[U-Boot] [PATCH] kgdb: Remove first_entry for kgdb
There are two ways to run into handle_exception, run command 'kgdb' and encounter a breakpoint which triggers exception handling.
The origin source code only saves regs when first run command 'kgdb'. Take the following for example, When run 'kgdb', regs is saved to entry_regs. When run 'bootz', regs is not saved. However, if we set a breakpoint, then continue. When breakpoint is reached, run `quit`, and Now return to the instruction which follows kgdb, but not bootz.This may cause errors. So, save regs for each handle_exception call to return to the correct place. Example: Target | Host =>kgdb | (gdb)b bootz | (gdb)c =>bootz | | (gdb)Here stop because of breakpoint | (gdb)q
Signed-off-by: Peng Fan van.freenix@gmail.com --- common/kgdb.c | 14 ++------------ 1 file changed, 2 insertions(+), 12 deletions(-)
diff --git a/common/kgdb.c b/common/kgdb.c index 8a621ad..d357463 100644 --- a/common/kgdb.c +++ b/common/kgdb.c @@ -103,7 +103,7 @@ static char remcomOutBuffer[BUFMAX]; static char remcomRegBuffer[BUFMAX];
static int initialized = 0; -static int kgdb_active = 0, first_entry = 1; +static int kgdb_active; static struct pt_regs entry_regs; static long error_jmp_buf[BUFMAX/2]; static int longjmp_on_fault = 0; @@ -348,16 +348,7 @@ handle_exception (struct pt_regs *regs)
kgdb_enter(regs, &kd);
- if (first_entry) { - /* - * the first time we enter kgdb, we save the processor - * state so that we can return to the monitor if the - * remote end quits gdb (or at least, tells us to quit - * with the 'k' packet) - */ - entry_regs = *regs; - first_entry = 0; - } + entry_regs = *regs;
ptr = remcomOutBuffer;
@@ -459,7 +450,6 @@ handle_exception (struct pt_regs *regs) case 'k': /* kill the program, actually return to monitor */ kd.extype = KGDBEXIT_KILL; *regs = entry_regs; - first_entry = 1; goto doexit;
case 'C': /* CSS continue with signal SS */
Peng Fan
