[U-Boot] [PATCH 1/5 v2] mtd/nand: Add function board_nand_init_tail() for some special NAND controllers
In some NAND controllers there is a size limitation of RAM buffer(2K bytes). To support large-page NAND chips with greater than 2K pagesize, we need a large buffer, but we don't know pagesize before calling nand_scan_ident(), for more flexible and to identify different cases of large-page greater than 2K bytes, we have a board_nand_init_tail() between nand_scan_ident() and nand_scan_tail().
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- drivers/mtd/nand/nand.c | 19 ++++++++++++++++++- 1 files changed, 18 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/nand/nand.c b/drivers/mtd/nand/nand.c index d987f4c..14b4d67 100644 --- a/drivers/mtd/nand/nand.c +++ b/drivers/mtd/nand/nand.c @@ -39,6 +39,14 @@ static ulong base_address[CONFIG_SYS_MAX_NAND_DEVICE] = CONFIG_SYS_NAND_BASE_LIS static const char default_nand_name[] = "nand"; static __attribute__((unused)) char dev_name[CONFIG_SYS_MAX_NAND_DEVICE][8];
+int __board_nand_init_tail(struct mtd_info *mtd) +{ + /* Allow for init at tail in controller-specific file for some reason */ + return 0; +} +int board_nand_init_tail(struct mtd_info *mtd) +__attribute__((weak, alias("__board_nand_init_tail"))); + static void nand_init_chip(struct mtd_info *mtd, struct nand_chip *nand, ulong base_addr) { @@ -51,7 +59,16 @@ static void nand_init_chip(struct mtd_info *mtd, struct nand_chip *nand,
nand->IO_ADDR_R = nand->IO_ADDR_W = (void __iomem *)base_addr; if (board_nand_init(nand) == 0) { - if (nand_scan(mtd, maxchips) == 0) { + if (!nand_scan_ident(mtd, maxchips, NULL)) { + if (board_nand_init_tail(mtd)) { + mtd->name = NULL; + return; + } + + if (nand_scan_tail(mtd)) { + mtd->name = NULL; + return; + } if (!mtd->name) mtd->name = (char *)default_nand_name; #ifdef CONFIG_NEEDS_MANUAL_RELOC
In the past the ONFI never worked dut to u-boot aborted when nand device id not found in ids table. Now if not found in ids table, u-boot still continues to detect by ONFI way.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- drivers/mtd/nand/nand_base.c | 26 ++++++++++++++++---------- 1 files changed, 16 insertions(+), 10 deletions(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 27f6c77..fd38477 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2592,10 +2592,17 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, if (*dev_id == type->id) break;
+ if (!type->name || !type->pagesize) { + /* Check if chip is ONFI compliant */ + ret = nand_flash_detect_onfi(mtd, chip, &busw); + if (ret) + goto ident_done; + } + if (!type->name) { /* supress warning if there is no nand */ if (*maf_id != 0x00 && *maf_id != 0xff && - *dev_id != 0x00 && *dev_id != 0xff) + *dev_id != 0x00 && *dev_id != 0xff) printk(KERN_INFO "%s: unknown NAND device: " "Manufacturer ID: 0x%02x, Chip ID: 0x%02x\n", __func__, *maf_id, *dev_id); @@ -2608,14 +2615,19 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->chipsize = (uint64_t)type->chipsize << 20; chip->onfi_version = 0;
- ret = nand_flash_detect_onfi(mtd, chip, &busw); - if (!ret) - nand_flash_detect_non_onfi(mtd, chip, type, &busw); + nand_flash_detect_non_onfi(mtd, chip, type, &busw);
/* Get chip options, preserve non chip based options */ chip->options &= ~NAND_CHIPOPTIONS_MSK; chip->options |= type->options & NAND_CHIPOPTIONS_MSK;
+ /* Check if chip is a not a samsung device. Do not clear the + * options for chips which are not having an extended id. + */ + if (*maf_id != NAND_MFR_SAMSUNG && !type->pagesize) + chip->options &= ~NAND_SAMSUNG_LP_OPTIONS; + +ident_done: /* * Set chip as a default. Board drivers can override it, if necessary */ @@ -2657,12 +2669,6 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->badblockpos = mtd->writesize > 512 ? NAND_LARGE_BADBLOCK_POS : NAND_SMALL_BADBLOCK_POS;
- /* Check if chip is a not a samsung device. Do not clear the - * options for chips which are not having an extended id. - */ - if (*maf_id != NAND_MFR_SAMSUNG && !type->pagesize) - chip->options &= ~NAND_SAMSUNG_LP_OPTIONS; - /* Check for AND chips with 4 page planes */ if (chip->options & NAND_4PAGE_ARRAY) chip->erase_cmd = multi_erase_cmd;
remove CONFIG_SYS_NAND_ONFI_DETECTION to enable ONFI detection.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- drivers/mtd/nand/nand_base.c | 9 --------- include/linux/mtd/nand.h | 2 -- 2 files changed, 0 insertions(+), 11 deletions(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index fd38477..80c9e5c 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2415,7 +2415,6 @@ static void nand_set_defaults(struct nand_chip *chip, int busw) chip->controller = &chip->hwcontrol; }
-#ifdef CONFIG_SYS_NAND_ONFI_DETECTION static u16 onfi_crc16(u16 crc, u8 const *p, size_t len) { int i; @@ -2493,14 +2492,6 @@ static int nand_flash_detect_onfi(struct mtd_info *mtd,
return 1; } -#else -static inline int nand_flash_detect_onfi(struct mtd_info *mtd, - struct nand_chip *chip, - int *busw) -{ - return 0; -} -#endif
static void nand_flash_detect_non_onfi(struct mtd_info *mtd, struct nand_chip *chip, diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 1cdc7ae..fc35102 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -472,9 +472,7 @@ struct nand_chip { uint8_t cellinfo; int badblockpos; int onfi_version; -#ifdef CONFIG_SYS_NAND_ONFI_DETECTION struct nand_onfi_params onfi_params; -#endif
int state;
- fix NAND_CMD_READID command for ONFI detect. - add NAND_CMD_PARAM command to read the ONFI parameter page.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- drivers/mtd/nand/fsl_elbc_nand.c | 17 ++++++++++------- 1 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/nand/fsl_elbc_nand.c b/drivers/mtd/nand/fsl_elbc_nand.c index 4d1e527..99d1061 100644 --- a/drivers/mtd/nand/fsl_elbc_nand.c +++ b/drivers/mtd/nand/fsl_elbc_nand.c @@ -340,18 +340,21 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command,
/* READID must read all 5 possible bytes while CEB is active */ case NAND_CMD_READID: - vdbg("fsl_elbc_cmdfunc: NAND_CMD_READID.\n"); + case NAND_CMD_PARAM: + vdbg("fsl_elbc_cmdfunc: NAND_CMD 0x%x.\n", command);
out_be32(&lbc->fir, (FIR_OP_CW0 << FIR_OP0_SHIFT) | (FIR_OP_UA << FIR_OP1_SHIFT) | (FIR_OP_RBW << FIR_OP2_SHIFT)); - out_be32(&lbc->fcr, NAND_CMD_READID << FCR_CMD0_SHIFT); - /* 5 bytes for manuf, device and exts */ - out_be32(&lbc->fbcr, 5); - ctrl->read_bytes = 5; + out_be32(&lbc->fcr, command << FCR_CMD0_SHIFT); + /* + * although currently it's 8 bytes for READID, we always read + * the maximum 256 bytes(for PARAM) + */ + out_be32(&lbc->fbcr, 256); + ctrl->read_bytes = 256; ctrl->use_mdr = 1; - ctrl->mdr = 0; - + ctrl->mdr = column; set_addr(mtd, 0, 0, 0); fsl_elbc_run_command(mtd); return;
Freescale FCM controller has a 2K size limitation of buffer RAM. In order to support the Nand flash chip with pagesize larger than 2K bytes, we read/write 2k data repeatedly by issuing FIR_OP_RB/FIR_OP_WB and save them to a large buffer.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com Signed-off-by: Liu Shuo b35362@freescale.com --- drivers/mtd/nand/fsl_elbc_nand.c | 283 +++++++++++++++++++++++++++++++++---- 1 files changed, 252 insertions(+), 31 deletions(-)
diff --git a/drivers/mtd/nand/fsl_elbc_nand.c b/drivers/mtd/nand/fsl_elbc_nand.c index 99d1061..a2d8067 100644 --- a/drivers/mtd/nand/fsl_elbc_nand.c +++ b/drivers/mtd/nand/fsl_elbc_nand.c @@ -64,7 +64,6 @@ struct fsl_elbc_mtd { struct device *dev; int bank; /* Chip select bank number */ u8 __iomem *vbase; /* Chip select base virtual address */ - int page_size; /* NAND page size (0=512, 1=2048) */ unsigned int fmr; /* FCM Flash Mode Register value */ };
@@ -85,6 +84,8 @@ struct fsl_elbc_ctrl { unsigned int mdr; /* UPM/FCM Data Register value */ unsigned int use_mdr; /* Non zero if the MDR is to be set */ unsigned int oob; /* Non zero if operating on OOB data */ + char *buffer; /* Just used when pagesize is greater */ + /* than FCM RAM 2K limitation */ };
/* These map to the positions used by the FCM hardware ECC generator */ @@ -159,6 +160,35 @@ static struct nand_bbt_descr bbt_mirror_descr = { .pattern = mirror_pattern, };
+static void io_to_buffer(struct mtd_info *mtd, int subpage, int oob) +{ + struct nand_chip *chip = mtd->priv; + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + void *src, *dst; + int len = oob ? 64 : 2048; + + /* for emulating 4096+ bytes NAND using 2048-byte FCM RAM */ + dst = ctrl->buffer + (oob ? mtd->writesize : 0) + subpage * len; + src = ctrl->addr + (oob ? 2048 : 0); + memcpy_fromio(dst, src, len); +} + +static void buffer_to_io(struct mtd_info *mtd, int subpage, int oob) +{ + struct nand_chip *chip = mtd->priv; + struct fsl_elbc_mtd *priv = chip->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + void *src, *dst; + int len = oob ? 64 : 2048; + + src = ctrl->buffer + (oob ? mtd->writesize : 0) + subpage * len; + dst = ctrl->addr + (oob ? 2048 : 0); + memcpy_toio(dst, src, len); + /* See the in_8() in fsl_elbc_write_buf() */ + in_8(ctrl->addr); +} + /*=================================*/
/* @@ -175,7 +205,7 @@ static void set_addr(struct mtd_info *mtd, int column, int page_addr, int oob)
ctrl->page = page_addr;
- if (priv->page_size) { + if (mtd->writesize >= 2048) { out_be32(&lbc->fbar, page_addr >> 6); out_be32(&lbc->fpar, ((page_addr << FPAR_LP_PI_SHIFT) & FPAR_LP_PI) | @@ -194,7 +224,7 @@ static void set_addr(struct mtd_info *mtd, int column, int page_addr, int oob)
/* for OOB data point to the second half of the buffer */ if (oob) - ctrl->index += priv->page_size ? 2048 : 512; + ctrl->index += mtd->writesize;
vdbg("set_addr: bank=%d, ctrl->addr=0x%p (0x%p), " "index %x, pes %d ps %d\n", @@ -256,13 +286,14 @@ static int fsl_elbc_run_command(struct mtd_info *mtd) return ctrl->status == LTESR_CC ? 0 : -EIO; }
-static void fsl_elbc_do_read(struct nand_chip *chip, int oob) +static void fsl_elbc_do_read(struct mtd_info *mtd, int oob) { + struct nand_chip *chip = mtd->priv; struct fsl_elbc_mtd *priv = chip->priv; struct fsl_elbc_ctrl *ctrl = priv->ctrl; fsl_lbc_t *lbc = ctrl->regs;
- if (priv->page_size) { + if (mtd->writesize >= 2048) { out_be32(&lbc->fir, (FIR_OP_CW0 << FIR_OP0_SHIFT) | (FIR_OP_CA << FIR_OP1_SHIFT) | @@ -295,6 +326,7 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, struct fsl_elbc_mtd *priv = chip->priv; struct fsl_elbc_ctrl *ctrl = priv->ctrl; fsl_lbc_t *lbc = ctrl->regs; + int i, nps = mtd->writesize / 2048;
ctrl->use_mdr = 0;
@@ -319,8 +351,28 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, ctrl->read_bytes = mtd->writesize + mtd->oobsize; ctrl->index += column;
- fsl_elbc_do_read(chip, 0); + fsl_elbc_do_read(mtd, 0); fsl_elbc_run_command(mtd); + + if (mtd->writesize <= 2048) + return; + + /* Continue to read the rest bytes if writesize > 2048 */ + io_to_buffer(mtd, 0, 0); + io_to_buffer(mtd, 0, 1); + /* + * Maybe there are some reasons of FCM hardware timing, + * we must insert a FIR_OP_NOP(0x00) before FIR_OP_RB. + */ + out_be32(&lbc->fir, FIR_OP_NOP << FIR_OP0_SHIFT | + FIR_OP_RB << FIR_OP1_SHIFT); + + for (i = 1; i < nps; i++) { + fsl_elbc_run_command(mtd); + io_to_buffer(mtd, i, 0); + io_to_buffer(mtd, i, 1); + } + return;
/* READOOB reads only the OOB because no ECC is performed. */ @@ -328,14 +380,35 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, vdbg("fsl_elbc_cmdfunc: NAND_CMD_READOOB, page_addr:" " 0x%x, column: 0x%x.\n", page_addr, column);
- out_be32(&lbc->fbcr, mtd->oobsize - column); - set_addr(mtd, column, page_addr, 1); + if (mtd->writesize <= 2048) { + out_be32(&lbc->fbcr, mtd->oobsize - column); + set_addr(mtd, column, page_addr, 1); + } else { + out_be32(&lbc->fbcr, 64); + set_addr(mtd, 0, page_addr, 1); + ctrl->index += column; + }
ctrl->read_bytes = mtd->writesize + mtd->oobsize; - - fsl_elbc_do_read(chip, 1); + fsl_elbc_do_read(mtd, 1); fsl_elbc_run_command(mtd);
+ if (mtd->writesize <= 2048) + return; + + if (column < 64) + io_to_buffer(mtd, 0, 1); + + out_be32(&lbc->fpar, in_be32(&lbc->fpar) & ~FPAR_LP_MS); + out_be32(&lbc->fir, FIR_OP_RB << FIR_OP1_SHIFT); + out_be32(&lbc->fbcr, 2112); + + for (i = 1; i < nps; i++) { + fsl_elbc_run_command(mtd); + if (column < (64 * (i + 1))) + io_to_buffer(mtd, i, 1); + } + return;
/* READID must read all 5 possible bytes while CEB is active */ @@ -357,6 +430,8 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, ctrl->mdr = column; set_addr(mtd, 0, 0, 0); fsl_elbc_run_command(mtd); + if (mtd->writesize > 2048) + memcpy_fromio(ctrl->buffer, ctrl->addr, 256); return;
/* ERASE1 stores the block and page address */ @@ -393,9 +468,28 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, page_addr, column);
ctrl->column = column; - ctrl->oob = 0; + if (column >= mtd->writesize) { + /* OOB area */ + column -= mtd->writesize; + ctrl->oob = 1; + } else { + ctrl->oob = 0; + } + + if (mtd->writesize > 2048) { + /* writesize > 2048 */ + fcr = (NAND_CMD_STATUS << FCR_CMD1_SHIFT) | + (NAND_CMD_SEQIN << FCR_CMD2_SHIFT) | + (NAND_CMD_PAGEPROG << FCR_CMD3_SHIFT); + if (ctrl->oob) + fcr |= NAND_CMD_RNDIN << FCR_CMD0_SHIFT;
- if (priv->page_size) { + out_be32(&lbc->fir, + (FIR_OP_CM2 << FIR_OP0_SHIFT) | + (FIR_OP_CA << FIR_OP1_SHIFT) | + (FIR_OP_PA << FIR_OP2_SHIFT) | + (FIR_OP_WB << FIR_OP3_SHIFT)); + } else if (mtd->writesize == 2048) { fcr = (NAND_CMD_SEQIN << FCR_CMD0_SHIFT) | (NAND_CMD_PAGEPROG << FCR_CMD1_SHIFT);
@@ -417,11 +511,9 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, (FIR_OP_WB << FIR_OP4_SHIFT) | (FIR_OP_CW1 << FIR_OP5_SHIFT));
- if (column >= mtd->writesize) { + if (ctrl->oob) { /* OOB area --> READOOB */ - column -= mtd->writesize; fcr |= NAND_CMD_READOOB << FCR_CMD0_SHIFT; - ctrl->oob = 1; } else if (column < 256) { /* First 256 bytes --> READ0 */ fcr |= NAND_CMD_READ0 << FCR_CMD0_SHIFT; @@ -432,12 +524,19 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, }
out_be32(&lbc->fcr, fcr); - set_addr(mtd, column, page_addr, ctrl->oob); + if (column >= mtd->writesize && mtd->writesize > 2048) { + /* for write oob && writesize > 2048 */ + set_addr(mtd, 0, page_addr, 0); + ctrl->index = column; + } else { + set_addr(mtd, column, page_addr, ctrl->oob); + } return; }
/* PAGEPROG reuses all of the setup from SEQIN and adds the length */ case NAND_CMD_PAGEPROG: { + int pos; vdbg("fsl_elbc_cmdfunc: NAND_CMD_PAGEPROG " "writing %d bytes.\n", ctrl->index);
@@ -445,14 +544,71 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, * then set the exact length, otherwise use a full page * write so the HW generates the ECC. */ + if (ctrl->oob || ctrl->column != 0 || - ctrl->index != mtd->writesize + mtd->oobsize) - out_be32(&lbc->fbcr, ctrl->index); - else + ctrl->index != mtd->writesize + mtd->oobsize) { + if (ctrl->oob && mtd->writesize > 2048) { + out_be32(&lbc->fbcr, 64); + } else { + out_be32(&lbc->fbcr, ctrl->index - + ctrl->column); + } + } else { out_be32(&lbc->fbcr, 0); + } + + if (mtd->writesize > 2048) { + if (!ctrl->oob) + buffer_to_io(mtd, 0, 0); + buffer_to_io(mtd, 0, 1); + }
+ if (mtd->writesize <= 2048) + return; + + if (ctrl->oob) { + pos = 2048; + out_be32(&lbc->fir, + (FIR_OP_CM0 << FIR_OP0_SHIFT) | + (FIR_OP_UA << FIR_OP1_SHIFT) | + (FIR_OP_UA << FIR_OP2_SHIFT) | + (FIR_OP_WB << FIR_OP3_SHIFT)); + + for (i = 1; i < nps; i++) { + pos += 2112; + ctrl->mdr = pos; + ctrl->use_mdr = 1; + if (i == nps - 1) { + out_be32(&lbc->fir, + (FIR_OP_CM0 << FIR_OP1_SHIFT) | + (FIR_OP_UA << FIR_OP2_SHIFT) | + (FIR_OP_UA << FIR_OP3_SHIFT) | + (FIR_OP_WB << FIR_OP4_SHIFT) | + (FIR_OP_CM3 << FIR_OP5_SHIFT) | + (FIR_OP_CW1 << FIR_OP6_SHIFT) | + (FIR_OP_RS << FIR_OP7_SHIFT)); + } + buffer_to_io(mtd, i, 1); + fsl_elbc_run_command(mtd); + } + } else { + out_be32(&lbc->fir, FIR_OP_WB << FIR_OP1_SHIFT); + for (i = 1; i < nps; i++) { + if (i == nps - 1) { + ctrl->use_mdr = 1; + out_be32(&lbc->fir, + (FIR_OP_WB << FIR_OP1_SHIFT) | + (FIR_OP_CM3 << FIR_OP2_SHIFT) | + (FIR_OP_CW1 << FIR_OP3_SHIFT) | + (FIR_OP_RS << FIR_OP4_SHIFT)); + } + buffer_to_io(mtd, i, 0); + buffer_to_io(mtd, i, 1); + fsl_elbc_run_command(mtd); + } + } return; }
@@ -473,6 +629,8 @@ static void fsl_elbc_cmdfunc(struct mtd_info *mtd, unsigned int command, * write-protected, even when it is not. */ out_8(ctrl->addr, in_8(ctrl->addr) | NAND_STATUS_WP); + if (mtd->writesize > 2048) + ctrl->buffer[0] = in_8(ctrl->addr); return;
/* RESET without waiting for the ready line */ @@ -519,7 +677,11 @@ static void fsl_elbc_write_buf(struct mtd_info *mtd, const u8 *buf, int len) len = bufsize - ctrl->index; }
- memcpy_toio(&ctrl->addr[ctrl->index], buf, len); + if (mtd->writesize > 2048) + memcpy(&ctrl->buffer[ctrl->index], buf, len); + else + memcpy_toio(&ctrl->addr[ctrl->index], buf, len); + /* * This is workaround for the weird elbc hangs during nand write, * Scott Wood says: "...perhaps difference in how long it takes a @@ -543,8 +705,13 @@ static u8 fsl_elbc_read_byte(struct mtd_info *mtd) struct fsl_elbc_ctrl *ctrl = priv->ctrl;
/* If there are still bytes in the FCM, then use the next byte. */ - if (ctrl->index < ctrl->read_bytes) - return in_8(&ctrl->addr[ctrl->index++]); + if (ctrl->index < ctrl->read_bytes) { + int index = ctrl->index++; + if (mtd->writesize > 2048) + return ctrl->buffer[index]; + else + return in_8(&ctrl->addr[index]); + }
printf("read_byte beyond end of buffer\n"); return ERR_BYTE; @@ -564,7 +731,10 @@ static void fsl_elbc_read_buf(struct mtd_info *mtd, u8 *buf, int len) return;
avail = min((unsigned int)len, ctrl->read_bytes - ctrl->index); - memcpy_fromio(buf, &ctrl->addr[ctrl->index], avail); + if (mtd->writesize > 2048) + memcpy(buf, &ctrl->buffer[ctrl->index], avail); + else + memcpy_fromio(buf, &ctrl->addr[ctrl->index], avail); ctrl->index += avail;
if (len > avail) @@ -598,9 +768,17 @@ static int fsl_elbc_verify_buf(struct mtd_info *mtd, return -EINVAL; }
- for (i = 0; i < len; i++) - if (in_8(&ctrl->addr[ctrl->index + i]) != buf[i]) - break; + if (mtd->writesize > 2048) { + for (i = 0; i < len; i++) { + if (ctrl->buffer[ctrl->index + i] != buf[i]) + break; + } + } else { + for (i = 0; i < len; i++) { + if (in_8(&ctrl->addr[ctrl->index + i]) != buf[i]) + break; + } + }
ctrl->index += len; return i == len && ctrl->status == LTESR_CC ? 0 : -EIO; @@ -637,6 +815,8 @@ static int fsl_elbc_wait(struct mtd_info *mtd, struct nand_chip *chip) * write-protected, even when it is not. */ out_8(ctrl->addr, in_8(ctrl->addr) | NAND_STATUS_WP); + if (mtd->writesize > 2048) + ctrl->buffer[0] = in_8(ctrl->addr); return fsl_elbc_read_byte(mtd); }
@@ -666,11 +846,11 @@ static void fsl_elbc_write_page(struct mtd_info *mtd,
static struct fsl_elbc_ctrl *elbc_ctrl;
-static void fsl_elbc_ctrl_init(void) +static int fsl_elbc_ctrl_init(void) { elbc_ctrl = kzalloc(sizeof(*elbc_ctrl), GFP_KERNEL); if (!elbc_ctrl) - return; + return -ENOMEM;
elbc_ctrl->regs = LBC_BASE_ADDR;
@@ -684,6 +864,21 @@ static void fsl_elbc_ctrl_init(void) elbc_ctrl->read_bytes = 0; elbc_ctrl->index = 0; elbc_ctrl->addr = NULL; + + /* + * Freescale FCM controller has a 2KB size limitation of buffer RAM, + * so elbc_ctrl->buffer have to be used if pagesize of NAND devices + * chip greater than 2048. We malloc a large enough buffer(just max + * 8K pagesize for now) at this point, because we don't know pagesize + * before calling nand_scan_ident(). + */ + elbc_ctrl->buffer = kmalloc(1024 * 8 + 1024, GFP_KERNEL); + if (!elbc_ctrl->buffer) { + printf("failed to allocate memory for elbc_ctrl->buffer\n"); + return -ENOMEM; + } + + return 0; }
int board_nand_init(struct nand_chip *nand) @@ -692,8 +887,7 @@ int board_nand_init(struct nand_chip *nand) uint32_t br = 0, or = 0;
if (!elbc_ctrl) { - fsl_elbc_ctrl_init(); - if (!elbc_ctrl) + if (fsl_elbc_ctrl_init()) return -1; }
@@ -782,7 +976,6 @@ int board_nand_init(struct nand_chip *nand)
/* Large-page-specific setup */ if (or & OR_FCM_PGS) { - priv->page_size = 1; nand->badblock_pattern = &largepage_memorybased;
/* adjust ecc setup if needed */ @@ -796,3 +989,31 @@ int board_nand_init(struct nand_chip *nand)
return 0; } + +int board_nand_init_tail(struct mtd_info *mtd) +{ + struct nand_chip *nand = mtd->priv; + struct fsl_elbc_mtd *priv = nand->priv; + struct fsl_elbc_ctrl *ctrl = priv->ctrl; + + /* adjust Option Register and ECC to match Flash page size */ + if (mtd->writesize == 512) { + clrbits_be32(&ctrl->regs->bank[priv->bank].or, OR_FCM_PGS); + } else if (mtd->writesize >= 2048 && mtd->writesize <= 8192) { + setbits_be32(&ctrl->regs->bank[priv->bank].or, OR_FCM_PGS); + /* adjust ecc setup if needed */ + if ((in_be32(&ctrl->regs->bank[priv->bank].br) & BR_DECC) == + BR_DECC_CHK_GEN) { + nand->ecc.size = 512; + nand->ecc.layout = (priv->fmr & FMR_ECCM) ? + &fsl_elbc_oob_lp_eccm1 : &fsl_elbc_oob_lp_eccm0; + nand->badblock_pattern = &largepage_memorybased; + } + } else { + printf("%s: page size %d is not supported\n", __func__, + mtd->writesize); + return -1; + } + + return 0; +}
I've asked you several times what you're planning on doing for bad block marker migration. I am not going to let you ignore this. NACK until you have a migration tool, and a scheme for marking the flash as having been migrated.
Also please mention below the --- what has changed since v1.
ctrl->oob = 0;
/* OOB area */
ctrl->oob = 1;
} else {
ctrl->oob = 0;
[snip]
How can column >= mtd->writesize be true at this point? You've already subtracted it out.
else
} else {
ctrl->column);
Again, if we're going to make an API assumption that we get either a full page access or a full OOB access, then make the assumption fully. Don't half-implement partial accessses.
- struct nand_chip *nand = mtd->priv;
- struct fsl_elbc_mtd *priv = nand->priv;
- struct fsl_elbc_ctrl *ctrl = priv->ctrl;
- /* adjust Option Register and ECC to match Flash page size */
- if (mtd->writesize == 512) {
- } else if (mtd->writesize >= 2048 && mtd->writesize <= 8192) {
BR_DECC_CHK_GEN) {
Please find some way to indent the continuation line so it doesn't line up with the if-body.
Those oob layouts won't be quite right for larger page sizes.
-Scott
Applied to u-boot-nand-flash
-Scott
Why?
-Scott
Scott Wood
Shengzhou Liu
