_DTSEC1, - miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME)); - fm_info_set_mdio(FM1_DTSEC2, - miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME)); - - /* Make SERDES connected to SGMII by cleaing bcsr19[7] */ - if (fm_info_get_enet_if(FM1_DTSEC1) == PHY_INTERFACE_MODE_SGMII) - clrbits_8(&bcsr[19], BCSR19_SGMII_SEL_L); - -#ifdef CONFIG_FMAN_ENET - cpu_eth_init(bis); -#endif - - return pci_eth_init(bis); -} - -#if defined(CONFIG_OF_BOARD_SETUP) -void ft_board_setup(void *blob, bd_t *bd) -{ - phys_addr_t base; - phys_size_t size; - - ft_cpu_setup(blob, bd); - - base = getenv_bootm_low(); - size = getenv_bootm_size(); - - fdt_fixup_memory(blob, (u64)base, (u64)size); - - /* By default NOR is on, and NAND is disabled */ -#ifdef CONFIG_NAND_U_BOOT - do_fixup_by_path_string(blob, "nor_flash", "status", "disabled"); - do_fixup_by_path_string(blob, "nand_flash", "status", "okay"); -#endif -#ifdef CONFIG_HAS_FSL_DR_USB - fdt_fixup_dr_usb(blob, bd); -#endif - - fdt_fixup_fman_ethernet(blob); -} -#endif diff --git a/board/freescale/p1023rds/tlb.c b/board/freescale/p1023rds/tlb.c deleted file mode 100644 index 8b2bf50..0000000 --- a/board/freescale/p1023rds/tlb.c +++ /dev/null @@ -1,102 +0,0 @@ -/* - * Copyright 2010-2011 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/mmu.h> - -struct fsl_e_tlb_entry tlb_table[] = { - /* TLB 0 - for temp stack in cache */ - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, - CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, - CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, - CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - - /* TLB 1 */ - /* *I*** - Covers boot page */ - SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I, - 0, 0, BOOKE_PAGESZ_4K, 1), - - /* *I*G* - CCSRBAR */ - SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 1, BOOKE_PAGESZ_4M, 1), - -#ifndef CONFIG_NAND_SPL - /* *W*G* - BCSR and NOR flash on local bus*/ - /* This will be changed to *I*G* after relocation to RAM. */ - SET_TLB_ENTRY(1, CONFIG_SYS_BCSR_BASE, CONFIG_SYS_BCSR_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, - 0, 2, BOOKE_PAGESZ_256M, 1), - - /* *I*G* - PCI */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT, CONFIG_SYS_PCIE3_MEM_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 3, BOOKE_PAGESZ_1G, 1), - - /* *I*G* - PCI */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x40000000, - CONFIG_SYS_PCIE3_MEM_PHYS + 0x40000000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 4, BOOKE_PAGESZ_256M, 1), - - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT + 0x50000000, - CONFIG_SYS_PCIE3_MEM_PHYS + 0x50000000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 5, BOOKE_PAGESZ_256M, 1), - - /* *I*G* - PCI I/O */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_IO_VIRT, CONFIG_SYS_PCIE3_IO_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 6, BOOKE_PAGESZ_256K, 1), - - /* Bman/Qman */ - SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE, CONFIG_SYS_BMAN_MEM_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 7, BOOKE_PAGESZ_1M, 1), - SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE + 0x00100000, - CONFIG_SYS_BMAN_MEM_PHYS + 0x00100000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 8, BOOKE_PAGESZ_1M, 1), - SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE, CONFIG_SYS_QMAN_MEM_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_M, - 0, 9, BOOKE_PAGESZ_1M, 1), - SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE + 0x00100000, - CONFIG_SYS_QMAN_MEM_PHYS + 0x00100000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 10, BOOKE_PAGESZ_1M, 1), -#endif - - /* *I*G - NAND */ - SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 11, BOOKE_PAGESZ_1M, 1), - -#ifdef CONFIG_SYS_RAMBOOT - SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, - CONFIG_SYS_DDR_SDRAM_BASE, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 12, BOOKE_PAGESZ_1G, 1), - - SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, - CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 13, BOOKE_PAGESZ_1G, 1), -#endif -}; - -int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index b8cfead..844b1fd 100644 --- a/boards.cfg +++ b/boards.cfg @@ -862,8 +862,6 @@ Active powerpc mpc85xx - freescale p1022ds Active powerpc mpc85xx - freescale p1022ds P1022DS_SDCARD P1022DS:SDCARD Timur Tabi timur@freescale.com Active powerpc mpc85xx - freescale p1022ds P1022DS_SPIFLASH P1022DS:SPIFLASH Timur Tabi timur@freescale.com Active powerpc mpc85xx - freescale p1023rdb P1023RDB - - -Active powerpc mpc85xx - freescale p1023rds P1023RDS - Roy Zang tie-fei.zang@freescale.com -Active powerpc mpc85xx - freescale p1023rds P1023RDS_NAND P1023RDS:NAND Roy Zang tie-fei.zang@freescale.com Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB P1_P2_RDB:P1011RDB - Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_36BIT P1_P2_RDB:P1011RDB,36BIT - Active powerpc mpc85xx - freescale p1_p2_rdb P1011RDB_36BIT_SDCARD P1_P2_RDB:P1011RDB,36BIT,SDCARD - diff --git a/include/configs/P1023RDS.h b/include/configs/P1023RDS.h deleted file mode 100644 index 8601eec..0000000 --- a/include/configs/P1023RDS.h +++ /dev/null @@ -1,523 +0,0 @@ -/* - * Copyright 2010-2012 Freescale Semiconductor, Inc. - * - * Authors: Roy Zang tie-fei.zang@freescale.com - * Chunhe Lan b25806@freescale.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * p1023rds board configuration file - * - */ -#ifndef __CONFIG_H -#define __CONFIG_H - -#ifdef CONFIG_NAND -#define CONFIG_NAND_U_BOOT -#define CONFIG_RAMBOOT_NAND -#endif - -#ifdef CONFIG_NAND_U_BOOT -#define CONFIG_SYS_TEXT_BASE_SPL 0xfff00000 -#define CONFIG_SYS_TEXT_BASE 0x11001000 - -#ifdef CONFIG_NAND_SPL -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE_SPL /* start of monitor */ -#else -#define CONFIG_SYS_LDSCRIPT $(CPUDIR)/u-boot-nand.lds -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ -#endif /* CONFIG_NAND_SPL */ -#endif - -#ifndef CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_TEXT_BASE 0xeff40000 -#endif - -#ifndef CONFIG_SYS_MONITOR_BASE -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ -#endif - -#ifndef CONFIG_RESET_VECTOR_ADDRESS -#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc -#endif - -/* High Level Configuration Options */ -#define CONFIG_BOOKE /* BOOKE */ -#define CONFIG_E500 /* BOOKE e500 family */ -#define CONFIG_P1023 -#define CONFIG_P1023RDS -#define CONFIG_MP /* support multiple processors */ - -#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ -#define CONFIG_PCI /* Enable PCI/PCIE */ -#define CONFIG_PCIE1 /* PCIE controler 1 (slot 1) */ -#define CONFIG_PCIE2 /* PCIE controler 2 (slot 2) */ -#define CONFIG_PCIE3 /* PCIE controler 3 (slot 3) */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ -#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ -#define CONFIG_FSL_LAW /* Use common FSL init code */ - -#ifndef __ASSEMBLY__ -extern unsigned long get_clock_freq(void); -#endif - -#define CONFIG_SYS_CLK_FREQ 66666666 -#define CONFIG_DDR_CLK_FREQ CONFIG_SYS_CLK_FREQ - -/* - * These can be toggled for performance analysis, otherwise use default. - */ -#define CONFIG_L2_CACHE /* toggle L2 cache */ -#define CONFIG_BTB /* toggle branch predition */ -#define CONFIG_HWCONFIG - -#define CONFIG_ENABLE_36BIT_PHYS - -#define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x1fffffff /* fix me, only 1G */ -#define CONFIG_PANIC_HANG /* do not reset board on panic */ - -#define CONFIG_SYS_LBC_LBCR 0x00000000 /* Implement conversion of - addresses in the LBC */ - -/* DDR Setup */ -#define CONFIG_VERY_BIG_RAM - -#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER -#define CONFIG_MEM_INIT_VALUE 0xDeadBeef - -#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE - -#define CONFIG_DIMM_SLOTS_PER_CTLR 1 -#define CONFIG_CHIP_SELECTS_PER_CTRL 2 - -/* These are used when DDR doesn't use SPD. */ -#define CONFIG_SYS_SDRAM_SIZE 2048u /* DDR is 2GB */ - -/* Default settings for "stable" mode */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000003F -#define CONFIG_SYS_DDR_CS1_BNDS 0x0040007F -#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014302 -#define CONFIG_SYS_DDR_CS1_CONFIG 0x80014302 -#define CONFIG_SYS_DDR_TIMING_3 0x00020000 -#define CONFIG_SYS_DDR_TIMING_0 0x40110104 -#define CONFIG_SYS_DDR_TIMING_1 0x5C59E544 -#define CONFIG_SYS_DDR_TIMING_2 0x0fA888CA -#define CONFIG_SYS_DDR_MODE_1 0x00441210 -#define CONFIG_SYS_DDR_MODE_2 0x00000000 -#define CONFIG_SYS_DDR_MODE_CTRL 0x00000000 -#define CONFIG_SYS_DDR_INTERVAL 0x0A280100 -#define CONFIG_SYS_DDR_DATA_INIT 0xdeadbeef -#define CONFIG_SYS_DDR_CLK_CTRL 0x01800000 -#define CONFIG_SYS_DDR_TIMING_4 0x00000001 -#define CONFIG_SYS_DDR_TIMING_5 0x01401400 -#define CONFIG_SYS_DDR_ZQ_CNTL 0x89080600 -#define CONFIG_SYS_DDR_WRLVL_CNTL 0x8675F605 -#define CONFIG_SYS_DDR_CONTROL 0xC70C0008 /* Type = DDR3: No Interleaving */ -#define CONFIG_SYS_DDR_CONTROL2 0x24401010 -#define CONFIG_SYS_DDR_CDR1 0x00000000 -#define CONFIG_SYS_DDR_CDR2 0x00000000 - -#define CONFIG_SYS_DDR_ERR_INT_EN 0x00000000 -#define CONFIG_SYS_DDR_ERR_DIS 0x00000000 -#define CONFIG_SYS_DDR_SBE 0x00000000 - -/* Settings that differ for "performance" mode */ -#define CONFIG_SYS_DDR_CS0_BNDS_PERF 0x0000007F /* Interleaving Enabled */ -#define CONFIG_SYS_DDR_CS1_BNDS_PERF 0x00000000 /* Interleaving Enabled */ -#define CONFIG_SYS_DDR_CS1_CONFIG_PERF 0x80014302 -#define CONFIG_SYS_DDR_TIMING_1_PERF 0x5C58E544 -#define CONFIG_SYS_DDR_TIMING_2_PERF 0x0FA888CA -/* Type = DDR3: cs0-cs1 interleaving */ -#define CONFIG_SYS_DDR_CONTROL_PERF 0xC70C4008 -#define CONFIG_SYS_DDR_CDR_1 0x00000000 -#define CONFIG_SYS_DDR_CDR_2 0x00000000 - - -/* - * Memory map - * - * 0x0000_0000 0x7fff_ffff DDR 2G Cacheable - * 0x8000_0000 0xbfff_ffff PCI Express Mem 1G non-cacheable - * 0xc000_0000 0xdfff_ffff PCI 512M non-cacheable - * 0xe100_0000 0xe3ff_ffff PCI IO range 4M non-cacheable - * - * Localbus non-cacheable - * 0xe000_0000 0xe003_ffff BCSR 256K BCSR - * 0xee00_0000 0xefff_ffff NOR flash 32M NOR flash - * 0xff00_0000 0xff3f_ffff DPAA_QBMAN 4M - * 0xff60_0000 0xff7f_ffff CCSR 2M non-cacheable - * 0xffa0_0000 0xffaf_ffff NAND 1M non-cacheable - * 0xffd0_0000 0xffd0_3fff L1 for stack 16K Cacheable TLB0 - */ - -/* - * Local Bus Definitions - */ -#define CONFIG_SYS_BCSR_BASE 0xe0000000 /* start of on board FPGA */ -#define CONFIG_SYS_BCSR_BASE_PHYS CONFIG_SYS_BCSR_BASE - -#ifndef CONFIG_NAND -#define CONFIG_SYS_FLASH_BASE 0xee000000 /* start of FLASH 32M */ - -#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE - -#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ - | BR_PS_16 | BR_V) -#define CONFIG_FLASH_OR_PRELIM 0xfe000ff7 - -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_EMPTY_INFO - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ -#else -#define CONFIG_SYS_NO_FLASH -#endif - -#if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) -#define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f function */ -#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ - -#define CONFIG_SYS_INIT_RAM_LOCK -#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ - -#define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_LEN (768 * 1024) -#define CONFIG_SYS_MALLOC_LEN (6 * 1024 * 1024) /* Reserved for malloc */ - -#ifndef CONFIG_NAND_SPL -#define CONFIG_SYS_NAND_BASE 0xffa00000 -#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE -#else -#define CONFIG_SYS_NAND_BASE 0xfff00000 -#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE -#endif - -#define CONFIG_SYS_NAND_BASE_LIST {CONFIG_SYS_NAND_BASE} -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_MTD_NAND_VERIFY_WRITE -#define CONFIG_CMD_NAND -#define CONFIG_NAND_FSL_ELBC -#define CONFIG_SYS_NAND_BLOCK_SIZE (16 * 1024) - -/* NAND boot: 4K NAND loader config */ -#define CONFIG_SYS_NAND_SPL_SIZE 0x1000 -#define CONFIG_SYS_NAND_U_BOOT_SIZE ((768 << 10) + CONFIG_SYS_NAND_SPL_SIZE) -#define CONFIG_SYS_NAND_U_BOOT_DST (0x11000000 - CONFIG_SYS_NAND_SPL_SIZE) -#define CONFIG_SYS_NAND_U_BOOT_START 0x11000000 -#define CONFIG_SYS_NAND_U_BOOT_OFFS (0) -#define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000 -#define CONFIG_SYS_NAND_U_BOOT_RELOC_SP (CONFIG_SYS_NAND_U_BOOT_RELOC + 0x10000) - -/* NAND flash config */ -#define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8bit */ \ - | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_NAND_OR_PRELIM (0xFFF80000 /* length 32K */ \ - | OR_FCM_CSCT \ - | OR_FCM_CST \ - | OR_FCM_CHT \ - | OR_FCM_SCY_1 \ - | OR_FCM_TRLX \ - | OR_FCM_EHTR) - -#ifdef CONFIG_RAMBOOT_NAND -/* NAND Base Address */ -#define CONFIG_SYS_BR0_PRELIM CONFIG_SYS_NAND_BR_PRELIM -#define CONFIG_SYS_OR0_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ -/* chip select 1 - BCSR */ -#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_BCSR_BASE_PHYS) \ - | BR_MS_GPCM | BR_PS_8 | BR_V) -#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB | OR_GPCM_CSNT | OR_GPCM_XACS \ - | OR_GPCM_SCY | OR_GPCM_TRLX | OR_GPCM_EHTR \ - | OR_GPCM_EAD) -#else -#define CONFIG_SYS_BR0_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ -#define CONFIG_SYS_OR0_PRELIM CONFIG_FLASH_OR_PRELIM /* NOR Options */ -/* chip select 1 - BCSR */ -#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_BCSR_BASE_PHYS) \ - | BR_MS_GPCM | BR_PS_8 | BR_V) -#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB | OR_GPCM_CSNT | OR_GPCM_XACS \ - | OR_GPCM_SCY | OR_GPCM_TRLX | OR_GPCM_EHTR \ - | OR_GPCM_EAD) -#endif - -/* Serial Port - * open - index 2 - * shorted - index 1 - */ -#define CONFIG_CONS_INDEX 1 -#undef CONFIG_SERIAL_SOFTWARE_FIFO -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) -#ifdef CONFIG_NAND_SPL -#define CONFIG_NS16550_MIN_FUNCTIONS -#endif - -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} - -#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600) - -/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - -/* - * Pass open firmware flat tree - */ -#define CONFIG_OF_LIBFDT -#define CONFIG_OF_BOARD_SETUP -#define CONFIG_OF_STDOUT_VIA_ALIAS - -/* new uImage format support */ -#define CONFIG_FIT -#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ - -/* I2C */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_FSL -#define CONFIG_SYS_FSL_I2C_SPEED 400000 -#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 -#define CONFIG_SYS_FSL_I2C2_SPEED 400000 -#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x51 - -/* - * I2C2 EEPROM - */ -#define CONFIG_ID_EEPROM -#ifdef CONFIG_ID_EEPROM -#define CONFIG_SYS_I2C_EEPROM_NXID -#endif -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x51 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_EEPROM_BUS_NUM 0 - -#define CONFIG_CMD_I2C - -/* - * eSPI - Enhanced SPI - */ -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_ATMEL - -#define CONFIG_HARD_SPI -#define CONFIG_FSL_ESPI - -#define CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 - -/* - * General PCI - * Memory space is mapped 1-1, but I/O space must start from 0. - */ - -/* controller 3, Slot 1, tgtid 3, Base address b000 */ -#define CONFIG_SYS_PCIE3_NAME "Slot 3" -#define CONFIG_SYS_PCIE3_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 -#define CONFIG_SYS_PCIE3_MEM_PHYS 0x80000000 -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE3_IO_VIRT 0xffc00000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_PHYS 0xffc00000 -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ - -/* controller 2, direct to uli, tgtid 2, Base address 9000 */ -#define CONFIG_SYS_PCIE2_NAME "Slot 2" -#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE2_IO_VIRT 0xffc10000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ - -/* controller 1, Slot 2, tgtid 1, Base address a000 */ -#define CONFIG_SYS_PCIE1_NAME "Slot 1" -#define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 -#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc0000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_VIRT 0xffc20000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_PHYS 0xffc20000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ - -#if defined(CONFIG_PCI) -#define CONFIG_E1000 /* Defind e1000 pci Ethernet card */ -#define CONFIG_PCI_PNP /* do pci plug-and-play */ -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif /* CONFIG_PCI */ - -/* - * Environment - */ -#define CONFIG_ENV_OVERWRITE - -#if defined(CONFIG_SYS_RAMBOOT) -#if defined(CONFIG_RAMBOOT_NAND) -#define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET ((768 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x4000) -#define CONFIG_ENV_SIZE 0x2000 -#endif -#else -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif - -#define CONFIG_LOADS_ECHO /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING -#define CONFIG_CMD_MII -#define CONFIG_CMD_ELF -#define CONFIG_CMD_SETEXPR -#define CONFIG_CMD_REGINFO - -#if defined(CONFIG_PCI) -#define CONFIG_CMD_PCI -#define CONFIG_CMD_NET -#endif - -/* - * USB - */ -#define CONFIG_HAS_FSL_DR_USB -#ifdef CONFIG_HAS_FSL_DR_USB -#define CONFIG_USB_EHCI - -#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_USB_EHCI_FSL -#define CONFIG_USB_STORAGE -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION -#endif -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_CMDLINE_EDITING /* Command-line editing */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -/* Boot Argument Buffer Size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE - -/* - * For booting Linux, the board info and command line data - * have to be in the first 16 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ -#define CONFIG_SYS_BOOTM_LEN (16 << 20) /* Increase max gunzip size */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#endif - -/* - * Environment Configuration - */ -#define CONFIG_BOOTFILE "uImage" -#define CONFIG_UBOOTPATH (u-boot.bin) /* U-Boot image on TFTP server */ - -/* default location for tftp and bootm */ -#define CONFIG_LOADADDR 1000000 - -#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ - -#define CONFIG_BAUDRATE 115200 - -/* Qman/Bman */ -#define CONFIG_SYS_DPAA_QBMAN /* support Q/Bman */ -#define CONFIG_SYS_QMAN_MEM_BASE 0xff000000 -#define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE -#define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 -#define CONFIG_SYS_BMAN_MEM_BASE 0xff200000 -#define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE -#define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 - -/* For FM */ -#define CONFIG_SYS_DPAA_FMAN -#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ - -#ifdef CONFIG_SYS_DPAA_FMAN -#define CONFIG_FMAN_ENET -#define CONFIG_PHY_MARVELL -#endif - -#ifndef CONFIG_NAND -/* Default address of microcode for the Linux Fman driver */ -/* QE microcode/firmware address */ -#define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_FMAN_FW_ADDR 0xEFF00000 -#else -#define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_FMAN_FW_ADDR 0x1f00000 -#endif -#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 -#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) - -#ifdef CONFIG_FMAN_ENET -#define CONFIG_SYS_FM1_DTSEC1_PHY_ADDR 0x2 -#define CONFIG_SYS_FM1_DTSEC2_PHY_ADDR 0x7 - -#define CONFIG_SYS_TBIPA_VALUE 8 -#define CONFIG_MII /* MII PHY management */ -#define CONFIG_ETHPRIME "FM1@DTSEC1" -#endif - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "hwconfig=usb1:dr_mode=host,phy_type=ulpi\0" - -#endif /* __CONFIG_H */ diff --git a/nand_spl/board/freescale/p1023rds/Makefile b/nand_spl/board/freescale/p1023rds/Makefile deleted file mode 100644 index fba9f93..0000000 --- a/nand_spl/board/freescale/p1023rds/Makefile +++ /dev/null @@ -1,87 +0,0 @@ -# -# Copyright 2010-2011 Freescale Semiconductor, Inc. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -PAD_TO := 0xfff01000 - -nandobj := $(objtree)/nand_spl/ - -LDSCRIPT= $(srctree)/$(CPUDIR)/u-boot-nand_spl.lds -LDFLAGS := -T $(nandobj)u-boot-nand_spl.lds -Ttext $(CONFIG_SYS_TEXT_BASE_SPL) \ - $(LDFLAGS) $(LDFLAGS_FINAL) -asflags-y += -DCONFIG_NAND_SPL -ccflags-y += -DCONFIG_NAND_SPL - -SOBJS = start.o resetvec.o -COBJS = cache.o cpu_init_early.o spl_minimal.o fsl_law.o law.o \ - nand_boot.o nand_boot_fsl_elbc.o ns16550.o tlb.o tlb_table.o - -OBJS := $(addprefix $(obj)/,$(SOBJS) $(COBJS)) -__OBJS := $(SOBJS) $(COBJS) -LNDIR := $(nandobj)board/$(BOARDDIR) - -targets += $(__OBJS) - -all: $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin - -$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl - $(OBJCOPY) $(OBJCOPYFLAGS) --pad-to=$(PAD_TO) -O binary $< $@ - -$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl - $(OBJCOPY) $(OBJCOPYFLAGS) -O binary $< $@ - -$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot-nand_spl.lds - cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) $(PLATFORM_LIBS) \ - -Map $(nandobj)u-boot-spl.map -o $@ - -$(nandobj)u-boot-nand_spl.lds: $(LDSCRIPT) - $(CPP) $(cpp_flags) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ - -ansi -D__ASSEMBLY__ -P - <$< >$@ - -# create symbolic links for common files - -$(obj)/cache.c: - @rm -f $@ - ln -sf $(srctree)/arch/powerpc/lib/cache.c $@ - -$(obj)/cpu_init_early.c: - @rm -f $@ - ln -sf $(srctree)/$(CPUDIR)/cpu_init_early.c $@ - -$(obj)/spl_minimal.c: - @rm -f $@ - ln -sf $(srctree)/$(CPUDIR)/spl_minimal.c $@ - -$(obj)/fsl_law.c: - @rm -f $@ - ln -sf $(srctree)/arch/powerpc/cpu/mpc8xxx/law.c $@ - -$(obj)/law.c: - @rm -f $@ - ln -sf $(srctree)/board/$(BOARDDIR)/law.c $@ - -$(obj)/nand_boot_fsl_elbc.c: - @rm -f $@ - ln -sf $(srctree)/nand_spl/nand_boot_fsl_elbc.c $@ - -$(obj)/ns16550.c: - @rm -f $@ - ln -sf $(srctree)/drivers/serial/ns16550.c $@ - -$(obj)/resetvec.S: - @rm -f $@ - ln -s $(srctree)/$(CPUDIR)/resetvec.S $@ - -$(obj)/start.S: - @rm -f $@ - ln -sf $(srctree)/$(CPUDIR)/start.S $@ - -$(obj)/tlb.c: - @rm -f $@ - ln -sf $(srctree)/$(CPUDIR)/tlb.c $@ - -$(obj)/tlb_table.c: - @rm -f $@ - ln -sf $(srctree)/board/$(BOARDDIR)/tlb.c $@ diff --git a/nand_spl/board/freescale/p1023rds/nand_boot.c b/nand_spl/board/freescale/p1023rds/nand_boot.c deleted file mode 100644 index d9afa6d..0000000 --- a/nand_spl/board/freescale/p1023rds/nand_boot.c +++ /dev/null @@ -1,96 +0,0 @@ -/* - * Copyright 2010-2011 Freescale Semiconductor, Inc. - * Author: Roy Zang tie-fei.zang@freescale.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <ns16550.h> -#include <asm/io.h> -#include <nand.h> -#include <asm/fsl_law.h> -#include <fsl_ddr_sdram.h> -#include <asm/global_data.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* Fixed sdram init -- doesn't use serial presence detect. */ -void sdram_init(void) -{ - struct ccsr_ddr __iomem *ddr = - (struct ccsr_ddr __iomem *)CONFIG_SYS_FSL_DDR_ADDR; - - set_next_law(0, LAW_SIZE_2G, LAW_TRGT_IF_DDR_1); - - __raw_writel(CONFIG_SYS_DDR_CS0_BNDS, &ddr->cs0_bnds); - __raw_writel(CONFIG_SYS_DDR_CS0_CONFIG, &ddr->cs0_config); - __raw_writel(CONFIG_SYS_DDR_CS1_BNDS, &ddr->cs1_bnds); - __raw_writel(CONFIG_SYS_DDR_CS1_CONFIG, &ddr->cs1_config); - __raw_writel(CONFIG_SYS_DDR_TIMING_3, &ddr->timing_cfg_3); - __raw_writel(CONFIG_SYS_DDR_TIMING_0, &ddr->timing_cfg_0); - __raw_writel(CONFIG_SYS_DDR_TIMING_1, &ddr->timing_cfg_1); - __raw_writel(CONFIG_SYS_DDR_TIMING_2, &ddr->timing_cfg_2); - __raw_writel(CONFIG_SYS_DDR_CONTROL2, &ddr->sdram_cfg_2); - __raw_writel(CONFIG_SYS_DDR_MODE_1, &ddr->sdram_mode); - __raw_writel(CONFIG_SYS_DDR_MODE_2, &ddr->sdram_mode_2); - __raw_writel(CONFIG_SYS_DDR_INTERVAL, &ddr->sdram_interval); - __raw_writel(CONFIG_SYS_DDR_DATA_INIT, &ddr->sdram_data_init); - __raw_writel(CONFIG_SYS_DDR_CLK_CTRL, &ddr->sdram_clk_cntl); - __raw_writel(CONFIG_SYS_DDR_TIMING_4, &ddr->timing_cfg_4); - __raw_writel(CONFIG_SYS_DDR_TIMING_5, &ddr->timing_cfg_5); - __raw_writel(CONFIG_SYS_DDR_ZQ_CNTL, &ddr->ddr_zq_cntl); - __raw_writel(CONFIG_SYS_DDR_WRLVL_CNTL, &ddr->ddr_wrlvl_cntl); - __raw_writel(CONFIG_SYS_DDR_CDR_1, &ddr->ddr_cdr1); - __raw_writel(CONFIG_SYS_DDR_CDR_2, &ddr->ddr_cdr2); - /* Set, but do not enable the memory */ - __raw_writel(CONFIG_SYS_DDR_CONTROL & ~SDRAM_CFG_MEM_EN, &ddr->sdram_cfg); - - asm volatile("sync;isync"); - udelay(500); - - /* Let the controller go */ - out_be32(&ddr->sdram_cfg, in_be32(&ddr->sdram_cfg) | SDRAM_CFG_MEM_EN); -} - -void board_init_f(ulong bootflag) -{ - u32 plat_ratio; - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; - - /* initialize selected port with appropriate baud rate */ - plat_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_PLAT_RATIO; - plat_ratio >>= 1; - gd->bus_clk = CONFIG_SYS_CLK_FREQ * plat_ratio; - NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM1, - gd->bus_clk / 16 / CONFIG_BAUDRATE); - - puts("\nNAND boot... "); - /* Initialize the DDR3 */ - sdram_init(); - /* copy code to RAM and jump to it - this should not return */ - /* NOTE - code has to be copied out of NAND buffer before - * other blocks can be read. - */ - relocate_code(CONFIG_SYS_NAND_U_BOOT_RELOC_SP, 0, - CONFIG_SYS_NAND_U_BOOT_RELOC); -} - -void board_init_r(gd_t *gd, ulong dest_addr) -{ - nand_boot(); -} - -void putc(char c) -{ - if (c == '\n') - NS16550_putc((NS16550_t)CONFIG_SYS_NS16550_COM1, '\r'); - - NS16550_putc((NS16550_t)CONFIG_SYS_NS16550_COM1, c); -} - -void puts(const char *str) -{ - while (*str) - putc(*str++); -}
Dear Lijun Pan,
In message 1402085638-12144-1-git-send-email-Lijun.Pan@freescale.com you wrote:
So are there not any boards left in the field that should be supported?
On 06/06/2014 03:14 PM, Wolfgang Denk wrote:
Dear Lijun Pan,
Wolfgang,
Incidentally, I have been trying to get a list of EOL boards from Freescale. Presume if I get the list, shall we drop the support for those boards right away or wait for some time, or keep them until we are tired of maintenance?
York
Dear York,
In general, EOL of a board at the vendor is of little meaning to the U-Boot community. As long as the boards are in use, and ther eis someone who is willing to take care of supporting it (even at the level of running tests) we do not drop a board.
Boards get dropped only if they become a burson, i. e. if they need fixing (or at least testing) and no active user / maintainer can be found any more.
If we would rrop boards as soon as the vendor declares them EOL, we'd have to spend a lof of work now on removal patches ;-)
Guten Tag Wolfgang,
On 06/06/2014 05:14 PM, Wolfgang Denk wrote:
Dear Lijun Pan,
Seems that we sold about 10 RDS boards before the RDB became available. Even internally, at this time, I'm unable to locate a RDS board if I'd want to test patches of relevance to this platform. Please note we've already dropped support for this board from the kernel
Alles gute,
Dear Emil,
I see. Thanks.
Emil Medve
Lijun Pan
York Sun
