[U-Boot] [PATCH V2] mtd: uboot: Fix hanging during mtd list command
Some boards using simple NAND drivers (like omap3_logic) hang when executing the new 'mtd list' command. This patch enhances the checks for conditions that would preclude mtd_probe_devices() from operating.
Fixes: 5db66b3aee6f ("cmd: mtd: add 'mtd' command")
Suggested-by: Boris Brezillon boris.brezillon@bootlin.com Signed-off-by: Adam Ford aford173@gmail.com --- V2: Move the check for NULL mtdparts or mtdids until after the partitions have been removed.
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 6a211d52ff..7d7a11c990 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -104,7 +104,10 @@ int mtd_probe_devices(void) mtd_probe_uclass_mtd_devs();
/* Check if mtdparts/mtdids changed since last call, otherwise: exit */ - if (!strcmp(mtdparts, old_mtdparts) && !strcmp(mtdids, old_mtdids)) + if ((!mtdparts && !old_mtdparts && !mtdids && !old_mtdids) || + (mtdparts && old_mtdparts && mtdids && old_mtdids && + !strcmp(mtdparts, old_mtdparts) && + !strcmp(mtdids, old_mtdids))) return 0;
/* Update the local copy of mtdparts */ @@ -140,6 +143,10 @@ int mtd_probe_devices(void) } }
+ /* If either mtdparts or mtdids is empty, then exit */ + if (!mtdparts || !mtdids) + return 0; + /* Start the parsing by ignoring the extra 'mtdparts=' prefix, if any */ if (strstr(mtdparts, "mtdparts=")) mtdparts += 9;
^One too many spaces here.
Also, i don't think it has to do with simple/old NAND drivers vs new ones, it's more related to how the platform behaves when you access address 0 (NULL). I guess on Miquel's CPU address 0 is accessible, on yours it's not.
You can drop the blank line here.
Once my comments on the commit message are addressed, you can add
Reviewed-by: Boris Brezillon boris.brezillon@bootlin.com
- /* If either mtdparts or mtdids is empty, then exit */
- if (!mtdparts || !mtdids)
- /* Start the parsing by ignoring the extra 'mtdparts=' prefix, if any */ if (strstr(mtdparts, "mtdparts=")) mtdparts += 9;
Adam Ford
Boris Brezillon
