[U-Boot] [PATCH] USB storage count
Here's another USB storage patch. Currently U-Boot handles storage devices #0 - #4 as valid devices, even if there is none connected. This patch fixes usb_stor_get_dev() to check detected device count instead of MAX-define.
This is very important for ill behaving devices. usb_dev_desc[] can be partially initialized if device probe fails.
After fixing get_dev() it was easy to fix "usb part" etc commands. Previously it outputed "Unknown partition table" five times, now it's "no USB devices available".
Signed-off-by: Kim B. Heino Kim.Heino@bluegiga.com
diff -ur u-boot.orig/common/cmd_usb.c u-boot/common/cmd_usb.c --- u-boot.orig/common/cmd_usb.c 2010-03-12 10:49:23.000000000 +0200 +++ u-boot/common/cmd_usb.c 2010-03-12 15:21:57.587689570 +0200 @@ -387,7 +387,7 @@
dev = simple_strtoul(boot_device, &ep, 16); stor_dev = usb_stor_get_dev(dev); - if (stor_dev->type == DEV_TYPE_UNKNOWN) { + if (stor_dev == NULL || stor_dev->type == DEV_TYPE_UNKNOWN) { printf("\n** Device %d not available\n", dev); return 1; } @@ -595,8 +595,10 @@ if (strncmp(argv[1], "part", 4) == 0) { int devno, ok = 0; if (argc == 2) { - for (devno = 0; devno < USB_MAX_STOR_DEV; ++devno) { + for (devno = 0; ; ++devno) { stor_dev = usb_stor_get_dev(devno); + if (stor_dev == NULL) + break; if (stor_dev->type != DEV_TYPE_UNKNOWN) { ok++; if (devno) @@ -608,7 +610,8 @@ } else { devno = simple_strtoul(argv[2], NULL, 16); stor_dev = usb_stor_get_dev(devno); - if (stor_dev->type != DEV_TYPE_UNKNOWN) { + if (stor_dev != NULL && + stor_dev->type != DEV_TYPE_UNKNOWN) { ok++; printf("print_part of %x\n", devno); print_part(stor_dev); @@ -668,12 +671,12 @@ if (argc == 3) { int dev = (int)simple_strtoul(argv[2], NULL, 10); printf("\nUSB device %d: ", dev); - if (dev >= USB_MAX_STOR_DEV) { + stor_dev = usb_stor_get_dev(dev); + if (stor_dev == NULL) { printf("unknown device\n"); return 1; } printf("\n Device %d: ", dev); - stor_dev = usb_stor_get_dev(dev); dev_print(stor_dev); if (stor_dev->type == DEV_TYPE_UNKNOWN) return 1; diff -ur u-boot.orig/common/usb_storage.c u-boot/common/usb_storage.c --- u-boot.orig/common/usb_storage.c 2010-03-12 10:49:23.000000000 +0200 +++ u-boot/common/usb_storage.c 2010-03-12 15:18:34.000564615 +0200 @@ -175,7 +175,7 @@
block_dev_desc_t *usb_stor_get_dev(int index) { - return (index < USB_MAX_STOR_DEV) ? &usb_dev_desc[index] : NULL; + return (index < usb_max_devs) ? &usb_dev_desc[index] : NULL; }
2010/3/12 Kim B. Heino Kim.Heino@bluegiga.com:
Applied to U-boot-usb Thanks.
Remy
Kim B. Heino
Remy Bohmer
