[PATCH v2 00/13] x86: coral: Add support for Cr50
This series adds a driver for the Cr50 security chip and enables it on coral. This supports the 'tpm' command.
In order to make this work a few other changes are included: - Additional UCLASS_IRQ operations to support requesting and reading interrupts, using the device tree - A driver for ACPI general-purpose events
There are also a few small clean-ups to the recently landed Apollo Lake support.
This series relies on this patch:
http://patchwork.ozlabs.org/patch/1214541/
Changes in v2: - Significant rewrite of cr50 init procedure - Support use of interrupts - Update the commit message - Add new patches to handle requesting interrupts and interrupt state
Simon Glass (13): x86: Add a clock driver for Intel devices x86: apl: Use the clock driver x86: apl: Drop the I2C config in FSP-S x86: coral: Update i2c and rtc status dm: irq: Add support for interrupt controller types x86: Give each driver an IRQ type x86: itss: Add of-platdata support dm: irq: Add support for requesting interrupts x86: Add support for ACPI general-purpose events x86: coral: Add I2C and TPM device-tree definitions tpm: Add more TPM2 definitions tpm: Add a driver for H1/Cr50 x86: coral: Enable TPM
arch/sandbox/dts/test.dts | 5 +- arch/sandbox/include/asm/test.h | 4 + arch/x86/Kconfig | 33 + arch/x86/cpu/Makefile | 1 + arch/x86/cpu/acpi_gpe.c | 85 +++ arch/x86/cpu/apollolake/Kconfig | 4 + arch/x86/cpu/apollolake/fsp_s.c | 62 +- arch/x86/cpu/apollolake/itss.c | 12 +- arch/x86/cpu/i386/interrupt.c | 3 +- arch/x86/cpu/irq.c | 3 +- arch/x86/dts/chromebook_coral.dts | 93 +++ configs/chromebook_coral_defconfig | 3 +- doc/board/google/chromebook_coral.rst | 2 - .../interrupt-controller/intel,acpi-gpe.txt | 30 + .../interrupt-controller/interrupts.txt | 131 ++++ drivers/clk/Kconfig | 10 + drivers/clk/Makefile | 1 + drivers/clk/intel/Makefile | 6 + drivers/clk/intel/clk_intel.c | 41 ++ drivers/misc/irq-uclass.c | 140 +++- drivers/misc/irq_sandbox.c | 43 +- drivers/pinctrl/intel/pinctrl.c | 2 +- drivers/tpm/Kconfig | 10 + drivers/tpm/Makefile | 1 + drivers/tpm/cr50_i2c.c | 661 ++++++++++++++++++ include/dt-bindings/clock/intel-clock.h | 15 + include/irq.h | 138 ++++ include/tpm-v2.h | 31 + test/dm/irq.c | 45 ++ 29 files changed, 1545 insertions(+), 70 deletions(-) create mode 100644 arch/x86/cpu/acpi_gpe.c create mode 100644 doc/device-tree-bindings/interrupt-controller/intel,acpi-gpe.txt create mode 100644 doc/device-tree-bindings/interrupt-controller/interrupts.txt create mode 100644 drivers/clk/intel/Makefile create mode 100644 drivers/clk/intel/clk_intel.c create mode 100644 drivers/tpm/cr50_i2c.c create mode 100644 include/dt-bindings/clock/intel-clock.h
So far we have avoided adding a clock driver for Intel devices. But the Designware I2C driver needs a different clock (133MHz) on Intel devices than on others (166MHz). Add a simple driver that provides this information.
This driver can be expanded later as needed.
Changes in v2: None
drivers/clk/Kconfig | 10 ++++++ drivers/clk/Makefile | 1 + drivers/clk/intel/Makefile | 6 ++++ drivers/clk/intel/clk_intel.c | 41 +++++++++++++++++++++++++ include/dt-bindings/clock/intel-clock.h | 15 +++++++++ 5 files changed, 73 insertions(+) create mode 100644 drivers/clk/intel/Makefile create mode 100644 drivers/clk/intel/clk_intel.c create mode 100644 include/dt-bindings/clock/intel-clock.h
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 16d4237f89..1992d4a4b4 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -73,6 +73,16 @@ config CLK_COMPOSITE_CCF Enable this option if you want to (re-)use the Linux kernel's Common Clock Framework [CCF] composite code in U-Boot's clock driver.
+config CLK_INTEL + bool "Enable clock driver for Intel x86" + depends on CLK && X86 + help + This provides very basic support for clocks on Intel SoCs. The driver + is barely used at present but could be expanded as needs arise. + Much clock configuration in U-Boot is either set up by the FSP, or + set up by U-Boot itself but only statically. Thus the driver does not + support changing clock rates, only querying them. + config CLK_STM32F bool "Enable clock driver support for STM32F family" depends on CLK && (STM32F7 || STM32F4) diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 06131edb9f..e01783391d 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -25,6 +25,7 @@ obj-$(CONFIG_CLK_MVEBU) += mvebu/ obj-$(CONFIG_CLK_BCM6345) += clk_bcm6345.o obj-$(CONFIG_CLK_BOSTON) += clk_boston.o obj-$(CONFIG_CLK_EXYNOS) += exynos/ +obj-$(CONFIG_$(SPL_TPL_)CLK_INTEL) += intel/ obj-$(CONFIG_CLK_HSDK) += clk-hsdk-cgu.o obj-$(CONFIG_CLK_MPC83XX) += mpc83xx_clk.o obj-$(CONFIG_CLK_OWL) += owl/ diff --git a/drivers/clk/intel/Makefile b/drivers/clk/intel/Makefile new file mode 100644 index 0000000000..45e93d7024 --- /dev/null +++ b/drivers/clk/intel/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2010 Google LLC +# + +obj-y += clk_intel.o diff --git a/drivers/clk/intel/clk_intel.c b/drivers/clk/intel/clk_intel.c new file mode 100644 index 0000000000..d2e15491a3 --- /dev/null +++ b/drivers/clk/intel/clk_intel.c @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <dm.h> +#include <clk-uclass.h> +#include <dt-bindings/clock/intel-clock.h> + +static ulong intel_clk_get_rate(struct clk *clk) +{ + ulong rate; + + switch (clk->id) { + case CLK_I2C: + /* Hard-coded to 133MHz on current platforms */ + return 133333333; + default: + return -ENODEV; + } + + return rate; +} + +static struct clk_ops intel_clk_ops = { + .get_rate = intel_clk_get_rate, +}; + +static const struct udevice_id intel_clk_ids[] = { + { .compatible = "intel,apl-clk" }, + { } +}; + +U_BOOT_DRIVER(clk_intel) = { + .name = "clk_intel", + .id = UCLASS_CLK, + .of_match = intel_clk_ids, + .ops = &intel_clk_ops, +}; diff --git a/include/dt-bindings/clock/intel-clock.h b/include/dt-bindings/clock/intel-clock.h new file mode 100644 index 0000000000..e1edd3c71d --- /dev/null +++ b/include/dt-bindings/clock/intel-clock.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * This header provides constants for Intel clocks. + * + * The constants defined in this header are used in the device tree + * + * Copyright 2019 Google LLC + */ + +#ifndef _DT_BINDINGS_CLK_INTEL_H +#define _DT_BINDINGS_CLK_INTEL_H + +#define CLK_I2C 1 + +#endif
Changes in v2: None
Enable the Intel clock driver and modify coral's device tree to use it.
Changes in v2: None
arch/x86/cpu/apollolake/Kconfig | 3 +++ arch/x86/dts/chromebook_coral.dts | 6 ++++++ 2 files changed, 9 insertions(+)
diff --git a/arch/x86/cpu/apollolake/Kconfig b/arch/x86/cpu/apollolake/Kconfig index fcff176c27..ec9f993808 100644 --- a/arch/x86/cpu/apollolake/Kconfig +++ b/arch/x86/cpu/apollolake/Kconfig @@ -39,6 +39,9 @@ config INTEL_APOLLOLAKE imply HAVE_X86_FIT imply INTEL_GPIO imply SMP + imply CLK + imply CMD_CLK + imply CLK_INTEL
if INTEL_APOLLOLAKE
diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index 24fcbb5063..8802e7a9f6 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -15,6 +15,7 @@ #include "flashmap-16mb-rw.dtsi" #endif
+#include <dt-bindings/clock/intel-clock.h> #include <asm/intel_pinctrl_defs.h> #include <asm/arch-apollolake/cpu.h> #include <asm/arch-apollolake/gpio.h> @@ -39,6 +40,11 @@ stdout-path = &serial; };
+ clk: clock { + compatible = "intel,apl-clk"; + #clock-cells = <1>; + }; + cpus { u-boot,dm-pre-reloc; #address-cells = <1>;
Hi Simon,
Changes in v2: None
imply CLK
imply CMD_CLK
imply CLK_INTEL
if INTEL_APOLLOLAKE
nits: this include is not needed in this commit, but should be put in the patch that actually references CLK_I2C.
clk: clock {
#clock-cells = <1>;
Other than above, Reviewed-by: Bin Meng bmeng.cn@gmail.com
Regards, Bin
This config is not actually used here and in U-Boot it seems better to set this using the device tree for each individual controller. The monolithic config of the FSP-S is only necessary if the FSP is actually configuring something, but here it is not.
The FSP-S does enable/disable the various I2C ports. It might be nice to handle this using the okay/disabled property of each port, but that can be considered later.
Changes in v2: None
arch/x86/cpu/apollolake/fsp_s.c | 58 --------------------------------- 1 file changed, 58 deletions(-)
diff --git a/arch/x86/cpu/apollolake/fsp_s.c b/arch/x86/cpu/apollolake/fsp_s.c index 9804227f80..f8fa4dec8f 100644 --- a/arch/x86/cpu/apollolake/fsp_s.c +++ b/arch/x86/cpu/apollolake/fsp_s.c @@ -24,7 +24,6 @@ #define HIDE_BIT BIT(0)
#define INTEL_GSPI_MAX 3 -#define INTEL_I2C_DEV_MAX 8 #define MAX_USB2_PORTS 8
enum { @@ -32,36 +31,6 @@ enum { CHIPSET_LOCKDOWN_COREBOOT, /* coreboot handles locking */ };
-enum i2c_speed { - I2C_SPEED_STANDARD = 100000, - I2C_SPEED_FAST = 400000, - I2C_SPEED_FAST_PLUS = 1000000, - I2C_SPEED_HIGH = 3400000, - I2C_SPEED_FAST_ULTRA = 5000000, -}; - -/* - * Timing values are in units of clock period, with the clock speed - * provided by the SOC - * - * TODO(sjg@chromium.org): Connect this up to the I2C driver - */ -struct dw_i2c_speed_config { - enum i2c_speed speed; - /* SCL high and low period count */ - u16 scl_lcnt; - u16 scl_hcnt; - /* - * SDA hold time should be 300ns in standard and fast modes - * and long enough for deterministic logic level change in - * fast-plus and high speed modes. - * - * [15:0] SDA TX Hold Time - * [23:16] SDA RX Hold Time - */ - u32 sda_hold; -}; - /* Serial IRQ control. SERIRQ_QUIET is the default (0) */ enum serirq_mode { SERIRQ_QUIET, @@ -69,32 +38,6 @@ enum serirq_mode { SERIRQ_OFF, };
-/* - * This I2C controller has support for 3 independent speed configs but can - * support both FAST_PLUS and HIGH speeds through the same set of speed - * config registers. These are treated separately so the speed config values - * can be provided via ACPI to the OS. - */ -#define DW_I2C_SPEED_CONFIG_COUNT 4 - -struct dw_i2c_bus_config { - /* Bus should be enabled in TPL with temporary base */ - int early_init; - /* Bus speed in Hz, default is I2C_SPEED_FAST (400 KHz) */ - enum i2c_speed speed; - /* - * If rise_time_ns is non-zero the calculations for lcnt and hcnt - * registers take into account the times of the bus. However, if - * there is a match in speed_config those register values take - * precedence - */ - int rise_time_ns; - int fall_time_ns; - int data_hold_time_ns; - /* Specific bus speed configuration */ - struct dw_i2c_speed_config speed_config[DW_I2C_SPEED_CONFIG_COUNT]; -}; - struct gspi_cfg { /* Bus speed in MHz */ u32 speed_mhz; @@ -110,7 +53,6 @@ struct gspi_cfg { struct soc_intel_common_config { int chipset_lockdown; struct gspi_cfg gspi[INTEL_GSPI_MAX]; - struct dw_i2c_bus_config i2c[INTEL_I2C_DEV_MAX]; };
enum pnp_settings {
Changes in v2: None
These are actually working correctly, so update the status.
Changes in v2: None
doc/board/google/chromebook_coral.rst | 2 -- 1 file changed, 2 deletions(-)
diff --git a/doc/board/google/chromebook_coral.rst b/doc/board/google/chromebook_coral.rst index 515fd06d76..8e0bd95167 100644 --- a/doc/board/google/chromebook_coral.rst +++ b/doc/board/google/chromebook_coral.rst @@ -211,9 +211,7 @@ To do - left-side USB - USB-C - Cr50 (security chip: a basic driver is running but not included here) - - I2C (driver exists but not enabled in device tree) - Sound (Intel I2S support exists, but need da7219 driver) - - RTC (driver exists but not enabled in device tree) - Various minor features supported by LPC, etc. - Booting Chrome OS, e.g. with verified boot - Integrate with Chrome OS vboot
Changes in v2: None
There can be different types of interrupt controllers in a system and some drivers may need to distinguish between these. In general this can be handled using the device tree by adding the interrupt information to device nodes.
However on x86 devices we have interrupt controllers which are not tied to any particular device and not really used in U-Boot. These still need to be inited, so a convenient method is to give each controller a type and allow a particular controller type to be probed.
Add support for this in sandbox along with a test.
Changes in v2: None
arch/sandbox/include/asm/test.h | 4 ++++ drivers/misc/irq-uclass.c | 24 +++++++++++++++++++++++- drivers/misc/irq_sandbox.c | 2 +- include/irq.h | 21 +++++++++++++++++++++ test/dm/irq.c | 14 ++++++++++++++ 5 files changed, 63 insertions(+), 2 deletions(-)
diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index fdb0ecfed1..0a11dfeefb 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -45,6 +45,10 @@ #define PCI_EA_BAR2_MAGIC 0x72727272 #define PCI_EA_BAR4_MAGIC 0x74747474
+enum { + SANDBOX_IRQN_PEND = 1, /* Interrupt number for 'pending' test */ +}; + /* System controller driver data */ enum { SYSCON0 = 32, diff --git a/drivers/misc/irq-uclass.c b/drivers/misc/irq-uclass.c index d5182cf149..38498a66a4 100644 --- a/drivers/misc/irq-uclass.c +++ b/drivers/misc/irq-uclass.c @@ -1,11 +1,13 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * Copyright 2019 Google, LLC + * Written by Simon Glass sjg@chromium.org */
#include <common.h> #include <dm.h> #include <irq.h> +#include <dm/device-internal.h>
int irq_route_pmc_gpio_gpe(struct udevice *dev, uint pmc_gpe_num) { @@ -47,6 +49,26 @@ int irq_restore_polarities(struct udevice *dev) return ops->restore_polarities(dev); }
+int irq_first_device_type(enum irq_dev_t type, struct udevice **devp) +{ + struct udevice *dev; + struct uclass *uc; + int ret; + + ret = uclass_get(UCLASS_IRQ, &uc); + if (ret) + return ret; + uclass_foreach_dev(dev, uc) { + if (dev_get_driver_data(dev) == type) { + *devp = dev; + + return device_probe(dev); + } + } + + return -ENODEV; +} + UCLASS_DRIVER(irq) = { .id = UCLASS_IRQ, .name = "irq", diff --git a/drivers/misc/irq_sandbox.c b/drivers/misc/irq_sandbox.c index 6dda1a4c44..011022ac62 100644 --- a/drivers/misc/irq_sandbox.c +++ b/drivers/misc/irq_sandbox.c @@ -43,7 +43,7 @@ static const struct irq_ops sandbox_irq_ops = { };
static const struct udevice_id sandbox_irq_ids[] = { - { .compatible = "sandbox,irq"}, + { .compatible = "sandbox,irq", SANDBOX_IRQT_BASE }, { } };
diff --git a/include/irq.h b/include/irq.h index 01ded64f16..1db97b5c3f 100644 --- a/include/irq.h +++ b/include/irq.h @@ -8,6 +8,17 @@ #ifndef __irq_H #define __irq_H
+/* + * Interrupt controller types available. You can find a particular one with + * irq_first_device_type() + */ +enum irq_dev_t { + X86_IRQT_BASE, /* Base controller */ + X86_IRQT_ITSS, /* ITSS controller, e.g. on APL */ + X86_IRQT_ACPI_GPE, /* ACPI General-Purpose Events controller */ + SANDBOX_IRQT_BASE, /* Sandbox testing */ +}; + /** * struct irq_ops - Operations for the IRQ */ @@ -85,4 +96,14 @@ int irq_snapshot_polarities(struct udevice *dev); */ int irq_restore_polarities(struct udevice *dev);
+/** + * irq_first_device_type() - Get a particular interrupt controller + * + * @type: Type to find + * @devp: Returns the device, if found + * @return 0 if OK, -ENODEV if not found, other -ve error if uclass failed to + * probe + */ +int irq_first_device_type(enum irq_dev_t type, struct udevice **devp); + #endif diff --git a/test/dm/irq.c b/test/dm/irq.c index 726189c59f..0f23f108a7 100644 --- a/test/dm/irq.c +++ b/test/dm/irq.c @@ -8,6 +8,7 @@ #include <common.h> #include <dm.h> #include <irq.h> +#include <asm/test.h> #include <dm/test.h> #include <test/ut.h>
@@ -30,3 +31,16 @@ static int dm_test_irq_base(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_irq_base, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test of irq_first_device_type() */ +static int dm_test_irq_type(struct unit_test_state *uts) +{ + struct udevice *dev; + + ut_assertok(irq_first_device_type(SANDBOX_IRQT_BASE, &dev)); + ut_asserteq(-ENODEV, irq_first_device_type(X86_IRQT_BASE, &dev)); + + return 0; +} +DM_TEST(dm_test_irq_type, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +
Hi Simon,
Changes in v2: None
+enum {
- Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com
- Copyright 2019 Google, LLC
- Written by Simon Glass sjg@chromium.org
struct uclass *uc;
int ret;
if (ret)
return ret;
*devp = dev;
The logic is generic and should not be limited to IRQ uclass. Maybe we should put this API in DM core, and name it as something like uclass_first_device_drvdata()?
return -ENODEV;
- Interrupt controller types available. You can find a particular one with
- irq_first_device_type()
+enum irq_dev_t {
- struct irq_ops - Operations for the IRQ
- irq_first_device_type() - Get a particular interrupt controller
- @type: Type to find
- @devp: Returns the device, if found
- @return 0 if OK, -ENODEV if not found, other -ve error if uclass failed to
probe
Regards, Bin
Add an IRQ type to each driver and use irq_first_device_type() to find and probe the correct one.
Changes in v2: None
arch/x86/cpu/apollolake/fsp_s.c | 4 ++-- arch/x86/cpu/apollolake/itss.c | 2 +- arch/x86/cpu/i386/interrupt.c | 3 ++- arch/x86/cpu/irq.c | 3 ++- drivers/pinctrl/intel/pinctrl.c | 2 +- include/irq.h | 2 ++ 6 files changed, 10 insertions(+), 6 deletions(-)
diff --git a/arch/x86/cpu/apollolake/fsp_s.c b/arch/x86/cpu/apollolake/fsp_s.c index f8fa4dec8f..b2d9130841 100644 --- a/arch/x86/cpu/apollolake/fsp_s.c +++ b/arch/x86/cpu/apollolake/fsp_s.c @@ -535,7 +535,7 @@ int arch_fsps_preinit(void) struct udevice *itss; int ret;
- ret = uclass_first_device_err(UCLASS_IRQ, &itss); + ret = irq_first_device_type(X86_IRQT_ITSS, &itss); if (ret) return log_msg_ret("no itss", ret); /* @@ -576,7 +576,7 @@ int arch_fsp_init_r(void) if (ret) return ret;
- ret = uclass_first_device_err(UCLASS_IRQ, &itss); + ret = irq_first_device_type(X86_IRQT_ITSS, &itss); if (ret) return log_msg_ret("no itss", ret); /* Restore GPIO IRQ polarities back to previous settings */ diff --git a/arch/x86/cpu/apollolake/itss.c b/arch/x86/cpu/apollolake/itss.c index 8789f8e6bb..9a4d159ebf 100644 --- a/arch/x86/cpu/apollolake/itss.c +++ b/arch/x86/cpu/apollolake/itss.c @@ -199,7 +199,7 @@ static const struct irq_ops apl_itss_ops = { };
static const struct udevice_id apl_itss_ids[] = { - { .compatible = "intel,apl-itss"}, + { .compatible = "intel,apl-itss", .data = X86_IRQT_ITSS }, { } };
diff --git a/arch/x86/cpu/i386/interrupt.c b/arch/x86/cpu/i386/interrupt.c index 78aa51a3ea..5a886fd031 100644 --- a/arch/x86/cpu/i386/interrupt.c +++ b/arch/x86/cpu/i386/interrupt.c @@ -13,6 +13,7 @@ #include <common.h> #include <dm.h> #include <efi_loader.h> +#include <irq.h> #include <irq_func.h> #include <asm/control_regs.h> #include <asm/i8259.h> @@ -262,7 +263,7 @@ int interrupt_init(void) int ret;
/* Try to set up the interrupt router, but don't require one */ - ret = uclass_first_device_err(UCLASS_IRQ, &dev); + ret = irq_first_device_type(X86_IRQT_BASE, &dev); if (ret && ret != -ENODEV) return ret;
diff --git a/arch/x86/cpu/irq.c b/arch/x86/cpu/irq.c index ed9938f7f7..bafa031082 100644 --- a/arch/x86/cpu/irq.c +++ b/arch/x86/cpu/irq.c @@ -7,6 +7,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <irq.h> #include <malloc.h> #include <asm/io.h> #include <asm/irq.h> @@ -351,7 +352,7 @@ int irq_router_probe(struct udevice *dev) }
static const struct udevice_id irq_router_ids[] = { - { .compatible = "intel,irq-router" }, + { .compatible = "intel,irq-router", .data = X86_IRQT_BASE }, { } };
diff --git a/drivers/pinctrl/intel/pinctrl.c b/drivers/pinctrl/intel/pinctrl.c index 4875a3b0b5..bd58b85dd8 100644 --- a/drivers/pinctrl/intel/pinctrl.c +++ b/drivers/pinctrl/intel/pinctrl.c @@ -613,7 +613,7 @@ int intel_pinctrl_ofdata_to_platdata(struct udevice *dev, log_err("Cannot find community for pid %d\n", pplat->pid); return -EDOM; } - ret = uclass_first_device_err(UCLASS_IRQ, &priv->itss); + ret = irq_first_device_type(X86_IRQT_ITSS, &priv->itss); if (ret) return log_msg_ret("Cannot find ITSS", ret); priv->comm = comm; diff --git a/include/irq.h b/include/irq.h index 1db97b5c3f..8b4e2ecfc0 100644 --- a/include/irq.h +++ b/include/irq.h @@ -99,6 +99,8 @@ int irq_restore_polarities(struct udevice *dev); /** * irq_first_device_type() - Get a particular interrupt controller * + * On success this returns an activated interrupt device. + * * @type: Type to find * @devp: Returns the device, if found * @return 0 if OK, -ENODEV if not found, other -ve error if uclass failed to
Hi Simon,
Changes in v2: None
- On success this returns an activated interrupt device.
This change should be in the previous patch, where this new API was added.
Regards, Bin
Allow this driver to be used in TPL by setting up the interrupt type correctly.
Changes in v2: None
arch/x86/cpu/apollolake/itss.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/x86/cpu/apollolake/itss.c b/arch/x86/cpu/apollolake/itss.c index 9a4d159ebf..8aec64e000 100644 --- a/arch/x86/cpu/apollolake/itss.c +++ b/arch/x86/cpu/apollolake/itss.c @@ -146,6 +146,15 @@ static int apl_route_pmc_gpio_gpe(struct udevice *dev, uint pmc_gpe_num) return -ENOENT; }
+static int apl_itss_bind(struct udevice *dev) +{ + /* This is not set with of-platdata, so set it manually */ + if (CONFIG_IS_ENABLED(OF_PLATDATA)) + dev->driver_data = X86_IRQT_ITSS; + + return 0; +} + static int apl_itss_ofdata_to_platdata(struct udevice *dev) { struct apl_itss_priv *priv = dev_get_priv(dev); @@ -208,6 +217,7 @@ U_BOOT_DRIVER(apl_itss_drv) = { .id = UCLASS_IRQ, .of_match = apl_itss_ids, .ops = &apl_itss_ops, + .bind = apl_itss_bind, .ofdata_to_platdata = apl_itss_ofdata_to_platdata, .platdata_auto_alloc_size = sizeof(struct apl_itss_platdata), .priv_auto_alloc_size = sizeof(struct apl_itss_priv),
Changes in v2: None
At present driver model supports the IRQ uclass but there is no way to request a particular interrupt for a driver.
Add a mechanism, similar to clock and reset, to read the interrupts required by a device from the device tree and to request those interrupts.
U-Boot itself does not have interrupt-driven handlers, so just provide a means to read and clear an interrupt. This can be useful to handle peripherals which must use an interrupt to determine when data is available, for example.
Bring over the basic binding file as well, from Linux v5.4. Note that the older binding is not supported in U-Boot; the newer 'special form' must be used.
Add a simple test of the new functionality.
Changes in v2: None
arch/sandbox/dts/test.dts | 5 +- .../interrupt-controller/interrupts.txt | 131 ++++++++++++++++++ drivers/misc/irq-uclass.c | 116 ++++++++++++++++ drivers/misc/irq_sandbox.c | 41 ++++++ include/irq.h | 115 +++++++++++++++ test/dm/irq.c | 31 +++++ 6 files changed, 438 insertions(+), 1 deletion(-) create mode 100644 doc/device-tree-bindings/interrupt-controller/interrupts.txt
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 57513a449f..0620f9aa2a 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -93,6 +93,7 @@ <&gpio_b 9 0xc 3 2 1>; int-value = <1234>; uint-value = <(-1234)>; + interrupts-extended = <&irq 3 0>; };
junk { @@ -353,8 +354,10 @@ vss-microvolts = <0>; };
- irq { + irq: irq { compatible = "sandbox,irq"; + interrupt-controller; + #interrupt-cells = <2>; };
lcd { diff --git a/doc/device-tree-bindings/interrupt-controller/interrupts.txt b/doc/device-tree-bindings/interrupt-controller/interrupts.txt new file mode 100644 index 0000000000..38a399a6b1 --- /dev/null +++ b/doc/device-tree-bindings/interrupt-controller/interrupts.txt @@ -0,0 +1,131 @@ +Specifying interrupt information for devices +============================================ + +1) Interrupt client nodes +------------------------- + +Nodes that describe devices which generate interrupts must contain an +"interrupts" property, an "interrupts-extended" property, or both. If both are +present, the latter should take precedence; the former may be provided simply +for compatibility with software that does not recognize the latter. These +properties contain a list of interrupt specifiers, one per output interrupt. The +format of the interrupt specifier is determined by the interrupt controller to +which the interrupts are routed; see section 2 below for details. + + Example: + interrupt-parent = <&intc1>; + interrupts = <5 0>, <6 0>; + +The "interrupt-parent" property is used to specify the controller to which +interrupts are routed and contains a single phandle referring to the interrupt +controller node. This property is inherited, so it may be specified in an +interrupt client node or in any of its parent nodes. Interrupts listed in the +"interrupts" property are always in reference to the node's interrupt parent. + +The "interrupts-extended" property is a special form; useful when a node needs +to reference multiple interrupt parents or a different interrupt parent than +the inherited one. Each entry in this property contains both the parent phandle +and the interrupt specifier. + + Example: + interrupts-extended = <&intc1 5 1>, <&intc2 1 0>; + +(NOTE: only this 'special form' is supported in U-Boot) + + +2) Interrupt controller nodes +----------------------------- + +A device is marked as an interrupt controller with the "interrupt-controller" +property. This is a empty, boolean property. An additional "#interrupt-cells" +property defines the number of cells needed to specify a single interrupt. + +It is the responsibility of the interrupt controller's binding to define the +length and format of the interrupt specifier. The following two variants are +commonly used: + + a) one cell + ----------- + The #interrupt-cells property is set to 1 and the single cell defines the + index of the interrupt within the controller. + + Example: + + vic: intc@10140000 { + compatible = "arm,versatile-vic"; + interrupt-controller; + #interrupt-cells = <1>; + reg = <0x10140000 0x1000>; + }; + + sic: intc@10003000 { + compatible = "arm,versatile-sic"; + interrupt-controller; + #interrupt-cells = <1>; + reg = <0x10003000 0x1000>; + interrupt-parent = <&vic>; + interrupts = <31>; /* Cascaded to vic */ + }; + + b) two cells + ------------ + The #interrupt-cells property is set to 2 and the first cell defines the + index of the interrupt within the controller, while the second cell is used + to specify any of the following flags: + - bits[3:0] trigger type and level flags + 1 = low-to-high edge triggered + 2 = high-to-low edge triggered + 4 = active high level-sensitive + 8 = active low level-sensitive + + Example: + + i2c@7000c000 { + gpioext: gpio-adnp@41 { + compatible = "ad,gpio-adnp"; + reg = <0x41>; + + interrupt-parent = <&gpio>; + interrupts = <160 1>; + + gpio-controller; + #gpio-cells = <1>; + + interrupt-controller; + #interrupt-cells = <2>; + + nr-gpios = <64>; + }; + + sx8634@2b { + compatible = "smtc,sx8634"; + reg = <0x2b>; + + interrupt-parent = <&gpioext>; + interrupts = <3 0x8>; + + #address-cells = <1>; + #size-cells = <0>; + + threshold = <0x40>; + sensitivity = <7>; + }; + }; + + +Example of special form (supported by U-Boot): + + acpi_gpe: general-purpose-events { + reg = <IOMAP_ACPI_BASE IOMAP_ACPI_SIZE>; + compatible = "intel,acpi-gpe"; + interrupt-controller; + #interrupt-cells = <2>; + }; + + tpm@50 { + reg = <0x50>; + compatible = "google,cr50"; + u-boot,i2c-offset-len = <0>; + ready-gpio = <&gpio_n 28 GPIO_ACTIVE_LOW>; + interrupts-extended = <&acpi_gpe 0x3c 0>; + }; diff --git a/drivers/misc/irq-uclass.c b/drivers/misc/irq-uclass.c index 38498a66a4..7d65192858 100644 --- a/drivers/misc/irq-uclass.c +++ b/drivers/misc/irq-uclass.c @@ -4,8 +4,11 @@ * Written by Simon Glass sjg@chromium.org */
+#define LOG_CATEGORY UCLASS_IRQ + #include <common.h> #include <dm.h> +#include <dt-structs.h> #include <irq.h> #include <dm/device-internal.h>
@@ -49,6 +52,119 @@ int irq_restore_polarities(struct udevice *dev) return ops->restore_polarities(dev); }
+int irq_read_and_clear(struct irq *irq) +{ + const struct irq_ops *ops = irq_get_ops(irq->dev); + + if (!ops->read_and_clear) + return -ENOSYS; + + return ops->read_and_clear(irq); +} + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +int irq_get_by_index_platdata(struct udevice *dev, int index, + struct phandle_1_arg *cells, struct irq *irq) +{ + int ret; + + if (index != 0) + return -ENOSYS; + ret = uclass_get_device(UCLASS_IRQ, 0, &irq->dev); + if (ret) + return ret; + irq->id = cells[0].arg[0]; + + return 0; +} +#else +static int irq_of_xlate_default(struct irq *irq, + struct ofnode_phandle_args *args) +{ + log_debug("(irq=%p)\n", irq); + + if (args->args_count > 1) { + log_debug("Invaild args_count: %d\n", args->args_count); + return -EINVAL; + } + + if (args->args_count) + irq->id = args->args[0]; + else + irq->id = 0; + + return 0; +} + +static int irq_get_by_index_tail(int ret, ofnode node, + struct ofnode_phandle_args *args, + const char *list_name, int index, + struct irq *irq) +{ + struct udevice *dev_irq; + const struct irq_ops *ops; + + assert(irq); + irq->dev = NULL; + if (ret) + goto err; + + ret = uclass_get_device_by_ofnode(UCLASS_IRQ, args->node, &dev_irq); + if (ret) { + log_debug("uclass_get_device_by_ofnode failed: err=%d\n", ret); + return ret; + } + + irq->dev = dev_irq; + + ops = irq_get_ops(dev_irq); + + if (ops->of_xlate) + ret = ops->of_xlate(irq, args); + else + ret = irq_of_xlate_default(irq, args); + if (ret) { + log_debug("of_xlate() failed: %d\n", ret); + return ret; + } + + return irq_request(dev_irq, irq); +err: + log_debug("Node '%s', property '%s', failed to request IRQ index %d: %d\n", + ofnode_get_name(node), list_name, index, ret); + return ret; +} + +int irq_get_by_index(struct udevice *dev, int index, struct irq *irq) +{ + struct ofnode_phandle_args args; + int ret; + + ret = dev_read_phandle_with_args(dev, "interrupts-extended", + "#interrupt-cells", 0, index, &args); + + return irq_get_by_index_tail(ret, dev_ofnode(dev), &args, + "interrupts-extended", index > 0, irq); +} +#endif /* OF_PLATDATA */ + +int irq_request(struct udevice *dev, struct irq *irq) +{ + const struct irq_ops *ops; + + log_debug("(dev=%p, irq=%p)\n", dev, irq); + if (!irq) + return 0; + ops = irq_get_ops(dev); + + irq->dev = dev; + + if (!ops->request) + return 0; + + return ops->request(irq); +} + int irq_first_device_type(enum irq_dev_t type, struct udevice **devp) { struct udevice *dev; diff --git a/drivers/misc/irq_sandbox.c b/drivers/misc/irq_sandbox.c index 011022ac62..54bc47c8d8 100644 --- a/drivers/misc/irq_sandbox.c +++ b/drivers/misc/irq_sandbox.c @@ -8,6 +8,18 @@ #include <common.h> #include <dm.h> #include <irq.h> +#include <asm/test.h> + +/** + * struct sandbox_irq_priv - private data for this driver + * + * @count: Counts the number calls to the read_and_clear() method + * @pending: true if an interrupt is pending, else false + */ +struct sandbox_irq_priv { + int count; + bool pending; +};
static int sandbox_set_polarity(struct udevice *dev, uint irq, bool active_low) { @@ -35,11 +47,39 @@ static int sandbox_restore_polarities(struct udevice *dev) return 0; }
+static int sandbox_irq_read_and_clear(struct irq *irq) +{ + struct sandbox_irq_priv *priv = dev_get_priv(irq->dev); + + if (irq->id != SANDBOX_IRQN_PEND) + return -EINVAL; + priv->count++; + if (priv->pending) { + priv->pending = false; + return 1; + } + + if (!(priv->count % 3)) + priv->pending = true; + + return 0; +} + +static int sandbox_irq_of_xlate(struct irq *irq, + struct ofnode_phandle_args *args) +{ + irq->id = args->args[0]; + + return 0; +} + static const struct irq_ops sandbox_irq_ops = { .route_pmc_gpio_gpe = sandbox_route_pmc_gpio_gpe, .set_polarity = sandbox_set_polarity, .snapshot_polarities = sandbox_snapshot_polarities, .restore_polarities = sandbox_restore_polarities, + .read_and_clear = sandbox_irq_read_and_clear, + .of_xlate = sandbox_irq_of_xlate, };
static const struct udevice_id sandbox_irq_ids[] = { @@ -52,4 +92,5 @@ U_BOOT_DRIVER(sandbox_irq_drv) = { .id = UCLASS_IRQ, .of_match = sandbox_irq_ids, .ops = &sandbox_irq_ops, + .priv_auto_alloc_size = sizeof(struct sandbox_irq_priv), }; diff --git a/include/irq.h b/include/irq.h index 8b4e2ecfc0..b71afe9bee 100644 --- a/include/irq.h +++ b/include/irq.h @@ -19,8 +19,21 @@ enum irq_dev_t { SANDBOX_IRQT_BASE, /* Sandbox testing */ };
+/** + * struct irq - A single irq line handled by an interrupt controller + * + * @dev: IRQ device that handles this irq + * @id: ID to identify this irq with the device + */ +struct irq { + struct udevice *dev; + ulong id; +}; + /** * struct irq_ops - Operations for the IRQ + * + * Each IRQ device can handle mulitple IRQ lines */ struct irq_ops { /** @@ -57,6 +70,55 @@ struct irq_ops { * @return 0 */ int (*restore_polarities)(struct udevice *dev); + + /** + * read_and_clear() - get the value of an interrupt and clear it + * + * Clears the interrupt if pending + * + * @irq: IRQ line + * @return 0 if interrupt is not pending, 1 if it was (and so has been + * cleared), -ve on error + */ + int (*read_and_clear)(struct irq *irq); + /** + * of_xlate - Translate a client's device-tree (OF) irq specifier. + * + * The irq core calls this function as the first step in implementing + * a client's irq_get_by_*() call. + * + * If this function pointer is set to NULL, the irq core will use a + * default implementation, which assumes #interrupt-cells = <1>, and + * that the DT cell contains a simple integer irq ID. + * + * @irq: The irq struct to hold the translation result. + * @args: The irq specifier values from device tree. + * @return 0 if OK, or a negative error code. + */ + int (*of_xlate)(struct irq *irq, struct ofnode_phandle_args *args); + /** + * request - Request a translated irq. + * + * The irq core calls this function as the second step in + * implementing a client's irq_get_by_*() call, following a successful + * xxx_xlate() call, or as the only step in implementing a client's + * irq_request() call. + * + * @irq: The irq struct to request; this has been fille in by + * a previoux xxx_xlate() function call, or by the caller + * of irq_request(). + * @return 0 if OK, or a negative error code. + */ + int (*request)(struct irq *irq); + /** + * free - Free a previously requested irq. + * + * This is the implementation of the client irq_free() API. + * + * @irq: The irq to free. + * @return 0 if OK, or a negative error code. + */ + int (*free)(struct irq *irq); };
#define irq_get_ops(dev) ((struct irq_ops *)(dev)->driver->ops) @@ -96,6 +158,59 @@ int irq_snapshot_polarities(struct udevice *dev); */ int irq_restore_polarities(struct udevice *dev);
+/** + * read_and_clear() - get the value of an interrupt and clear it + * + * Clears the interrupt if pending + * + * @dev: IRQ device + * @return 0 if interrupt is not pending, 1 if it was (and so has been + * cleared), -ve on error + */ +int irq_read_and_clear(struct irq *irq); + +/** + * irq_get_by_index - Get/request an irq by integer index. + * + * This looks up and requests an irq. The index is relative to the client + * device; each device is assumed to have n irqs associated with it somehow, + * and this function finds and requests one of them. The mapping of client + * device irq indices to provider irqs may be via device-tree + * properties, board-provided mapping tables, or some other mechanism. + * + * @dev: The client device. + * @index: The index of the irq to request, within the client's list of + * irqs. + * @irq: A pointer to a irq struct to initialise. + * @return 0 if OK, or a negative error code. + */ +int irq_get_by_index(struct udevice *dev, int index, struct irq *irq); + +/** + * irq_request - Request a irq by provider-specific ID. + * + * This requests a irq using a provider-specific ID. Generally, this function + * should not be used, since irq_get_by_index/name() provide an interface that + * better separates clients from intimate knowledge of irq providers. + * However, this function may be useful in core SoC-specific code. + * + * @dev: The irq provider device. + * @irq: A pointer to a irq struct to initialise. The caller must + * have already initialised any field in this struct which the + * irq provider uses to identify the irq. + * @return 0 if OK, or a negative error code. + */ +int irq_request(struct udevice *dev, struct irq *irq); + +/** + * irq_free - Free a previously requested irq. + * + * @irq: A irq struct that was previously successfully requested by + * irq_request/get_by_*(). + * @return 0 if OK, or a negative error code. + */ +int irq_free(struct irq *irq); + /** * irq_first_device_type() - Get a particular interrupt controller * diff --git a/test/dm/irq.c b/test/dm/irq.c index 0f23f108a7..192d80d7e1 100644 --- a/test/dm/irq.c +++ b/test/dm/irq.c @@ -44,3 +44,34 @@ static int dm_test_irq_type(struct unit_test_state *uts) } DM_TEST(dm_test_irq_type, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
+/* Test of irq_read_and_clear() */ +static int dm_test_read_and_clear(struct unit_test_state *uts) +{ + struct irq irq; + + ut_assertok(irq_first_device_type(SANDBOX_IRQT_BASE, &irq.dev)); + irq.id = SANDBOX_IRQN_PEND; + ut_asserteq(0, irq_read_and_clear(&irq)); + ut_asserteq(0, irq_read_and_clear(&irq)); + ut_asserteq(0, irq_read_and_clear(&irq)); + ut_asserteq(1, irq_read_and_clear(&irq)); + ut_asserteq(0, irq_read_and_clear(&irq)); + + return 0; +} +DM_TEST(dm_test_read_and_clear, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test of irq_request() */ +static int dm_test_request(struct unit_test_state *uts) +{ + struct udevice *dev; + struct irq irq; + + ut_assertok(uclass_first_device_err(UCLASS_TEST_FDT, &dev)); + ut_asserteq_str("a-test", dev->name); + ut_assertok(irq_get_by_index(dev, 0, &irq)); + ut_asserteq(3, irq.id); + + return 0; +} +DM_TEST(dm_test_request, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Hi Simon,
Changes in v2: None
interrupts-extended = <&irq 3 0>; }; junk {
irq {
#interrupt-cells = <2>; }; lcd {
- Example:
- Example:
- a) one cell
- The #interrupt-cells property is set to 1 and the single cell defines the
- index of the interrupt within the controller.
- Example:
- b) two cells
- The #interrupt-cells property is set to 2 and the first cell defines the
- index of the interrupt within the controller, while the second cell is used
- to specify any of the following flags:
- Example:
i2c@7000c000 {
reg = <0x41>;
gpio-controller;
#gpio-cells = <1>;
nr-gpios = <64>;
sx8634@2b {
reg = <0x2b>;
#size-cells = <0>;
threshold = <0x40>;
sensitivity = <7>;
tpm@50 {
reg = <0x50>;
return -ENOSYS;
int ret;
if (index != 0)
return -ENOSYS;
if (ret)
return ret;
return -EINVAL;
else
irq->id = 0;
It's odd to pass the return value of some other functions to this function and check it here. Can we please remove ret, and check its value at where we get that?
struct irq *irq)
assert(irq);
irq->dev = NULL;
if (ret)
goto err;
if (ret) {
return ret;
irq->dev = dev_irq;
if (ops->of_xlate)
else
if (ret) {
return ret;
+err:
return ret;
int ret;
if (!irq)
irq->dev = dev;
if (!ops->request)
- struct sandbox_irq_priv - private data for this driver
- @count: Counts the number calls to the read_and_clear() method
- @pending: true if an interrupt is pending, else false
int count;
bool pending;
return -EINVAL;
priv->count++;
return 1;
This
- struct irq - A single irq line handled by an interrupt controller
- @dev: IRQ device that handles this irq
- @id: ID to identify this irq with the device
+struct irq {
ulong id;
- Each IRQ device can handle mulitple IRQ lines
* @irq: IRQ line
* of irq_request().
- read_and_clear() - get the value of an interrupt and clear it
- Clears the interrupt if pending
- @dev: IRQ device
- @return 0 if interrupt is not pending, 1 if it was (and so has been
- irq_get_by_index - Get/request an irq by integer index.
- This looks up and requests an irq. The index is relative to the client
- device; each device is assumed to have n irqs associated with it somehow,
- and this function finds and requests one of them. The mapping of client
- device irq indices to provider irqs may be via device-tree
- properties, board-provided mapping tables, or some other mechanism.
- @dev: The client device.
- @index: The index of the irq to request, within the client's list of
irqs.
- @irq: A pointer to a irq struct to initialise.
- @return 0 if OK, or a negative error code.
- irq_request - Request a irq by provider-specific ID.
- This requests a irq using a provider-specific ID. Generally, this function
- should not be used, since irq_get_by_index/name() provide an interface that
- better separates clients from intimate knowledge of irq providers.
- However, this function may be useful in core SoC-specific code.
- @dev: The irq provider device.
- @irq: A pointer to a irq struct to initialise. The caller must
- irq_free - Free a previously requested irq.
- @irq: A irq struct that was previously successfully requested by
struct irq irq;
struct irq irq;
Regards, Bin
Hi Bin,
On Mon, 3 Feb 2020 at 10:05, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Changes in v2: None
return -ENOSYS;
int ret;
if (index != 0)
return -ENOSYS;
if (ret)
return ret;
return -EINVAL;
else
irq->id = 0;
This pattern is similar to how it is done in DM core. It routes all return paths through a single function where you can do error checking, etc. So I think this is better than the alternative. The only strange thing here is that this function is only used one. I did this since I suspected there would be others coming. But I could inline if it you like..
This
Hi Simon,
On Tue, Feb 4, 2020 at 8:19 AM Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Changes in v2: None
return -ENOSYS;
int ret;
if (index != 0)
return -ENOSYS;
if (ret)
return ret;
return -EINVAL;
else
irq->id = 0;
If that's the way how other DM codes do, I am okay with that.
This
I must have been working too long yesterday ...
Regards, Bin
ACPI GPEs are used to signal interrupts from peripherals that are accessed via ACPI. In U-Boot these are modelled as interrupts using a separate interrupt controller. Configuration is via the device tree.
Add a simple driver for this.
Changes in v2: None
arch/x86/Kconfig | 33 +++++++ arch/x86/cpu/Makefile | 1 + arch/x86/cpu/acpi_gpe.c | 85 +++++++++++++++++++ .../interrupt-controller/intel,acpi-gpe.txt | 30 +++++++ 4 files changed, 149 insertions(+) create mode 100644 arch/x86/cpu/acpi_gpe.c create mode 100644 doc/device-tree-bindings/interrupt-controller/intel,acpi-gpe.txt
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 89b93e5de2..c4a9a9f624 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -910,4 +910,37 @@ config X86_OFFSET_SPL depends on SPL && X86 default SPL_TEXT_BASE
+config ACPI_GPE + bool "Support ACPI general-purpose events" + help + Enable a driver for ACPI GPEs to allow peripherals to send interrupts + via ACPI to the OS. In U-Boot this is only used when U-Boot itself + needs access to these interrupts. This can happen when it uses a + peripheral that is set up to use GPEs and so cannot use the normal + GPIO mechanism for polling an input. + + See https://queue.acm.org/blogposting.cfm?id=18977 for more info + +config SPL_ACPI_GPE + bool "Support ACPI general-purpose events in SPL" + help + Enable a driver for ACPI GPEs to allow peripherals to send interrupts + via ACPI to the OS. In U-Boot this is only used when U-Boot itself + needs access to these interrupts. This can happen when it uses a + peripheral that is set up to use GPEs and so cannot use the normal + GPIO mechanism for polling an input. + + See https://queue.acm.org/blogposting.cfm?id=18977 for more info + +config TPL_ACPI_GPE + bool "Support ACPI general-purpose events in TPL" + help + Enable a driver for ACPI GPEs to allow peripherals to send interrupts + via ACPI to the OS. In U-Boot this is only used when U-Boot itself + needs access to these interrupts. This can happen when it uses a + peripheral that is set up to use GPEs and so cannot use the normal + GPIO mechanism for polling an input. + + See https://queue.acm.org/blogposting.cfm?id=18977 for more info + endmenu diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 5b40838e60..307267a8fb 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -55,6 +55,7 @@ obj-$(CONFIG_INTEL_QUEENSBAY) += queensbay/ obj-$(CONFIG_INTEL_TANGIER) += tangier/ obj-$(CONFIG_APIC) += lapic.o ioapic.o obj-$(CONFIG_$(SPL_TPL_)X86_32BIT_INIT) += irq.o +obj-$(CONFIG_$(SPL_TPL_)ACPI_GPE) += acpi_gpe.o obj-$(CONFIG_QFW) += qfw_cpu.o ifndef CONFIG_$(SPL_)X86_64 obj-$(CONFIG_SMP) += mp_init.o diff --git a/arch/x86/cpu/acpi_gpe.c b/arch/x86/cpu/acpi_gpe.c new file mode 100644 index 0000000000..55005455c0 --- /dev/null +++ b/arch/x86/cpu/acpi_gpe.c @@ -0,0 +1,85 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 Google, LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <dm.h> +#include <irq.h> +#include <asm/io.h> + +/** + * struct acpi_gpe_priv - private driver information + * + * @acpi_base: Base I/O address of ACPI registers + */ +struct acpi_gpe_priv { + ulong acpi_base; +}; + +#define GPE0_STS(x) (0x20 + ((x) * 4)) + +static int acpi_gpe_read_and_clear(struct irq *irq) +{ + struct acpi_gpe_priv *priv = dev_get_priv(irq->dev); + u32 mask, sts; + ulong start; + int ret = 0; + int bank; + + bank = irq->id / 32; + mask = 1 << (irq->id % 32); + + /* Wait up to 1ms for GPE status to clear */ + start = get_timer(0); + do { + if (get_timer(start) > 1) + return ret; + + sts = inl(priv->acpi_base + GPE0_STS(bank)); + if (sts & mask) { + outl(mask, priv->acpi_base + GPE0_STS(bank)); + ret = 1; + } + } while (sts & mask); + + return ret; +} + +static int acpi_gpe_ofdata_to_platdata(struct udevice *dev) +{ + struct acpi_gpe_priv *priv = dev_get_priv(dev); + + priv->acpi_base = dev_read_addr(dev); + if (!priv->acpi_base || priv->acpi_base == FDT_ADDR_T_NONE) + return log_msg_ret("acpi_base", -EINVAL); + + return 0; +} + +static int acpi_gpe_of_xlate(struct irq *irq, struct ofnode_phandle_args *args) +{ + irq->id = args->args[0]; + + return 0; +} + +static const struct irq_ops acpi_gpe_ops = { + .read_and_clear = acpi_gpe_read_and_clear, + .of_xlate = acpi_gpe_of_xlate, +}; + +static const struct udevice_id acpi_gpe_ids[] = { + { .compatible = "intel,acpi-gpe", .data = X86_IRQT_ACPI_GPE }, + { } +}; + +U_BOOT_DRIVER(acpi_gpe_drv) = { + .name = "acpi_gpe", + .id = UCLASS_IRQ, + .of_match = acpi_gpe_ids, + .ops = &acpi_gpe_ops, + .ofdata_to_platdata = acpi_gpe_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct acpi_gpe_priv), +}; diff --git a/doc/device-tree-bindings/interrupt-controller/intel,acpi-gpe.txt b/doc/device-tree-bindings/interrupt-controller/intel,acpi-gpe.txt new file mode 100644 index 0000000000..d9252bf29f --- /dev/null +++ b/doc/device-tree-bindings/interrupt-controller/intel,acpi-gpe.txt @@ -0,0 +1,30 @@ +* Intel Advanced Configuration and Power Interface General Purpose Events + +This describes an interrupt controller which provides access to GPEs supported +by the SoC. + +Required properties: + +- compatible : "intel,acpi-gpe" +- interrupt-controller : Identifies the node as an interrupt controller +- #interrupt-cells : The number of cells to define the interrupts. Must be 2: + cell 0: interrupt number (normally >=32 since GPEs below that are reserved) + cell 1: 0 (flags, but none are currently defined) +- reg : The register bank for the controller (set this to the ACPI base). + +Example: + + general-purpose-events { + reg = <IOMAP_ACPI_BASE IOMAP_ACPI_SIZE>; + compatible = "intel,acpi-gpe"; + interrupt-controller; + #interrupt-cells = <2>; + }; + + ... + tpm@50 { + reg = <0x50>; + compatible = "google,cr50"; + ready-gpio = <&gpio_n 0x1c GPIO_ACTIVE_LOW>; + interrupts-extended = <&acpi_gpe 0x3c 0>; + };
Add nodes to the device tree for Cr50 and other available I2C ports. Also enable the ACPI interrupt driver.
Changes in v2: None
arch/x86/cpu/apollolake/Kconfig | 1 + arch/x86/dts/chromebook_coral.dts | 87 +++++++++++++++++++++++++++++++ 2 files changed, 88 insertions(+)
diff --git a/arch/x86/cpu/apollolake/Kconfig b/arch/x86/cpu/apollolake/Kconfig index ec9f993808..2ae6837f75 100644 --- a/arch/x86/cpu/apollolake/Kconfig +++ b/arch/x86/cpu/apollolake/Kconfig @@ -42,6 +42,7 @@ config INTEL_APOLLOLAKE imply CLK imply CMD_CLK imply CLK_INTEL + imply ACPI_GPE
if INTEL_APOLLOLAKE
diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index 8802e7a9f6..4e8c0a6c8a 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -30,6 +30,14 @@ cros-ec0 = &cros_ec; fsp = &fsp_s; spi0 = &spi; + i2c0 = &i2c_0; + i2c1 = &i2c_1; + i2c2 = &i2c_2; + i2c3 = &i2c_3; + i2c4 = &i2c_4; + i2c5 = &i2c_5; + i2c6 = &i2c_6; + i2c7 = &i2c_7; };
config { @@ -81,6 +89,13 @@
+ acpi_gpe: general-purpose-events { + reg = <IOMAP_ACPI_BASE IOMAP_ACPI_SIZE>; + compatible = "intel,acpi-gpe"; + interrupt-controller; + #interrupt-cells = <2>; + }; + keyboard { intel,duplicate-por; }; @@ -249,6 +264,78 @@ }; };
+ i2c_0: i2c2@16,0 { + compatible = "intel,apl-i2c"; + reg = <0x0200b010 0 0 0 0>; + clocks = <&clk CLK_I2C>; + i2c-scl-rising-time-ns = <104>; + i2c-scl-falling-time-ns = <52>; + }; + + i2c_1: i2c2@16,1 { + compatible = "intel,apl-i2c"; + reg = <0x0200b110 0 0 0 0>; + clocks = <&clk CLK_I2C>; + status = "disabled"; + }; + + i2c_2: i2c2@16,2 { + compatible = "intel,apl-i2c"; + reg = <0x0200b210 0 0 0 0>; + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <400000>; + clocks = <&clk CLK_I2C>; + i2c-scl-rising-time-ns = <57>; + i2c-scl-falling-time-ns = <28>; + tpm@50 { + reg = <0x50>; + compatible = "google,cr50"; + u-boot,i2c-offset-len = <0>; + ready-gpio = <&gpio_n 28 GPIO_ACTIVE_LOW>; + interrupts-extended = <&acpi_gpe 0x3c 0>; + }; + }; + + i2c_3: i2c2@16,3 { + compatible = "intel,apl-i2c"; + reg = <0x0200b110 0 0 0 0>; + clocks = <&clk CLK_I2C>; + i2c-scl-rising-time-ns = <76>; + i2c-scl-falling-time-ns = <164>; + }; + + i2c_4: i2c2@17,0 { + compatible = "intel,apl-i2c"; + reg = <0x0200b110 0 0 0 0>; + clocks = <&clk CLK_I2C>; + i2c-sda-hold-time-ns = <350>; + i2c-scl-rising-time-ns = <114>; + i2c-scl-falling-time-ns = <164>; + }; + + i2c_5: i2c2@17,1 { + compatible = "intel,apl-i2c"; + reg = <0x0200b110 0 0 0 0>; + clocks = <&clk CLK_I2C>; + i2c-scl-rising-time-ns = <76>; + i2c-scl-falling-time-ns = <164>; + }; + + i2c_6: i2c2@17,2 { + compatible = "intel,apl-i2c"; + reg = <0x0200b110 0 0 0 0>; + clocks = <&clk CLK_I2C>; + status = "disabled"; + }; + + i2c_7: i2c2@17,3 { + compatible = "intel,apl-i2c"; + reg = <0x0200b110 0 0 0 0>; + clocks = <&clk CLK_I2C>; + status = "disabled"; + }; + serial: serial@18,2 { reg = <0x0200c210 0 0 0 0>; u-boot,dm-pre-reloc;
Add definitions for access and status.
Need to drop the mixed case.
Changes in v2: None
include/tpm-v2.h | 31 +++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+)
diff --git a/include/tpm-v2.h b/include/tpm-v2.h index ae00803f6d..d53d2e4023 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -161,6 +161,37 @@ enum tpm_index_attrs { TPMA_NV_AUTHWRITE | TPMA_NV_POLICYWRITE, };
+enum { + TPM_ACCESS_VALID = 1 << 7, + TPM_ACCESS_ACTIVE_LOCALITY = 1 << 5, + TPM_ACCESS_REQUEST_PENDING = 1 << 2, + TPM_ACCESS_REQUEST_USE = 1 << 1, + TPM_ACCESS_ESTABLISHMENT = 1 << 0, +}; + +enum { + TPM_STS_FAMILY_SHIFT = 26, + TPM_STS_FAMILY_MASK = 0x3 << TPM_STS_FAMILY_SHIFT, + TPM_STS_FAMILY_TPM2 = 1 << TPM_STS_FAMILY_SHIFT, + TPM_STS_RESE_TESTABLISMENT_BIT = 1 << 25, + TPM_STS_COMMAND_CANCEL = 1 << 24, + TPM_STS_BURST_COUNT_SHIFT = 8, + TPM_STS_BURST_COUNT_MASK = 0xffff << TPM_STS_BURST_COUNT_SHIFT, + TPM_STS_VALID = 1 << 7, + TPM_STS_COMMAND_READY = 1 << 6, + TPM_STS_GO = 1 << 5, + TPM_STS_DATA_AVAIL = 1 << 4, + TPM_STS_DATA_EXPECT = 1 << 3, + TPM_STS_SELF_TEST_DONE = 1 << 2, + TPM_STS_RESPONSE_RETRY = 1 << 1, +}; + +enum { + TPM_CMD_COUNT_OFFSET = 2, + TPM_CMD_ORDINAL_OFFSET = 6, + TPM_MAX_BUF_SIZE = 1260, +}; + /** * Issue a TPM2_Startup command. *
H1 is a Google security chip present in recent Chromebooks, Pixel phones and other devices. Cr50 is the name of the software that runs on H1 in Chromebooks.
This chip is used to handle TPM-like functionality and also has quite a few additional features.
Add a driver for this.
drivers/tpm/Kconfig | 10 + drivers/tpm/Makefile | 1 + drivers/tpm/cr50_i2c.c | 661 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 672 insertions(+) create mode 100644 drivers/tpm/cr50_i2c.c
diff --git a/drivers/tpm/Kconfig b/drivers/tpm/Kconfig index 94629dffd2..00d7dc8e48 100644 --- a/drivers/tpm/Kconfig +++ b/drivers/tpm/Kconfig @@ -127,6 +127,16 @@ config TPM_V2
if TPM_V2
+config TPM2_CR50_I2C + bool "Enable support for Google cr50 TPM" + depends on DM_I2C + help + Cr50 is an implementation of a TPM on Google's H1 security chip. + This uses the same open-source firmware as the Chromium OS EC. + While Cr50 has other features, its primary role is as the root of + trust for a devuce, It operates like a TPM and can be used with + verified boot. Cr50 is used on recent Chromebooks (since 2017). + config TPM2_TIS_SANDBOX bool "Enable sandbox TPMv2.x driver" depends on TPM_V2 && SANDBOX diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index 94c337b8ed..4c866b37c5 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -10,5 +10,6 @@ obj-$(CONFIG_TPM_TIS_SANDBOX) += tpm_tis_sandbox.o obj-$(CONFIG_TPM_ST33ZP24_I2C) += tpm_tis_st33zp24_i2c.o obj-$(CONFIG_TPM_ST33ZP24_SPI) += tpm_tis_st33zp24_spi.o
+obj-$(CONFIG_TPM2_CR50_I2C) += cr50_i2c.o obj-$(CONFIG_TPM2_TIS_SANDBOX) += tpm2_tis_sandbox.o obj-$(CONFIG_TPM2_TIS_SPI) += tpm2_tis_spi.o diff --git a/drivers/tpm/cr50_i2c.c b/drivers/tpm/cr50_i2c.c new file mode 100644 index 0000000000..ec40e8f735 --- /dev/null +++ b/drivers/tpm/cr50_i2c.c @@ -0,0 +1,661 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Cr50 / H1 TPM support + * + * Copyright 2018 Google LLC + */ + +#define LOG_CATEGORY UCLASS_TPM + +#include <common.h> +#include <dm.h> +#include <i2c.h> +#include <irq.h> +#include <spl.h> +#include <tpm-v2.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/iomap.h> +#include <asm/arch/pm.h> + +enum { + TIMEOUT_INIT_MS = 30000, /* Very long timeout for TPM init */ + TIMEOUT_LONG_US = 2 * 1000 * 1000, + TIMEOUT_SHORT_US = 2 * 1000, + TIMEOUT_NO_IRQ_US = 20 * 1000, + TIMEOUT_IRQ_US = 100 * 1000, +}; + +enum { + CR50_DID_VID = 0x00281ae0L +}; + +enum { + CR50_MAX_BUF_SIZE = 63, +}; + +struct cr50_priv { + struct gpio_desc ready_gpio; + struct irq irq; + int locality; + uint vendor; + bool use_irq; +}; + +/* Wait for interrupt to indicate TPM is ready */ +static int cr50_i2c_wait_tpm_ready(struct udevice *dev) +{ + struct cr50_priv *priv = dev_get_priv(dev); + ulong timeout, base; + int i; + + if (!priv->use_irq && !dm_gpio_is_valid(&priv->ready_gpio)) { + /* Fixed delay if interrupt not supported */ + udelay(TIMEOUT_NO_IRQ_US); + return 0; + } + + base = timer_get_us(); + timeout = base + TIMEOUT_IRQ_US; + + i = 0; + while (priv->use_irq ? !irq_read_and_clear(&priv->irq) : + !dm_gpio_get_value(&priv->ready_gpio)) { + i++; + if ((int)(timer_get_us() - timeout) >= 0) { + log_warning("Timeout\n"); + /* + * Use this instead of -ETIMEDOUT which is used by i2c + */ + return -ETIME; + } + } + log_debug("i=%d\n", i); + + return 0; +} + +/* Clear pending interrupts */ +static void cr50_i2c_clear_tpm_irq(struct udevice *dev) +{ + struct cr50_priv *priv = dev_get_priv(dev); + + if (priv->use_irq) + irq_read_and_clear(&priv->irq); +} + +/* + * cr50_i2c_read() - read from TPM register + * + * @tpm: TPM chip information + * @addr: register address to read from + * @buffer: provided by caller + * @len: number of bytes to read + * + * 1) send register address byte 'addr' to the TPM + * 2) wait for TPM to indicate it is ready + * 3) read 'len' bytes of TPM response into the provided 'buffer' + * + * Return 0 on success. -ve on error + */ +static int cr50_i2c_read(struct udevice *dev, u8 addr, u8 *buffer, + size_t len) +{ + int ret; + + /* Clear interrupt before starting transaction */ + cr50_i2c_clear_tpm_irq(dev); + + /* Send the register address byte to the TPM */ + ret = dm_i2c_write(dev, 0, &addr, 1); + if (ret) { + log_err("Address write failed (err=%d)\n", ret); + return ret; + } + + /* Wait for TPM to be ready with response data */ + ret = cr50_i2c_wait_tpm_ready(dev); + if (ret) + return ret; + + /* Read response data frrom the TPM */ + ret = dm_i2c_read(dev, 0, buffer, len); + if (ret) { + log_err("Read response failed (err=%d)\n", ret); + return ret; + } + + return 0; +} + +/* + * cr50_i2c_write() - write to TPM register + * + * @tpm: TPM chip information + * @addr: register address to write to + * @buffer: data to write + * @len: number of bytes to write + * + * 1) prepend the provided address to the provided data + * 2) send the address+data to the TPM + * 3) wait for TPM to indicate it is done writing + * + * Returns -1 on error, 0 on success. + */ +static int cr50_i2c_write(struct udevice *dev, u8 addr, const u8 *buffer, + size_t len) +{ + u8 buf[len + 1]; + int ret; + + if (len > CR50_MAX_BUF_SIZE) { + log_err("Length %zd is too large\n", len); + return -E2BIG; + } + + /* Prepend the 'register address' to the buffer */ + buf[0] = addr; + memcpy(buf + 1, buffer, len); + + /* Clear interrupt before starting transaction */ + cr50_i2c_clear_tpm_irq(dev); + + /* Send write request buffer with address */ + ret = dm_i2c_write(dev, 0, buf, len + 1); + if (ret) { + log_err("Error writing to TPM (err=%d)\n", ret); + return ret; + } + + /* Wait for TPM to be ready */ + return cr50_i2c_wait_tpm_ready(dev); +} + +static inline u8 tpm_access(u8 locality) +{ + return 0x0 | (locality << 4); +} + +static inline u8 tpm_sts(u8 locality) +{ + return 0x1 | (locality << 4); +} + +static inline u8 tpm_data_fifo(u8 locality) +{ + return 0x5 | (locality << 4); +} + +static inline u8 tpm_did_vid(u8 locality) +{ + return 0x6 | (locality << 4); +} + +static int release_locality(struct udevice *dev, int force) +{ + struct cr50_priv *priv = dev_get_priv(dev); + u8 mask = TPM_ACCESS_VALID | TPM_ACCESS_REQUEST_PENDING; + u8 addr = tpm_access(priv->locality); + int ret; + u8 buf; + + ret = cr50_i2c_read(dev, addr, &buf, 1); + if (ret) + return ret; + + if (force || (buf & mask) == mask) { + buf = TPM_ACCESS_ACTIVE_LOCALITY; + cr50_i2c_write(dev, addr, &buf, 1); + } + + priv->locality = 0; + + return 0; +} + +/* cr50 requires all 4 bytes of status register to be read */ +static int cr50_i2c_status(struct udevice *dev) +{ + struct cr50_priv *priv = dev_get_priv(dev); + u8 buf[4]; + int ret; + + ret = cr50_i2c_read(dev, tpm_sts(priv->locality), buf, sizeof(buf)); + if (ret) { + log_warning("%s: Failed to read status\n", __func__); + return ret; + } + + return buf[0]; +} + +/* cr50 requires all 4 bytes of status register to be written */ +static int cr50_i2c_ready(struct udevice *dev) +{ + struct cr50_priv *priv = dev_get_priv(dev); + u8 buf[4] = { TPM_STS_COMMAND_READY }; + int ret; + + ret = cr50_i2c_write(dev, tpm_sts(priv->locality), buf, sizeof(buf)); + if (ret) + return ret; + + udelay(TIMEOUT_SHORT_US); + + return 0; +} + +static int cr50_i2c_wait_burststs(struct udevice *dev, u8 mask, + size_t *burst, int *status) +{ + struct cr50_priv *priv = dev_get_priv(dev); + ulong timeout; + u32 buf; + + /* + * cr50 uses bytes 3:2 of status register for burst count and all 4 + * bytes must be read + */ + timeout = timer_get_us() + TIMEOUT_LONG_US; + while (timer_get_us() < timeout) { + if (cr50_i2c_read(dev, tpm_sts(priv->locality), + (u8 *)&buf, sizeof(buf)) < 0) { + udelay(TIMEOUT_SHORT_US); + continue; + } + + *status = buf & 0xff; + *burst = le16_to_cpu((buf >> 8) & 0xffff); + + if ((*status & mask) == mask && + *burst > 0 && *burst <= CR50_MAX_BUF_SIZE) + return 0; + + udelay(TIMEOUT_SHORT_US); + } + + log_warning("Timeout reading burst and status\n"); + + return -ETIMEDOUT; +} + +static int cr50_i2c_recv(struct udevice *dev, u8 *buf, size_t buf_len) +{ + struct cr50_priv *priv = dev_get_priv(dev); + size_t burstcnt, expected, current, len; + u8 addr = tpm_data_fifo(priv->locality); + u8 mask = TPM_STS_VALID | TPM_STS_DATA_AVAIL; + u32 expected_buf; + int status; + int ret; + + debug("%s: len=%x\n", __func__, buf_len); + if (buf_len < TPM_HEADER_SIZE) + return -E2BIG; + + ret = cr50_i2c_wait_burststs(dev, mask, &burstcnt, &status); + if (ret < 0) { + log_warning("First chunk not available\n"); + goto out_err; + } + + /* Read first chunk of burstcnt bytes */ + if (cr50_i2c_read(dev, addr, buf, burstcnt) < 0) { + log_warning("Read failed\n"); + goto out_err; + } + + /* Determine expected data in the return buffer */ + memcpy(&expected_buf, buf + TPM_CMD_COUNT_OFFSET, sizeof(expected_buf)); + expected = be32_to_cpu(expected_buf); + if (expected > buf_len) { + log_warning("Too much data: %zu > %zu\n", expected, buf_len); + goto out_err; + } + + /* Now read the rest of the data */ + current = burstcnt; + while (current < expected) { + /* Read updated burst count and check status */ + if (cr50_i2c_wait_burststs(dev, mask, &burstcnt, &status) < 0) { + log_warning("- burst failure1\n"); + goto out_err; + } + + len = min(burstcnt, expected - current); + if (cr50_i2c_read(dev, addr, buf + current, len) != 0) { + log_warning("Read failed\n"); + goto out_err; + } + + current += len; + } + + if (cr50_i2c_wait_burststs(dev, TPM_STS_VALID, &burstcnt, + &status) < 0) { + log_warning("- burst failure2\n"); + goto out_err; + } + if (status & TPM_STS_DATA_AVAIL) { + log_warning("Data still available\n"); + goto out_err; + } + + return current; + +out_err: + /* Abort current transaction if still pending */ + ret = cr50_i2c_status(dev); + if (ret < 0) + return ret; + if (ret & TPM_STS_COMMAND_READY) { + ret = cr50_i2c_ready(dev); + if (ret) + return ret; + } + + return -EIO; +} + +static int cr50_i2c_send(struct udevice *dev, const u8 *buf, size_t len) +{ + struct cr50_priv *priv = dev_get_priv(dev); + + int status; + size_t burstcnt, limit, sent = 0; + u8 tpm_go[4] = { TPM_STS_GO }; + ulong timeout; + int ret; + + debug("%s: len=%x\n", __func__, len); + timeout = timer_get_us() + TIMEOUT_LONG_US; + do { + ret = cr50_i2c_status(dev); + if (ret < 0) + goto out_err; + if (ret & TPM_STS_COMMAND_READY) + break; + + if (timer_get_us() > timeout) + goto out_err; + + ret = cr50_i2c_ready(dev); + if (ret) + goto out_err; + } while (1); + + while (len > 0) { + u8 mask = TPM_STS_VALID; + + /* Wait for data if this is not the first chunk */ + if (sent > 0) + mask |= TPM_STS_DATA_EXPECT; + + if (cr50_i2c_wait_burststs(dev, mask, &burstcnt, &status) < 0) + goto out_err; + + /* + * Use burstcnt - 1 to account for the address byte + * that is inserted by cr50_i2c_write() + */ + limit = min(burstcnt - 1, len); + if (cr50_i2c_write(dev, tpm_data_fifo(priv->locality), + &buf[sent], limit) != 0) { + log_warning("Write failed\n"); + goto out_err; + } + + sent += limit; + len -= limit; + } + + /* Ensure TPM is not expecting more data */ + if (cr50_i2c_wait_burststs(dev, TPM_STS_VALID, &burstcnt, &status) < 0) + goto out_err; + if (status & TPM_STS_DATA_EXPECT) { + log_warning("Data still expected\n"); + goto out_err; + } + + /* Start the TPM command */ + ret = cr50_i2c_write(dev, tpm_sts(priv->locality), tpm_go, + sizeof(tpm_go)); + if (ret) { + log_warning("Start command failed\n"); + goto out_err; + } + + return sent; + +out_err: + /* Abort current transaction if still pending */ + ret = cr50_i2c_status(dev); + + if (ret < 0 || (ret & TPM_STS_COMMAND_READY)) { + ret = cr50_i2c_ready(dev); + if (ret) + return ret; + } + + return -EIO; +} + +/** + * process_reset() - Wait for the Cr50 to reset + * + * Cr50 processes reset requests asynchronously and consceivably could be busy + * executing a long command and not reacting to the reset pulse for a while. + * + * This function will make sure that the AP does not proceed with boot until + * TPM finished reset processing. + * + * @dev: Cr50 device + * @return 0 if OK, -EPERM if locality could not be taken + */ +static int process_reset(struct udevice *dev) +{ + const int loc = 0; + u8 access; + ulong start; + + /* + * Locality is released by TPM reset. + * + * If locality is taken at this point, this could be due to the fact + * that the TPM is performing a long operation and has not processed + * reset request yet. We'll wait up to CR50_TIMEOUT_INIT_MS and see if + * it releases locality when reset is processed. + */ + start = get_timer(0); + do { + const u8 mask = TPM_ACCESS_VALID | TPM_ACCESS_ACTIVE_LOCALITY; + int ret; + + ret = cr50_i2c_read(dev, tpm_access(loc), + &access, sizeof(access)); + if (ret || ((access & mask) == mask)) { + /* + * Don't bombard the chip with traffic; let it keep + * processing the command. + */ + mdelay(2); + continue; + } + + log_warning("TPM ready after %ld ms\n", get_timer(start)); + + return 0; + } while (get_timer(start) < TIMEOUT_INIT_MS); + + log_warning("TPM failed to reset after %ld ms, status: %#x\n", + get_timer(start), access); + + return -EPERM; +} + +/* + * Locality could be already claimed (if this is a later coreboot stage and + * the RO did not release it), or not yet claimed, if this is verstage or the + * older RO did release it. + */ +static int claim_locality(struct udevice *dev, int loc) +{ + const u8 mask = TPM_ACCESS_VALID | TPM_ACCESS_ACTIVE_LOCALITY; + u8 access; + int ret; + + ret = cr50_i2c_read(dev, tpm_access(loc), &access, sizeof(access)); + if (ret) + return log_msg_ret("read1", ret); + + if ((access & mask) == mask) { + log_warning("Locality already claimed\n"); + return 0; + } + + access = TPM_ACCESS_REQUEST_USE; + ret = cr50_i2c_write(dev, tpm_access(loc), &access, sizeof(access)); + if (ret) + return log_msg_ret("write", ret); + + ret = cr50_i2c_read(dev, tpm_access(loc), &access, sizeof(access)); + if (ret) + return log_msg_ret("read2", ret); + + if ((access & mask) != mask) { + log_err("Failed to claim locality\n"); + return -EPERM; + } + log_info("Claimed locality %d\n", loc); + + return 0; +} + +static int cr50_i2c_get_desc(struct udevice *dev, char *buf, int size) +{ + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + struct cr50_priv *priv = dev_get_priv(dev); + + return snprintf(buf, size, "cr50 TPM 2.0 (i2c %02x id %x) irq=%d", + chip->chip_addr, priv->vendor >> 16, priv->use_irq); +} + +static int cr50_i2c_open(struct udevice *dev) +{ + char buf[80]; + int ret; + + ret = process_reset(dev); + if (ret) + return log_msg_ret("reset", ret); + + ret = claim_locality(dev, 0); + if (ret) + return log_msg_ret("claim", ret); + + cr50_i2c_get_desc(dev, buf, sizeof(buf)); + log_debug("%s\n", buf); + + return 0; +} + +static int cr50_i2c_cleanup(struct udevice *dev) +{ + release_locality(dev, 1); + + return 0; +} + +enum { + TPM_TIMEOUT_MS = 5, + SHORT_TIMEOUT_MS = 750, + LONG_TIMEOUT_MS = 2000, +}; + +static int cr50_i2c_ofdata_to_platdata(struct udevice *dev) +{ + struct tpm_chip_priv *upriv = dev_get_uclass_priv(dev); + struct cr50_priv *priv = dev_get_priv(dev); + struct irq irq; + int ret; + + upriv->version = TPM_V2; + upriv->duration_ms[TPM_SHORT] = SHORT_TIMEOUT_MS; + upriv->duration_ms[TPM_MEDIUM] = LONG_TIMEOUT_MS; + upriv->duration_ms[TPM_LONG] = LONG_TIMEOUT_MS; + upriv->retry_time_ms = TPM_TIMEOUT_MS; + + upriv->pcr_count = 32; + upriv->pcr_select_min = 2; + + /* Optional GPIO to track when cr50 is ready */ + ret = irq_get_by_index(dev, 0, &irq); + if (!ret) { + priv->irq = irq; + priv->use_irq = true; + } else { + ret = gpio_request_by_name(dev, "ready-gpio", 0, + &priv->ready_gpio, GPIOD_IS_IN); + if (ret) { + log_warning("Cr50 does not have an ready GPIO/interrupt (err=%d)\n", + ret); + } + } + + return 0; +} + +static int cr50_i2c_probe(struct udevice *dev) +{ + struct cr50_priv *priv = dev_get_priv(dev); + u32 vendor = 0; + ulong start; + + /* + * 150ms should be enough to synchronise with the TPM even under the + * worst nested-reset-request conditions. In the vast majority of cases + * there will be no wait at all. + */ + start = get_timer(0); + while (get_timer(start) < 150) { + int ret; + + /* Exit once DID and VID verified */ + ret = cr50_i2c_read(dev, tpm_did_vid(0), (u8 *)&vendor, 4); + if (!ret && vendor == CR50_DID_VID) + break; + + /* TPM might be resetting; let's retry in a bit */ + mdelay(10); + } + if (vendor != CR50_DID_VID) { + log_debug("DID_VID %08x not recognised\n", vendor); + return log_msg_ret("vendor-id", -EXDEV); + } + priv->vendor = vendor; + + return 0; +} + +static const struct tpm_ops cr50_i2c_ops = { + .open = cr50_i2c_open, + .get_desc = cr50_i2c_get_desc, + .send = cr50_i2c_send, + .recv = cr50_i2c_recv, + .cleanup = cr50_i2c_cleanup, +}; + +static const struct udevice_id cr50_i2c_ids[] = { + { .compatible = "google,cr50" }, + { } +}; + +U_BOOT_DRIVER(cr50_i2c) = { + .name = "cr50_i2c", + .id = UCLASS_TPM, + .of_match = cr50_i2c_ids, + .ops = &cr50_i2c_ops, + .ofdata_to_platdata = cr50_i2c_ofdata_to_platdata, + .probe = cr50_i2c_probe, + .priv_auto_alloc_size = sizeof(struct cr50_priv), +};
Signed-off-by: Simon Glass sjg@chromium.org
Changes in v2:
- Significant rewrite of cr50 init procedure
- Support use of interrupts
I see that I did not make the timeout changes mentioned in the v1 patch.
I'm actually not sure they are an improvement.
Enable TPM2 so that we can use cr50.
Changes in v2: - Update the commit message - Add new patches to handle requesting interrupts and interrupt state
configs/chromebook_coral_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index 566d47d22f..fcb2952d98 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -54,7 +54,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y -CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y @@ -91,6 +90,8 @@ CONFIG_SPI=y CONFIG_ICH_SPI=y CONFIG_TPL_SYSRESET=y CONFIG_TPM_TIS_LPC=y +# CONFIG_TPM_V1 is not set +CONFIG_TPM2_CR50_I2C=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y
Bin Meng
