[U-Boot] [PATCH 1/2] arm: socfpga: cyclone5: Enable Macronix flash support
Enable Macronix flash support for Cyclone5 SoC
Signed-off-by: Chin Liang See chin.liang.see@intel.com --- configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + 6 files changed, 6 insertions(+)
diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 6ebd8a9..aa535c6 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -53,6 +53,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 08628ab..7be720a 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -48,6 +48,7 @@ CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 8ebe394..6edb47f 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -53,6 +53,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 9f42481..7c2428a 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -54,6 +54,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MICREL=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index f9ed1a3..df1ee31 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -53,6 +53,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_DM_ETH=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 6670b9f..512d701 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -69,6 +69,7 @@ CONFIG_LED_STATUS_CMD=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set
Do these boards actually have a macronix flash ? Most of the ones I know of do not.
Good question.
Actually they are pin compatible and customer can replace the existing one. FYI, there seems a NOR flash shortage worldwide which lead to requests by customer to change the BOM list.
Thanks Chin Liang
Good question.
But at least the Socrates seems to be out of production. I don't see why we would have to change the defconfig here.
Simon
Thanks Chin Liang
Good question.
I'm quite sure better half of those boards won't . If you want to enable the SPI NORs on the devkits, fine, but the is1, sr1500 and vining are unlikely to get a replacement memory type.
Good question.
Actually the way the code works is detecting JEDEC ID and associate it with correct flash drivers like Micron, Spansion or Macronix. Hence it would not yield any issue except slightly larger code. But I can take out sr1500 and vining if it yield a concern.
Thanks Chin Liang
Good question.
Which on those boards I listed is useless dead code.
IS1 too.
See, Chin Liang
Simon Goldschmidt
