[PATCH] test: cmd: mbr: Fix Smatch static checker warning
This patch fixes Smatch static checker warning: test/cmd/mbr.c:243 mbr_test_run() warn: sizeof(NUMBER)?
Reported-by: Dan Carpenter dan.carpenter@linaro.org Signed-off-by: Alexander Gendin agendin@matrox.com --- test/cmd/mbr.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/test/cmd/mbr.c b/test/cmd/mbr.c index 46b78e706c..235b363290 100644 --- a/test/cmd/mbr.c +++ b/test/cmd/mbr.c @@ -240,7 +240,11 @@ static int mbr_test_run(struct unit_test_state *uts) ut_assert(ofnode_valid(node)); ut_assertok(lists_bind_fdt(gd->dm_root, node, &dev, NULL, false));
- mbr_parts_max = sizeof('\0') + 2 + + /* + * 1 byte for null character + * 2 reserved bytes + */ + mbr_parts_max = 1 + 2 + strlen(mbr_parts_header) + strlen(mbr_parts_p1) + strlen(mbr_parts_p2) +
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
* 2 reserved bytes
- mbr_parts_max = 1 + 2 + strlen(mbr_parts_header) + strlen(mbr_parts_p1) + strlen(mbr_parts_p2) +
Reported-by: Dan Carpenter dan.carpenter@linaro.org Signed-off-by: Alexander Gendin agendin@matrox.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Alexander Gendin
