[U-Boot] [PATCH] CPU9260 : fix machine ID when using a CPU9G20.
Signed-off-by: Eric Benard eric@eukrea.com --- board/eukrea/cpu9260/cpu9260.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/eukrea/cpu9260/cpu9260.c b/board/eukrea/cpu9260/cpu9260.c index 0b4f0d4..af8a4a2 100644 --- a/board/eukrea/cpu9260/cpu9260.c +++ b/board/eukrea/cpu9260/cpu9260.c @@ -165,7 +165,7 @@ int board_init(void)
/* arch number of the board */ #if defined(CONFIG_CPU9G20) - gd->bd->bi_arch_number = MACH_TYPE_CPUAT9260; + gd->bd->bi_arch_number = MACH_TYPE_CPUAT9G20; #elif defined(CONFIG_CPU9260) gd->bd->bi_arch_number = MACH_TYPE_CPUAT9260; #endif
- gd->bd->bi_arch_number = MACH_TYPE_CPUAT9G20;
Looks like an obvious change Ack
Tom
Eric, This has been pushed to arm/master-sync. Tom
Eric Benard
Tom Rix
