[U-Boot] [PATCH v1 00/19] DM_I2C_COMPAT removal for all ti platforms
This series remove the usage of the DM_I2C_COMPAT option for all the ti platforms. It also takes this opportunity to not disable DM_I2C in the SPL.
There are a couples of issues to fix: - CMD_EEPROM does not support the DM API. Fixed by removing this option when DM_I2C is used without DM_I2C_COMPAT - i2c_get_chip_for_busnum() does not work when OF_CONTROL is not used (as is the case with am33xx SPL). - The I2C driver do not support DM_I2C without OF_CONTROL. - Most of the PMIC drivers do not support the I2C DM API. - Board detection is done prior DM initialization. Fixed by moving it after DM is initialized. That move breaks the DRA7 platforms (The fixes for that are at the last 5 patches this series)
When all this is taken care of DM_I2C_COMPAT can be removed and DM_I2C enabled in the SPL.
This has been tested with the following boards: - am437x SK - am335x SK - am335x beaglebone (both DM and non-DM config) - dra76 evm - am572 evm - k2g evm
Andreas Dannenberg (1): ti: common: board_detect: Allow DM I2C without CONFIG_DM_I2C_COMPAT
Jean-Jacques Hiblot (17): cmd: Kconfig: Do not include EEPROM if DM_I2C is used without DM_I2C_COMPAT dm: i2c: Add dm_i2c_probe_device() to test the presence of a chip dm: device: Allow using uclass_find_device_by_seq() without OF_CONTROL configs: am335x: am57x: dra7x: Enable CONFIG_SPL_DM_SEQ_ALIAS i2c: omap24xx_i2c: Use platdata to probe the device am335x: Register the I2C controllers if DM_I2C is used. dts: am43x: omap5: Add node for I2C in SPL omap: detect the board after DM is available power: make most tps drivers and the twl4030 driver compatible with DM_I2C configs: am335x_pdu001: Explicitly enable CONFIG_I2C_COMPAT ti: remove usage of DM_I2C_COMPAT and don't disable DM_I2C in SPL am57xx: remove non-DM I2C code configs: dra7xx-evm: increase the size of the malloc's pool before relocation lib: fdtdec: Add function re-setup the fdt more effeciently drivers: core: Add the option SPL_DM_DEVICE_REMOVE to the Kconfig drivers: core: nullify gd->dm_root after dm_uninit() dra7: Allow selecting a new dtb after board detection.
Vignesh R (1): i2c: omap24xx_i2c: Move away from SoC specific headers for reg offset
arch/arm/dts/am437x-gp-evm-u-boot.dtsi | 4 + arch/arm/dts/omap5-u-boot.dtsi | 4 + arch/arm/include/asm/arch-am33xx/i2c.h | 47 +-- arch/arm/include/asm/arch-omap3/i2c.h | 47 --- arch/arm/include/asm/arch-omap4/i2c.h | 45 --- arch/arm/include/asm/arch-omap5/i2c.h | 45 --- arch/arm/include/asm/omap_i2c.h | 24 ++ arch/arm/mach-keystone/ddr3_spd.c | 7 + arch/arm/mach-omap2/am33xx/board.c | 24 +- arch/arm/mach-omap2/am33xx/clk_synthesizer.c | 56 +++- arch/arm/mach-omap2/clocks-common.c | 2 + arch/arm/mach-omap2/hwinit-common.c | 23 +- board/ti/am335x/board.c | 17 +- board/ti/am335x/mux.c | 14 + board/ti/am43xx/board.c | 35 +- board/ti/am57xx/board.c | 25 +- board/ti/common/board_detect.c | 110 +++---- board/ti/ks2_evm/board_k2g.c | 11 + cmd/Kconfig | 1 + configs/am335x_pdu001_defconfig | 2 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/dra7xx_evm_defconfig | 4 +- configs/dra7xx_hs_evm_defconfig | 1 + configs/omap3_logic_defconfig | 1 + drivers/core/Kconfig | 12 +- drivers/core/device.c | 10 +- drivers/core/root.c | 1 + drivers/core/uclass.c | 24 ++ drivers/i2c/i2c-uclass.c | 8 + drivers/i2c/omap24xx_i2c.c | 467 ++++++++++++++++++--------- drivers/power/palmas.c | 39 +++ drivers/power/pmic/pmic_tps62362.c | 27 ++ drivers/power/pmic/pmic_tps65217.c | 47 ++- drivers/power/pmic/pmic_tps65218.c | 88 +++++ drivers/power/pmic/pmic_tps65910.c | 60 +++- drivers/power/twl4030.c | 39 +++ include/asm-generic/global_data.h | 4 + include/configs/am43xx_evm.h | 2 + include/configs/ti_armv7_common.h | 18 +- include/dm/uclass-internal.h | 13 + include/fdtdec.h | 17 + include/i2c.h | 13 + include/palmas.h | 5 + include/power/tps65217.h | 2 + include/power/tps65910.h | 1 + include/twl4030.h | 6 +- lib/fdtdec.c | 38 ++- 48 files changed, 1033 insertions(+), 459 deletions(-) create mode 100644 arch/arm/include/asm/omap_i2c.h
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
cmd/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 7ed3c9c..b4e1cbf 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -445,6 +445,7 @@ config CRC32_VERIFY
config CMD_EEPROM bool "eeprom - EEPROM subsystem" + depends on !DM_I2C || DM_I2C_COMPAT help (deprecated, needs conversion to driver model) Provides commands to read and write EEPROM (Electrically Erasable
hm this is a little bit short commit message.
M
- depends on !DM_I2C || DM_I2C_COMPAT help (deprecated, needs conversion to driver model) Provides commands to read and write EEPROM (Electrically Erasable
In a non-DM environment, it is possible to test the presence of a chip using i2c_probe(chip_addr). dm_i2c_probe_device() brings the same functionality with a DM interface. The intent is to be able to test the presence of a chip for the device has been created with i2c_get_chip_for_busnum(bus_num, chip_addr, ...)
drivers/i2c/i2c-uclass.c | 8 ++++++++ include/i2c.h | 13 +++++++++++++ 2 files changed, 21 insertions(+)
diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index c5a3c4e..ec88168 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -378,6 +378,14 @@ int dm_i2c_probe(struct udevice *bus, uint chip_addr, uint chip_flags, return ret; }
+int dm_i2c_probe_device(struct udevice *dev) +{ + struct udevice *bus = dev_get_parent(dev); + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + + return i2c_probe_chip(bus, chip->chip_addr, chip->flags); +} + int dm_i2c_set_bus_speed(struct udevice *bus, unsigned int speed) { struct dm_i2c_ops *ops = i2c_get_ops(bus); diff --git a/include/i2c.h b/include/i2c.h index d33f827..3c8fde2 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -167,6 +167,19 @@ int dm_i2c_probe(struct udevice *bus, uint chip_addr, uint chip_flags, struct udevice **devp);
/** + * dm_i2c_probe_dev() - probe the presence of a I2C device + * + * This can be useful to check for the existence of a chip already probed + * (software wise). + * It is typically implemented by writing the chip address to the bus + * and checking that the chip replies with an ACK. + * + * @bus: Device to probe + * @return 0 if a chip was found at that address, -ve if not + */ +int dm_i2c_probe_device(struct udevice *dev); + +/** * dm_i2c_reg_read() - Read a value from an I2C register * * This reads a single value from the given address in an I2C chip
If OF_CONTROL is not enabled and DM_SEQ_ALIAS is enabled, we must assign an alias (requested sequence number) to devices that belongs to a class with the DM_UC_FLAG_SEQ_ALIAS flag. Otherwise uclass_find_device_by_seq() cannot be used to get/probe a device. In particular i2c_get_chip_for_busnum() cannot be used.
drivers/core/device.c | 10 ++++++---- drivers/core/uclass.c | 24 ++++++++++++++++++++++++ include/dm/uclass-internal.h | 13 +++++++++++++ 3 files changed, 43 insertions(+), 4 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index feed43c..e441021 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -70,7 +70,8 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv,
dev->seq = -1; dev->req_seq = -1; - if (CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(DM_SEQ_ALIAS)) { + if (CONFIG_IS_ENABLED(DM_SEQ_ALIAS) && + (uc->uc_drv->flags & DM_UC_FLAG_SEQ_ALIAS)) { /* * Some devices, such as a SPI bus, I2C bus and serial ports * are numbered using aliases. @@ -78,10 +79,11 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv, * This is just a 'requested' sequence, and will be * resolved (and ->seq updated) when the device is probed. */ - if (uc->uc_drv->flags & DM_UC_FLAG_SEQ_ALIAS) { - if (uc->uc_drv->name && ofnode_valid(node)) { + if (CONFIG_IS_ENABLED(OF_CONTROL)) { + if (uc->uc_drv->name && ofnode_valid(node)) dev_read_alias_seq(dev, &dev->req_seq); - } + } else { + dev->req_seq = uclass_find_next_free_req_seq(drv->id); } }
diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 3113d6a..376f882 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -269,6 +269,30 @@ int uclass_find_device_by_name(enum uclass_id id, const char *name, return -ENODEV; }
+#if !CONFIG_IS_ENABLED(OF_CONTROL) +int uclass_find_next_free_req_seq(enum uclass_id id) +{ + struct uclass *uc; + struct udevice *dev; + int ret; + int max = -1; + + ret = uclass_get(id, &uc); + if (ret) + return ret; + + list_for_each_entry(dev, &uc->dev_head, uclass_node) { + if ((dev->req_seq != -1) && (dev->req_seq > max)) + max = dev->req_seq; + } + + if (max == -1) + return 0; + + return max + 1; +} +#endif + int uclass_find_device_by_seq(enum uclass_id id, int seq_or_req_seq, bool find_req_seq, struct udevice **devp) { diff --git a/include/dm/uclass-internal.h b/include/dm/uclass-internal.h index 30d5a4f..18a838c 100644 --- a/include/dm/uclass-internal.h +++ b/include/dm/uclass-internal.h @@ -12,6 +12,19 @@ #include <dm/ofnode.h>
/** + * uclass_find_next_free_req_seq() - Get the next free req_seq number + * + * This returns the next free req_seq number. This is useful only if + * OF_CONTROL is not used. The next free req_seq number is simply the + * maximum req_seq of the uclass + 1. + * This allows assiging req_seq number in the binding order. + * + * @id: Id number of the uclass + * @return The next free req_seq number + */ +int uclass_find_next_free_req_seq(enum uclass_id id); + +/** * uclass_get_device_tail() - handle the end of a get_device call * * This handles returning an error or probing a device as needed.
What about conditions where both OF_CONTROL and PLATDATA are set? I am not sure what it all does, so maybe it's OK, but I know PLATDATA is a reduced library which I know the omap3_logic uses to keep SPL small.
Is there are reason these cannot be #if statements (opposed to just 'if') to let the pre-compiler enable/disable code? I am assuming these values won't change, but I could be wrong.
} else {
struct uclass *uc;
int ret;
int max = -1;
if (ret)
return ret;
max = dev->req_seq;
if (max == -1)
return max + 1;
+} +#endif
- uclass_find_next_free_req_seq() - Get the next free req_seq number
- This returns the next free req_seq number. This is useful only if
- OF_CONTROL is not used. The next free req_seq number is simply the
- maximum req_seq of the uclass + 1.
- This allows assiging req_seq number in the binding order.
- @id: Id number of the uclass
- @return The next free req_seq number
- uclass_get_device_tail() - handle the end of a get_device call
- This handles returning an error or probing a device as needed.
-- 2.7.4
Hi Adam,
Thanks for the review and for trying the patches.
if OF_PLATDATA is used, dts is not parsed at all, so alias can't be read from dt => the seq_alias should be computed as if OF_CONTROL is not set.
Now I'm curious how enabling OF_PLATDATA even works on omap3_logic. Most TI drivers (all ?) do not support it. I don't have any omap3 board, but I'll give it a try on beaglebone.
The solution woulb de to use if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) instead of if (CONFIG_IS_ENABLED(OF_CONTROL)
} else {
ditto
struct uclass *uc;
int ret;
int max = -1;
if (ret)
return ret;
max = dev->req_seq;
if (max == -1)
return max + 1;
+} +#endif
- int uclass_find_device_by_seq(enum uclass_id id, int seq_or_req_seq, bool find_req_seq, struct udevice **devp) {
-- 2.7.4
On 05/10/2018 10:50, Jean-Jacques Hiblot wrote:
Hi Adam,
OK. So I think I understand a bit more what is happening here. The omap3_logic does not actually take advantage of SPL_OF_PLATDATA nor SPL_OF_CONTROL. Devices are instantiated by the SPL the old way, using U_BOOT_DEVICE() (board/logicpd/omap3logic.c:45-70). In the SPL, the I2C instantiation is missing, but I guess that it is ok because nobody checks the return value of the calls to twl4030 functions.
You probably can remove SPL_OF_PLATDATA and SPL_OF_CONTROL and still be able to boot.
JJ
ditto
+/** * uclass_get_device_tail() - handle the end of a get_device call * * This handles returning an error or probing a device as needed. -- 2.7.4
Those platforms need CONFIG_SPL_DM_SEQ_ALIAS because they enable both DM_I2C and SPL_DM. Without CONFIG_SPL_DM_SEQ_ALIAS, it is not possible to get the I2C bus with i2c_get_chip_for_busnum().
configs/am335x_pdu001_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/omap3_logic_defconfig | 1 + 5 files changed, 5 insertions(+)
diff --git a/configs/am335x_pdu001_defconfig b/configs/am335x_pdu001_defconfig index 8a61d84..a666318 100644 --- a/configs/am335x_pdu001_defconfig +++ b/configs/am335x_pdu001_defconfig @@ -35,6 +35,7 @@ CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="am335x-pdu001" # CONFIG_NET is not set CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index da347f3..56335f4 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -37,6 +37,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SCSI_AHCI=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 6cf4f9a..7c404d3 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -40,6 +40,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SCSI_AHCI=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index bd4ae0e..35c626d 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -41,6 +41,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_DWC_AHCI=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 9b50a30..b8c8738 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -34,6 +34,7 @@ CONFIG_SPL_OF_PLATDATA=y # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_DM_I2C=y
Move away from SoC specific headers to handle different register layout. Instead use driver data to get appropriate register layouts like in the kernel. While at it, perform some mostly cosmetic alignment/cleanup in the functions being updated.
Signed-off-by: Vignesh R vigneshr@ti.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
arch/arm/include/asm/arch-am33xx/i2c.h | 45 ---- arch/arm/include/asm/arch-omap3/i2c.h | 47 ---- arch/arm/include/asm/arch-omap4/i2c.h | 45 ---- arch/arm/include/asm/arch-omap5/i2c.h | 45 ---- drivers/i2c/omap24xx_i2c.c | 458 ++++++++++++++++++++++----------- 5 files changed, 314 insertions(+), 326 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/i2c.h b/arch/arm/include/asm/arch-am33xx/i2c.h index 491fca9..b3cc3df 100644 --- a/arch/arm/include/asm/arch-am33xx/i2c.h +++ b/arch/arm/include/asm/arch-am33xx/i2c.h @@ -12,51 +12,6 @@
#define I2C_DEFAULT_BASE I2C_BASE1
-struct i2c { - unsigned short revnb_lo; /* 0x00 */ - unsigned short res1; - unsigned short revnb_hi; /* 0x04 */ - unsigned short res2[5]; - unsigned short sysc; /* 0x10 */ - unsigned short res3[9]; - unsigned short irqstatus_raw; /* 0x24 */ - unsigned short res4; - unsigned short stat; /* 0x28 */ - unsigned short res5; - unsigned short ie; /* 0x2C */ - unsigned short res6; - unsigned short irqenable_clr; /* 0x30 */ - unsigned short res7; - unsigned short iv; /* 0x34 */ - unsigned short res8[45]; - unsigned short syss; /* 0x90 */ - unsigned short res9; - unsigned short buf; /* 0x94 */ - unsigned short res10; - unsigned short cnt; /* 0x98 */ - unsigned short res11; - unsigned short data; /* 0x9C */ - unsigned short res13; - unsigned short res14; /* 0xA0 */ - unsigned short res15; - unsigned short con; /* 0xA4 */ - unsigned short res16; - unsigned short oa; /* 0xA8 */ - unsigned short res17; - unsigned short sa; /* 0xAC */ - unsigned short res18; - unsigned short psc; /* 0xB0 */ - unsigned short res19; - unsigned short scll; /* 0xB4 */ - unsigned short res20; - unsigned short sclh; /* 0xB8 */ - unsigned short res21; - unsigned short systest; /* 0xBC */ - unsigned short res22; - unsigned short bufstat; /* 0xC0 */ - unsigned short res23; -}; - #define I2C_IP_CLK 48000000 #define I2C_INTERNAL_SAMPLING_CLK 12000000
diff --git a/arch/arm/include/asm/arch-omap3/i2c.h b/arch/arm/include/asm/arch-omap3/i2c.h index 5ddaa0d..b04c012 100644 --- a/arch/arm/include/asm/arch-omap3/i2c.h +++ b/arch/arm/include/asm/arch-omap3/i2c.h @@ -8,51 +8,4 @@
-struct i2c { - unsigned short rev; /* 0x00 */ - unsigned short res1; - unsigned short ie; /* 0x04 */ - unsigned short res2; - unsigned short stat; /* 0x08 */ - unsigned short res3; - unsigned short we; /* 0x0C */ - unsigned short res4; - unsigned short syss; /* 0x10 */ - unsigned short res4a; - unsigned short buf; /* 0x14 */ - unsigned short res5; - unsigned short cnt; /* 0x18 */ - unsigned short res6; - unsigned short data; /* 0x1C */ - unsigned short res7; - unsigned short sysc; /* 0x20 */ - unsigned short res8; - unsigned short con; /* 0x24 */ - unsigned short res9; - unsigned short oa; /* 0x28 */ - unsigned short res10; - unsigned short sa; /* 0x2C */ - unsigned short res11; - unsigned short psc; /* 0x30 */ - unsigned short res12; - unsigned short scll; /* 0x34 */ - unsigned short res13; - unsigned short sclh; /* 0x38 */ - unsigned short res14; - unsigned short systest; /* 0x3c */ - unsigned short res15; - unsigned short bufstat; /* 0x40 */ - unsigned short res16; - unsigned short oa1; /* 0x44 */ - unsigned short res17; - unsigned short oa2; /* 0x48 */ - unsigned short res18; - unsigned short oa3; /* 0x4c */ - unsigned short res19; - unsigned short actoa; /* 0x50 */ - unsigned short res20; - unsigned short sblock; /* 0x54 */ - unsigned short res21; -}; - #endif /* _OMAP3_I2C_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/i2c.h b/arch/arm/include/asm/arch-omap4/i2c.h index c60aac7..c8f2f97 100644 --- a/arch/arm/include/asm/arch-omap4/i2c.h +++ b/arch/arm/include/asm/arch-omap4/i2c.h @@ -8,49 +8,4 @@
-struct i2c { - unsigned short revnb_lo; /* 0x00 */ - unsigned short res1; - unsigned short revnb_hi; /* 0x04 */ - unsigned short res2[5]; - unsigned short sysc; /* 0x10 */ - unsigned short res3[9]; - unsigned short irqstatus_raw; /* 0x24 */ - unsigned short res4; - unsigned short stat; /* 0x28 */ - unsigned short res5; - unsigned short ie; /* 0x2C */ - unsigned short res6; - unsigned short irqenable_clr; /* 0x30 */ - unsigned short res7; - unsigned short iv; /* 0x34 */ - unsigned short res8[45]; - unsigned short syss; /* 0x90 */ - unsigned short res9; - unsigned short buf; /* 0x94 */ - unsigned short res10; - unsigned short cnt; /* 0x98 */ - unsigned short res11; - unsigned short data; /* 0x9C */ - unsigned short res13; - unsigned short res14; /* 0xA0 */ - unsigned short res15; - unsigned short con; /* 0xA4 */ - unsigned short res16; - unsigned short oa; /* 0xA8 */ - unsigned short res17; - unsigned short sa; /* 0xAC */ - unsigned short res18; - unsigned short psc; /* 0xB0 */ - unsigned short res19; - unsigned short scll; /* 0xB4 */ - unsigned short res20; - unsigned short sclh; /* 0xB8 */ - unsigned short res21; - unsigned short systest; /* 0xBC */ - unsigned short res22; - unsigned short bufstat; /* 0xC0 */ - unsigned short res23; -}; - #endif /* _OMAP4_I2C_H_ */ diff --git a/arch/arm/include/asm/arch-omap5/i2c.h b/arch/arm/include/asm/arch-omap5/i2c.h index 60e2b4b..9e1edcf 100644 --- a/arch/arm/include/asm/arch-omap5/i2c.h +++ b/arch/arm/include/asm/arch-omap5/i2c.h @@ -8,49 +8,4 @@
-struct i2c { - unsigned short revnb_lo; /* 0x00 */ - unsigned short res1; - unsigned short revnb_hi; /* 0x04 */ - unsigned short res2[5]; - unsigned short sysc; /* 0x10 */ - unsigned short res3[9]; - unsigned short irqstatus_raw; /* 0x24 */ - unsigned short res4; - unsigned short stat; /* 0x28 */ - unsigned short res5; - unsigned short ie; /* 0x2C */ - unsigned short res6; - unsigned short irqenable_clr; /* 0x30 */ - unsigned short res7; - unsigned short iv; /* 0x34 */ - unsigned short res8[45]; - unsigned short syss; /* 0x90 */ - unsigned short res9; - unsigned short buf; /* 0x94 */ - unsigned short res10; - unsigned short cnt; /* 0x98 */ - unsigned short res11; - unsigned short data; /* 0x9C */ - unsigned short res13; - unsigned short res14; /* 0xA0 */ - unsigned short res15; - unsigned short con; /* 0xA4 */ - unsigned short res16; - unsigned short oa; /* 0xA8 */ - unsigned short res17; - unsigned short sa; /* 0xAC */ - unsigned short res18; - unsigned short psc; /* 0xB0 */ - unsigned short res19; - unsigned short scll; /* 0xB4 */ - unsigned short res20; - unsigned short sclh; /* 0xB8 */ - unsigned short res21; - unsigned short systest; /* 0xBC */ - unsigned short res22; - unsigned short bufstat; /* 0xC0 */ - unsigned short res23; -}; - #endif /* _OMAP5_I2C_H_ */ diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index 54bf35e..dacaded 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -42,9 +42,18 @@ #include <dm.h> #include <i2c.h>
-#include <asm/arch/i2c.h> #include <asm/io.h>
+/* + * Provide access to architecture-specific I2C header files for platforms + * that are NOT yet solely relying on CONFIG_DM_I2C, CONFIG_OF_CONTROL, and + * the defaults provided in 'omap24xx_i2c.h' for all U-Boot stages where I2C + * access is desired. + */ +#ifndef CONFIG_ARCH_K3 +#include <asm/arch/i2c.h> +#endif + #include "omap24xx_i2c.h"
#define I2C_TIMEOUT 1000 @@ -52,14 +61,112 @@ /* Absolutely safe for status update at 100 kHz I2C: */ #define I2C_WAIT 200
+enum { + OMAP_I2C_REV_V1 = 0, + OMAP_I2C_REV_V2 = 1, +}; + +enum { + OMAP_I2C_REV_REG = 0, /* Only on IP V1 (OMAP34XX) */ + OMAP_I2C_IE_REG, /* Only on IP V1 (OMAP34XX) */ + OMAP_I2C_STAT_REG, + OMAP_I2C_WE_REG, + OMAP_I2C_SYSS_REG, + OMAP_I2C_BUF_REG, + OMAP_I2C_CNT_REG, + OMAP_I2C_DATA_REG, + OMAP_I2C_SYSC_REG, + OMAP_I2C_CON_REG, + OMAP_I2C_OA_REG, + OMAP_I2C_SA_REG, + OMAP_I2C_PSC_REG, + OMAP_I2C_SCLL_REG, + OMAP_I2C_SCLH_REG, + OMAP_I2C_SYSTEST_REG, + OMAP_I2C_BUFSTAT_REG, + /* Only on IP V2 (OMAP4430, etc.) */ + OMAP_I2C_IP_V2_REVNB_LO, + OMAP_I2C_IP_V2_REVNB_HI, + OMAP_I2C_IP_V2_IRQSTATUS_RAW, + OMAP_I2C_IP_V2_IRQENABLE_SET, + OMAP_I2C_IP_V2_IRQENABLE_CLR, +}; + +static const u8 __maybe_unused reg_map_ip_v1[] = { + [OMAP_I2C_REV_REG] = 0x00, + [OMAP_I2C_IE_REG] = 0x04, + [OMAP_I2C_STAT_REG] = 0x08, + [OMAP_I2C_WE_REG] = 0x0c, + [OMAP_I2C_SYSS_REG] = 0x10, + [OMAP_I2C_BUF_REG] = 0x14, + [OMAP_I2C_CNT_REG] = 0x18, + [OMAP_I2C_DATA_REG] = 0x1c, + [OMAP_I2C_SYSC_REG] = 0x20, + [OMAP_I2C_CON_REG] = 0x24, + [OMAP_I2C_OA_REG] = 0x28, + [OMAP_I2C_SA_REG] = 0x2c, + [OMAP_I2C_PSC_REG] = 0x30, + [OMAP_I2C_SCLL_REG] = 0x34, + [OMAP_I2C_SCLH_REG] = 0x38, + [OMAP_I2C_SYSTEST_REG] = 0x3c, + [OMAP_I2C_BUFSTAT_REG] = 0x40, +}; + +static const u8 __maybe_unused reg_map_ip_v2[] = { + [OMAP_I2C_STAT_REG] = 0x28, + [OMAP_I2C_WE_REG] = 0x34, + [OMAP_I2C_SYSS_REG] = 0x90, + [OMAP_I2C_BUF_REG] = 0x94, + [OMAP_I2C_CNT_REG] = 0x98, + [OMAP_I2C_DATA_REG] = 0x9c, + [OMAP_I2C_SYSC_REG] = 0x10, + [OMAP_I2C_CON_REG] = 0xa4, + [OMAP_I2C_OA_REG] = 0xa8, + [OMAP_I2C_SA_REG] = 0xac, + [OMAP_I2C_PSC_REG] = 0xb0, + [OMAP_I2C_SCLL_REG] = 0xb4, + [OMAP_I2C_SCLH_REG] = 0xb8, + [OMAP_I2C_SYSTEST_REG] = 0xbc, + [OMAP_I2C_BUFSTAT_REG] = 0xc0, + [OMAP_I2C_IP_V2_REVNB_LO] = 0x00, + [OMAP_I2C_IP_V2_REVNB_HI] = 0x04, + [OMAP_I2C_IP_V2_IRQSTATUS_RAW] = 0x24, + [OMAP_I2C_IP_V2_IRQENABLE_SET] = 0x2c, + [OMAP_I2C_IP_V2_IRQENABLE_CLR] = 0x30, +}; + struct omap_i2c { struct udevice *clk; + int ip_rev; struct i2c *regs; unsigned int speed; int waitdelay; int clk_id; };
+static inline const u8 *omap_i2c_get_ip_reg_map(int ip_rev) +{ + switch (ip_rev) { + case OMAP_I2C_REV_V1: + return reg_map_ip_v1; + case OMAP_I2C_REV_V2: + /* Fall through... */ + default: + return reg_map_ip_v2; + } +} + +static inline void omap_i2c_write_reg(void __iomem *base, int ip_rev, + u16 val, int reg) +{ + writew(val, base + omap_i2c_get_ip_reg_map(ip_rev)[reg]); +} + +static inline u16 omap_i2c_read_reg(void __iomem *base, int ip_rev, int reg) +{ + return readw(base + omap_i2c_get_ip_reg_map(ip_rev)[reg]); +} + static int omap24_i2c_findpsc(u32 *pscl, u32 *psch, uint speed) { unsigned long internal_clk = 0, fclk; @@ -114,29 +221,31 @@ static int omap24_i2c_findpsc(u32 *pscl, u32 *psch, uint speed) * Wait for the bus to be free by checking the Bus Busy (BB) * bit to become clear */ -static int wait_for_bb(struct i2c *i2c_base, int waitdelay) +static int wait_for_bb(void __iomem *i2c_base, int ip_rev, int waitdelay) { int timeout = I2C_TIMEOUT; + int irq_stat_reg; u16 stat;
- writew(0xFFFF, &i2c_base->stat); /* clear current interrupts...*/ -#if defined(CONFIG_OMAP34XX) - while ((stat = readw(&i2c_base->stat) & I2C_STAT_BB) && timeout--) { -#else - /* Read RAW status */ - while ((stat = readw(&i2c_base->irqstatus_raw) & + irq_stat_reg = (ip_rev == OMAP_I2C_REV_V1) ? + OMAP_I2C_STAT_REG : OMAP_I2C_IP_V2_IRQSTATUS_RAW; + + /* clear current interrupts */ + omap_i2c_write_reg(i2c_base, ip_rev, 0xFFFF, OMAP_I2C_STAT_REG); + + while ((stat = omap_i2c_read_reg(i2c_base, ip_rev, irq_stat_reg) & I2C_STAT_BB) && timeout--) { -#endif - writew(stat, &i2c_base->stat); + omap_i2c_write_reg(i2c_base, ip_rev, stat, OMAP_I2C_STAT_REG); udelay(waitdelay); }
if (timeout <= 0) { - printf("Timed out in wait_for_bb: status=%04x\n", - stat); + printf("Timed out in %s: status=%04x\n", __func__, stat); return 1; } - writew(0xFFFF, &i2c_base->stat); /* clear delayed stuff*/ + + /* clear delayed stuff */ + omap_i2c_write_reg(i2c_base, ip_rev, 0xFFFF, OMAP_I2C_STAT_REG); return 0; }
@@ -144,40 +253,37 @@ static int wait_for_bb(struct i2c *i2c_base, int waitdelay) * Wait for the I2C controller to complete current action * and update status */ -static u16 wait_for_event(struct i2c *i2c_base, int waitdelay) +static u16 wait_for_event(void __iomem *i2c_base, int ip_rev, int waitdelay) { u16 status; int timeout = I2C_TIMEOUT; + int irq_stat_reg;
+ irq_stat_reg = (ip_rev == OMAP_I2C_REV_V1) ? + OMAP_I2C_STAT_REG : OMAP_I2C_IP_V2_IRQSTATUS_RAW; do { udelay(waitdelay); -#if defined(CONFIG_OMAP34XX) - status = readw(&i2c_base->stat); -#else - /* Read RAW status */ - status = readw(&i2c_base->irqstatus_raw); -#endif + status = omap_i2c_read_reg(i2c_base, ip_rev, irq_stat_reg); } while (!(status & (I2C_STAT_ROVR | I2C_STAT_XUDF | I2C_STAT_XRDY | I2C_STAT_RRDY | I2C_STAT_ARDY | I2C_STAT_NACK | I2C_STAT_AL)) && timeout--);
if (timeout <= 0) { - printf("Timed out in wait_for_event: status=%04x\n", - status); + printf("Timed out in %s: status=%04x\n", __func__, status); /* * If status is still 0 here, probably the bus pads have * not been configured for I2C, and/or pull-ups are missing. */ printf("Check if pads/pull-ups of bus are properly configured\n"); - writew(0xFFFF, &i2c_base->stat); + omap_i2c_write_reg(i2c_base, ip_rev, 0xFFFF, OMAP_I2C_STAT_REG); status = 0; }
return status; }
-static void flush_fifo(struct i2c *i2c_base) +static void flush_fifo(void __iomem *i2c_base, int ip_rev) { u16 stat;
@@ -186,17 +292,18 @@ static void flush_fifo(struct i2c *i2c_base) * you get a bus error */ while (1) { - stat = readw(&i2c_base->stat); + stat = omap_i2c_read_reg(i2c_base, ip_rev, OMAP_I2C_STAT_REG); if (stat == I2C_STAT_RRDY) { - readb(&i2c_base->data); - writew(I2C_STAT_RRDY, &i2c_base->stat); + omap_i2c_read_reg(i2c_base, ip_rev, OMAP_I2C_DATA_REG); + omap_i2c_write_reg(i2c_base, ip_rev, + I2C_STAT_RRDY, OMAP_I2C_STAT_REG); udelay(1000); } else break; } }
-static int __omap24_i2c_setspeed(struct i2c *i2c_base, uint speed, +static int __omap24_i2c_setspeed(void __iomem *i2c_base, int ip_rev, uint speed, int *waitdelay) { int psc, fsscll = 0, fssclh = 0; @@ -248,79 +355,89 @@ static int __omap24_i2c_setspeed(struct i2c *i2c_base, uint speed, } }
- *waitdelay = (10000000 / speed) * 2; /* wait for 20 clkperiods */ - writew(0, &i2c_base->con); - writew(psc, &i2c_base->psc); - writew(scll, &i2c_base->scll); - writew(sclh, &i2c_base->sclh); - writew(I2C_CON_EN, &i2c_base->con); - writew(0xFFFF, &i2c_base->stat); /* clear all pending status */ + /* wait for 20 clkperiods */ + *waitdelay = (10000000 / speed) * 2; + + omap_i2c_write_reg(i2c_base, ip_rev, 0, OMAP_I2C_CON_REG); + omap_i2c_write_reg(i2c_base, ip_rev, psc, OMAP_I2C_PSC_REG); + omap_i2c_write_reg(i2c_base, ip_rev, scll, OMAP_I2C_SCLL_REG); + omap_i2c_write_reg(i2c_base, ip_rev, sclh, OMAP_I2C_SCLH_REG); + omap_i2c_write_reg(i2c_base, ip_rev, I2C_CON_EN, OMAP_I2C_CON_REG); + + /* clear all pending status */ + omap_i2c_write_reg(i2c_base, ip_rev, 0xFFFF, OMAP_I2C_STAT_REG);
return 0; }
-static void omap24_i2c_deblock(struct i2c *i2c_base) +static void omap24_i2c_deblock(void __iomem *i2c_base, int ip_rev) { int i; u16 systest; u16 orgsystest;
/* set test mode ST_EN = 1 */ - orgsystest = readw(&i2c_base->systest); + orgsystest = omap_i2c_read_reg(i2c_base, ip_rev, OMAP_I2C_SYSTEST_REG); systest = orgsystest; + /* enable testmode */ systest |= I2C_SYSTEST_ST_EN; - writew(systest, &i2c_base->systest); + omap_i2c_write_reg(i2c_base, ip_rev, systest, OMAP_I2C_SYSTEST_REG); systest &= ~I2C_SYSTEST_TMODE_MASK; systest |= 3 << I2C_SYSTEST_TMODE_SHIFT; - writew(systest, &i2c_base->systest); + omap_i2c_write_reg(i2c_base, ip_rev, systest, OMAP_I2C_SYSTEST_REG);
/* set SCL, SDA = 1 */ systest |= I2C_SYSTEST_SCL_O | I2C_SYSTEST_SDA_O; - writew(systest, &i2c_base->systest); + omap_i2c_write_reg(i2c_base, ip_rev, systest, OMAP_I2C_SYSTEST_REG); udelay(10);
/* toggle scl 9 clocks */ for (i = 0; i < 9; i++) { /* SCL = 0 */ systest &= ~I2C_SYSTEST_SCL_O; - writew(systest, &i2c_base->systest); + omap_i2c_write_reg(i2c_base, ip_rev, + systest, OMAP_I2C_SYSTEST_REG); udelay(10); /* SCL = 1 */ systest |= I2C_SYSTEST_SCL_O; - writew(systest, &i2c_base->systest); + omap_i2c_write_reg(i2c_base, ip_rev, + systest, OMAP_I2C_SYSTEST_REG); udelay(10); }
/* send stop */ systest &= ~I2C_SYSTEST_SDA_O; - writew(systest, &i2c_base->systest); + omap_i2c_write_reg(i2c_base, ip_rev, systest, OMAP_I2C_SYSTEST_REG); udelay(10); systest |= I2C_SYSTEST_SCL_O | I2C_SYSTEST_SDA_O; - writew(systest, &i2c_base->systest); + omap_i2c_write_reg(i2c_base, ip_rev, systest, OMAP_I2C_SYSTEST_REG); udelay(10);
/* restore original mode */ - writew(orgsystest, &i2c_base->systest); + omap_i2c_write_reg(i2c_base, ip_rev, orgsystest, OMAP_I2C_SYSTEST_REG); }
-static void __omap24_i2c_init(struct i2c *i2c_base, int speed, int slaveadd, - int *waitdelay) +static void __omap24_i2c_init(void __iomem *i2c_base, int ip_rev, int speed, + int slaveadd, int *waitdelay) { int timeout = I2C_TIMEOUT; int deblock = 1;
retry: - if (readw(&i2c_base->con) & I2C_CON_EN) { - writew(0, &i2c_base->con); + if (omap_i2c_read_reg(i2c_base, ip_rev, OMAP_I2C_CON_REG) & + I2C_CON_EN) { + omap_i2c_write_reg(i2c_base, ip_rev, 0, OMAP_I2C_CON_REG); udelay(50000); }
- writew(0x2, &i2c_base->sysc); /* for ES2 after soft reset */ + /* for ES2 after soft reset */ + omap_i2c_write_reg(i2c_base, ip_rev, 0x2, OMAP_I2C_SYSC_REG); udelay(1000);
- writew(I2C_CON_EN, &i2c_base->con); - while (!(readw(&i2c_base->syss) & I2C_SYSS_RDONE) && timeout--) { + omap_i2c_write_reg(i2c_base, ip_rev, I2C_CON_EN, OMAP_I2C_CON_REG); + while (!(omap_i2c_read_reg(i2c_base, ip_rev, OMAP_I2C_SYSS_REG) & + I2C_SYSS_RDONE) && timeout--) { if (timeout <= 0) { puts("ERROR: Timeout in soft-reset\n"); return; @@ -328,30 +445,33 @@ retry: udelay(1000); }
- if (0 != __omap24_i2c_setspeed(i2c_base, speed, waitdelay)) { + if (__omap24_i2c_setspeed(i2c_base, ip_rev, speed, waitdelay)) { printf("ERROR: failed to setup I2C bus-speed!\n"); return; }
/* own address */ - writew(slaveadd, &i2c_base->oa); + omap_i2c_write_reg(i2c_base, ip_rev, slaveadd, OMAP_I2C_OA_REG); + + if (ip_rev == OMAP_I2C_REV_V1) { + /* + * Have to enable interrupts for OMAP2/3, these IPs don't have + * an 'irqstatus_raw' register and we shall have to poll 'stat' + */ + omap_i2c_write_reg(i2c_base, ip_rev, I2C_IE_XRDY_IE | + I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | + I2C_IE_NACK_IE | I2C_IE_AL_IE, + OMAP_I2C_IE_REG); + }
-#if defined(CONFIG_OMAP34XX) - /* - * Have to enable interrupts for OMAP2/3, these IPs don't have - * an 'irqstatus_raw' register and we shall have to poll 'stat' - */ - writew(I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | - I2C_IE_NACK_IE | I2C_IE_AL_IE, &i2c_base->ie); -#endif udelay(1000); - flush_fifo(i2c_base); - writew(0xFFFF, &i2c_base->stat); + flush_fifo(i2c_base, ip_rev); + omap_i2c_write_reg(i2c_base, ip_rev, 0xFFFF, OMAP_I2C_STAT_REG);
/* Handle possible failed I2C state */ - if (wait_for_bb(i2c_base, *waitdelay)) + if (wait_for_bb(i2c_base, ip_rev, *waitdelay)) if (deblock == 1) { - omap24_i2c_deblock(i2c_base); + omap24_i2c_deblock(i2c_base, ip_rev); deblock = 0; goto retry; } @@ -361,25 +481,28 @@ retry: * i2c_probe: Use write access. Allows to identify addresses that are * write-only (like the config register of dual-port EEPROMs) */ -static int __omap24_i2c_probe(struct i2c *i2c_base, int waitdelay, uchar chip) +static int __omap24_i2c_probe(void __iomem *i2c_base, int ip_rev, int waitdelay, + uchar chip) { u16 status; int res = 1; /* default = fail */
- if (chip == readw(&i2c_base->oa)) + if (chip == omap_i2c_read_reg(i2c_base, ip_rev, OMAP_I2C_OA_REG)) return res;
/* Wait until bus is free */ - if (wait_for_bb(i2c_base, waitdelay)) + if (wait_for_bb(i2c_base, ip_rev, waitdelay)) return res;
/* No data transfer, slave addr only */ - writew(chip, &i2c_base->sa); + omap_i2c_write_reg(i2c_base, ip_rev, chip, OMAP_I2C_SA_REG); + /* Stop bit needed here */ - writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX | - I2C_CON_STP, &i2c_base->con); + omap_i2c_write_reg(i2c_base, ip_rev, I2C_CON_EN | I2C_CON_MST | + I2C_CON_STT | I2C_CON_TRX | I2C_CON_STP, + OMAP_I2C_CON_REG);
- status = wait_for_event(i2c_base, waitdelay); + status = wait_for_event(i2c_base, ip_rev, waitdelay);
if ((status & ~I2C_STAT_XRDY) == 0 || (status & I2C_STAT_AL)) { /* @@ -400,14 +523,17 @@ static int __omap24_i2c_probe(struct i2c *i2c_base, int waitdelay, uchar chip) res = 0; /* Device found */ udelay(waitdelay);/* Required by AM335X in SPL */ /* Abort transfer (force idle state) */ - writew(I2C_CON_MST | I2C_CON_TRX, &i2c_base->con); /* Reset */ + omap_i2c_write_reg(i2c_base, ip_rev, I2C_CON_MST | I2C_CON_TRX, + OMAP_I2C_CON_REG); /* Reset */ udelay(1000); - writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_TRX | - I2C_CON_STP, &i2c_base->con); /* STP */ + omap_i2c_write_reg(i2c_base, ip_rev, I2C_CON_EN | I2C_CON_MST | + I2C_CON_TRX | I2C_CON_STP, + OMAP_I2C_CON_REG); /* STP */ } + pr_exit: - flush_fifo(i2c_base); - writew(0xFFFF, &i2c_base->stat); + flush_fifo(i2c_base, ip_rev); + omap_i2c_write_reg(i2c_base, ip_rev, 0xFFFF, OMAP_I2C_STAT_REG); return res; }
@@ -424,8 +550,9 @@ pr_exit: * or that do not need a register address at all (such as some clock * distributors). */ -static int __omap24_i2c_read(struct i2c *i2c_base, int waitdelay, uchar chip, - uint addr, int alen, uchar *buffer, int len) +static int __omap24_i2c_read(void __iomem *i2c_base, int ip_rev, int waitdelay, + uchar chip, uint addr, int alen, uchar *buffer, + int len) { int i2c_error = 0; u16 status; @@ -434,10 +561,12 @@ static int __omap24_i2c_read(struct i2c *i2c_base, int waitdelay, uchar chip, puts("I2C read: addr len < 0\n"); return 1; } + if (len < 0) { puts("I2C read: data len < 0\n"); return 1; } + if (buffer == NULL) { puts("I2C read: NULL pointer passed\n"); return 1; @@ -471,28 +600,29 @@ static int __omap24_i2c_read(struct i2c *i2c_base, int waitdelay, uchar chip, #endif
/* Wait until bus not busy */ - if (wait_for_bb(i2c_base, waitdelay)) + if (wait_for_bb(i2c_base, ip_rev, waitdelay)) return 1;
/* Zero, one or two bytes reg address (offset) */ - writew(alen, &i2c_base->cnt); + omap_i2c_write_reg(i2c_base, ip_rev, alen, OMAP_I2C_CNT_REG); /* Set slave address */ - writew(chip, &i2c_base->sa); + omap_i2c_write_reg(i2c_base, ip_rev, chip, OMAP_I2C_SA_REG);
if (alen) { /* Must write reg offset first */ #ifdef CONFIG_I2C_REPEATED_START /* No stop bit, use Repeated Start (Sr) */ - writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | - I2C_CON_TRX, &i2c_base->con); + omap_i2c_write_reg(i2c_base, ip_rev, I2C_CON_EN | I2C_CON_MST | + I2C_CON_STT | I2C_CON_TRX, OMAP_I2C_CON_REG); #else /* Stop - Start (P-S) */ - writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP | - I2C_CON_TRX, &i2c_base->con); + omap_i2c_write_reg(i2c_base, ip_rev, I2C_CON_EN | I2C_CON_MST | + I2C_CON_STT | I2C_CON_STP | I2C_CON_TRX, + OMAP_I2C_CON_REG); #endif /* Send register offset */ while (1) { - status = wait_for_event(i2c_base, waitdelay); + status = wait_for_event(i2c_base, ip_rev, waitdelay); /* Try to identify bus that is not padconf'd for I2C */ if (status == I2C_STAT_XRDY) { i2c_error = 2; @@ -508,31 +638,37 @@ static int __omap24_i2c_read(struct i2c *i2c_base, int waitdelay, uchar chip, } if (alen) { if (status & I2C_STAT_XRDY) { + u8 addr_byte; alen--; - /* Do we have to use byte access? */ - writeb((addr >> (8 * alen)) & 0xff, - &i2c_base->data); - writew(I2C_STAT_XRDY, &i2c_base->stat); + addr_byte = (addr >> (8 * alen)) & 0xff; + omap_i2c_write_reg(i2c_base, ip_rev, + addr_byte, + OMAP_I2C_DATA_REG); + omap_i2c_write_reg(i2c_base, ip_rev, + I2C_STAT_XRDY, + OMAP_I2C_STAT_REG); } } if (status & I2C_STAT_ARDY) { - writew(I2C_STAT_ARDY, &i2c_base->stat); + omap_i2c_write_reg(i2c_base, ip_rev, + I2C_STAT_ARDY, + OMAP_I2C_STAT_REG); break; } } } + /* Set slave address */ - writew(chip, &i2c_base->sa); + omap_i2c_write_reg(i2c_base, ip_rev, chip, OMAP_I2C_SA_REG); /* Read len bytes from slave */ - writew(len, &i2c_base->cnt); + omap_i2c_write_reg(i2c_base, ip_rev, len, OMAP_I2C_CNT_REG); /* Need stop bit here */ - writew(I2C_CON_EN | I2C_CON_MST | - I2C_CON_STT | I2C_CON_STP, - &i2c_base->con); + omap_i2c_write_reg(i2c_base, ip_rev, I2C_CON_EN | I2C_CON_MST | + I2C_CON_STT | I2C_CON_STP, OMAP_I2C_CON_REG);
/* Receive data */ while (1) { - status = wait_for_event(i2c_base, waitdelay); + status = wait_for_event(i2c_base, ip_rev, waitdelay); /* * Try to identify bus that is not padconf'd for I2C. This * state could be left over from previous transactions if @@ -549,24 +685,28 @@ static int __omap24_i2c_read(struct i2c *i2c_base, int waitdelay, uchar chip, goto rd_exit; } if (status & I2C_STAT_RRDY) { - *buffer++ = readb(&i2c_base->data); - writew(I2C_STAT_RRDY, &i2c_base->stat); + *buffer++ = omap_i2c_read_reg(i2c_base, ip_rev, + OMAP_I2C_DATA_REG); + omap_i2c_write_reg(i2c_base, ip_rev, + I2C_STAT_RRDY, OMAP_I2C_STAT_REG); } if (status & I2C_STAT_ARDY) { - writew(I2C_STAT_ARDY, &i2c_base->stat); + omap_i2c_write_reg(i2c_base, ip_rev, + I2C_STAT_ARDY, OMAP_I2C_STAT_REG); break; } }
rd_exit: - flush_fifo(i2c_base); - writew(0xFFFF, &i2c_base->stat); + flush_fifo(i2c_base, ip_rev); + omap_i2c_write_reg(i2c_base, ip_rev, 0xFFFF, OMAP_I2C_STAT_REG); return i2c_error; }
/* i2c_write: Address (reg offset) may be 0, 1 or 2 bytes long. */ -static int __omap24_i2c_write(struct i2c *i2c_base, int waitdelay, uchar chip, - uint addr, int alen, uchar *buffer, int len) +static int __omap24_i2c_write(void __iomem *i2c_base, int ip_rev, int waitdelay, + uchar chip, uint addr, int alen, uchar *buffer, + int len) { int i; u16 status; @@ -617,20 +757,21 @@ static int __omap24_i2c_write(struct i2c *i2c_base, int waitdelay, uchar chip, #endif
/* Start address phase - will write regoffset + len bytes data */ - writew(alen + len, &i2c_base->cnt); + omap_i2c_write_reg(i2c_base, ip_rev, alen + len, OMAP_I2C_CNT_REG); /* Set slave address */ - writew(chip, &i2c_base->sa); + omap_i2c_write_reg(i2c_base, ip_rev, chip, OMAP_I2C_SA_REG); /* Stop bit needed here */ - writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX | - I2C_CON_STP, &i2c_base->con); + omap_i2c_write_reg(i2c_base, ip_rev, I2C_CON_EN | I2C_CON_MST | + I2C_CON_STT | I2C_CON_TRX | I2C_CON_STP, + OMAP_I2C_CON_REG);
while (alen) { /* Must write reg offset (one or two bytes) */ - status = wait_for_event(i2c_base, waitdelay); + status = wait_for_event(i2c_base, ip_rev, waitdelay); /* Try to identify bus that is not padconf'd for I2C */ if (status == I2C_STAT_XRDY) { i2c_error = 2; @@ -646,8 +787,11 @@ static int __omap24_i2c_write(struct i2c *i2c_base, int waitdelay, uchar chip, } if (status & I2C_STAT_XRDY) { alen--; - writeb((addr >> (8 * alen)) & 0xff, &i2c_base->data); - writew(I2C_STAT_XRDY, &i2c_base->stat); + omap_i2c_write_reg(i2c_base, ip_rev, + (addr >> (8 * alen)) & 0xff, + OMAP_I2C_DATA_REG); + omap_i2c_write_reg(i2c_base, ip_rev, + I2C_STAT_XRDY, OMAP_I2C_STAT_REG); } else { i2c_error = 1; printf("i2c_write: bus not ready for addr Tx (status=0x%x)\n", @@ -655,9 +799,10 @@ static int __omap24_i2c_write(struct i2c *i2c_base, int waitdelay, uchar chip, goto wr_exit; } } + /* Address phase is over, now write data */ for (i = 0; i < len; i++) { - status = wait_for_event(i2c_base, waitdelay); + status = wait_for_event(i2c_base, ip_rev, waitdelay); if (status == 0 || (status & I2C_STAT_NACK)) { i2c_error = 1; printf("i2c_write: error waiting for data ACK (status=0x%x)\n", @@ -665,8 +810,10 @@ static int __omap24_i2c_write(struct i2c *i2c_base, int waitdelay, uchar chip, goto wr_exit; } if (status & I2C_STAT_XRDY) { - writeb(buffer[i], &i2c_base->data); - writew(I2C_STAT_XRDY, &i2c_base->stat); + omap_i2c_write_reg(i2c_base, ip_rev, + buffer[i], OMAP_I2C_DATA_REG); + omap_i2c_write_reg(i2c_base, ip_rev, + I2C_STAT_XRDY, OMAP_I2C_STAT_REG); } else { i2c_error = 1; printf("i2c_write: bus not ready for data Tx (i=%d)\n", @@ -674,19 +821,20 @@ static int __omap24_i2c_write(struct i2c *i2c_base, int waitdelay, uchar chip, goto wr_exit; } } + /* * poll ARDY bit for making sure that last byte really has been * transferred on the bus. */ do { - status = wait_for_event(i2c_base, waitdelay); + status = wait_for_event(i2c_base, ip_rev, waitdelay); } while (!(status & I2C_STAT_ARDY) && timeout--); if (timeout <= 0) printf("i2c_write: timed out writig last byte!\n");
wr_exit: - flush_fifo(i2c_base); - writew(0xFFFF, &i2c_base->stat); + flush_fifo(i2c_base, ip_rev); + omap_i2c_write_reg(i2c_base, ip_rev, 0xFFFF, OMAP_I2C_STAT_REG); return i2c_error; }
@@ -695,26 +843,26 @@ wr_exit: * The legacy I2C functions. These need to get removed once * all users of this driver are converted to DM. */ -static struct i2c *omap24_get_base(struct i2c_adapter *adap) +static void __iomem *omap24_get_base(struct i2c_adapter *adap) { switch (adap->hwadapnr) { case 0: - return (struct i2c *)I2C_BASE1; + return (void __iomem *)I2C_BASE1; break; case 1: - return (struct i2c *)I2C_BASE2; + return (void __iomem *)I2C_BASE2; break; #if (CONFIG_SYS_I2C_BUS_MAX > 2) case 2: - return (struct i2c *)I2C_BASE3; + return (void __iomem *)I2C_BASE3; break; #if (CONFIG_SYS_I2C_BUS_MAX > 3) case 3: - return (struct i2c *)I2C_BASE4; + return (void __iomem *)I2C_BASE4; break; #if (CONFIG_SYS_I2C_BUS_MAX > 4) case 4: - return (struct i2c *)I2C_BASE5; + return (void __iomem *)I2C_BASE5; break; #endif #endif @@ -723,35 +871,46 @@ static struct i2c *omap24_get_base(struct i2c_adapter *adap) printf("wrong hwadapnr: %d\n", adap->hwadapnr); break; } + return NULL; }
+static int omap24_get_ip_rev(void) +{ +#ifdef CONFIG_OMAP34XX + return OMAP_I2C_REV_V1; +#else + return OMAP_I2C_REV_V2; +#endif +}
static int omap24_i2c_read(struct i2c_adapter *adap, uchar chip, uint addr, int alen, uchar *buffer, int len) { - struct i2c *i2c_base = omap24_get_base(adap); + void __iomem *i2c_base = omap24_get_base(adap); + int ip_rev = omap24_get_ip_rev();
- return __omap24_i2c_read(i2c_base, adap->waitdelay, chip, addr, + return __omap24_i2c_read(i2c_base, ip_rev, adap->waitdelay, chip, addr, alen, buffer, len); }
- static int omap24_i2c_write(struct i2c_adapter *adap, uchar chip, uint addr, int alen, uchar *buffer, int len) { - struct i2c *i2c_base = omap24_get_base(adap); + void __iomem *i2c_base = omap24_get_base(adap); + int ip_rev = omap24_get_ip_rev();
- return __omap24_i2c_write(i2c_base, adap->waitdelay, chip, addr, + return __omap24_i2c_write(i2c_base, ip_rev, adap->waitdelay, chip, addr, alen, buffer, len); }
static uint omap24_i2c_setspeed(struct i2c_adapter *adap, uint speed) { - struct i2c *i2c_base = omap24_get_base(adap); + void __iomem *i2c_base = omap24_get_base(adap); + int ip_rev = omap24_get_ip_rev(); int ret;
- ret = __omap24_i2c_setspeed(i2c_base, speed, &adap->waitdelay); + ret = __omap24_i2c_setspeed(i2c_base, ip_rev, speed, &adap->waitdelay); if (ret) { pr_err("%s: set i2c speed failed\n", __func__); return ret; @@ -764,16 +923,19 @@ static uint omap24_i2c_setspeed(struct i2c_adapter *adap, uint speed)
static void omap24_i2c_init(struct i2c_adapter *adap, int speed, int slaveadd) { - struct i2c *i2c_base = omap24_get_base(adap); + void __iomem *i2c_base = omap24_get_base(adap); + int ip_rev = omap24_get_ip_rev();
- return __omap24_i2c_init(i2c_base, speed, slaveadd, &adap->waitdelay); + return __omap24_i2c_init(i2c_base, ip_rev, speed, slaveadd, + &adap->waitdelay); }
static int omap24_i2c_probe(struct i2c_adapter *adap, uchar chip) { - struct i2c *i2c_base = omap24_get_base(adap); + void __iomem *i2c_base = omap24_get_base(adap); + int ip_rev = omap24_get_ip_rev();
- return __omap24_i2c_probe(i2c_base, adap->waitdelay, chip); + return __omap24_i2c_probe(i2c_base, ip_rev, adap->waitdelay, chip); }
#if !defined(CONFIG_SYS_OMAP24_I2C_SPEED1) @@ -793,6 +955,7 @@ U_BOOT_I2C_ADAP_COMPLETE(omap24_1, omap24_i2c_init, omap24_i2c_probe, CONFIG_SYS_OMAP24_I2C_SPEED1, CONFIG_SYS_OMAP24_I2C_SLAVE1, 1) + #if (CONFIG_SYS_I2C_BUS_MAX > 2) #if !defined(CONFIG_SYS_OMAP24_I2C_SPEED2) #define CONFIG_SYS_OMAP24_I2C_SPEED2 CONFIG_SYS_OMAP24_I2C_SPEED @@ -847,11 +1010,13 @@ static int omap_i2c_xfer(struct udevice *bus, struct i2c_msg *msg, int nmsgs) for (; nmsgs > 0; nmsgs--, msg++) { debug("i2c_xfer: chip=0x%x, len=0x%x\n", msg->addr, msg->len); if (msg->flags & I2C_M_RD) { - ret = __omap24_i2c_read(priv->regs, priv->waitdelay, + ret = __omap24_i2c_read(priv->regs, priv->ip_rev, + priv->waitdelay, msg->addr, 0, 0, msg->buf, msg->len); } else { - ret = __omap24_i2c_write(priv->regs, priv->waitdelay, + ret = __omap24_i2c_write(priv->regs, priv->ip_rev, + priv->waitdelay, msg->addr, 0, 0, msg->buf, msg->len); } @@ -870,7 +1035,8 @@ static int omap_i2c_set_bus_speed(struct udevice *bus, unsigned int speed)
priv->speed = speed;
- return __omap24_i2c_setspeed(priv->regs, speed, &priv->waitdelay); + return __omap24_i2c_setspeed(priv->regs, priv->ip_rev, speed, + &priv->waitdelay); }
static int omap_i2c_probe_chip(struct udevice *bus, uint chip_addr, @@ -878,14 +1044,18 @@ static int omap_i2c_probe_chip(struct udevice *bus, uint chip_addr, { struct omap_i2c *priv = dev_get_priv(bus);
- return __omap24_i2c_probe(priv->regs, priv->waitdelay, chip_addr); + return __omap24_i2c_probe(priv->regs, priv->ip_rev, priv->waitdelay, + chip_addr); }
static int omap_i2c_probe(struct udevice *bus) { struct omap_i2c *priv = dev_get_priv(bus);
- __omap24_i2c_init(priv->regs, priv->speed, 0, &priv->waitdelay); + priv->ip_rev = dev_get_driver_data(bus); + + __omap24_i2c_init(priv->regs, priv->ip_rev, priv->speed, 0, + &priv->waitdelay);
return 0; } @@ -903,8 +1073,8 @@ static int omap_i2c_ofdata_to_platdata(struct udevice *bus) }
static const struct udevice_id omap_i2c_ids[] = { - { .compatible = "ti,omap3-i2c" }, - { .compatible = "ti,omap4-i2c" }, + { .compatible = "ti,omap3-i2c", .data = OMAP_I2C_REV_V1 }, + { .compatible = "ti,omap4-i2c", .data = OMAP_I2C_REV_V2 }, { } }; #endif
This allows the driver to be used without OF_CONTROL. AM335x support DM_SPL but does not use SPL_OF_CONTROL. Enabling DM_I2C in SPL thus requires that the omap I2C can be passed platdata.
arch/arm/include/asm/arch-am33xx/i2c.h | 2 ++ arch/arm/include/asm/omap_i2c.h | 24 ++++++++++++++++++++++++ drivers/i2c/omap24xx_i2c.c | 21 +++++++++++---------- 3 files changed, 37 insertions(+), 10 deletions(-) create mode 100644 arch/arm/include/asm/omap_i2c.h
diff --git a/arch/arm/include/asm/arch-am33xx/i2c.h b/arch/arm/include/asm/arch-am33xx/i2c.h index b3cc3df..c2a9850 100644 --- a/arch/arm/include/asm/arch-am33xx/i2c.h +++ b/arch/arm/include/asm/arch-am33xx/i2c.h @@ -6,6 +6,8 @@ #ifndef _I2C_AM33XX_H_ #define _I2C_AM33XX_H_
+#include <asm/omap_i2c.h> + #define I2C_BASE1 0x44E0B000 #define I2C_BASE2 0x4802A000 #define I2C_BASE3 0x4819C000 diff --git a/arch/arm/include/asm/omap_i2c.h b/arch/arm/include/asm/omap_i2c.h new file mode 100644 index 0000000..c1695cb --- /dev/null +++ b/arch/arm/include/asm/omap_i2c.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0 */ + +#ifndef _OMAP_I2C_H +#define _OMAP_I2C_H + +#include <asm/arch/cpu.h> + +#ifdef CONFIG_DM_I2C + +/* Information about a GPIO bank */ +struct omap_i2c_platdata { + ulong base; /* address of registers in physical memory */ + int speed; + int ip_rev; +}; + +#endif + +enum { + OMAP_I2C_REV_V1 = 0, + OMAP_I2C_REV_V2 = 1, +}; + +#endif /* _OMAP_I2C_H */ diff --git a/drivers/i2c/omap24xx_i2c.c b/drivers/i2c/omap24xx_i2c.c index dacaded..134d622 100644 --- a/drivers/i2c/omap24xx_i2c.c +++ b/drivers/i2c/omap24xx_i2c.c @@ -43,6 +43,7 @@ #include <i2c.h>
#include <asm/io.h> +#include <asm/omap_i2c.h>
/* * Provide access to architecture-specific I2C header files for platforms @@ -62,11 +63,6 @@ #define I2C_WAIT 200
enum { - OMAP_I2C_REV_V1 = 0, - OMAP_I2C_REV_V2 = 1, -}; - -enum { OMAP_I2C_REV_REG = 0, /* Only on IP V1 (OMAP34XX) */ OMAP_I2C_IE_REG, /* Only on IP V1 (OMAP34XX) */ OMAP_I2C_STAT_REG, @@ -1051,8 +1047,12 @@ static int omap_i2c_probe_chip(struct udevice *bus, uint chip_addr, static int omap_i2c_probe(struct udevice *bus) { struct omap_i2c *priv = dev_get_priv(bus); + struct omap_i2c_platdata *plat = dev_get_platdata(bus);
- priv->ip_rev = dev_get_driver_data(bus); + priv->speed = plat->speed; + priv->regs = map_physmem(plat->base, sizeof(void *), + MAP_NOCACHE); + priv->ip_rev = plat->ip_rev;
__omap24_i2c_init(priv->regs, priv->ip_rev, priv->speed, 0, &priv->waitdelay); @@ -1063,11 +1063,11 @@ static int omap_i2c_probe(struct udevice *bus) #if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) static int omap_i2c_ofdata_to_platdata(struct udevice *bus) { - struct omap_i2c *priv = dev_get_priv(bus); + struct omap_i2c_platdata *plat = dev_get_platdata(bus);
- priv->regs = map_physmem(devfdt_get_addr(bus), sizeof(void *), - MAP_NOCACHE); - priv->speed = CONFIG_SYS_OMAP24_I2C_SPEED; + plat->base = devfdt_get_addr(bus); + plat->speed = dev_read_u32_default(bus, "clock-frequency", 100000); + plat->ip_rev = dev_get_driver_data(bus);
return 0; } @@ -1091,6 +1091,7 @@ U_BOOT_DRIVER(i2c_omap) = { #if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) .of_match = omap_i2c_ids, .ofdata_to_platdata = omap_i2c_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct omap_i2c_platdata), #endif .probe = omap_i2c_probe, .priv_auto_alloc_size = sizeof(struct omap_i2c),
If DM_I2C is used , the I2C controllers must be registered as U_BOOT_DEVICE because OF_CONTROL is not used in the SPL.
arch/arm/mach-omap2/am33xx/board.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index f5f2bd5..c121f27 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -19,6 +19,7 @@ #include <asm/arch/ddr_defs.h> #include <asm/arch/clock.h> #include <asm/arch/gpio.h> +#include <asm/arch/i2c.h> #include <asm/arch/mem.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> @@ -93,6 +94,20 @@ U_BOOT_DEVICES(am33xx_uarts) = { # endif };
+#ifdef CONFIG_DM_I2C +static const struct omap_i2c_platdata am33xx_i2c[] = { + { I2C_BASE1, 100000, OMAP_I2C_REV_V2}, + { I2C_BASE2, 100000, OMAP_I2C_REV_V2}, + { I2C_BASE3, 100000, OMAP_I2C_REV_V2}, +}; + +U_BOOT_DEVICES(am33xx_i2c) = { + { "i2c_omap", &am33xx_i2c[0] }, + { "i2c_omap", &am33xx_i2c[1] }, + { "i2c_omap", &am33xx_i2c[2] }, +}; +#endif + #ifdef CONFIG_DM_GPIO static const struct omap_gpio_platdata am33xx_gpio[] = { { 0, AM33XX_GPIO0_BASE },
arch/arm/dts/am437x-gp-evm-u-boot.dtsi | 4 ++++ arch/arm/dts/omap5-u-boot.dtsi | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/arch/arm/dts/am437x-gp-evm-u-boot.dtsi b/arch/arm/dts/am437x-gp-evm-u-boot.dtsi index 530f549..03a1c1d 100644 --- a/arch/arm/dts/am437x-gp-evm-u-boot.dtsi +++ b/arch/arm/dts/am437x-gp-evm-u-boot.dtsi @@ -36,3 +36,7 @@ &phy_sel { u-boot,dm-spl; }; + +&i2c0 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/omap5-u-boot.dtsi b/arch/arm/dts/omap5-u-boot.dtsi index bf2684c..30833a3 100644 --- a/arch/arm/dts/omap5-u-boot.dtsi +++ b/arch/arm/dts/omap5-u-boot.dtsi @@ -91,3 +91,7 @@ &gpio7 { u-boot,dm-spl; }; + +&i2c1 { + u-boot,dm-spl; +};
In order to use DM_I2C, we need to move the board detection after the early SPL initialization.
arch/arm/mach-omap2/am33xx/board.c | 9 ++++++--- arch/arm/mach-omap2/hwinit-common.c | 5 ++--- 2 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index c121f27..2fc364d 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -472,12 +472,15 @@ void early_system_init(void) #ifdef CONFIG_DEBUG_UART_OMAP debug_uart_init(); #endif -#ifdef CONFIG_TI_I2C_BOARD_DETECT - do_board_detect(); -#endif + #ifdef CONFIG_SPL_BUILD spl_early_init(); #endif + +#ifdef CONFIG_TI_I2C_BOARD_DETECT + do_board_detect(); +#endif + #if defined(CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC) /* Enable RTC32K clock */ rtc32k_enable(); diff --git a/arch/arm/mach-omap2/hwinit-common.c b/arch/arm/mach-omap2/hwinit-common.c index 1a24acb..d0781d7 100644 --- a/arch/arm/mach-omap2/hwinit-common.c +++ b/arch/arm/mach-omap2/hwinit-common.c @@ -193,11 +193,10 @@ void early_system_init(void) * to prevent overwrites. */ save_omap_boot_params(); -#endif - do_board_detect(); -#ifdef CONFIG_SPL_BUILD spl_early_init(); #endif + do_board_detect(); + vcores_init(); #ifdef CONFIG_DEBUG_UART_OMAP debug_uart_init();
Those driver are not DM drivers per se (not using the PMIC/regulator framework) and are using the legacy I2C API. Make them compatible with the DM_I2C API.
This impacts the following drivers: - palmas (used by am57xx/dra7xx evms) - tps65218 (used by am43xx evms) - tps65217 and tps65910 (used by am335x evms and am335x boneblack vboot) - twl4030 (used by omap3_logicpd) - tps65217 (used by brppt1)
twl6030 could also have been modified, but as of today, it is not used with DM_I2C enabled
drivers/power/palmas.c | 39 +++++++++++++++++ drivers/power/pmic/pmic_tps62362.c | 27 ++++++++++++ drivers/power/pmic/pmic_tps65217.c | 47 +++++++++++++++++++- drivers/power/pmic/pmic_tps65218.c | 88 ++++++++++++++++++++++++++++++++++++++ drivers/power/pmic/pmic_tps65910.c | 60 ++++++++++++++++++++++---- drivers/power/twl4030.c | 39 +++++++++++++++++ include/palmas.h | 5 +++ include/power/tps65217.h | 2 + include/power/tps65910.h | 1 + include/twl4030.h | 6 ++- 10 files changed, 303 insertions(+), 11 deletions(-)
diff --git a/drivers/power/palmas.c b/drivers/power/palmas.c index 6d5abba..2584bea 100644 --- a/drivers/power/palmas.c +++ b/drivers/power/palmas.c @@ -175,3 +175,42 @@ int twl603x_enable_bb_charge(u8 bb_fields) val, err); return err; } + +#ifdef CONFIG_DM_I2C +int palmas_i2c_write_u8(u8 chip_no, u8 reg, u8 val) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, chip_no, 1, &dev); + if (ret) { + pr_err("unable to get I2C bus. ret %d\n", ret); + return ret; + } + ret = dm_i2c_reg_write(dev, reg, val); + if (ret) { + pr_err("writing to palmas failed. ret %d\n", ret); + return ret; + } + return 0; +} + +int palmas_i2c_read_u8(u8 chip_no, u8 reg, u8 *valp) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, chip_no, 1, &dev); + if (ret) { + pr_err("unable to get I2C bus. ret %d\n", ret); + return ret; + } + ret = dm_i2c_reg_read(dev, reg); + if (ret < 0) { + pr_err("reading from palmas failed. ret %d\n", ret); + return ret; + } + *valp = (u8)ret; + return 0; +} +#endif diff --git a/drivers/power/pmic/pmic_tps62362.c b/drivers/power/pmic/pmic_tps62362.c index f2987de..d2fd955 100644 --- a/drivers/power/pmic/pmic_tps62362.c +++ b/drivers/power/pmic/pmic_tps62362.c @@ -10,6 +10,10 @@ #include <power/pmic.h> #include <power/tps62362.h>
+#ifdef CONFIG_DM_I2C +struct udevice *tps62362_dev __attribute__((section(".data"))) = NULL; +#endif + /** * tps62362_voltage_update() - Function to change a voltage level, as this * is a multi-step process. @@ -22,9 +26,16 @@ int tps62362_voltage_update(unsigned char reg, unsigned char volt_sel) if (reg > TPS62362_NUM_REGS) return 1;
+#ifndef CONFIG_DM_I2C return i2c_write(TPS62362_I2C_ADDR, reg, 1, &volt_sel, 1); +#else + if (!tps62362_dev) + return -ENODEV; + return dm_i2c_reg_write(tps62362_dev, reg, volt_sel); +#endif }
+#ifndef CONFIG_DM_I2C int power_tps62362_init(unsigned char bus) { static const char name[] = "TPS62362"; @@ -44,3 +55,19 @@ int power_tps62362_init(unsigned char bus)
return 0; } +#else +int power_tps62362_init(unsigned char bus) +{ + struct udevice *dev = NULL; + int rc; + + rc = i2c_get_chip_for_busnum(bus, TPS62362_I2C_ADDR, 1, &dev); + if (rc) + return rc; + rc = dm_i2c_probe_device(dev); + if (rc) + return rc; + tps62362_dev = dev; + return 0; +} +#endif diff --git a/drivers/power/pmic/pmic_tps65217.c b/drivers/power/pmic/pmic_tps65217.c index 01c0ad1..773eb74 100644 --- a/drivers/power/pmic/pmic_tps65217.c +++ b/drivers/power/pmic/pmic_tps65217.c @@ -8,6 +8,8 @@ #include <i2c.h> #include <power/tps65217.h>
+struct udevice *tps65217_dev __attribute__((section(".data"))) = NULL; + /** * tps65217_reg_read() - Generic function that can read a TPS65217 register * @src_reg: Source register address @@ -16,7 +18,11 @@ */ int tps65217_reg_read(uchar src_reg, uchar *src_val) { +#ifndef CONFIG_DM_I2C return i2c_read(TPS65217_CHIP_PM, src_reg, 1, src_val, 1); +#else + return dm_i2c_read(tps65217_dev, src_reg, src_val, 1); +#endif }
/** @@ -46,9 +52,14 @@ int tps65217_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val, * mask */ if (mask != TPS65217_MASK_ALL_BITS) { +#ifndef CONFIG_DM_I2C ret = i2c_read(TPS65217_CHIP_PM, dest_reg, 1, &read_val, 1); +#else + ret = dm_i2c_read(tps65217_dev, dest_reg, &read_val, 1); +#endif if (ret) return ret; + read_val &= (~mask); read_val |= (dest_val & mask); dest_val = read_val; @@ -56,23 +67,40 @@ int tps65217_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val,
if (prot_level > 0) { xor_reg = dest_reg ^ TPS65217_PASSWORD_UNLOCK; +#ifndef CONFIG_DM_I2C ret = i2c_write(TPS65217_CHIP_PM, TPS65217_PASSWORD, 1, &xor_reg, 1); +#else + ret = dm_i2c_write(tps65217_dev, TPS65217_PASSWORD, + &xor_reg, 1); +#endif if (ret) return ret; } - +#ifndef CONFIG_DM_I2C ret = i2c_write(TPS65217_CHIP_PM, dest_reg, 1, &dest_val, 1); +#else + ret = dm_i2c_write(tps65217_dev, dest_reg, &dest_val, 1); +#endif if (ret) return ret;
if (prot_level == TPS65217_PROT_LEVEL_2) { +#ifndef CONFIG_DM_I2C ret = i2c_write(TPS65217_CHIP_PM, TPS65217_PASSWORD, 1, &xor_reg, 1); +#else + ret = dm_i2c_write(tps65217_dev, TPS65217_PASSWORD, + &xor_reg, 1); +#endif if (ret) return ret;
+#ifndef CONFIG_DM_I2C ret = i2c_write(TPS65217_CHIP_PM, dest_reg, 1, &dest_val, 1); +#else + ret = dm_i2c_write(tps65217_dev, dest_reg, &dest_val, 1); +#endif if (ret) return ret; } @@ -106,3 +134,20 @@ int tps65217_voltage_update(uchar dc_cntrl_reg, uchar volt_sel)
return 0; } + +int power_tps65217_init(unsigned char bus) +{ +#ifdef CONFIG_DM_I2C + struct udevice *dev = NULL; + int rc; + + rc = i2c_get_chip_for_busnum(bus, TPS65217_CHIP_PM, 1, &dev); + if (rc) + return rc; + rc = dm_i2c_probe_device(dev); + if (rc) + return rc; + tps65217_dev = dev; +#endif + return 0; +} diff --git a/drivers/power/pmic/pmic_tps65218.c b/drivers/power/pmic/pmic_tps65218.c index b50953b..89fe50f 100644 --- a/drivers/power/pmic/pmic_tps65218.c +++ b/drivers/power/pmic/pmic_tps65218.c @@ -10,6 +10,7 @@ #include <power/pmic.h> #include <power/tps65218.h>
+#ifndef CONFIG_DM_I2C int tps65218_reg_read(uchar dest_reg, uchar *dest_val) { uchar read_val; @@ -84,6 +85,76 @@ int tps65218_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val,
return 0; } +#else +struct udevice *tps65218_dev __attribute__((section(".data"))) = NULL; + +int tps65218_reg_read(uchar dest_reg, uchar *dest_val) +{ + uchar read_val; + int ret; + + if (!tps65218_dev) + return -ENODEV; + + ret = dm_i2c_read(tps65218_dev, dest_reg, &read_val, 1); + if (ret) + return ret; + + *dest_val = read_val; + + return 0; +} + +int tps65218_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val, + uchar mask) +{ + uchar read_val; + uchar xor_reg; + int ret; + + if (!tps65218_dev) + return -ENODEV; + + /* + * If we are affecting only a bit field, read dest_reg and apply the + * mask + */ + if (mask != TPS65218_MASK_ALL_BITS) { + ret = dm_i2c_read(tps65218_dev, dest_reg, &read_val, 1); + if (ret) + return ret; + + read_val &= (~mask); + read_val |= (dest_val & mask); + dest_val = read_val; + } + + if (prot_level > 0) { + xor_reg = dest_reg ^ TPS65218_PASSWORD_UNLOCK; + ret = dm_i2c_write(tps65218_dev, TPS65218_PASSWORD, &xor_reg, + 1); + if (ret) + return ret; + } + + ret = dm_i2c_write(tps65218_dev, dest_reg, &dest_val, 1); + if (ret) + return ret; + + if (prot_level == TPS65218_PROT_LEVEL_2) { + ret = dm_i2c_write(tps65218_dev, TPS65218_PASSWORD, &xor_reg, + 1); + if (ret) + return ret; + + ret = dm_i2c_write(tps65218_dev, dest_reg, &dest_val, 1); + if (ret) + return ret; + } + + return 0; +} +#endif
/** * tps65218_voltage_update() - Function to change a voltage level, as this @@ -154,6 +225,7 @@ int tps65218_lock_fseal(void) return 0; }
+#ifndef CONFIG_DM_I2C int power_tps65218_init(unsigned char bus) { static const char name[] = "TPS65218_PMIC"; @@ -173,3 +245,19 @@ int power_tps65218_init(unsigned char bus)
return 0; } +#else +int power_tps65218_init(unsigned char bus) +{ + struct udevice *dev = NULL; + int rc; + + rc = i2c_get_chip_for_busnum(bus, TPS65218_CHIP_PM, 1, &dev); + if (rc) + return rc; + rc = dm_i2c_probe_device(dev); + if (rc) + return rc; + tps65218_dev = dev; + return 0; +} +#endif diff --git a/drivers/power/pmic/pmic_tps65910.c b/drivers/power/pmic/pmic_tps65910.c index f4d2aa1..a062779 100644 --- a/drivers/power/pmic/pmic_tps65910.c +++ b/drivers/power/pmic/pmic_tps65910.c @@ -8,6 +8,50 @@ #include <i2c.h> #include <power/tps65910.h>
+struct udevice *tps65910_dev __attribute__((section(".data"))) = NULL; + +static inline int tps65910_read_reg(int addr, uchar *buf) +{ +#ifndef CONFIG_DM_I2C + return i2c_read(TPS65910_CTRL_I2C_ADDR, addr, 1, buf, 1); +#else + int rc; + + rc = dm_i2c_reg_read(tps65910_dev, addr); + if (rc < 0) + return rc; + *buf = (uchar)rc; + return 0; +#endif +} + +static inline int tps65910_write_reg(int addr, uchar *buf) +{ +#ifndef CONFIG_DM_I2C + return i2c_write(TPS65910_CTRL_I2C_ADDR, addr, 1, buf, 1); +#else + return dm_i2c_reg_write(tps65910_dev, addr, *buf); +#endif +} + +int power_tps65910_init(unsigned char bus) +{ +#ifdef CONFIG_DM_I2C + struct udevice *dev = NULL; + int rc; + + rc = i2c_get_chip_for_busnum(bus, TPS65910_CTRL_I2C_ADDR, 1, &dev); + + if (rc) + return rc; + rc = dm_i2c_probe_device(dev); + if (rc) + return rc; + tps65910_dev = dev; +#endif + return 0; +} + /* * tps65910_set_i2c_control() - Set the TPS65910 to be controlled via the I2C * interface. @@ -19,16 +63,14 @@ int tps65910_set_i2c_control(void) uchar buf;
/* VDD1/2 voltage selection register access by control i/f */ - ret = i2c_read(TPS65910_CTRL_I2C_ADDR, TPS65910_DEVCTRL_REG, 1, - &buf, 1); + ret = tps65910_read_reg(TPS65910_DEVCTRL_REG, &buf);
buf |= TPS65910_DEVCTRL_REG_SR_CTL_I2C_SEL_CTL_I2C;
- return i2c_write(TPS65910_CTRL_I2C_ADDR, TPS65910_DEVCTRL_REG, 1, - &buf, 1); + return tps65910_write_reg(TPS65910_DEVCTRL_REG, &buf); }
/* @@ -49,29 +91,29 @@ int tps65910_voltage_update(unsigned int module, unsigned char vddx_op_vol_sel) reg_offset = TPS65910_VDD2_OP_REG;
/* Select VDDx OP */ - ret = i2c_read(TPS65910_CTRL_I2C_ADDR, reg_offset, 1, &buf, 1); + ret = tps65910_read_reg(reg_offset, &buf); if (ret) return ret;
buf &= ~TPS65910_OP_REG_CMD_MASK;
- ret = i2c_write(TPS65910_CTRL_I2C_ADDR, reg_offset, 1, &buf, 1); + ret = tps65910_write_reg(reg_offset, &buf); if (ret) return ret;
/* Configure VDDx OP Voltage */ - ret = i2c_read(TPS65910_CTRL_I2C_ADDR, reg_offset, 1, &buf, 1); + ret = tps65910_read_reg(reg_offset, &buf); if (ret) return ret;
buf &= ~TPS65910_OP_REG_SEL_MASK; buf |= vddx_op_vol_sel;
diff --git a/drivers/power/twl4030.c b/drivers/power/twl4030.c index 5246001..42c9001 100644 --- a/drivers/power/twl4030.c +++ b/drivers/power/twl4030.c @@ -179,3 +179,42 @@ int do_poweroff(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; } #endif + +#ifdef CONFIG_DM_I2C +int twl4030_i2c_write_u8(u8 chip_no, u8 reg, u8 val) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, chip_no, 1, &dev); + if (ret) { + pr_err("unable to get I2C bus. ret %d\n", ret); + return ret; + } + ret = dm_i2c_reg_write(dev, reg, val); + if (ret) { + pr_err("writing to twl4030 failed. ret %d\n", ret); + return ret; + } + return 0; +} + +int twl4030_i2c_read_u8(u8 chip_no, u8 reg, u8 *valp) +{ + struct udevice *dev; + int ret; + + ret = i2c_get_chip_for_busnum(0, chip_no, 1, &dev); + if (ret) { + pr_err("unable to get I2C bus. ret %d\n", ret); + return ret; + } + ret = dm_i2c_reg_read(dev, reg); + if (ret < 0) { + pr_err("reading from twl4030 failed. ret %d\n", ret); + return ret; + } + *valp = (u8)ret; + return 0; +} +#endif diff --git a/include/palmas.h b/include/palmas.h index 229de53..20c7e48 100644 --- a/include/palmas.h +++ b/include/palmas.h @@ -117,6 +117,7 @@ #define BB_VSEL_VBAT (3 << 1) #define BB_CHRG_EN (1 << 0)
+#ifndef CONFIG_DM_I2C /* * Functions to read and write from TPS659038/TWL6035/TWL6037 * or other Palmas family of TI PMICs @@ -130,6 +131,10 @@ static inline int palmas_i2c_read_u8(u8 chip_no, u8 reg, u8 *val) { return i2c_read(chip_no, reg, 1, val, 1); } +#else +int palmas_i2c_write_u8(u8 chip_no, u8 reg, u8 val); +int palmas_i2c_read_u8(u8 chip_no, u8 reg, u8 *val); +#endif
void palmas_init_settings(void); int palmas_mmc1_poweron_ldo(uint ldo_volt, uint ldo_ctrl, uint voltage); diff --git a/include/power/tps65217.h b/include/power/tps65217.h index 00fbab8..669a94a 100644 --- a/include/power/tps65217.h +++ b/include/power/tps65217.h @@ -80,6 +80,8 @@ enum { #define TPS65217_PWR_SRC_USB_BITMASK 0x4 #define TPS65217_PWR_SRC_AC_BITMASK 0x8
+int power_tps65217_init(unsigned char bus); + int tps65217_reg_read(uchar src_reg, uchar *src_val); int tps65217_reg_write(uchar prot_level, uchar dest_reg, uchar dest_val, uchar mask); diff --git a/include/power/tps65910.h b/include/power/tps65910.h index 48e0b2c..21b2a21 100644 --- a/include/power/tps65910.h +++ b/include/power/tps65910.h @@ -72,6 +72,7 @@ enum { #define TPS65910_DEVCTRL_REG_SR_CTL_I2C_SEL_SR_I2C (0x0 << 4) #define TPS65910_DEVCTRL_REG_SR_CTL_I2C_SEL_CTL_I2C (0x1 << 4)
+int power_tps65910_init(unsigned char bus); int tps65910_set_i2c_control(void); int tps65910_voltage_update(unsigned int module, unsigned char vddx_op_vol_sel); #endif /* __POWER_TPS65910_H__ */ diff --git a/include/twl4030.h b/include/twl4030.h index 46a9306..c27ad61 100644 --- a/include/twl4030.h +++ b/include/twl4030.h @@ -648,6 +648,7 @@ * examples are TWL4030_PM_RECEIVER_VMMC1_DEV_GRP and * TWL4030_LED_LEDEN. */ +#ifndef CONFIG_DM_I2C static inline int twl4030_i2c_write_u8(u8 chip_no, u8 reg, u8 val) { return i2c_write(chip_no, reg, 1, &val, 1); @@ -657,7 +658,10 @@ static inline int twl4030_i2c_read_u8(u8 chip_no, u8 reg, u8 *val) { return i2c_read(chip_no, reg, 1, val, 1); } - +#else +int twl4030_i2c_write_u8(u8 chip_no, u8 reg, u8 val); +int twl4030_i2c_read_u8(u8 chip_no, u8 reg, u8 *val); +#endif /* * Power */
The EEPROM reading in the board detection code is done through legacy I2C functions which on platforms using DM_I2C this functionality is provided via the CONFIG_DM_I2C_COMPAT layer. To allow newer platforms to use the board detection code without relying on CONFIG_DM_I2C_COMPAT go ahead and add an I2C handling implementation that directly uses the I2C DM functionality.
board/ti/common/board_detect.c | 54 ++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 52 insertions(+), 2 deletions(-)
diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index c475f10..085e732 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -50,6 +50,7 @@ int __maybe_unused ti_i2c_set_alen(int bus_addr, int dev_addr, int alen) } #endif
+#if !defined(CONFIG_DM_I2C) || defined(CONFIG_DM_I2C_COMPAT) /** * ti_i2c_eeprom_init - Initialize an i2c bus and probe for a device * @i2c_bus: i2c bus number to initialize @@ -94,6 +95,7 @@ static int __maybe_unused ti_i2c_eeprom_read(int dev_addr, int offset,
return i2c_read(dev_addr, offset, alen, ep, epsize); } +#endif
/** * ti_eeprom_string_cleanup() - Handle eeprom programming errors @@ -122,9 +124,57 @@ __weak void gpi2c_init(void) static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr, u32 header, u32 size, uint8_t *ep) { - u32 byte, hdr_read; + u32 hdr_read; int rc;
+#if defined(CONFIG_DM_I2C) && !defined(CONFIG_DM_I2C_COMPAT) + struct udevice *dev; + struct udevice *bus; + + rc = uclass_get_device_by_seq(UCLASS_I2C, bus_addr, &bus); + if (rc) + return rc; + rc = i2c_get_chip(bus, dev_addr, 1, &dev); + if (rc) + return rc; + + /* + * Read the header first then only read the other contents. + */ + rc = i2c_set_chip_offset_len(dev, 2); + if (rc) + return rc; + + rc = dm_i2c_read(dev, 0, (uint8_t *)&hdr_read, 4); + if (rc) + return rc; + + /* Corrupted data??? */ + if (hdr_read != header) { + rc = dm_i2c_read(dev, 0, (uint8_t *)&hdr_read, 4); + /* + * read the eeprom header using i2c again, but use only a + * 1 byte address (some legacy boards need this..) + */ + if (rc) { + rc = i2c_set_chip_offset_len(dev, 1); + if (rc) + return rc; + + rc = dm_i2c_read(dev, 0, (uint8_t *)&hdr_read, 4); + } + if (rc) + return rc; + } + if (hdr_read != header) + return -1; + + rc = dm_i2c_read(dev, 0, ep, size); + if (rc) + return rc; +#else + u32 byte; + gpi2c_init(); rc = ti_i2c_eeprom_init(bus_addr, dev_addr); if (rc) @@ -168,7 +218,7 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr, rc = i2c_read(dev_addr, 0x0, byte, ep, size); if (rc) return rc; - +#endif return 0; }
CONFIG_I2C_COMPAT is currently enabled in ti_armv7_common.h Let us use the Kconfig option instead so that any change to CONFIG_I2C_COMPAT in ti_armv7_common.h doesn't break this platform.
configs/am335x_pdu001_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am335x_pdu001_defconfig b/configs/am335x_pdu001_defconfig index a666318..6e66e68 100644 --- a/configs/am335x_pdu001_defconfig +++ b/configs/am335x_pdu001_defconfig @@ -38,6 +38,7 @@ CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y +CONFIG_DM_I2C_COMPAT=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_SDHCI=y CONFIG_PINCTRL=y
Hello Jean-Jacques,
As I can't find CONFIG_I2C_COMPAT anywhere I guess it is a typo and you had meant CONFIG_DM_I2C_COMPAT.
This is neither required nor wanted. CONFIG_DM_I2C_COMPAT is _undefined_ in file pdu001.h, from which I quote lines 15-19:
--- /* No more need for I2C legacy compatibility for this board. * CONFIG_DM_I2C_COMPAT is defined in ti_armv7_common.h. See the comment there * for the right moment to delete the following line. */ #undef CONFIG_DM_I2C_COMPAT ---
Once CONFIG_DM_I2C_COMPAT is removed from ti_armv7_common.h the above #undef could be removed as well.
regards, Felix
Hi Felix,
On 05/10/2018 14:25, Felix Brack wrote:
Hello Jean-Jacques,
- CONFIG_DM_I2C_COMPAT is defined in ti_armv7_common.h. See the comment
there
- for the right moment to delete the following line.
Nevertheless there is a call to i2c_init() in get_dpll_ddr_params() (board.c:212). I'll remove this call in v2 and DM_I2C_COMPAT from config file
regards, Felix
Hello Jean-Jacques,
On 05.10.2018 15:09, Jean-Jacques Hiblot wrote:
Hi Felix,
Hello Jean-Jacques,
Correct, looks like a leftover. I have just tested and can confirm that the board runs fine without the call to i2c_init().
Yes, many thanks for your work!
Felix
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C API when DM_I2C is used. The goal is to eventually remove DM_I2C_COMPAT when all I2C "clients" have been migrated to use the DM API. This a step in that direction for the TI based platforms. Build tested with buildman: buildman -dle am33xx ti omap3 omap4 omap5 davinci keystone
boot tested with: am335x_evm, am335x_boneblack, am335x_boneblack_vboot (DM version), am57xx_evm, dra7xx_evm, k2g_evm, am437x_evm
arch/arm/mach-keystone/ddr3_spd.c | 7 ++++ arch/arm/mach-omap2/am33xx/clk_synthesizer.c | 56 +++++++++++++++++++++----- arch/arm/mach-omap2/clocks-common.c | 2 + board/ti/am335x/board.c | 17 +++++++- board/ti/am335x/mux.c | 14 +++++++ board/ti/am43xx/board.c | 35 +++++++++++++--- board/ti/am57xx/board.c | 29 +++++++++++++- board/ti/common/board_detect.c | 60 ++-------------------------- board/ti/ks2_evm/board_k2g.c | 11 +++++ include/configs/am43xx_evm.h | 2 + include/configs/ti_armv7_common.h | 18 +-------- 11 files changed, 159 insertions(+), 92 deletions(-)
diff --git a/arch/arm/mach-keystone/ddr3_spd.c b/arch/arm/mach-keystone/ddr3_spd.c index 2613092..6eee9ad 100644 --- a/arch/arm/mach-keystone/ddr3_spd.c +++ b/arch/arm/mach-keystone/ddr3_spd.c @@ -403,6 +403,7 @@ static void init_ddr3param(struct ddr3_spd_cb *spd_cb, static int ddr3_read_spd(ddr3_spd_eeprom_t *spd_params) { int ret; +#ifndef CONFIG_DM_I2C int old_bus;
i2c_init(CONFIG_SYS_DAVINCI_I2C_SPEED, CONFIG_SYS_DAVINCI_I2C_SLAVE); @@ -413,7 +414,13 @@ static int ddr3_read_spd(ddr3_spd_eeprom_t *spd_params) ret = i2c_read(0x53, 0, 1, (unsigned char *)spd_params, 256);
i2c_set_bus_num(old_bus); +#else + struct udevice *dev;
+ ret = i2c_get_chip_for_busnum(1, 0x53, 1, &dev); + if (!ret) + ret = dm_i2c_read(dev, 0, (unsigned char *)spd_params, 256); +#endif if (ret) { printf("Cannot read DIMM params\n"); return 1; diff --git a/arch/arm/mach-omap2/am33xx/clk_synthesizer.c b/arch/arm/mach-omap2/am33xx/clk_synthesizer.c index 0e7ad1d..ff1bfaf 100644 --- a/arch/arm/mach-omap2/am33xx/clk_synthesizer.c +++ b/arch/arm/mach-omap2/am33xx/clk_synthesizer.c @@ -14,6 +14,7 @@
/** * clk_synthesizer_reg_read - Read register from synthesizer. + * dev: i2c bus device (not used if CONFIG_DM_I2C is not set) * @addr: addr within the i2c device * buf: Buffer to which value is to be read. * @@ -21,13 +22,14 @@ * be send along with enabling byte read more, and then read can happen. * Returns 0 on success */ -static int clk_synthesizer_reg_read(int addr, uint8_t *buf) +static int clk_synthesizer_reg_read(struct udevice *dev, int addr, u8 *buf) { int rc;
/* Enable Bye read */ addr = addr | CLK_SYNTHESIZER_BYTE_MODE;
+#ifndef CONFIG_DM_I2C /* Send the command byte */ rc = i2c_write(CLK_SYNTHESIZER_I2C_ADDR, addr, 1, buf, 1); if (rc) @@ -35,26 +37,46 @@ static int clk_synthesizer_reg_read(int addr, uint8_t *buf)
/* Read the Data */ return i2c_read(CLK_SYNTHESIZER_I2C_ADDR, addr, 1, buf, 1); +#else + /* Send the command byte */ + rc = dm_i2c_reg_write(dev, addr, *buf); + if (rc) + printf("Failed to send command to clock synthesizer\n"); + + /* Read the Data */ + rc = dm_i2c_reg_read(dev, addr); + if (rc < 0) + return rc; + + *buf = (u8)rc; + return 0; +#endif + }
/** * clk_synthesizer_reg_write - Write a value to register in synthesizer. + * dev: i2c bus device (not used if CONFIG_DM_I2C is not set) * @addr: addr within the i2c device * val: Value to be written in the addr. * * Enable the byte read mode in the address and start the i2c transfer. * Returns 0 on success */ -static int clk_synthesizer_reg_write(int addr, uint8_t val) +static int clk_synthesizer_reg_write(struct udevice *dev, int addr, u8 val) { - uint8_t cmd[2]; + u8 cmd[2]; int rc = 0;
/* Enable byte write */ cmd[0] = addr | CLK_SYNTHESIZER_BYTE_MODE; cmd[1] = val;
+#ifndef CONFIG_DM_I2C rc = i2c_write(CLK_SYNTHESIZER_I2C_ADDR, addr, 1, cmd, 2); +#else + rc = dm_i2c_write(dev, addr, cmd, 2); +#endif if (rc) printf("Clock synthesizer reg write failed at addr = 0x%x\n", addr); @@ -72,30 +94,42 @@ static int clk_synthesizer_reg_write(int addr, uint8_t val) int setup_clock_synthesizer(struct clk_synth *data) { int rc; - uint8_t val; - + u8 val = 0; + struct udevice *dev = NULL; +#ifndef CONFIG_DM_I2C rc = i2c_probe(CLK_SYNTHESIZER_I2C_ADDR); if (rc) { printf("i2c probe failed at address 0x%x\n", CLK_SYNTHESIZER_I2C_ADDR); return rc; } - - rc = clk_synthesizer_reg_read(CLK_SYNTHESIZER_ID_REG, &val); +#else + rc = i2c_get_chip_for_busnum(0, CLK_SYNTHESIZER_I2C_ADDR, 1, &dev); + if (rc) { + printf("failed to get device for synthesizer at address 0x%x\n", + CLK_SYNTHESIZER_I2C_ADDR); + return rc; + } +#endif + rc = clk_synthesizer_reg_read(dev, CLK_SYNTHESIZER_ID_REG, &val); if (val != data->id) return rc;
/* Crystal Load capacitor selection */ - rc = clk_synthesizer_reg_write(CLK_SYNTHESIZER_XCSEL, data->capacitor); + rc = clk_synthesizer_reg_write(dev, CLK_SYNTHESIZER_XCSEL, + data->capacitor); if (rc) return rc; - rc = clk_synthesizer_reg_write(CLK_SYNTHESIZER_MUX_REG, data->mux); + rc = clk_synthesizer_reg_write(dev, CLK_SYNTHESIZER_MUX_REG, + data->mux); if (rc) return rc; - rc = clk_synthesizer_reg_write(CLK_SYNTHESIZER_PDIV2_REG, data->pdiv2); + rc = clk_synthesizer_reg_write(dev, CLK_SYNTHESIZER_PDIV2_REG, + data->pdiv2); if (rc) return rc; - rc = clk_synthesizer_reg_write(CLK_SYNTHESIZER_PDIV3_REG, data->pdiv3); + rc = clk_synthesizer_reg_write(dev, CLK_SYNTHESIZER_PDIV3_REG, + data->pdiv3); if (rc) return rc;
diff --git a/arch/arm/mach-omap2/clocks-common.c b/arch/arm/mach-omap2/clocks-common.c index 790548e..5932d69 100644 --- a/arch/arm/mach-omap2/clocks-common.c +++ b/arch/arm/mach-omap2/clocks-common.c @@ -909,6 +909,7 @@ void prcm_init(void) enable_basic_uboot_clocks(); }
+#if !defined(CONFIG_DM_I2C) void gpi2c_init(void) { static int gpi2c = 1; @@ -919,3 +920,4 @@ void gpi2c_init(void) gpi2c = 0; } } +#endif diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 1384525..d67f94a 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -70,8 +70,9 @@ static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; void do_board_detect(void) { enable_i2c0_pin_mux(); +#ifndef CONFIG_DM_I2C i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE); - +#endif if (ti_i2c_eeprom_am_get(CONFIG_EEPROM_BUS_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS)) printf("ti_i2c_eeprom_init failed\n"); @@ -328,8 +329,14 @@ static void scale_vcores_bone(int freq) if (board_is_bone() && !strncmp(board_ti_get_rev(), "00A1", 4)) return;
+#ifndef CONFIG_DM_I2C if (i2c_probe(TPS65217_CHIP_PM)) return; +#else + if (power_tps65217_init(0)) + return; +#endif +
/* * On Beaglebone White we need to ensure we have AC power @@ -421,9 +428,13 @@ void scale_vcores_generic(int freq) * 1.10V. For MPU voltage we need to switch based on * the frequency we are running at. */ +#ifndef CONFIG_DM_I2C if (i2c_probe(TPS65910_CTRL_I2C_ADDR)) return; - +#else + if (power_tps65910_init(0)) + return; +#endif /* * Depending on MPU clock and PG we will need a different * VDD to drive at that speed. @@ -451,8 +462,10 @@ void gpi2c_init(void)
if (first_time) { enable_i2c0_pin_mux(); +#ifndef CONFIG_DM_I2C i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE); +#endif first_time = false; } } diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index 41333f9..5040e34 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -329,12 +329,26 @@ static unsigned short detect_daughter_board_profile(void) { unsigned short val;
+#ifndef CONFIG_DM_I2C if (i2c_probe(I2C_CPLD_ADDR)) return PROFILE_NONE;
if (i2c_read(I2C_CPLD_ADDR, CFG_REG, 1, (unsigned char *)(&val), 2)) return PROFILE_NONE; +#else + struct udevice *dev = NULL; + int rc;
+ rc = i2c_get_chip_for_busnum(0, I2C_CPLD_ADDR, 1, &dev); + if (rc) + return PROFILE_NONE; + rc = dm_i2c_probe_device(dev); + if (rc) + return PROFILE_NONE; + rc = dm_i2c_read(dev, CFG_REG, (unsigned char *)(&val), 2); + if (rc) + return PROFILE_NONE; +#endif return (1 << (val & PROFILE_MASK)); }
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 2a59b06..5790196 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -43,6 +43,8 @@ static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; #ifdef CONFIG_TI_I2C_BOARD_DETECT void do_board_detect(void) { + /* Ensure I2C is initialized for EEPROM access*/ + gpi2c_init(); if (ti_i2c_eeprom_am_get(CONFIG_EEPROM_BUS_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS)) printf("ti_i2c_eeprom_init failed\n"); @@ -386,8 +388,13 @@ void scale_vcores_generic(u32 m) { int mpu_vdd, ddr_volt;
+#ifndef CONFIG_DM_I2C if (i2c_probe(TPS65218_CHIP_PM)) return; +#else + if (power_tps65218_init(0)) + return; +#endif
switch (m) { case 1000: @@ -439,8 +446,13 @@ void scale_vcores_idk(u32 m) { int mpu_vdd;
+#ifndef CONFIG_DM_I2C if (i2c_probe(TPS62362_I2C_ADDR)) return; +#else + if (power_tps62362_init(0)) + return; +#endif
switch (m) { case 1000: @@ -462,14 +474,12 @@ void scale_vcores_idk(u32 m) puts("Unknown MPU clock, not scaling\n"); return; } - /* Set VDD_MPU voltage */ if (tps62362_voltage_update(TPS62362_SET3, mpu_vdd)) { printf("%s failure\n", __func__); return; } } - void gpi2c_init(void) { /* When needed to be invoked prior to BSS initialization */ @@ -477,8 +487,10 @@ void gpi2c_init(void)
if (first_time) { enable_i2c0_pin_mux(); +#ifndef CONFIG_DM_I2C i2c_init(CONFIG_SYS_OMAP24_I2C_SPEED, CONFIG_SYS_OMAP24_I2C_SLAVE); +#endif first_time = false; } } @@ -497,6 +509,7 @@ void scale_vcores(void) scale_vcores_idk(mpu_params->m); else scale_vcores_generic(mpu_params->m); + }
void set_uart_mux_conf(void) @@ -614,18 +627,30 @@ void sdram_init(void) /* setup board specific PMIC */ int power_init_board(void) { + int rc; +#ifndef CONFIG_DM_I2C struct pmic *p; - +#endif if (board_is_idk()) { - power_tps62362_init(I2C_PMIC); + rc = power_tps62362_init(0); +#ifndef CONFIG_DM_I2C p = pmic_get("TPS62362"); if (p && !pmic_probe(p)) puts("PMIC: TPS62362\n"); +#else + if (!rc) + puts("PMIC: TPS62362\n"); +#endif } else { - power_tps65218_init(I2C_PMIC); + rc = power_tps65218_init(0); +#ifndef CONFIG_DM_I2C p = pmic_get("TPS65218_PMIC"); if (p && !pmic_probe(p)) puts("PMIC: TPS65218\n"); +#else + if (!rc) + puts("PMIC: TPS65218\n"); +#endif }
return 0; diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 177a324..355ea55 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -623,7 +623,7 @@ void am57x_idk_lcd_detect(void) { int r = -ENODEV; char *idk_lcd = "no"; - uint8_t buf = 0; + u8 buf = 0;
/* Only valid for IDKs */ if (board_is_x15() || board_is_am572x_evm()) @@ -633,6 +633,7 @@ void am57x_idk_lcd_detect(void) if (board_is_am571x_idk() && !am571x_idk_needs_lcd()) goto out;
+#ifndef CONFIG_DM_I2C r = i2c_set_bus_num(OSD_TS_FT_BUS_ADDRESS); if (r) { printf("%s: Failed to set bus address to %d: %d\n", @@ -657,6 +658,32 @@ void am57x_idk_lcd_detect(void) OSD_TS_FT_REG_ID, r); goto out; } +#else + struct udevice *dev; + + r = i2c_get_chip_for_busnum(OSD_TS_FT_BUS_ADDRESS, + OSD_TS_FT_CHIP_ADDRESS, 1, &dev); + if (r) { + printf("%s: Failed to get I2C device %d/%d (ret %d)\n", + __func__, OSD_TS_FT_BUS_ADDRESS, OSD_TS_FT_CHIP_ADDRESS, + r); + /* AM572x IDK has no explicit settings for optional LCD kit */ + if (board_is_am571x_idk()) + printf("%s: Touch screen detect failed: %d!\n", + __func__, r); + goto out; + } + + /* Read FT ID */ + r = dm_i2c_reg_read(dev, OSD_TS_FT_REG_ID); + if (r < 0) { + printf("%s: Touch screen ID read %d:0x%02x[0x%02x] failed:%d\n", + __func__, OSD_TS_FT_BUS_ADDRESS, OSD_TS_FT_CHIP_ADDRESS, + OSD_TS_FT_REG_ID, r); + goto out; + } + buf = (u8)r; +#endif
switch (buf) { case OSD_TS_FT_ID_5606: diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index 085e732..e258e22 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -14,43 +14,7 @@
#include "board_detect.h"
-#if defined(CONFIG_DM_I2C_COMPAT) -/** - * ti_i2c_set_alen - Set chip's i2c address length - * @bus_addr - I2C bus number - * @dev_addr - I2C eeprom id - * @alen - I2C address length in bytes - * - * DM_I2C by default sets the address length to be used to 1. This - * function allows this address length to be changed to match the - * eeprom used for board detection. - */ -int __maybe_unused ti_i2c_set_alen(int bus_addr, int dev_addr, int alen) -{ - struct udevice *dev; - struct udevice *bus; - int rc; - - rc = uclass_get_device_by_seq(UCLASS_I2C, bus_addr, &bus); - if (rc) - return rc; - rc = i2c_get_chip(bus, dev_addr, 1, &dev); - if (rc) - return rc; - rc = i2c_set_chip_offset_len(dev, alen); - if (rc) - return rc; - - return 0; -} -#else -int __maybe_unused ti_i2c_set_alen(int bus_addr, int dev_addr, int alen) -{ - return 0; -} -#endif - -#if !defined(CONFIG_DM_I2C) || defined(CONFIG_DM_I2C_COMPAT) +#if !defined(CONFIG_DM_I2C) /** * ti_i2c_eeprom_init - Initialize an i2c bus and probe for a device * @i2c_bus: i2c bus number to initialize @@ -83,17 +47,7 @@ static int __maybe_unused ti_i2c_eeprom_init(int i2c_bus, int dev_addr) static int __maybe_unused ti_i2c_eeprom_read(int dev_addr, int offset, uchar *ep, int epsize) { - int bus_num, rc, alen; - - bus_num = i2c_get_bus_num(); - - alen = 2; - - rc = ti_i2c_set_alen(bus_num, dev_addr, alen); - if (rc) - return rc; - - return i2c_read(dev_addr, offset, alen, ep, epsize); + return i2c_read(dev_addr, offset, 2, ep, epsize); } #endif
@@ -127,7 +81,7 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr, u32 hdr_read; int rc;
-#if defined(CONFIG_DM_I2C) && !defined(CONFIG_DM_I2C_COMPAT) +#if defined(CONFIG_DM_I2C) struct udevice *dev; struct udevice *bus;
@@ -185,10 +139,6 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr, */ byte = 2;
- rc = ti_i2c_set_alen(bus_addr, dev_addr, byte); - if (rc) - return rc; - rc = i2c_read(dev_addr, 0x0, byte, (uint8_t *)&hdr_read, 4); if (rc) return rc; @@ -202,10 +152,6 @@ static int __maybe_unused ti_i2c_eeprom_get(int bus_addr, int dev_addr, */ byte = 1; if (rc) { - rc = ti_i2c_set_alen(bus_addr, dev_addr, byte); - if (rc) - return rc; - rc = i2c_read(dev_addr, 0x0, byte, (uint8_t *)&hdr_read, 4); } diff --git a/board/ti/ks2_evm/board_k2g.c b/board/ti/ks2_evm/board_k2g.c index 9bc94fb..f3a42f1 100644 --- a/board/ti/ks2_evm/board_k2g.c +++ b/board/ti/ks2_evm/board_k2g.c @@ -251,6 +251,7 @@ int board_fit_config_name_match(const char *name) #if defined(CONFIG_DTB_RESELECT) static int k2g_alt_board_detect(void) { +#ifndef CONFIG_DM_I2C int rc;
rc = i2c_set_bus_num(1); @@ -260,7 +261,17 @@ static int k2g_alt_board_detect(void) rc = i2c_probe(K2G_GP_AUDIO_CODEC_ADDRESS); if (rc) return rc; +#else + struct udevice *bus, *dev; + int rc;
+ rc = uclass_get_device_by_seq(UCLASS_I2C, 1, &bus); + if (rc) + return rc; + rc = dm_i2c_probe(bus, K2G_GP_AUDIO_CODEC_ADDRESS, 0, &dev); + if (rc) + return rc; +#endif ti_i2c_eeprom_am_set("66AK2GGP", "1.0X");
return 0; diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 9d0d342..ed71f4c 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -27,8 +27,10 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2
/* Power */ +#ifndef CONFIG_DM_I2C #define CONFIG_POWER #define CONFIG_POWER_I2C +#endif #define CONFIG_POWER_TPS65218 #define CONFIG_POWER_TPS62362
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 55b9b45..4aca3f9 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -74,24 +74,10 @@ /* Timer information. */ #define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */
-/* - * Disable DM_* for SPL build and can be re-enabled after adding - * DM support in SPL - */ -#ifdef CONFIG_SPL_BUILD -#undef CONFIG_DM_I2C -#endif - -/* I2C IP block */ +/* If DM_I2C, enable non-DM I2C support */ +#if !defined(CONFIG_DM_I2C) #define CONFIG_I2C -#ifndef CONFIG_DM_I2C #define CONFIG_SYS_I2C -#else -/* - * Enable CONFIG_DM_I2C_COMPAT temporarily until all the i2c client - * devices are adopted to DM - */ -#define CONFIG_DM_I2C_COMPAT #endif
am57xx configs uses DM_I2C both in SPL and u-boot. Remove code for non-DM I2C support.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
board/ti/am57xx/board.c | 36 +++--------------------------------- 1 file changed, 3 insertions(+), 33 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 355ea55..9738beb 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -623,7 +623,7 @@ void am57x_idk_lcd_detect(void) { int r = -ENODEV; char *idk_lcd = "no"; - u8 buf = 0; + struct udevice *dev;
/* Only valid for IDKs */ if (board_is_x15() || board_is_am572x_evm()) @@ -633,34 +633,6 @@ void am57x_idk_lcd_detect(void) if (board_is_am571x_idk() && !am571x_idk_needs_lcd()) goto out;
-#ifndef CONFIG_DM_I2C - r = i2c_set_bus_num(OSD_TS_FT_BUS_ADDRESS); - if (r) { - printf("%s: Failed to set bus address to %d: %d\n", - __func__, OSD_TS_FT_BUS_ADDRESS, r); - goto out; - } - r = i2c_probe(OSD_TS_FT_CHIP_ADDRESS); - if (r) { - /* AM572x IDK has no explicit settings for optional LCD kit */ - if (board_is_am571x_idk()) { - printf("%s: Touch screen detect failed: %d!\n", - __func__, r); - } - goto out; - } - - /* Read FT ID */ - r = i2c_read(OSD_TS_FT_CHIP_ADDRESS, OSD_TS_FT_REG_ID, 1, &buf, 1); - if (r) { - printf("%s: Touch screen ID read %d:0x%02x[0x%02x] failed:%d\n", - __func__, OSD_TS_FT_BUS_ADDRESS, OSD_TS_FT_CHIP_ADDRESS, - OSD_TS_FT_REG_ID, r); - goto out; - } -#else - struct udevice *dev; - r = i2c_get_chip_for_busnum(OSD_TS_FT_BUS_ADDRESS, OSD_TS_FT_CHIP_ADDRESS, 1, &dev); if (r) { @@ -682,10 +654,8 @@ void am57x_idk_lcd_detect(void) OSD_TS_FT_REG_ID, r); goto out; } - buf = (u8)r; -#endif
- switch (buf) { + switch (r) { case OSD_TS_FT_ID_5606: idk_lcd = "osd101t2045"; break; @@ -694,7 +664,7 @@ void am57x_idk_lcd_detect(void) break; default: printf("%s: Unidentifed Touch screen ID 0x%02x\n", - __func__, buf); + __func__, r); /* we will let default be "no lcd" */ } out:
This is required to take advantage of MULTI_DTB_FIT before relocation. If it is too low, DM will be initialized only after relocation has taken place. That is too late for the DRA7 because I2C DM is used before the relocation to setup the voltages required, among other things, to properly initialize the DRAM.
configs/dra7xx_evm_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 14adaab..9546b5e 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_OMAP54XX=y CONFIG_TARGET_DRA7XX_EVM=y CONFIG_SPL=y
In some cases it may be useful to be able to change the fdt we have been using and use another one instead. For example, the TI platforms uses an EEPROM to store board information and, based on the type of board, different dtbs are used by the SPL. When DM_I2C is used, a first dtb must be used before the I2C is initialized and only then the final dtb can be selected. To speed up the process and reduce memory usage, introduce a new function fdtdec_setup_best_match() that re-use the DTBs loaded in memory by fdtdec_setup() to select the best match.
include/asm-generic/global_data.h | 4 ++++ include/fdtdec.h | 17 +++++++++++++++++ lib/fdtdec.c | 38 +++++++++++++++++++++++++++++++++++++- 3 files changed, 58 insertions(+), 1 deletion(-)
diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index c83fc01..49287fa 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -77,6 +77,10 @@ typedef struct global_data { #ifdef CONFIG_OF_LIVE struct device_node *of_root; #endif + +#if CONFIG_IS_ENABLED(MULTI_DTB_FIT) + const void *multi_dtb_fit; +#endif struct jt_funcs *jt; /* jump table */ char env_buf[32]; /* buffer for env_get() before reloc. */ #ifdef CONFIG_TRACE diff --git a/include/fdtdec.h b/include/fdtdec.h index 83be064..2cb3da2 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -996,6 +996,23 @@ int fdtdec_setup_memory_banksize(void); */ int fdtdec_setup(void);
+#if CONFIG_IS_ENABLED(MULTI_DTB_FIT) +/** + * fdtdec_resetup() - Set up the device tree ready for use again. + * + * The main difference with fdtdec_setup() is that it returns if the fdt has + * changed because a better match has been found. + * This is typically used for boards that rely on a DM driver to detect the + * board type. + * + * @param rescan Return a flag indicating that fdt has changed and rescaning the + * fdt is required. + * + * @return 0 if OK, -ve on error + */ +int fdtdec_resetup(int *rescan); +#endif + /** * Board-specific FDT initialization. Returns the address to a device tree blob. * Called when CONFIG_OF_BOARD is defined, or if CONFIG_OF_SEPARATE is defined diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 74196ce..3b80bd4 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1353,14 +1353,50 @@ int fdtdec_setup(void) * If so, pick the most relevant */ fdt_blob = locate_dtb_in_fit(gd->fdt_blob); - if (fdt_blob) + if (fdt_blob) { + gd->multi_dtb_fit = gd->fdt_blob; gd->fdt_blob = fdt_blob; + } + # endif #endif
return fdtdec_prepare_fdt(); }
+#if CONFIG_IS_ENABLED(MULTI_DTB_FIT) +int fdtdec_resetup(int *rescan) +{ + void *fdt_blob; + + /* + * If the current DTB is part of a compressed FIT image, + * try to locate the best match from the uncompressed + * FIT image stillpresent there. Save the time and space + * required to uncompress it again. + */ + if (gd->multi_dtb_fit) { + fdt_blob = locate_dtb_in_fit(gd->multi_dtb_fit); + + if (fdt_blob == gd->fdt_blob) { + /* + * The best match did not change. no need to tear down + * the DM and rescan the fdt. + */ + *rescan = 0; + return 0; + } + + *rescan = 1; + gd->fdt_blob = fdt_blob; + return fdtdec_prepare_fdt(); + } + + *rescan = 1; + return fdtdec_setup(); +} +#endif + #ifdef CONFIG_NR_DRAM_BANKS int fdtdec_decode_ram_size(const void *blob, const char *area, int board_id, phys_addr_t *basep, phys_size_t *sizep, bd_t *bd)
drivers/core/Kconfig | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index e8ba20c..046b87a 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -57,13 +57,21 @@ config DM_DEVICE_REMOVE default y help We can save some code space by dropping support for removing a - device. This is not normally required in SPL, so by default this - option is disabled for SPL. + device.
Note that this may have undesirable results in the USB subsystem as it causes unplugged devices to linger around in the dm-tree, and it causes USB host controllers to not be stopped when booting the OS.
+config SPL_DM_DEVICE_REMOVE + bool "Support device removal in SPL" + depends on SPL_DM + default n + help + We can save some code space by dropping support for removing a + device. This is not normally required in SPL, so by default this + option is disabled for SPL. + config DM_STDIO bool "Support stdio registration" depends on DM
To reset the DM after a new dtb is loaded, we need to call dm_uninit() and then dm_init(). This fails however because gd->dm_root is not nullified by dm_uninit(). Fixing it by setting gd->dm_root in dm_uninit().
drivers/core/root.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/core/root.c b/drivers/core/root.c index 47d10b8..ce59697 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -187,6 +187,7 @@ int dm_uninit(void) { device_remove(dm_root(), DM_REMOVE_NORMAL); device_unbind(dm_root()); + gd->dm_root = NULL;
return 0; }
The DRA7 platforms requires that the dtb used in the SPL really matches the platform to have the best MMC performances. To detect the board type/version an I2C EEPROM is read. This requires that DM is initialized before the detection. As a consequence we must reset the DM after the board detection is a new dtb would better match the platform.
arch/arm/mach-omap2/hwinit-common.c | 20 ++++++++++++++++++++ configs/dra7xx_evm_defconfig | 2 ++ 2 files changed, 22 insertions(+)
diff --git a/arch/arm/mach-omap2/hwinit-common.c b/arch/arm/mach-omap2/hwinit-common.c index d0781d7..772b4c4 100644 --- a/arch/arm/mach-omap2/hwinit-common.c +++ b/arch/arm/mach-omap2/hwinit-common.c @@ -12,6 +12,7 @@ */ #include <common.h> #include <debug_uart.h> +#include <fdtdec.h> #include <spl.h> #include <asm/arch/sys_proto.h> #include <linux/sizes.h> @@ -19,6 +20,7 @@ #include <asm/omap_common.h> #include <linux/compiler.h> #include <asm/system.h> +#include <dm/root.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -171,6 +173,10 @@ void __weak init_package_revision(void) */ void early_system_init(void) { +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_MULTI_DTB_FIT) + int ret; + int rescan; +#endif init_omap_revision(); hw_data_init(); init_package_revision(); @@ -186,6 +192,7 @@ void early_system_init(void) do_io_settings(); #endif setup_early_clocks(); + #ifdef CONFIG_SPL_BUILD /* * Save the boot parameters passed from romcode. @@ -197,6 +204,19 @@ void early_system_init(void) #endif do_board_detect();
+#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_MULTI_DTB_FIT) + /* + * Board detection has been done. + * Let us see if another dtb wouldn't be a better match + * for our board + */ + ret = fdtdec_resetup(&rescan); + if (!ret && rescan) { + dm_uninit(); + dm_init_and_scan(true); + } +#endif + vcores_init(); #ifdef CONFIG_DEBUG_UART_OMAP debug_uart_init(); diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 9546b5e..b4825a5 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -34,11 +34,13 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="dra7-evm" CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm dra76-evm" CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ=0x9000 CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y +CONFIG_SPL_DM_DEVICE_REMOVE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y
On Thu, Oct 4, 2018 at 8:48 AM Jean-Jacques Hiblot jjhiblot@ti.com wrote:
This series remove the usage of the DM_I2C_COMPAT option for all the ti platforms. It also takes this opportunity to not disable DM_I2C in the SPL.
Thanks for doing that, but I have some bad news. I started testing omap3_logic from a fresh pull of master, and I applied the entire 19 patch series. I did a distclean, then make omap3_logic, but I am getting build errors:
drivers/built-in.o: In function `dev_read_alias_seq': /home/aford/src/u-boot/include/dm/read.h:600: undefined reference to `fdtdec_get_alias_seq' scripts/Makefile.spl:357: recipe for target 'spl/u-boot-spl' failed make[1]: *** [spl/u-boot-spl] Error 1 Makefile:1534: recipe for target 'spl/u-boot-spl' failed make: *** [spl/u-boot-spl] Error 2
The good news is that the main U-Boot built, and I was able to test a few of the PMIC features (like poweroff), but I haven't had a chance to test other PMIC features (like the USB transceiver yet), but I'll do a more thorough test once SPL can correctly build.
adam
There are a couples of issues to fix:
- CMD_EEPROM does not support the DM API. Fixed by removing this option when DM_I2C is used without DM_I2C_COMPAT
- i2c_get_chip_for_busnum() does not work when OF_CONTROL is not used (as is the case with am33xx SPL).
- The I2C driver do not support DM_I2C without OF_CONTROL.
- Most of the PMIC drivers do not support the I2C DM API.
- Board detection is done prior DM initialization. Fixed by moving it after DM is initialized. That move breaks the DRA7 platforms (The fixes for that are at the last 5 patches this series)
When all this is taken care of DM_I2C_COMPAT can be removed and DM_I2C enabled in the SPL.
This has been tested with the following boards:
- am437x SK
- am335x SK
- am335x beaglebone (both DM and non-DM config)
- dra76 evm
- am572 evm
- k2g evm
Andreas Dannenberg (1): ti: common: board_detect: Allow DM I2C without CONFIG_DM_I2C_COMPAT
Jean-Jacques Hiblot (17): cmd: Kconfig: Do not include EEPROM if DM_I2C is used without DM_I2C_COMPAT dm: i2c: Add dm_i2c_probe_device() to test the presence of a chip dm: device: Allow using uclass_find_device_by_seq() without OF_CONTROL configs: am335x: am57x: dra7x: Enable CONFIG_SPL_DM_SEQ_ALIAS i2c: omap24xx_i2c: Use platdata to probe the device am335x: Register the I2C controllers if DM_I2C is used. dts: am43x: omap5: Add node for I2C in SPL omap: detect the board after DM is available power: make most tps drivers and the twl4030 driver compatible with DM_I2C configs: am335x_pdu001: Explicitly enable CONFIG_I2C_COMPAT ti: remove usage of DM_I2C_COMPAT and don't disable DM_I2C in SPL am57xx: remove non-DM I2C code configs: dra7xx-evm: increase the size of the malloc's pool before relocation lib: fdtdec: Add function re-setup the fdt more effeciently drivers: core: Add the option SPL_DM_DEVICE_REMOVE to the Kconfig drivers: core: nullify gd->dm_root after dm_uninit() dra7: Allow selecting a new dtb after board detection.
Vignesh R (1): i2c: omap24xx_i2c: Move away from SoC specific headers for reg offset
arch/arm/dts/am437x-gp-evm-u-boot.dtsi | 4 + arch/arm/dts/omap5-u-boot.dtsi | 4 + arch/arm/include/asm/arch-am33xx/i2c.h | 47 +-- arch/arm/include/asm/arch-omap3/i2c.h | 47 --- arch/arm/include/asm/arch-omap4/i2c.h | 45 --- arch/arm/include/asm/arch-omap5/i2c.h | 45 --- arch/arm/include/asm/omap_i2c.h | 24 ++ arch/arm/mach-keystone/ddr3_spd.c | 7 + arch/arm/mach-omap2/am33xx/board.c | 24 +- arch/arm/mach-omap2/am33xx/clk_synthesizer.c | 56 +++- arch/arm/mach-omap2/clocks-common.c | 2 + arch/arm/mach-omap2/hwinit-common.c | 23 +- board/ti/am335x/board.c | 17 +- board/ti/am335x/mux.c | 14 + board/ti/am43xx/board.c | 35 +- board/ti/am57xx/board.c | 25 +- board/ti/common/board_detect.c | 110 +++---- board/ti/ks2_evm/board_k2g.c | 11 + cmd/Kconfig | 1 + configs/am335x_pdu001_defconfig | 2 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/dra7xx_evm_defconfig | 4 +- configs/dra7xx_hs_evm_defconfig | 1 + configs/omap3_logic_defconfig | 1 + drivers/core/Kconfig | 12 +- drivers/core/device.c | 10 +- drivers/core/root.c | 1 + drivers/core/uclass.c | 24 ++ drivers/i2c/i2c-uclass.c | 8 + drivers/i2c/omap24xx_i2c.c | 467 ++++++++++++++++++--------- drivers/power/palmas.c | 39 +++ drivers/power/pmic/pmic_tps62362.c | 27 ++ drivers/power/pmic/pmic_tps65217.c | 47 ++- drivers/power/pmic/pmic_tps65218.c | 88 +++++ drivers/power/pmic/pmic_tps65910.c | 60 +++- drivers/power/twl4030.c | 39 +++ include/asm-generic/global_data.h | 4 + include/configs/am43xx_evm.h | 2 + include/configs/ti_armv7_common.h | 18 +- include/dm/uclass-internal.h | 13 + include/fdtdec.h | 17 + include/i2c.h | 13 + include/palmas.h | 5 + include/power/tps65217.h | 2 + include/power/tps65910.h | 1 + include/twl4030.h | 6 +- lib/fdtdec.c | 38 ++- 48 files changed, 1033 insertions(+), 459 deletions(-) create mode 100644 arch/arm/include/asm/omap_i2c.h
-- 2.7.4
Adam,
The quick fix is
--- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -79,7 +79,7 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv, * This is just a 'requested' sequence, and will be * resolved (and ->seq updated) when the device is probed. */ - if (CONFIG_IS_ENABLED(OF_CONTROL)) { + if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { if (uc->uc_drv->name && ofnode_valid(node)) dev_read_alias_seq(dev, &dev->req_seq); } else {
--- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -269,7 +269,7 @@ int uclass_find_device_by_name(enum uclass_id id, const char *name, return -ENODEV; }
-#if !CONFIG_IS_ENABLED(OF_CONTROL) +#if !CONFIG_IS_ENABLED(OF_CONTROL) || CONFIG_IS_ENABLED(OF_PLATDATA) int uclass_find_next_free_req_seq(enum uclass_id id) { struct uclass *uc;
It will be part of a v2. Thanks for catching this.
Can you also try to boot without OF_CONTROL and OF_PLATDATA (basically reverting e3b1aaa4 and 6931ab2f) ? Thanks, JJ
adam
- am437x SK
- am335x SK
- dra76 evm
- am572 evm
- k2g evm
-- 2.7.4
Hi JJ,
- am437x SK
- am335x SK
- dra76 evm
- am572 evm
- k2g evm
I triggered a Travis-CI buid[1] for this series and there are 2 build failures. Can you check?
[1] https://travis-ci.org/lokeshvutla/u-boot/builds/437487725
Thanks and regards, Lokesh
On 05/10/2018 13:59, Lokesh Vutla wrote:
Hi JJ,
- am437x SK
- am335x SK
- dra76 evm
- am572 evm
- k2g evm
Should be fixed in the v2. It passes buildman on my machine, but we may not have the same default compiler flags. Thanks, JJ
- am437x SK
- am335x SK
- dra76 evm
- am572 evm
- k2g evm
The whole series applied and
Tested-by: Adam Ford aford173@gmail.com #omap3_logic
adam
-- 2.7.4
- am437x SK
- am335x SK
- dra76 evm
- am572 evm
- k2g evm
Thanks for testing but I guess you meant that for v2 not v1 ? JJ
adam
-- 2.7.4
- am437x SK
- am335x SK
- dra76 evm
- am572 evm
- k2g evm
Sorry. I did intend that for the V2 patch. Thanks for doing that. I had started on it for the twl4030, but your implemention was a little cleaner than what I was doing.
adam
JJ
adam
-- 2.7.4
participants (5)
Adam Ford
Felix Brack
Jean-Jacques Hiblot
Lokesh Vutla
Michal Simek
