[U-Boot] [PATCH 0/5] ARM: vexpress: add support for more core tiles
This series adds support for the Cortex-A5 and Cortex-A15 core tiles for the ARM Versatile Express boards.
The first three patches have been around for about one and a half years in the Linaro tree now, they refactor the A9 support and add support for A5. I kept the original commits and authors, just resolved some trivial merge conflicts and checkpatch complaints.
Patch 4/5 adds support for the A15 core tile, this is actually the same as the A5 for now, but will be extended later.
Patch 5/5 enables bootz and hush parser for all boards, just for convenience.
Regards, Andre.
-- Andre Przywara Linaro Virtualization Team
The current ca9x4_ct_vxp platform contains support for a Versatile Express motherboard with a quad core A9 core tile.
This patch is the first stage of making separating the Versatile Express motherboard code and the A9 specific code, before adding support for the dual core A5 core tile.
Signed-off-by: Ryan Harkin ryan.harkin@linaro.org Signed-off-by: Andre Przywara andre.przywara@linaro.org --- MAINTAINERS | 2 +- board/armltd/vexpress/Makefile | 2 +- board/armltd/vexpress/ca9x4_ct_vxp.c | 257 -------------------------------- board/armltd/vexpress/vexpress_common.c | 257 ++++++++++++++++++++++++++++++++ boards.cfg | 2 +- include/configs/ca9x4_ct_vxp.h | 198 ------------------------ include/configs/vexpress_common.h | 198 ++++++++++++++++++++++++ 7 files changed, 458 insertions(+), 458 deletions(-) delete mode 100644 board/armltd/vexpress/ca9x4_ct_vxp.c create mode 100644 board/armltd/vexpress/vexpress_common.c delete mode 100644 include/configs/ca9x4_ct_vxp.h create mode 100644 include/configs/vexpress_common.h
diff --git a/MAINTAINERS b/MAINTAINERS index 1614b91..b4d9a35 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -960,7 +960,7 @@ Hugo Villeneuve hugo.villeneuve@lyrtech.com
Matt Waddel matt.waddel@linaro.org
- ca9x4_ct_vxp ARM ARMV7 (Quad Core) + vexpress_common ARM ARMV7 (Quad Core)
Otavio Salvador otavio@ossystems.com.br
diff --git a/board/armltd/vexpress/Makefile b/board/armltd/vexpress/Makefile index 8749590..6719f3d 100644 --- a/board/armltd/vexpress/Makefile +++ b/board/armltd/vexpress/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-COBJS := ca9x4_ct_vxp.o +COBJS := vexpress_common.o
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/armltd/vexpress/ca9x4_ct_vxp.c b/board/armltd/vexpress/ca9x4_ct_vxp.c deleted file mode 100644 index d5e109e..0000000 --- a/board/armltd/vexpress/ca9x4_ct_vxp.c +++ /dev/null @@ -1,257 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * (C) Copyright 2003 - * Texas Instruments, <www.ti.com> - * Kshitij Gupta Kshitij@ti.com - * - * (C) Copyright 2004 - * ARM Ltd. - * Philippe Robin, philippe.robin@arm.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> -#include <malloc.h> -#include <errno.h> -#include <netdev.h> -#include <asm/io.h> -#include <asm/arch/systimer.h> -#include <asm/arch/sysctrl.h> -#include <asm/arch/wdt.h> -#include "../drivers/mmc/arm_pl180_mmci.h" - -static ulong timestamp; -static ulong lastdec; - -static struct wdt *wdt_base = (struct wdt *)WDT_BASE; -static struct systimer *systimer_base = (struct systimer *)SYSTIMER_BASE; -static struct sysctrl *sysctrl_base = (struct sysctrl *)SCTL_BASE; - -static void flash__init(void); -static void vexpress_timer_init(void); -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_SHOW_BOOT_PROGRESS) -void show_boot_progress(int progress) -{ - printf("Boot reached stage %d\n", progress); -} -#endif - -static inline void delay(ulong loops) -{ - __asm__ volatile ("1:\n" - "subs %0, %1, #1\n" - "bne 1b" : "=r" (loops) : "0" (loops)); -} - -int board_init(void) -{ - gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; - gd->bd->bi_arch_number = MACH_TYPE_VEXPRESS; - gd->flags = 0; - - icache_enable(); - flash__init(); - vexpress_timer_init(); - - return 0; -} - -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_SMC911X - rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); -#endif - return rc; -} - -int cpu_mmc_init(bd_t *bis) -{ - int rc = 0; - (void) bis; -#ifdef CONFIG_ARM_PL180_MMCI - struct pl180_mmc_host *host; - - host = malloc(sizeof(struct pl180_mmc_host)); - if (!host) - return -ENOMEM; - memset(host, 0, sizeof(*host)); - - strcpy(host->name, "MMC"); - host->base = (struct sdi_registers *)CONFIG_ARM_PL180_MMCI_BASE; - host->pwr_init = INIT_PWR; - host->clkdiv_init = SDI_CLKCR_CLKDIV_INIT_V1 | SDI_CLKCR_CLKEN; - host->voltages = VOLTAGE_WINDOW_MMC; - host->caps = 0; - host->clock_in = ARM_MCLK; - host->clock_min = ARM_MCLK / (2 * (SDI_CLKCR_CLKDIV_INIT_V1 + 1)); - host->clock_max = CONFIG_ARM_PL180_MMCI_CLOCK_FREQ; - rc = arm_pl180_mmci_init(host); -#endif - return rc; -} - -static void flash__init(void) -{ - /* Setup the sytem control register to allow writing to flash */ - writel(readl(&sysctrl_base->scflashctrl) | VEXPRESS_FLASHPROG_FLVPPEN, - &sysctrl_base->scflashctrl); -} - -int dram_init(void) -{ - gd->ram_size = - get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, PHYS_SDRAM_1_SIZE); - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = - get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = - get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); -} - -int timer_init(void) -{ - return 0; -} - -/* - * Start timer: - * Setup a 32 bit timer, running at 1KHz - * Versatile Express Motherboard provides 1 MHz timer - */ -static void vexpress_timer_init(void) -{ - /* - * Set clock frequency in system controller: - * VEXPRESS_REFCLK is 32KHz - * VEXPRESS_TIMCLK is 1MHz - */ - writel(SP810_TIMER0_ENSEL | SP810_TIMER1_ENSEL | - SP810_TIMER2_ENSEL | SP810_TIMER3_ENSEL | - readl(&sysctrl_base->scctrl), &sysctrl_base->scctrl); - - /* - * Set Timer0 to be: - * Enabled, free running, no interrupt, 32-bit, wrapping - */ - writel(SYSTIMER_RELOAD, &systimer_base->timer0load); - writel(SYSTIMER_RELOAD, &systimer_base->timer0value); - writel(SYSTIMER_EN | SYSTIMER_32BIT | \ - readl(&systimer_base->timer0control), \ - &systimer_base->timer0control); - - reset_timer_masked(); -} - -/* Use the ARM Watchdog System to cause reset */ -void reset_cpu(ulong addr) -{ - writeb(WDT_EN, &wdt_base->wdogcontrol); - writel(WDT_RESET_LOAD, &wdt_base->wdogload); - while (1) - ; -} - -/* - * Delay x useconds AND perserve advance timstamp value - * assumes timer is ticking at 1 msec - */ -void __udelay(ulong usec) -{ - ulong tmo, tmp; - - tmo = usec / 1000; - tmp = get_timer(0); /* get current timestamp */ - - /* - * If setting this forward will roll time stamp then - * reset "advancing" timestamp to 0 and set lastdec value - * otherwise set the advancing stamp to the wake up time - */ - if ((tmo + tmp + 1) < tmp) - reset_timer_masked(); - else - tmo += tmp; - - while (get_timer_masked() < tmo) - ; /* loop till wakeup event */ -} - -ulong get_timer(ulong base) -{ - return get_timer_masked() - base; -} - -void reset_timer_masked(void) -{ - lastdec = readl(&systimer_base->timer0value) / 1000; - timestamp = 0; -} - -ulong get_timer_masked(void) -{ - ulong now = readl(&systimer_base->timer0value) / 1000; - - if (lastdec >= now) { /* normal mode (non roll) */ - timestamp += lastdec - now; - } else { /* count down timer overflowed */ - /* - * nts = ts + ld - now - * ts = old stamp, ld = time before passing through - 1 - * now = amount of time after passing though - 1 - * nts = new "advancing time stamp" - */ - timestamp += lastdec + SYSTIMER_RELOAD - now; - } - lastdec = now; - - return timestamp; -} - -void lowlevel_init(void) -{ -} - -ulong get_board_rev(void){ - return readl((u32 *)SYS_ID); -} - -unsigned long long get_ticks(void) -{ - return get_timer(0); -} - -ulong get_tbclk (void) -{ - return (ulong)CONFIG_SYS_HZ; -} diff --git a/board/armltd/vexpress/vexpress_common.c b/board/armltd/vexpress/vexpress_common.c new file mode 100644 index 0000000..c4f2520 --- /dev/null +++ b/board/armltd/vexpress/vexpress_common.c @@ -0,0 +1,257 @@ +/* + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * David Mueller, ELSOFT AG, d.mueller@elsoft.ch + * + * (C) Copyright 2003 + * Texas Instruments, <www.ti.com> + * Kshitij Gupta Kshitij@ti.com + * + * (C) Copyright 2004 + * ARM Ltd. + * Philippe Robin, philippe.robin@arm.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <malloc.h> +#include <errno.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/systimer.h> +#include <asm/arch/sysctrl.h> +#include <asm/arch/wdt.h> +#include "../drivers/mmc/arm_pl180_mmci.h" + +static ulong timestamp; +static ulong lastdec; + +static struct wdt *wdt_base = (struct wdt *)WDT_BASE; +static struct systimer *systimer_base = (struct systimer *)SYSTIMER_BASE; +static struct sysctrl *sysctrl_base = (struct sysctrl *)SCTL_BASE; + +static void flash__init(void); +static void vexpress_timer_init(void); +DECLARE_GLOBAL_DATA_PTR; + +#if defined(CONFIG_SHOW_BOOT_PROGRESS) +void show_boot_progress(int progress) +{ + printf("Boot reached stage %d\n", progress); +} +#endif + +static inline void delay(ulong loops) +{ + __asm__ volatile ("1:\n" + "subs %0, %1, #1\n" + "bne 1b" : "=r" (loops) : "0" (loops)); +} + +int board_init(void) +{ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + gd->bd->bi_arch_number = MACH_TYPE_VEXPRESS; + gd->flags = 0; + + icache_enable(); + flash__init(); + vexpress_timer_init(); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC911X + rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return rc; +} + +int cpu_mmc_init(bd_t *bis) +{ + int rc = 0; + (void) bis; +#ifdef CONFIG_ARM_PL180_MMCI + struct pl180_mmc_host *host; + + host = malloc(sizeof(struct pl180_mmc_host)); + if (!host) + return -ENOMEM; + memset(host, 0, sizeof(*host)); + + strcpy(host->name, "MMC"); + host->base = (struct sdi_registers *)CONFIG_ARM_PL180_MMCI_BASE; + host->pwr_init = INIT_PWR; + host->clkdiv_init = SDI_CLKCR_CLKDIV_INIT_V1 | SDI_CLKCR_CLKEN; + host->voltages = VOLTAGE_WINDOW_MMC; + host->caps = 0; + host->clock_in = ARM_MCLK; + host->clock_min = ARM_MCLK / (2 * (SDI_CLKCR_CLKDIV_INIT_V1 + 1)); + host->clock_max = CONFIG_ARM_PL180_MMCI_CLOCK_FREQ; + rc = arm_pl180_mmci_init(host); +#endif + return rc; +} + +static void flash__init(void) +{ + /* Setup the sytem control register to allow writing to flash */ + writel(readl(&sysctrl_base->scflashctrl) | VEXPRESS_FLASHPROG_FLVPPEN, + &sysctrl_base->scflashctrl); +} + +int dram_init(void) +{ + gd->ram_size = + get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, PHYS_SDRAM_1_SIZE); + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = + get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); +} + +int timer_init(void) +{ + return 0; +} + +/* + * Start timer: + * Setup a 32 bit timer, running at 1KHz + * Versatile Express Motherboard provides 1 MHz timer + */ +static void vexpress_timer_init(void) +{ + /* + * Set clock frequency in system controller: + * VEXPRESS_REFCLK is 32KHz + * VEXPRESS_TIMCLK is 1MHz + */ + writel(SP810_TIMER0_ENSEL | SP810_TIMER1_ENSEL | + SP810_TIMER2_ENSEL | SP810_TIMER3_ENSEL | + readl(&sysctrl_base->scctrl), &sysctrl_base->scctrl); + + /* + * Set Timer0 to be: + * Enabled, free running, no interrupt, 32-bit, wrapping + */ + writel(SYSTIMER_RELOAD, &systimer_base->timer0load); + writel(SYSTIMER_RELOAD, &systimer_base->timer0value); + writel(SYSTIMER_EN | SYSTIMER_32BIT | + readl(&systimer_base->timer0control), + &systimer_base->timer0control); + + reset_timer_masked(); +} + +/* Use the ARM Watchdog System to cause reset */ +void reset_cpu(ulong addr) +{ + writeb(WDT_EN, &wdt_base->wdogcontrol); + writel(WDT_RESET_LOAD, &wdt_base->wdogload); + while (1) + ; +} + +/* + * Delay x useconds AND perserve advance timstamp value + * assumes timer is ticking at 1 msec + */ +void __udelay(ulong usec) +{ + ulong tmo, tmp; + + tmo = usec / 1000; + tmp = get_timer(0); /* get current timestamp */ + + /* + * If setting this forward will roll time stamp then + * reset "advancing" timestamp to 0 and set lastdec value + * otherwise set the advancing stamp to the wake up time + */ + if ((tmo + tmp + 1) < tmp) + reset_timer_masked(); + else + tmo += tmp; + + while (get_timer_masked() < tmo) + ; /* loop till wakeup event */ +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void reset_timer_masked(void) +{ + lastdec = readl(&systimer_base->timer0value) / 1000; + timestamp = 0; +} + +ulong get_timer_masked(void) +{ + ulong now = readl(&systimer_base->timer0value) / 1000; + + if (lastdec >= now) { /* normal mode (non roll) */ + timestamp += lastdec - now; + } else { /* count down timer overflowed */ + /* + * nts = ts + ld - now + * ts = old stamp, ld = time before passing through - 1 + * now = amount of time after passing though - 1 + * nts = new "advancing time stamp" + */ + timestamp += lastdec + SYSTIMER_RELOAD - now; + } + lastdec = now; + + return timestamp; +} + +void lowlevel_init(void) +{ +} + +ulong get_board_rev(void){ + return readl((u32 *)SYS_ID); +} + +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +ulong get_tbclk(void) +{ + return (ulong)CONFIG_SYS_HZ; +} diff --git a/boards.cfg b/boards.cfg index 5fc70be..3c971d4 100644 --- a/boards.cfg +++ b/boards.cfg @@ -232,7 +232,7 @@ versatilepb arm arm926ejs versatile armltd versatileqemu arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_QEMU,ARCH_VERSATILE_PB integratorap_cm946es arm arm946es integrator armltd - integratorap:CM946ES integratorcp_cm946es arm arm946es integrator armltd - integratorcp:CM946ES -ca9x4_ct_vxp arm armv7 vexpress armltd +vexpress_common arm armv7 vexpress armltd am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1 am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT am335x_evm_uart1 arm armv7 am335x ti am33xx am335x_evm:SERIAL2,CONS_INDEX=2 diff --git a/include/configs/ca9x4_ct_vxp.h b/include/configs/ca9x4_ct_vxp.h deleted file mode 100644 index a7cd1d4..0000000 --- a/include/configs/ca9x4_ct_vxp.h +++ /dev/null @@ -1,198 +0,0 @@ -/* - * (C) Copyright 2010 Linaro - * Matt Waddel, matt.waddel@linaro.org - * - * Configuration for Versatile Express. Parts were derived from other ARM - * configurations. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* Board info register */ -#define SYS_ID 0x10000000 -#define CONFIG_REVISION_TAG 1 -#define CONFIG_SYS_TEXT_BASE 0x60800000 - -#define CONFIG_SYS_MEMTEST_START 0x60000000 -#define CONFIG_SYS_MEMTEST_END 0x20000000 -#define CONFIG_SYS_HZ 1000 - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_SYS_L2CACHE_OFF 1 -#define CONFIG_INITRD_TAG 1 - -#define CONFIG_OF_LIBFDT 1 - -/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) - -#define SCTL_BASE 0x10001000 -#define VEXPRESS_FLASHPROG_FLVPPEN (1 << 0) - -/* SMSC9115 Ethernet from SMSC9118 family */ -#define CONFIG_SMC911X 1 -#define CONFIG_SMC911X_32_BIT 1 -#define CONFIG_SMC911X_BASE 0x4E000000 - -/* PL011 Serial Configuration */ -#define CONFIG_PL011_SERIAL -#define CONFIG_PL011_CLOCK 24000000 -#define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0, \ - (void *)CONFIG_SYS_SERIAL1} -#define CONFIG_CONS_INDEX 0 - -#define CONFIG_BAUDRATE 38400 -#define CONFIG_SYS_SERIAL0 0x10009000 -#define CONFIG_SYS_SERIAL1 0x1000A000 - -/* Command line configuration */ -#define CONFIG_CMD_BDI -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PXE -#define CONFIG_MENU -#define CONFIG_CMD_ELF -#define CONFIG_CMD_ENV -#define CONFIG_CMD_FLASH -#define CONFIG_CMD_IMI -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_NET -#define CONFIG_CMD_PING -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_RUN - -#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION 1 -#define CONFIG_MMC 1 -#define CONFIG_CMD_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_ARM_PL180_MMCI -#define CONFIG_ARM_PL180_MMCI_BASE 0x10005000 -#define CONFIG_SYS_MMC_MAX_BLK_COUNT 127 -#define CONFIG_ARM_PL180_MMCI_CLOCK_FREQ 6250000 - -/* BOOTP options */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_PXE -#define CONFIG_BOOTP_PXE_CLIENTARCH 0x100 -#define CONFIG_BOOTP_VCI_STRING "U-boot.armv7.ca9x4_ct_vxp" - -/* Miscellaneous configurable options */ -#undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_LOAD_ADDR 0x60008000 /* load address */ -#define LINUX_BOOT_PARAM_ADDR 0x60000200 -#define CONFIG_BOOTDELAY 2 - -/* Physical Memory Map */ -#define CONFIG_NR_DRAM_BANKS 2 -#define PHYS_SDRAM_1 0x60000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_2 0x80000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x20000000 /* 512 MB */ -#define PHYS_SDRAM_2_SIZE 0x20000000 /* 512 MB */ - -/* additions for new relocation code */ -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ - CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET - -/* Basic environment settings */ -#define CONFIG_BOOTCOMMAND "run bootflash;" -#define CONFIG_EXTRA_ENV_SETTINGS \ - "loadaddr=0x80008000\0" \ - "ramdisk_addr_r=0x61000000\0" \ - "kernel_addr=0x44100000\0" \ - "ramdisk_addr=0x44800000\0" \ - "maxramdisk=0x1800000\0" \ - "pxefile_addr_r=0x88000000\0" \ - "kernel_addr_r=0x80008000\0" \ - "console=ttyAMA0,38400n8\0" \ - "dram=1024M\0" \ - "root=/dev/sda1 rw\0" \ - "mtd=armflash:1M@0x800000(uboot),7M@0x1000000(kernel)," \ - "24M@0x2000000(initrd)\0" \ - "flashargs=setenv bootargs root=${root} console=${console} " \ - "mem=${dram} mtdparts=${mtd} mmci.fmax=190000 " \ - "devtmpfs.mount=0 vmalloc=256M\0" \ - "bootflash=run flashargs; " \ - "cp ${ramdisk_addr} ${ramdisk_addr_r} ${maxramdisk}; " \ - "bootm ${kernel_addr} ${ramdisk_addr_r}\0" - -/* FLASH and environment organization */ -#define PHYS_FLASH_SIZE 0x04000000 /* 64MB */ -#define CONFIG_SYS_FLASH_CFI 1 -#define CONFIG_FLASH_CFI_DRIVER 1 -#define CONFIG_SYS_FLASH_SIZE 0x04000000 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 -#define CONFIG_SYS_FLASH_BASE0 0x40000000 -#define CONFIG_SYS_FLASH_BASE1 0x44000000 -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE0 - -/* Timeout values in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (2 * CONFIG_SYS_HZ) /* Erase Timeout */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (2 * CONFIG_SYS_HZ) /* Write Timeout */ - -/* 255 0x40000 sectors + first or last sector may have 4 erase regions = 259 */ -#define CONFIG_SYS_MAX_FLASH_SECT 259 /* Max sectors */ -#define FLASH_MAX_SECTOR_SIZE 0x00040000 /* 256 KB sectors */ - -/* Room required on the stack for the environment data */ -#define CONFIG_ENV_SIZE FLASH_MAX_SECTOR_SIZE - -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* use buffered writes */ - -/* - * Amount of flash used for environment: - * We don't know which end has the small erase blocks so we use the penultimate - * sector location for the environment - */ -#define CONFIG_ENV_SECT_SIZE FLASH_MAX_SECTOR_SIZE -#define CONFIG_ENV_OVERWRITE 1 - -/* Store environment at top of flash */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET (PHYS_FLASH_SIZE - \ - (2 * CONFIG_ENV_SECT_SIZE)) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE1 + \ - CONFIG_ENV_OFFSET) -#define CONFIG_SYS_FLASH_PROTECTION /* The devices have real protection */ -#define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE0, \ - CONFIG_SYS_FLASH_BASE1 } - -/* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PROMPT "VExpress# " -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ -#define CONFIG_CMD_SOURCE -#define CONFIG_SYS_LONGHELP -#define CONFIG_CMDLINE_EDITING 1 -#define CONFIG_SYS_MAXARGS 16 /* max command args */ - -#endif diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h new file mode 100644 index 0000000..a7cd1d4 --- /dev/null +++ b/include/configs/vexpress_common.h @@ -0,0 +1,198 @@ +/* + * (C) Copyright 2010 Linaro + * Matt Waddel, matt.waddel@linaro.org + * + * Configuration for Versatile Express. Parts were derived from other ARM + * configurations. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* Board info register */ +#define SYS_ID 0x10000000 +#define CONFIG_REVISION_TAG 1 +#define CONFIG_SYS_TEXT_BASE 0x60800000 + +#define CONFIG_SYS_MEMTEST_START 0x60000000 +#define CONFIG_SYS_MEMTEST_END 0x20000000 +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_SYS_L2CACHE_OFF 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_OF_LIBFDT 1 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) + +#define SCTL_BASE 0x10001000 +#define VEXPRESS_FLASHPROG_FLVPPEN (1 << 0) + +/* SMSC9115 Ethernet from SMSC9118 family */ +#define CONFIG_SMC911X 1 +#define CONFIG_SMC911X_32_BIT 1 +#define CONFIG_SMC911X_BASE 0x4E000000 + +/* PL011 Serial Configuration */ +#define CONFIG_PL011_SERIAL +#define CONFIG_PL011_CLOCK 24000000 +#define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0, \ + (void *)CONFIG_SYS_SERIAL1} +#define CONFIG_CONS_INDEX 0 + +#define CONFIG_BAUDRATE 38400 +#define CONFIG_SYS_SERIAL0 0x10009000 +#define CONFIG_SYS_SERIAL1 0x1000A000 + +/* Command line configuration */ +#define CONFIG_CMD_BDI +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PXE +#define CONFIG_MENU +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ENV +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_IMI +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_RUN + +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_MMC 1 +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_ARM_PL180_MMCI +#define CONFIG_ARM_PL180_MMCI_BASE 0x10005000 +#define CONFIG_SYS_MMC_MAX_BLK_COUNT 127 +#define CONFIG_ARM_PL180_MMCI_CLOCK_FREQ 6250000 + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_PXE +#define CONFIG_BOOTP_PXE_CLIENTARCH 0x100 +#define CONFIG_BOOTP_VCI_STRING "U-boot.armv7.ca9x4_ct_vxp" + +/* Miscellaneous configurable options */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_LOAD_ADDR 0x60008000 /* load address */ +#define LINUX_BOOT_PARAM_ADDR 0x60000200 +#define CONFIG_BOOTDELAY 2 + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 2 +#define PHYS_SDRAM_1 0x60000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_2 0x80000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x20000000 /* 512 MB */ +#define PHYS_SDRAM_2_SIZE 0x20000000 /* 512 MB */ + +/* additions for new relocation code */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET + +/* Basic environment settings */ +#define CONFIG_BOOTCOMMAND "run bootflash;" +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x80008000\0" \ + "ramdisk_addr_r=0x61000000\0" \ + "kernel_addr=0x44100000\0" \ + "ramdisk_addr=0x44800000\0" \ + "maxramdisk=0x1800000\0" \ + "pxefile_addr_r=0x88000000\0" \ + "kernel_addr_r=0x80008000\0" \ + "console=ttyAMA0,38400n8\0" \ + "dram=1024M\0" \ + "root=/dev/sda1 rw\0" \ + "mtd=armflash:1M@0x800000(uboot),7M@0x1000000(kernel)," \ + "24M@0x2000000(initrd)\0" \ + "flashargs=setenv bootargs root=${root} console=${console} " \ + "mem=${dram} mtdparts=${mtd} mmci.fmax=190000 " \ + "devtmpfs.mount=0 vmalloc=256M\0" \ + "bootflash=run flashargs; " \ + "cp ${ramdisk_addr} ${ramdisk_addr_r} ${maxramdisk}; " \ + "bootm ${kernel_addr} ${ramdisk_addr_r}\0" + +/* FLASH and environment organization */ +#define PHYS_FLASH_SIZE 0x04000000 /* 64MB */ +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_SIZE 0x04000000 +#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_FLASH_BASE0 0x40000000 +#define CONFIG_SYS_FLASH_BASE1 0x44000000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE0 + +/* Timeout values in ticks */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (2 * CONFIG_SYS_HZ) /* Erase Timeout */ +#define CONFIG_SYS_FLASH_WRITE_TOUT (2 * CONFIG_SYS_HZ) /* Write Timeout */ + +/* 255 0x40000 sectors + first or last sector may have 4 erase regions = 259 */ +#define CONFIG_SYS_MAX_FLASH_SECT 259 /* Max sectors */ +#define FLASH_MAX_SECTOR_SIZE 0x00040000 /* 256 KB sectors */ + +/* Room required on the stack for the environment data */ +#define CONFIG_ENV_SIZE FLASH_MAX_SECTOR_SIZE + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* use buffered writes */ + +/* + * Amount of flash used for environment: + * We don't know which end has the small erase blocks so we use the penultimate + * sector location for the environment + */ +#define CONFIG_ENV_SECT_SIZE FLASH_MAX_SECTOR_SIZE +#define CONFIG_ENV_OVERWRITE 1 + +/* Store environment at top of flash */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_OFFSET (PHYS_FLASH_SIZE - \ + (2 * CONFIG_ENV_SECT_SIZE)) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE1 + \ + CONFIG_ENV_OFFSET) +#define CONFIG_SYS_FLASH_PROTECTION /* The devices have real protection */ +#define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE0, \ + CONFIG_SYS_FLASH_BASE1 } + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PROMPT "VExpress# " +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ +#define CONFIG_CMD_SOURCE +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_SYS_MAXARGS 16 /* max command args */ + +#endif
Hi Andre,
On Wed, 3 Apr 2013 15:44:32 +0200, Andre Przywara andre.przywara@linaro.org wrote:
This patch seems to not take moves into account, and rather, lists these as deletes/creates. Did you use git format-patch, and if so, did you use tne -M option?
Also, the commit summary could be less generic, something like "ARM: vexpress: rename board ca9x4_ct_vxp as vexpress_common".
Amicalement,
On 04/04/2013 12:06 PM, Albert ARIBAUD wrote:
Hi Andre,
Hi Albert!
Thanks for the -M hint, didn't know about it. Indeed it makes the patches more readable. Will use it in v2.
OK, will fix this.
Thanks for the review, Andre.
This patch creates a new config for the A9 quad core tile that includes the generic config for the Versatile Express platform.
Signed-off-by: Ryan Harkin ryan.harkin@linaro.org Signed-off-by: Andre Przywara andre.przywara@linaro.org --- MAINTAINERS | 2 +- boards.cfg | 2 +- include/configs/vexpress_ca9x4.h | 34 ++++++++++++++++++++++++++++++++++ include/configs/vexpress_common.h | 1 - 4 files changed, 36 insertions(+), 3 deletions(-) create mode 100644 include/configs/vexpress_ca9x4.h
diff --git a/MAINTAINERS b/MAINTAINERS index b4d9a35..761c36c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -960,7 +960,7 @@ Hugo Villeneuve hugo.villeneuve@lyrtech.com
- vexpress_common ARM ARMV7 (Quad Core) + vexpress_ca9x4 ARM ARMV7 (Quad Core)
diff --git a/boards.cfg b/boards.cfg index 3c971d4..908e3bc 100644 --- a/boards.cfg +++ b/boards.cfg @@ -232,7 +232,7 @@ versatilepb arm arm926ejs versatile armltd versatileqemu arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_QEMU,ARCH_VERSATILE_PB integratorap_cm946es arm arm946es integrator armltd - integratorap:CM946ES integratorcp_cm946es arm arm946es integrator armltd - integratorcp:CM946ES -vexpress_common arm armv7 vexpress armltd +vexpress_ca9x4 arm armv7 vexpress armltd am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1 am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT am335x_evm_uart1 arm armv7 am335x ti am33xx am335x_evm:SERIAL2,CONS_INDEX=2 diff --git a/include/configs/vexpress_ca9x4.h b/include/configs/vexpress_ca9x4.h new file mode 100644 index 0000000..c3b6986 --- /dev/null +++ b/include/configs/vexpress_ca9x4.h @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2011 Linaro + * Ryan Harkin, ryan.harkin@linaro.org + * + * Configuration for Versatile Express. Parts were derived from other ARM + * configurations. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __VEXPRESS_CA9X4_H +#define __VEXPRESS_CA9X4_H + +#define CONFIG_VEXPRESS_ORIGINAL_MEMORY_MAP +#include "vexpress_common.h" +#define CONFIG_BOOTP_VCI_STRING "U-boot.armv7.vexpress_ca9x4" + +#endif /* VEXPRESS_CA9X4_H */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index a7cd1d4..9a3431e 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -97,7 +97,6 @@ #define CONFIG_BOOTP_HOSTNAME #define CONFIG_BOOTP_PXE #define CONFIG_BOOTP_PXE_CLIENTARCH 0x100 -#define CONFIG_BOOTP_VCI_STRING "U-boot.armv7.ca9x4_ct_vxp"
/* Miscellaneous configurable options */ #undef CONFIG_SYS_CLKS_IN_HZ
Hi Andre,
On Wed, 3 Apr 2013 15:44:33 +0200, Andre Przywara andre.przywara@linaro.org wrote:
Wait, so patch 1/5 renames ca9x4_ct_vxp as vexpress_common, then patch 2/5 renames vexpress_common as vexpress_ca9x4? If so then please make this a single patch without the intermediary/temporary step.
Amicalement,
On 04/04/2013 12:09 PM, Albert ARIBAUD wrote:
Hi Andre,
But that would not mark the actual file copy (vexpress_common.h is almost the same as vexpress_ca9x4.h) as such, right? So you would end up with a completely new file (_common.h) and a file with almost all content deleted (_ca9x4.h). The fact that the code just moved wouldn't be obvious. That would be extra pity with the nice -M move features in the previous patch.
However I have no problems with merging these two, if you insist.
Regards, Andre.
Hi Andre,
On Thu, 04 Apr 2013 12:31:08 +0200, Andre Przywara andre.przywara@linaro.org wrote:
Hi Andre,
Try -C too, for copies, and possibly --find-copies-harder.
I don't see how eliminating the intermediate target naming would prevent git from detecting moves and copies; and it will simplify the changes undergone by non-header files such as baords.cfg and MAINTAINERS.
I am fine with either of the two following solutions:
a) If patch 1/5 commonalizes vexpress code, then it should not rename any target, and patch 2/5 should do the renaming.
or
b) if patch 1/5 commonalizes and renames the target, it should give it its final name and patch 2 should be merged in.
Regards, Andre.
Amicalement,
This patch creates a new config for the A5 dual core tile that includes the generic config for the Versatile Express platform.
The generic config has been modified to provide support for the Extended Memory Map, as used on the A5 core tile. A5 does not support the legacy memory map.
Signed-off-by: Ryan Harkin ryan.harkin@linaro.org Signed-off-by: Andre Przywara andre.przywara@linaro.org --- MAINTAINERS | 1 + board/armltd/vexpress/vexpress_common.c | 29 ++++-- boards.cfg | 1 + include/configs/vexpress_ca5x2.h | 34 +++++++ include/configs/vexpress_common.h | 152 ++++++++++++++++++++++++++++---- 5 files changed, 192 insertions(+), 25 deletions(-) create mode 100644 include/configs/vexpress_ca5x2.h
diff --git a/MAINTAINERS b/MAINTAINERS index 761c36c..dccee97 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -961,6 +961,7 @@ Hugo Villeneuve hugo.villeneuve@lyrtech.com Matt Waddel matt.waddel@linaro.org
vexpress_ca9x4 ARM ARMV7 (Quad Core) + vexpress_ca5x2 ARM ARMV7 (Dual Core)
diff --git a/board/armltd/vexpress/vexpress_common.c b/board/armltd/vexpress/vexpress_common.c index c4f2520..2c54869 100644 --- a/board/armltd/vexpress/vexpress_common.c +++ b/board/armltd/vexpress/vexpress_common.c @@ -45,8 +45,7 @@ static ulong timestamp; static ulong lastdec;
-static struct wdt *wdt_base = (struct wdt *)WDT_BASE; -static struct systimer *systimer_base = (struct systimer *)SYSTIMER_BASE; +static struct systimer *systimer_base = (struct systimer *)V2M_TIMER01; static struct sysctrl *sysctrl_base = (struct sysctrl *)SCTL_BASE;
static void flash__init(void); @@ -173,13 +172,31 @@ static void vexpress_timer_init(void) reset_timer_masked(); }
+int v2m_cfg_write(u32 devfn, u32 data) +{ + /* Configuration interface broken? */ + u32 val; + + devfn |= SYS_CFG_START | SYS_CFG_WRITE; + + val = readl(V2M_SYS_CFGSTAT); + writel(val & ~SYS_CFG_COMPLETE, V2M_SYS_CFGSTAT); + + writel(data, V2M_SYS_CFGDATA); + writel(devfn, V2M_SYS_CFGCTRL); + + do { + val = readl(V2M_SYS_CFGSTAT); + } while (val == 0); + + return !!(val & SYS_CFG_ERR); +} + /* Use the ARM Watchdog System to cause reset */ void reset_cpu(ulong addr) { - writeb(WDT_EN, &wdt_base->wdogcontrol); - writel(WDT_RESET_LOAD, &wdt_base->wdogload); - while (1) - ; + if (v2m_cfg_write(SYS_CFG_REBOOT | SYS_CFG_SITE_MB, 0)) + printf("Unable to reboot\n"); }
/* diff --git a/boards.cfg b/boards.cfg index 908e3bc..df8d5e5 100644 --- a/boards.cfg +++ b/boards.cfg @@ -232,6 +232,7 @@ versatilepb arm arm926ejs versatile armltd versatileqemu arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_QEMU,ARCH_VERSATILE_PB integratorap_cm946es arm arm946es integrator armltd - integratorap:CM946ES integratorcp_cm946es arm arm946es integrator armltd - integratorcp:CM946ES +vexpress_ca5x2 arm armv7 vexpress armltd vexpress_ca9x4 arm armv7 vexpress armltd am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1 am335x_evm_spiboot arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPI_BOOT diff --git a/include/configs/vexpress_ca5x2.h b/include/configs/vexpress_ca5x2.h new file mode 100644 index 0000000..9331134 --- /dev/null +++ b/include/configs/vexpress_ca5x2.h @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2011 Linaro + * Ryan Harkin, ryan.harkin@linaro.org + * + * Configuration for Versatile Express. Parts were derived from other ARM + * configurations. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __VEXPRESS_CA5X2_h +#define __VEXPRESS_CA5X2_h + +#define CONFIG_VEXPRESS_EXTENDED_MEMORY_MAP +#include "vexpress_common.h" +#define CONFIG_BOOTP_VCI_STRING "U-boot.armv7.vexpress_ca5x2" + +#endif /* __VEXPRESS_CA5X2_h */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 9a3431e..cd268e3 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -1,4 +1,5 @@ /* + * (C) Copyright 2011 ARM Limited * (C) Copyright 2010 Linaro * Matt Waddel, matt.waddel@linaro.org * @@ -24,15 +25,113 @@ * MA 02111-1307 USA */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __VEXPRESS_COMMON_H +#define __VEXPRESS_COMMON_H + +/* + * Definitions copied from linux kernel: + * arch/arm/mach-vexpress/include/mach/motherboard.h + */ +#ifdef CONFIG_VEXPRESS_ORIGINAL_MEMORY_MAP +/* CS register bases for the original memory map. */ +#define V2M_PA_CS0 0x40000000 +#define V2M_PA_CS1 0x44000000 +#define V2M_PA_CS2 0x48000000 +#define V2M_PA_CS3 0x4c000000 +#define V2M_PA_CS7 0x10000000 + +#define V2M_PERIPH_OFFSET(x) (x << 12) +#define V2M_SYSREGS (V2M_PA_CS7 + V2M_PERIPH_OFFSET(0)) +#define V2M_SYSCTL (V2M_PA_CS7 + V2M_PERIPH_OFFSET(1)) +#define V2M_SERIAL_BUS_PCI (V2M_PA_CS7 + V2M_PERIPH_OFFSET(2)) + +#define V2M_BASE 0x60000000 +#define CONFIG_SYS_TEXT_BASE 0x60800000 +#elif defined(CONFIG_VEXPRESS_EXTENDED_MEMORY_MAP) +/* CS register bases for the extended memory map. */ +#define V2M_PA_CS0 0x08000000 +#define V2M_PA_CS1 0x0c000000 +#define V2M_PA_CS2 0x14000000 +#define V2M_PA_CS3 0x18000000 +#define V2M_PA_CS7 0x1c000000 + +#define V2M_PERIPH_OFFSET(x) (x << 16) +#define V2M_SYSREGS (V2M_PA_CS7 + V2M_PERIPH_OFFSET(1)) +#define V2M_SYSCTL (V2M_PA_CS7 + V2M_PERIPH_OFFSET(2)) +#define V2M_SERIAL_BUS_PCI (V2M_PA_CS7 + V2M_PERIPH_OFFSET(3)) + +#define V2M_BASE 0x80000000 +#define CONFIG_SYS_TEXT_BASE 0x80800000 +#endif + +/* + * Physical addresses, offset from V2M_PA_CS0-3 + */ +#define V2M_NOR0 (V2M_PA_CS0) +#define V2M_NOR1 (V2M_PA_CS1) +#define V2M_SRAM (V2M_PA_CS2) +#define V2M_VIDEO_SRAM (V2M_PA_CS3 + 0x00000000) +#define V2M_LAN9118 (V2M_PA_CS3 + 0x02000000) +#define V2M_ISP1761 (V2M_PA_CS3 + 0x03000000) + +/* Common peripherals relative to CS7. */ +#define V2M_AACI (V2M_PA_CS7 + V2M_PERIPH_OFFSET(4)) +#define V2M_MMCI (V2M_PA_CS7 + V2M_PERIPH_OFFSET(5)) +#define V2M_KMI0 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(6)) +#define V2M_KMI1 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(7)) + +#define V2M_UART0 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(9)) +#define V2M_UART1 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(10)) +#define V2M_UART2 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(11)) +#define V2M_UART3 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(12)) + +#define V2M_WDT (V2M_PA_CS7 + V2M_PERIPH_OFFSET(15)) + +#define V2M_TIMER01 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(17)) +#define V2M_TIMER23 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(18)) + +#define V2M_SERIAL_BUS_DVI (V2M_PA_CS7 + V2M_PERIPH_OFFSET(22)) +#define V2M_RTC (V2M_PA_CS7 + V2M_PERIPH_OFFSET(23)) + +#define V2M_CF (V2M_PA_CS7 + V2M_PERIPH_OFFSET(26)) + +#define V2M_CLCD (V2M_PA_CS7 + V2M_PERIPH_OFFSET(31)) +#define V2M_SIZE_CS7 V2M_PERIPH_OFFSET(32) + +/* System register offsets. */ +#define V2M_SYS_CFGDATA (V2M_SYSREGS + 0x0a0) +#define V2M_SYS_CFGCTRL (V2M_SYSREGS + 0x0a4) +#define V2M_SYS_CFGSTAT (V2M_SYSREGS + 0x0a8) + +/* + * Configuration + */ +#define SYS_CFG_START (1 << 31) +#define SYS_CFG_WRITE (1 << 30) +#define SYS_CFG_OSC (1 << 20) +#define SYS_CFG_VOLT (2 << 20) +#define SYS_CFG_AMP (3 << 20) +#define SYS_CFG_TEMP (4 << 20) +#define SYS_CFG_RESET (5 << 20) +#define SYS_CFG_SCC (6 << 20) +#define SYS_CFG_MUXFPGA (7 << 20) +#define SYS_CFG_SHUTDOWN (8 << 20) +#define SYS_CFG_REBOOT (9 << 20) +#define SYS_CFG_DVIMODE (11 << 20) +#define SYS_CFG_POWER (12 << 20) +#define SYS_CFG_SITE_MB (0 << 16) +#define SYS_CFG_SITE_DB1 (1 << 16) +#define SYS_CFG_SITE_DB2 (2 << 16) +#define SYS_CFG_STACK(n) ((n) << 12) + +#define SYS_CFG_ERR (1 << 1) +#define SYS_CFG_COMPLETE (1 << 0)
/* Board info register */ -#define SYS_ID 0x10000000 +#define SYS_ID V2M_SYSREGS #define CONFIG_REVISION_TAG 1 -#define CONFIG_SYS_TEXT_BASE 0x60800000
-#define CONFIG_SYS_MEMTEST_START 0x60000000 +#define CONFIG_SYS_MEMTEST_START V2M_BASE #define CONFIG_SYS_MEMTEST_END 0x20000000 #define CONFIG_SYS_HZ 1000
@@ -46,13 +145,13 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024)
-#define SCTL_BASE 0x10001000 +#define SCTL_BASE V2M_SYSCTL #define VEXPRESS_FLASHPROG_FLVPPEN (1 << 0)
/* SMSC9115 Ethernet from SMSC9118 family */ #define CONFIG_SMC911X 1 #define CONFIG_SMC911X_32_BIT 1 -#define CONFIG_SMC911X_BASE 0x4E000000 +#define CONFIG_SMC911X_BASE V2M_LAN9118
/* PL011 Serial Configuration */ #define CONFIG_PL011_SERIAL @@ -62,8 +161,9 @@ #define CONFIG_CONS_INDEX 0
#define CONFIG_BAUDRATE 38400 -#define CONFIG_SYS_SERIAL0 0x10009000 -#define CONFIG_SYS_SERIAL1 0x1000A000 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } +#define CONFIG_SYS_SERIAL0 V2M_UART0 +#define CONFIG_SYS_SERIAL1 V2M_UART1
/* Command line configuration */ #define CONFIG_CMD_BDI @@ -86,7 +186,7 @@ #define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_ARM_PL180_MMCI -#define CONFIG_ARM_PL180_MMCI_BASE 0x10005000 +#define CONFIG_ARM_PL180_MMCI_BASE V2M_MMCI #define CONFIG_SYS_MMC_MAX_BLK_COUNT 127 #define CONFIG_ARM_PL180_MMCI_CLOCK_FREQ 6250000
@@ -100,14 +200,15 @@
/* Miscellaneous configurable options */ #undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_LOAD_ADDR 0x60008000 /* load address */ -#define LINUX_BOOT_PARAM_ADDR 0x60000200 +#define CONFIG_SYS_LOAD_ADDR (V2M_BASE + 0x8000) +#define LINUX_BOOT_PARAM_ADDR (V2M_BASE + 0x2000) #define CONFIG_BOOTDELAY 2
/* Physical Memory Map */ #define CONFIG_NR_DRAM_BANKS 2 -#define PHYS_SDRAM_1 0x60000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_2 0x80000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1 (V2M_BASE) /* SDRAM Bank #1 */ +#define PHYS_SDRAM_2 (((unsigned int)V2M_BASE) + \ + ((unsigned int)0x20000000)) #define PHYS_SDRAM_1_SIZE 0x20000000 /* 512 MB */ #define PHYS_SDRAM_2_SIZE 0x20000000 /* 512 MB */
@@ -121,14 +222,27 @@
/* Basic environment settings */ #define CONFIG_BOOTCOMMAND "run bootflash;" -#define CONFIG_EXTRA_ENV_SETTINGS \ +#ifdef CONFIG_VEXPRESS_ORIGINAL_MEMORY_MAP +#define CONFIG_PLATFORM_ENV_SETTINGS \ "loadaddr=0x80008000\0" \ "ramdisk_addr_r=0x61000000\0" \ "kernel_addr=0x44100000\0" \ "ramdisk_addr=0x44800000\0" \ "maxramdisk=0x1800000\0" \ "pxefile_addr_r=0x88000000\0" \ - "kernel_addr_r=0x80008000\0" \ + "kernel_addr_r=0x80008000\0" +#elif defined(CONFIG_VEXPRESS_EXTENDED_MEMORY_MAP) +#define CONFIG_PLATFORM_ENV_SETTINGS \ + "loadaddr=0xa0008000\0" \ + "ramdisk_addr_r=0x81000000\0" \ + "kernel_addr=0x0c100000\0" \ + "ramdisk_addr=0x0c800000\0" \ + "maxramdisk=0x1800000\0" \ + "pxefile_addr_r=0xa8000000\0" \ + "kernel_addr_r=0xa0008000\0" +#endif +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_PLATFORM_ENV_SETTINGS \ "console=ttyAMA0,38400n8\0" \ "dram=1024M\0" \ "root=/dev/sda1 rw\0" \ @@ -147,8 +261,8 @@ #define CONFIG_FLASH_CFI_DRIVER 1 #define CONFIG_SYS_FLASH_SIZE 0x04000000 #define CONFIG_SYS_MAX_FLASH_BANKS 2 -#define CONFIG_SYS_FLASH_BASE0 0x40000000 -#define CONFIG_SYS_FLASH_BASE1 0x44000000 +#define CONFIG_SYS_FLASH_BASE0 V2M_NOR0 +#define CONFIG_SYS_FLASH_BASE1 V2M_NOR1 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE0
/* Timeout values in ticks */ @@ -194,4 +308,4 @@ #define CONFIG_CMDLINE_EDITING 1 #define CONFIG_SYS_MAXARGS 16 /* max command args */
-#endif +#endif /* VEXPRESS_COMMON_H */
This adds support for the Cortex-A15-TC2 core tile for the Versatile Express board by ARM. This is mostly a copy of the A5 support file, but will be extended later with A15 specific options.
Signed-off-by: Andre Przywara andre.przywara@linaro.org --- boards.cfg | 1 + include/configs/vexpress_ca15_tc2.h | 36 ++++++++++++++++++++++++++++++++++++ 2 files changed, 37 insertions(+) create mode 100644 include/configs/vexpress_ca15_tc2.h
diff --git a/boards.cfg b/boards.cfg index df8d5e5..e6a86a8 100644 --- a/boards.cfg +++ b/boards.cfg @@ -232,6 +232,7 @@ versatilepb arm arm926ejs versatile armltd versatileqemu arm arm926ejs versatile armltd versatile versatile:ARCH_VERSATILE_QEMU,ARCH_VERSATILE_PB integratorap_cm946es arm arm946es integrator armltd - integratorap:CM946ES integratorcp_cm946es arm arm946es integrator armltd - integratorcp:CM946ES +vexpress_ca15_tc2 arm armv7 vexpress armltd vexpress_ca5x2 arm armv7 vexpress armltd vexpress_ca9x4 arm armv7 vexpress armltd am335x_evm arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1 diff --git a/include/configs/vexpress_ca15_tc2.h b/include/configs/vexpress_ca15_tc2.h new file mode 100644 index 0000000..9e230ad --- /dev/null +++ b/include/configs/vexpress_ca15_tc2.h @@ -0,0 +1,36 @@ +/* + * (C) Copyright 2013 Linaro + * Andre Przywara, andre.przywara@linaro.org + * + * Configuration for Versatile Express. Parts were derived from other ARM + * configurations. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __VEXPRESS_CA15X2_TC2_h +#define __VEXPRESS_CA15X2_TC2_h + +#define CONFIG_VEXPRESS_EXTENDED_MEMORY_MAP +#include "vexpress_common.h" +#define CONFIG_BOOTP_VCI_STRING "U-boot.armv7.vexpress_ca15x2_tc2" + +#define CONFIG_SYS_CLK_FREQ 24000000 + +#endif
Signed-off-by: Andre Przywara andre.przywara@linaro.org --- include/configs/vexpress_common.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index cd268e3..65d0ce4 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -179,6 +179,7 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_SAVEENV #define CONFIG_CMD_RUN +#define CONFIG_CMD_BOOTZ
#define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION 1 @@ -302,6 +303,9 @@ #define CONFIG_SYS_PROMPT "VExpress# " #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ #define CONFIG_CMD_SOURCE #define CONFIG_SYS_LONGHELP
Albert ARIBAUD
Andre Przywara
