[PATCH v4 0/5] Qualcomm DWC3 USB support
This series enables support for Qualcomm platforms in the DWC3 driver, adds support for arbitrary sector sizes to the USB mass storage gadget, and fixes an issue with the CDC ACM driver where it wouldn't initialise the USB device.
Additionally, it fixes a syntax bug in the Qualcomm SMMU driver, and makes USB_DWC3_GADGET select DM_USB_GADGET to fix compilation with gadget mode.
This is part of a larger series enabling DWC3 USB support on Qualcomm platforms, a feature branch with all patches can be found at [1].
[1]: https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/tree/b4/qcom-li...
--- Changes in v4: - Use map_physmem() instead of casting fdt_addr_t directly to void* - Link to v3: https://lore.kernel.org/r/20240319-b4-qcom-usb-v3-0-09ba1f86d259@linaro.org
Changes in v3: - Fix ordering of QSCRATCH registers in qcom dwc3 glue. - Link to v2: https://lore.kernel.org/r/20240315-b4-qcom-usb-v2-0-5467ec27cb26@linaro.org
Changes in v2: - Drop custom set/clrbits implementation in qcom dwc3 glue. - Additional minor cleanup based on Marek's comments. - Link to v1: https://lore.kernel.org/r/20240131-b4-qcom-usb-v1-0-6438b2a2285e@linaro.org
--- Caleb Connolly (5): usb: dwc3-generic: implement Qualcomm wrapper usb: dwc3: select DM_USB_GADGET usb: gadget: CDC ACM: call usb_gadget_initialize usb: gadget: UMS: support multiple sector sizes iommu: qcom-smmu: fix debugging
cmd/usb_mass_storage.c | 4 -- drivers/iommu/qcom-hyp-smmu.c | 2 +- drivers/usb/dwc3/Kconfig | 1 + drivers/usb/dwc3/dwc3-generic.c | 81 ++++++++++++++++++++++++++++- drivers/usb/gadget/f_acm.c | 9 ++++ drivers/usb/gadget/f_mass_storage.c | 101 ++++++++++++++++++++---------------- drivers/usb/gadget/storage_common.c | 12 +++-- include/usb_mass_storage.h | 1 - 8 files changed, 156 insertions(+), 55 deletions(-) --- base-commit: a288571aff7b27eb9f593dbfd8269e1fbdbbfe18
// Caleb (they/them)
The Qualcomm specific dwc3 wrapper isn't hugely complicated, implemented the missing initialisation for host and gadget mode.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Marek Vasut marex@denx.de Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/usb/dwc3/dwc3-generic.c | 81 ++++++++++++++++++++++++++++++++++++++++- 1 file changed, 80 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index a379a0002e77..7a00529a2a8e 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -424,8 +424,79 @@ enum dwc3_omap_utmi_mode { struct dwc3_glue_ops ti_ops = { .glue_configure = dwc3_ti_glue_configure, };
+/* USB QSCRATCH Hardware registers */ +#define QSCRATCH_GENERAL_CFG 0x08 +#define PIPE_UTMI_CLK_SEL BIT(0) +#define PIPE3_PHYSTATUS_SW BIT(3) +#define PIPE_UTMI_CLK_DIS BIT(8) + +#define QSCRATCH_HS_PHY_CTRL 0x10 +#define UTMI_OTG_VBUS_VALID BIT(20) +#define SW_SESSVLD_SEL BIT(28) + +#define QSCRATCH_SS_PHY_CTRL 0x30 +#define LANE0_PWR_PRESENT BIT(24) + +#define PWR_EVNT_IRQ_STAT_REG 0x58 +#define PWR_EVNT_LPM_IN_L2_MASK BIT(4) +#define PWR_EVNT_LPM_OUT_L2_MASK BIT(5) + +#define SDM845_QSCRATCH_BASE_OFFSET 0xf8800 +#define SDM845_QSCRATCH_SIZE 0x400 +#define SDM845_DWC3_CORE_SIZE 0xcd00 + +static void dwc3_qcom_vbus_override_enable(void __iomem *qscratch_base, bool enable) +{ + if (enable) { + setbits_le32(qscratch_base + QSCRATCH_SS_PHY_CTRL, + LANE0_PWR_PRESENT); + setbits_le32(qscratch_base + QSCRATCH_HS_PHY_CTRL, + UTMI_OTG_VBUS_VALID | SW_SESSVLD_SEL); + } else { + clrbits_le32(qscratch_base + QSCRATCH_SS_PHY_CTRL, + LANE0_PWR_PRESENT); + clrbits_le32(qscratch_base + QSCRATCH_HS_PHY_CTRL, + UTMI_OTG_VBUS_VALID | SW_SESSVLD_SEL); + } +} + +/* For controllers running without superspeed PHYs */ +static void dwc3_qcom_select_utmi_clk(void __iomem *qscratch_base) +{ + /* Configure dwc3 to use UTMI clock as PIPE clock not present */ + setbits_le32(qscratch_base + QSCRATCH_GENERAL_CFG, + PIPE_UTMI_CLK_DIS); + + setbits_le32(qscratch_base + QSCRATCH_GENERAL_CFG, + PIPE_UTMI_CLK_SEL | PIPE3_PHYSTATUS_SW); + + clrbits_le32(qscratch_base + QSCRATCH_GENERAL_CFG, + PIPE_UTMI_CLK_DIS); +} + +static void dwc3_qcom_glue_configure(struct udevice *dev, int index, + enum usb_dr_mode mode) +{ + struct dwc3_glue_data *glue = dev_get_plat(dev); + void __iomem *qscratch_base = map_physmem(glue->regs, 0x400, MAP_NOCACHE); + if (IS_ERR_OR_NULL(qscratch_base)) { + log_err("%s: Invalid qscratch base address\n", dev->name); + return; + } + + if (dev_read_bool(dev, "qcom,select-utmi-as-pipe-clk")) + dwc3_qcom_select_utmi_clk(qscratch_base); + + if (mode != USB_DR_MODE_HOST) + dwc3_qcom_vbus_override_enable(qscratch_base, true); +} + +struct dwc3_glue_ops qcom_ops = { + .glue_configure = dwc3_qcom_glue_configure, +}; + static int dwc3_rk_glue_get_ctrl_dev(struct udevice *dev, ofnode *node) { *node = dev_ofnode(dev); if (!ofnode_valid(*node)) @@ -511,8 +582,16 @@ static int dwc3_glue_reset_init(struct udevice *dev, return 0; else if (ret) return ret;
+ if (device_is_compatible(dev, "qcom,dwc3")) { + reset_assert_bulk(&glue->resets); + /* We should wait at least 6 sleep clock cycles, that's + * (6 / 32764) * 1000000 ~= 200us. But some platforms + * have slower sleep clocks so we'll play it safe. + */ + udelay(500); + } ret = reset_deassert_bulk(&glue->resets); if (ret) { reset_release_bulk(&glue->resets); return ret; @@ -628,9 +707,9 @@ static const struct udevice_id dwc3_glue_ids[] = { { .compatible = "rockchip,rk3328-dwc3", .data = (ulong)&rk_ops }, { .compatible = "rockchip,rk3399-dwc3" }, { .compatible = "rockchip,rk3568-dwc3", .data = (ulong)&rk_ops }, { .compatible = "rockchip,rk3588-dwc3", .data = (ulong)&rk_ops }, - { .compatible = "qcom,dwc3" }, + { .compatible = "qcom,dwc3", .data = (ulong)&qcom_ops }, { .compatible = "fsl,imx8mp-dwc3", .data = (ulong)&imx8mp_ops }, { .compatible = "fsl,imx8mq-dwc3" }, { .compatible = "intel,tangier-dwc3" }, { }
DWC3 platforms depend on DM_USB_GADGET for gadget drivers to work, otherwise compilation fails due to no implementation of dm_usb_gadget_handle_interrupts().
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/usb/dwc3/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/usb/dwc3/Kconfig b/drivers/usb/dwc3/Kconfig index c0c8c16fd9c2..8a70bc682322 100644 --- a/drivers/usb/dwc3/Kconfig +++ b/drivers/usb/dwc3/Kconfig @@ -10,8 +10,9 @@ if USB_DWC3 config USB_DWC3_GADGET bool "USB Gadget support for DWC3" default y depends on USB_GADGET + select DM_USB_GADGET select USB_GADGET_DUALSPEED
comment "Platform Glue Driver Support"
To actually use the gadget the peripheral driver must be probed and we must call g_dnl_clear_detach(). Otherwise acm_stdio_start() will always fail to find a UDC on DT platforms.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/usb/gadget/f_acm.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/usb/gadget/f_acm.c b/drivers/usb/gadget/f_acm.c index de42e0189e8d..ba216128ab27 100644 --- a/drivers/usb/gadget/f_acm.c +++ b/drivers/usb/gadget/f_acm.c @@ -622,14 +622,23 @@ static void acm_stdio_puts(struct stdio_dev *dev, const char *str) }
static int acm_stdio_start(struct stdio_dev *dev) { + struct udevice *udc; int ret;
if (dev->priv) { /* function already exist */ return 0; }
+ ret = udc_device_get_by_index(0, &udc); + if (ret) { + pr_err("USB init failed: %d\n", ret); + return ret; + } + + g_dnl_clear_detach(); + ret = g_dnl_register("usb_serial_acm"); if (ret) return ret;
UFS storage often uses a 4096-byte sector size, add support for dynamic sector sizes based loosely on the Linux implementation.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- cmd/usb_mass_storage.c | 4 -- drivers/usb/gadget/f_mass_storage.c | 101 ++++++++++++++++++++---------------- drivers/usb/gadget/storage_common.c | 12 +++-- include/usb_mass_storage.h | 1 - 4 files changed, 65 insertions(+), 53 deletions(-)
diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index a8ddeb494628..751701fe73af 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -87,12 +87,8 @@ static int ums_init(const char *devtype, const char *devnums_part_str) */ if (!strchr(devnum_part_str, ':')) partnum = 0;
- /* f_mass_storage.c assumes SECTOR_SIZE sectors */ - if (block_dev->blksz != SECTOR_SIZE) - goto cleanup; - ums_new = realloc(ums, (ums_count + 1) * sizeof(*ums)); if (!ums_new) goto cleanup; ums = ums_new; diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index c725aed3f626..d880928044f4 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -723,14 +723,15 @@ static int do_read(struct fsg_common *common) if (lba >= curlun->num_sectors) { curlun->sense_data = SS_LOGICAL_BLOCK_ADDRESS_OUT_OF_RANGE; return -EINVAL; } - file_offset = ((loff_t) lba) << 9; + file_offset = ((loff_t)lba) << curlun->blkbits;
/* Carry out the file reads */ amount_left = common->data_size_from_cmnd; - if (unlikely(amount_left == 0)) + if (unlikely(amount_left == 0)) { return -EIO; /* No default reply */ + }
for (;;) {
/* Figure out how much we need to read: @@ -767,15 +768,15 @@ static int do_read(struct fsg_common *common) }
/* Perform the read */ rc = ums[common->lun].read_sector(&ums[common->lun], - file_offset / SECTOR_SIZE, - amount / SECTOR_SIZE, + file_offset / curlun->blksize, + amount / curlun->blksize, (char __user *)bh->buf); if (!rc) return -EIO;
- nread = rc * SECTOR_SIZE; + nread = rc * curlun->blksize;
VLDBG(curlun, "file read %u @ %llu -> %d\n", amount, (unsigned long long) file_offset, (int) nread); @@ -786,9 +787,9 @@ static int do_read(struct fsg_common *common) nread = 0; } else if (nread < amount) { LDBG(curlun, "partial file read: %d/%u\n", (int) nread, amount); - nread -= (nread & 511); /* Round down to a block */ + nread -= (nread & (curlun->blksize - 1)); /* Round down to a block */ } file_offset += nread; amount_left -= nread; common->residue -= nread; @@ -860,9 +861,9 @@ static int do_write(struct fsg_common *common) }
/* Carry out the file writes */ get_some_more = 1; - file_offset = usb_offset = ((loff_t) lba) << 9; + file_offset = usb_offset = ((loff_t)lba) << curlun->blkbits; amount_left_to_req = common->data_size_from_cmnd; amount_left_to_write = common->data_size_from_cmnd;
while (amount_left_to_write > 0) { @@ -892,9 +893,9 @@ static int do_write(struct fsg_common *common) SS_LOGICAL_BLOCK_ADDRESS_OUT_OF_RANGE; curlun->info_valid = 1; continue; } - amount -= (amount & 511); + amount -= (amount & (curlun->blksize - 1)); if (amount == 0) {
/* Why were we were asked to transfer a * partial block? */ @@ -941,14 +942,14 @@ static int do_write(struct fsg_common *common) amount = bh->outreq->actual;
/* Perform the write */ rc = ums[common->lun].write_sector(&ums[common->lun], - file_offset / SECTOR_SIZE, - amount / SECTOR_SIZE, + file_offset / curlun->blksize, + amount / curlun->blksize, (char __user *)bh->buf); if (!rc) return -EIO; - nwritten = rc * SECTOR_SIZE; + nwritten = rc * curlun->blksize;
VLDBG(curlun, "file write %u @ %llu -> %d\n", amount, (unsigned long long) file_offset, (int) nwritten); @@ -959,9 +960,9 @@ static int do_write(struct fsg_common *common) nwritten = 0; } else if (nwritten < amount) { LDBG(curlun, "partial file write: %d/%u\n", (int) nwritten, amount); - nwritten -= (nwritten & 511); + nwritten -= (nwritten & (curlun->blksize - 1)); /* Round down to a block */ } file_offset += nwritten; amount_left_to_write -= nwritten; @@ -1033,10 +1034,10 @@ static int do_verify(struct fsg_common *common) if (unlikely(verification_length == 0)) return -EIO; /* No default reply */
/* Prepare to carry out the file verify */ - amount_left = verification_length << 9; - file_offset = ((loff_t) lba) << 9; + amount_left = verification_length << curlun->blkbits; + file_offset = ((loff_t) lba) << curlun->blkbits;
/* Write out all the dirty buffers before invalidating them */
/* Just try to read the requested blocks */ @@ -1057,14 +1058,14 @@ static int do_verify(struct fsg_common *common) }
/* Perform the read */ rc = ums[common->lun].read_sector(&ums[common->lun], - file_offset / SECTOR_SIZE, - amount / SECTOR_SIZE, + file_offset / curlun->blksize, + amount / curlun->blksize, (char __user *)bh->buf); if (!rc) return -EIO; - nread = rc * SECTOR_SIZE; + nread = rc * curlun->blksize;
VLDBG(curlun, "file read %u @ %llu -> %d\n", amount, (unsigned long long) file_offset, (int) nread); @@ -1074,9 +1075,9 @@ static int do_verify(struct fsg_common *common) nread = 0; } else if (nread < amount) { LDBG(curlun, "partial file verify: %d/%u\n", (int) nread, amount); - nread -= (nread & 511); /* Round down to a sector */ + nread -= (nread & (curlun->blksize - 1)); /* Round down to a sector */ } if (nread == 0) { curlun->sense_data = SS_UNRECOVERED_READ_ERROR; curlun->info_valid = 1; @@ -1182,9 +1183,9 @@ static int do_read_capacity(struct fsg_common *common, struct fsg_buffhd *bh) }
put_unaligned_be32(curlun->num_sectors - 1, &buf[0]); /* Max logical block */ - put_unaligned_be32(512, &buf[4]); /* Block length */ + put_unaligned_be32(curlun->blksize, &buf[4]); /* Block length */ return 8; }
static int do_read_header(struct fsg_common *common, struct fsg_buffhd *bh) @@ -1369,9 +1370,9 @@ static int do_read_format_capacities(struct fsg_common *common, buf += 4;
put_unaligned_be32(curlun->num_sectors, &buf[0]); /* Number of blocks */ - put_unaligned_be32(512, &buf[4]); /* Block length */ + put_unaligned_be32(curlun->blksize, &buf[4]); /* Block length */ buf[4] = 0x02; /* Current capacity */ return 12; }
@@ -1780,8 +1781,18 @@ static int check_command(struct fsg_common *common, int cmnd_size,
return 0; }
+/* wrapper of check_command for data size in blocks handling */ +static int check_command_size_in_blocks(struct fsg_common *common, + int cmnd_size, enum data_direction data_dir, + unsigned int mask, int needs_medium, const char *name) +{ + common->data_size_from_cmnd <<= common->luns[common->lun].blkbits; + return check_command(common, cmnd_size, data_dir, + mask, needs_medium, name); +} +
static int do_scsi_command(struct fsg_common *common) { struct fsg_buffhd *bh; @@ -1864,32 +1875,32 @@ static int do_scsi_command(struct fsg_common *common) break;
case SC_READ_6: i = common->cmnd[4]; - common->data_size_from_cmnd = (i == 0 ? 256 : i) << 9; - reply = check_command(common, 6, DATA_DIR_TO_HOST, - (7<<1) | (1<<4), 1, - "READ(6)"); + common->data_size_from_cmnd = (i == 0 ? 256 : i); + reply = check_command_size_in_blocks(common, 6, DATA_DIR_TO_HOST, + (7<<1) | (1<<4), 1, + "READ(6)"); if (reply == 0) reply = do_read(common); break;
case SC_READ_10: common->data_size_from_cmnd = - get_unaligned_be16(&common->cmnd[7]) << 9; - reply = check_command(common, 10, DATA_DIR_TO_HOST, - (1<<1) | (0xf<<2) | (3<<7), 1, - "READ(10)"); + get_unaligned_be16(&common->cmnd[7]); + reply = check_command_size_in_blocks(common, 10, DATA_DIR_TO_HOST, + (1<<1) | (0xf<<2) | (3<<7), 1, + "READ(10)"); if (reply == 0) reply = do_read(common); break;
case SC_READ_12: common->data_size_from_cmnd = - get_unaligned_be32(&common->cmnd[6]) << 9; - reply = check_command(common, 12, DATA_DIR_TO_HOST, - (1<<1) | (0xf<<2) | (0xf<<6), 1, - "READ(12)"); + get_unaligned_be32(&common->cmnd[6]); + reply = check_command_size_in_blocks(common, 12, DATA_DIR_TO_HOST, + (1<<1) | (0xf<<2) | (0xf<<6), 1, + "READ(12)"); if (reply == 0) reply = do_read(common); break;
@@ -1982,32 +1993,32 @@ static int do_scsi_command(struct fsg_common *common) break;
case SC_WRITE_6: i = common->cmnd[4]; - common->data_size_from_cmnd = (i == 0 ? 256 : i) << 9; - reply = check_command(common, 6, DATA_DIR_FROM_HOST, - (7<<1) | (1<<4), 1, - "WRITE(6)"); + common->data_size_from_cmnd = (i == 0 ? 256 : i); + reply = check_command_size_in_blocks(common, 6, DATA_DIR_FROM_HOST, + (7<<1) | (1<<4), 1, + "WRITE(6)"); if (reply == 0) reply = do_write(common); break;
case SC_WRITE_10: common->data_size_from_cmnd = - get_unaligned_be16(&common->cmnd[7]) << 9; - reply = check_command(common, 10, DATA_DIR_FROM_HOST, - (1<<1) | (0xf<<2) | (3<<7), 1, - "WRITE(10)"); + get_unaligned_be16(&common->cmnd[7]); + reply = check_command_size_in_blocks(common, 10, DATA_DIR_FROM_HOST, + (1<<1) | (0xf<<2) | (3<<7), 1, + "WRITE(10)"); if (reply == 0) reply = do_write(common); break;
case SC_WRITE_12: common->data_size_from_cmnd = - get_unaligned_be32(&common->cmnd[6]) << 9; - reply = check_command(common, 12, DATA_DIR_FROM_HOST, - (1<<1) | (0xf<<2) | (0xf<<6), 1, - "WRITE(12)"); + get_unaligned_be32(&common->cmnd[6]); + reply = check_command_size_in_blocks(common, 12, DATA_DIR_FROM_HOST, + (1<<1) | (0xf<<2) | (0xf<<6), 1, + "WRITE(12)"); if (reply == 0) reply = do_write(common); break;
@@ -2496,9 +2507,9 @@ static struct fsg_common *fsg_common_init(struct fsg_common *common,
for (i = 0; i < nluns; i++) { common->luns[i].removable = 1;
- rc = fsg_lun_open(&common->luns[i], ums[i].num_sectors, ""); + rc = fsg_lun_open(&common->luns[i], ums[i].num_sectors, ums->block_dev.blksz, ""); if (rc) goto error_luns; } common->lun = 0; diff --git a/drivers/usb/gadget/storage_common.c b/drivers/usb/gadget/storage_common.c index 5674e8fe4940..97dc6b6f729c 100644 --- a/drivers/usb/gadget/storage_common.c +++ b/drivers/usb/gadget/storage_common.c @@ -268,8 +268,9 @@ struct interrupt_data { struct device_attribute { int i; }; #define ETOOSMALL 525
#include <log.h> +#include <linux/log2.h> #include <usb_mass_storage.h> #include <dm/device_compat.h>
/*-------------------------------------------------------------------------*/ @@ -289,8 +290,10 @@ struct fsg_lun {
u32 sense_data; u32 sense_data_info; u32 unit_attention_data; + unsigned int blkbits; + unsigned int blksize; /* logical block size of bound block device */
struct device dev; };
@@ -565,19 +568,22 @@ static struct usb_gadget_strings fsg_stringtab = { * the caller must own fsg->filesem for writing. */
static int fsg_lun_open(struct fsg_lun *curlun, unsigned int num_sectors, - const char *filename) + unsigned int sector_size, const char *filename) { int ro;
/* R/W if we can, R/O if we must */ ro = curlun->initially_ro;
curlun->ro = ro; - curlun->file_length = num_sectors << 9; + curlun->file_length = num_sectors * sector_size; curlun->num_sectors = num_sectors; - debug("open backing file: %s\n", filename); + curlun->blksize = sector_size; + curlun->blkbits = order_base_2(sector_size >> 9) + 9; + debug("blksize: %u\n", sector_size); + debug("open backing file: '%s'\n", filename);
return 0; }
diff --git a/include/usb_mass_storage.h b/include/usb_mass_storage.h index 83ab93b530d7..6d83d93cad7f 100644 --- a/include/usb_mass_storage.h +++ b/include/usb_mass_storage.h @@ -6,9 +6,8 @@
#ifndef __USB_MASS_STORAGE_H__ #define __USB_MASS_STORAGE_H__
-#define SECTOR_SIZE 0x200 #include <part.h> #include <linux/usb/composite.h>
/* Wait at maximum 60 seconds for cable connection */
The priv struct was wrong in dump_boot_mappings(). Causing errors when compiling with -DDEBUG. Fix this.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Neil Armstrong neil.armstrong@linaro.org Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/iommu/qcom-hyp-smmu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/iommu/qcom-hyp-smmu.c b/drivers/iommu/qcom-hyp-smmu.c index 8e5cdb581550..f2b39de56f4a 100644 --- a/drivers/iommu/qcom-hyp-smmu.c +++ b/drivers/iommu/qcom-hyp-smmu.c @@ -318,9 +318,9 @@ static int qcom_smmu_connect(struct udevice *dev) return 0; }
#ifdef DEBUG -static inline void dump_boot_mappings(struct arm_smmu_priv *priv) +static inline void dump_boot_mappings(struct qcom_smmu_priv *priv) { u32 val; int i;
Since this is mostly gadget and RB'd now, I think this should go through Mattijs / dfu tree.
Thanks
Yes please!
Thanks
Thanks all for the reviews.
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-dfu (u-boot-dfu-next)
[1/5] usb: dwc3-generic: implement Qualcomm wrapper https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/850b307789dca8d... [2/5] usb: dwc3: select DM_USB_GADGET https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/97d629372c8c58d... [3/5] usb: gadget: CDC ACM: call usb_gadget_initialize https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/86327b4e3201a55... [4/5] usb: gadget: UMS: support multiple sector sizes https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/7e71eeb39f4c528... [5/5] iommu: qcom-smmu: fix debugging https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/c9959ce7b54145a...
-- Mattijs
Hi Caleb,
It seems CI got broken with this series.
Baseline CI (passed): https://source.denx.de/u-boot/u-boot/-/pipelines/20006
With series applied (failed): https://source.denx.de/u-boot/custodians/u-boot-dfu/-/jobs/802278
It seems the change on UMS introduced some linking errors on arm32:
f_mass_storage.c:946:(.text.do_write.lto_priv.0+0x1de): undefined reference to `__aeabi_ldivmod'
Could you have a look, please?
Thank you. Mattijs
On jeu., mars 21, 2024 at 10:23, Mattijs Korpershoek mkorpershoek@baylibre.com wrote:
-- Mattijs
The patch introducing support for dynamic sector sizes changed the types used in some divisions, resulting in the compiler attempting to use libgcc helpers (__aeabi_ldivmod). Replace these divisions with calls to lldiv() to handle this correctly.
Fixes: 74e56e0c5065 ("usb: gadget: UMS: support multiple sector sizes") Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- Hi Mattijs,
Sorry for not catching that sooner! I compile tested this locally and a CI pipeline is running here: https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/pipelines/20029
Regards, Caleb --- drivers/usb/gadget/f_mass_storage.c | 13 +++++++------ 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index d880928044f4..ef90c7ec7fb5 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -239,8 +239,9 @@ /* #define VERBOSE_DEBUG */ /* #define DUMP_MSGS */
#include <config.h> +#include <div64.h> #include <hexdump.h> #include <log.h> #include <malloc.h> #include <common.h> @@ -768,10 +769,10 @@ static int do_read(struct fsg_common *common) }
/* Perform the read */ rc = ums[common->lun].read_sector(&ums[common->lun], - file_offset / curlun->blksize, - amount / curlun->blksize, + lldiv(file_offset, curlun->blksize), + lldiv(amount, curlun->blksize), (char __user *)bh->buf); if (!rc) return -EIO;
@@ -942,10 +943,10 @@ static int do_write(struct fsg_common *common) amount = bh->outreq->actual;
/* Perform the write */ rc = ums[common->lun].write_sector(&ums[common->lun], - file_offset / curlun->blksize, - amount / curlun->blksize, + lldiv(file_offset, curlun->blksize), + lldiv(amount, curlun->blksize), (char __user *)bh->buf); if (!rc) return -EIO; nwritten = rc * curlun->blksize; @@ -1058,10 +1059,10 @@ static int do_verify(struct fsg_common *common) }
/* Perform the read */ rc = ums[common->lun].read_sector(&ums[common->lun], - file_offset / curlun->blksize, - amount / curlun->blksize, + lldiv(file_offset, curlun->blksize), + lldiv(amount, curlun->blksize), (char __user *)bh->buf); if (!rc) return -EIO; nread = rc * curlun->blksize;
Hi Caleb,
Thank you for the patch.
On jeu., mars 21, 2024 at 15:28, Caleb Connolly caleb.connolly@linaro.org wrote:
Would it be okay if I squashed this into commit 74e56e0c5065 ("usb: gadget: UMS: support multiple sector sizes") ?
I'd like to not (intentionally) send any patches that don't compile to Tom.
Hi Mattijs,
No worries, thanks a lot for the quick fix.
I can see from the above pipeline that some other failures are ongoing, but they are not related to lldiv().
arm-linux-gnueabi-ld.bfd: common/dfu.o: in function `run_usb_dnl_gadget': common/dfu.c:82:(.text.run_usb_dnl_gadget+0xd8): undefined reference to `dm_usb_gadget_handle_interrupts' arm-linux-gnueabi-ld.bfd: common/dfu.c:108:(.text.run_usb_dnl_gadget+0x11c): undefined reference to `dm_usb_gadget_handle_interrupts' make[1]: *** [Makefile:1793: u-boot] Error
See: https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/jobs/802759#L47...
I suspect that this is related to: https://lore.kernel.org/r/all/20240225152715.1821613-1-jonas@kwiboo.se/
Regards, Caleb
if (!rc) return -EIO;lldiv(amount, curlun->blksize), (char __user *)bh->buf);
if (!rc) return -EIO; nread = rc * curlun->blksize;lldiv(amount, curlun->blksize), (char __user *)bh->buf);
-- 2.44.0
On 21/03/2024 16:48, Mattijs Korpershoek wrote:
Hi Caleb,
For sure, feel free to do that.
Hi Mattijs,
Ah! I guess this is caused by the "select DM_USB_GADGET" patch...
You can revert it for now and I'll just select DM_USB_GADGET for qcom.
It seems like there's a bunch going on around here with the cleanup by Marek. I can revisit this once that's settled
Is this fixed by the ("usb: udc: dwc3: Fold board dm_usb_gadget_handle_interrupts() into DWC3") series?
Regards, Caleb
-- 2.44.0
Hi Caleb,
On jeu., mars 21, 2024 at 17:01, Caleb Connolly caleb.connolly@linaro.org wrote:
Hi Caleb,
Done, here: https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/304fa0aa445384e...
Hi Mattijs,
Will do, I'll drop it from the branch.
Yeah, we are working on reworking the interrupt handling a bit since it has quite some limitations.
Unfortunately, no: https://source.denx.de/u-boot/custodians/u-boot-dfu/-/jobs/803228#L578
Regards, Caleb
-- 2.44.0
-- // Caleb (they/them)
Caleb Connolly
Mattijs Korpershoek
