[PATCH] dm: tpl: Add fdt address translation support in TPL
This is needed in the platforms that use "ranges" node property for address translation in their dts for TPL.
Signed-off-by: William Zhang william.zhang@broadcom.com
drivers/core/Kconfig | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index c9bf5de4332b..041d6c502690 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -350,6 +350,20 @@ config SPL_OF_TRANSLATE used for the address translation. This function is faster and smaller in size than fdt_translate_address().
+config TPL_OF_TRANSLATE + bool "Translate addresses using fdt_translate_address in TPL" + depends on TPL_DM && TPL_OF_CONTROL + help + If this option is enabled, the reg property will be translated + using the fdt_translate_address() function. This is necessary + on some platforms (e.g. MVEBU) using complex "ranges" + properties in many nodes. As this translation is not handled + correctly in the default simple_bus_translate() function. + + If this option is not enabled, simple_bus_translate() will be + used for the address translation. This function is faster and + smaller in size than fdt_translate_address() + config VPL_OF_TRANSLATE bool "Translate addresses using fdt_translate_address in SPL" depends on SPL_DM && VPL_OF_CONTROL
On Fri, 14 Oct 2022 at 12:05, William Zhang william.zhang@broadcom.com wrote:
Applied to u-boot-dm, thanks!
William Zhang
