[U-Boot] [PATCH] fdt: make fdt_get_base_address() return OF_BAD_ADDR when "reg" not found
Currently, fdt_get_base_address() returns 0 if the "reg" property is missing. Since 0 is a valid value, it is not suitable for the error handling. Return OF_BAD_ADDR instead.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
common/fdt_support.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index f31e9b0cc5a8..61c7b2096fbb 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1546,7 +1546,7 @@ u64 fdt_get_base_address(const void *fdt, int node)
prop = fdt_getprop(fdt, node, "reg", &size);
- return prop ? fdt_translate_address(fdt, node, prop) : 0; + return prop ? fdt_translate_address(fdt, node, prop) : OF_BAD_ADDR; }
On Thu, Jun 27, 2019 at 3:40 PM Masahiro Yamada yamada.masahiro@socionext.com wrote:
Reviewed-by: Bin Meng bmeng.cn@gmail.com _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Applied to u-boot-dm, thanks!
Bin Meng
Masahiro Yamada
sjg@google.com
