[PATCH v2] net: zynq: Add support for mdio bus address decoding
Xilinx DTS files are using two way how to describe ethernet phy.
The first (already supported) has phy as subnode of gem node. eth { phy-handle = <&phy0>; phy0: ethernet-phy@21 { ... }; };
The second has mdio subnode (with mdio name) which has phy subnode. This structure allow hadling MDIO reset signal (based on Linux mdio.yaml) eth { phy-handle = <&phy0>; mdio { phy0: ethernet-phy@21 { ... }; }; };
This patch adds support for the second case where mdio subnode is found driver will look at its parent to find out which gem is handling MDIO bus.
Changes in v2: - update commit message
drivers/net/zynq_gem.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 3e227725022d..fece077066df 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -846,6 +846,9 @@ static int zynq_gem_of_to_plat(struct udevice *dev) SPEED_1000);
parent = ofnode_get_parent(phandle_args.node); + if (ofnode_name_eq(parent, "mdio")) + parent = ofnode_get_parent(parent); + addr = ofnode_get_addr(parent); if (addr != FDT_ADDR_T_NONE) { debug("MDIO bus not found %s\n", dev->name);
po 6. 12. 2021 v 14:53 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
Changes in v2:
-- 2.33.1
Applied. M
Michal Simek
Michal Simek
