[RESEND PATCH 01/16] imx: ventana: ignore EEPROM config when checking for NAND support
EEPROM bits no longer indicate support for NAND so instead use hard-coded value from board config struct.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gw_ventana.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 468fb093b7..dc3300f7b7 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -1017,7 +1017,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; }
- if (test_bit(EECONFIG_NAND, info->config)) { + if (gpio_cfg[board_type].nand) { /* Update partition nodes using info from mtdparts env var */ puts(" Updating MTD partitions...\n"); fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes));
Move board/revision specific dt fixups for WDOG and UHS-I features so that we can call them early for U-Boot control dt as well.
Additionally drop a deprected non-mainline dt-prop fixup regarding HDMI input format.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 131 ++++++++++++++++ board/gateworks/gw_ventana/common.h | 2 + board/gateworks/gw_ventana/gw_ventana.c | 158 +------------------- board/gateworks/gw_ventana/gw_ventana_spl.c | 7 +- 4 files changed, 141 insertions(+), 157 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index c07eb627a2..f9ee167458 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -1697,6 +1697,137 @@ void setup_pmic(void) } }
+#include <fdt_support.h> +#define WDOG1_ADDR 0x20bc000 +#define WDOG2_ADDR 0x20c0000 +#define GPIO3_ADDR 0x20a4000 +#define USDHC3_ADDR 0x2198000 + +static void ft_board_wdog_fixup(void *blob, phys_addr_t addr) +{ + int off = fdt_node_offset_by_compat_reg(blob, "fsl,imx6q-wdt", addr); + + if (off) { + fdt_delprop(blob, off, "ext-reset-output"); + fdt_delprop(blob, off, "fsl,ext-reset-output"); + } +} + +void ft_early_fixup(void *blob, int board_type) +{ + struct ventana_board_info *info = &ventana_info; + char rev = 0; + int i; + + /* determine board revision */ + for (i = sizeof(ventana_info.model) - 1; i > 0; i--) { + if (ventana_info.model[i] >= 'A') { + rev = ventana_info.model[i]; + break; + } + } + + /* + * Board model specific fixups + */ + switch (board_type) { + case GW51xx: + /* + * disable wdog node for GW51xx-A/B to work around + * errata causing wdog timer to be unreliable. + */ + if (rev >= 'A' && rev < 'C') { + i = fdt_node_offset_by_compat_reg(blob, "fsl,imx6q-wdt", + WDOG1_ADDR); + if (i) + fdt_status_disabled(blob, i); + } + + /* GW51xx-E adds WDOG1_B external reset */ + if (rev < 'E') + ft_board_wdog_fixup(blob, WDOG1_ADDR); + break; + + case GW52xx: + /* GW522x Uses GPIO3_IO23 instead of GPIO1_IO29 */ + if (info->model[4] == '2') { + u32 handle = 0; + u32 *range = NULL; + + i = fdt_node_offset_by_compatible(blob, -1, + "fsl,imx6q-pcie"); + if (i) + range = (u32 *)fdt_getprop(blob, i, + "reset-gpio", NULL); + + if (range) { + i = fdt_node_offset_by_compat_reg(blob, + "fsl,imx6q-gpio", GPIO3_ADDR); + if (i) + handle = fdt_get_phandle(blob, i); + if (handle) { + range[0] = cpu_to_fdt32(handle); + range[1] = cpu_to_fdt32(23); + } + } + + /* these have broken usd_vsel */ + if (strstr((const char *)info->model, "SP318-B") || + strstr((const char *)info->model, "SP331-B")) + gpio_cfg[board_type].usd_vsel = 0; + + /* GW522x-B adds WDOG1_B external reset */ + if (rev < 'B') + ft_board_wdog_fixup(blob, WDOG1_ADDR); + } + + /* GW520x-E adds WDOG1_B external reset */ + else if (info->model[4] == '0' && rev < 'E') + ft_board_wdog_fixup(blob, WDOG1_ADDR); + break; + + case GW53xx: + /* GW53xx-E adds WDOG1_B external reset */ + if (rev < 'E') + ft_board_wdog_fixup(blob, WDOG1_ADDR); + break; + + case GW54xx: + /* + * disable serial2 node for GW54xx for compatibility with older + * 3.10.x kernel that improperly had this node enabled in the DT + */ + fdt_set_status_by_alias(blob, "serial2", FDT_STATUS_DISABLED, + 0); + + /* GW54xx-E adds WDOG2_B external reset */ + if (rev < 'E') + ft_board_wdog_fixup(blob, WDOG2_ADDR); + break; + + case GW551x: + /* GW551x-C adds WDOG1_B external reset */ + if (rev < 'C') + ft_board_wdog_fixup(blob, WDOG1_ADDR); + break; + case GW5901: + case GW5902: + /* GW5901/GW5901 revB adds WDOG1_B as an external reset */ + if (rev < 'B') + ft_board_wdog_fixup(blob, WDOG1_ADDR); + break; + } + + /* remove no-1-8-v if UHS-I support is present */ + if (gpio_cfg[board_type].usd_vsel) { + debug("Enabling UHS-I support\n"); + i = fdt_node_offset_by_compat_reg(blob, "fsl,imx6q-usdhc", + USDHC3_ADDR); + if (i) + fdt_delprop(blob, i, "no-1-8-v"); + } +} + #ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg usdhc_cfg[2];
diff --git a/board/gateworks/gw_ventana/common.h b/board/gateworks/gw_ventana/common.h index 813f7d9f56..8f226d109b 100644 --- a/board/gateworks/gw_ventana/common.h +++ b/board/gateworks/gw_ventana/common.h @@ -93,5 +93,7 @@ void setup_pmic(void); void setup_iomux_gpio(int board, struct ventana_board_info *); /* late setup of GPIO (configuration per baseboard and env) */ void setup_board_gpio(int board, struct ventana_board_info *); +/* early model/revision ft fixups */ +void ft_early_fixup(void *fdt, int board_type);
#endif /* #ifndef _GWVENTANA_COMMON_H_ */ diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index dc3300f7b7..7f43e1b620 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -967,16 +967,6 @@ void ft_board_pci_fixup(void *blob, struct bd_info *bd) } #endif /* if defined(CONFIG_CMD_PCI) */
-void ft_board_wdog_fixup(void *blob, phys_addr_t addr) -{ - int off = fdt_node_offset_by_compat_reg(blob, "fsl,imx6q-wdt", addr); - - if (off) { - fdt_delprop(blob, off, "ext-reset-output"); - fdt_delprop(blob, off, "fsl,ext-reset-output"); - } -} - /* * called prior to booting kernel or by 'fdt boardsetup' command * @@ -986,10 +976,6 @@ void ft_board_wdog_fixup(void *blob, phys_addr_t addr) * - board (full model from EEPROM) * - peripherals removed from DTB if not loaded on board (per EEPROM config) */ -#define WDOG1_ADDR 0x20bc000 -#define WDOG2_ADDR 0x20c0000 -#define GPIO3_ADDR 0x20a4000 -#define USDHC3_ADDR 0x2198000 #define PWM0_ADDR 0x2080000 int ft_board_setup(void *blob, struct bd_info *bd) { @@ -1043,139 +1029,8 @@ int ft_board_setup(void *blob, struct bd_info *bd) /* set desired digital video capture format */ ft_sethdmiinfmt(blob, env_get("hdmiinfmt"));
- /* - * Board model specific fixups - */ - switch (board_type) { - case GW51xx: - /* - * disable wdog node for GW51xx-A/B to work around - * errata causing wdog timer to be unreliable. - */ - if (rev >= 'A' && rev < 'C') { - i = fdt_node_offset_by_compat_reg(blob, "fsl,imx6q-wdt", - WDOG1_ADDR); - if (i) - fdt_status_disabled(blob, i); - } - - /* GW51xx-E adds WDOG1_B external reset */ - if (rev < 'E') - ft_board_wdog_fixup(blob, WDOG1_ADDR); - break; - - case GW52xx: - /* GW522x Uses GPIO3_IO23 instead of GPIO1_IO29 */ - if (info->model[4] == '2') { - u32 handle = 0; - u32 *range = NULL; - - i = fdt_node_offset_by_compatible(blob, -1, - "fsl,imx6q-pcie"); - if (i) - range = (u32 *)fdt_getprop(blob, i, - "reset-gpio", NULL); - - if (range) { - i = fdt_node_offset_by_compat_reg(blob, - "fsl,imx6q-gpio", GPIO3_ADDR); - if (i) - handle = fdt_get_phandle(blob, i); - if (handle) { - range[0] = cpu_to_fdt32(handle); - range[1] = cpu_to_fdt32(23); - } - } - - /* these have broken usd_vsel */ - if (strstr((const char *)info->model, "SP318-B") || - strstr((const char *)info->model, "SP331-B")) - gpio_cfg[board_type].usd_vsel = 0; - - /* GW522x-B adds WDOG1_B external reset */ - if (rev < 'B') - ft_board_wdog_fixup(blob, WDOG1_ADDR); - } - - /* GW520x-E adds WDOG1_B external reset */ - else if (info->model[4] == '0' && rev < 'E') - ft_board_wdog_fixup(blob, WDOG1_ADDR); - break; - - case GW53xx: - /* GW53xx-E adds WDOG1_B external reset */ - if (rev < 'E') - ft_board_wdog_fixup(blob, WDOG1_ADDR); - break; - - case GW54xx: - /* - * disable serial2 node for GW54xx for compatibility with older - * 3.10.x kernel that improperly had this node enabled in the DT - */ - fdt_set_status_by_alias(blob, "serial2", FDT_STATUS_DISABLED, - 0); - - /* GW54xx-E adds WDOG2_B external reset */ - if (rev < 'E') - ft_board_wdog_fixup(blob, WDOG2_ADDR); - break; - - case GW551x: - /* - * isolate CSI0_DATA_EN for GW551x-A to work around errata - * causing non functional digital video in (it is not hooked up) - */ - if (rev == 'A') { - u32 *range = NULL; - int len; - const u32 *handle = NULL; - - i = fdt_node_offset_by_compatible(blob, -1, - "fsl,imx-tda1997x-video"); - if (i) - handle = fdt_getprop(blob, i, "pinctrl-0", - NULL); - if (handle) - i = fdt_node_offset_by_phandle(blob, - fdt32_to_cpu(*handle)); - if (i) - range = (u32 *)fdt_getprop(blob, i, "fsl,pins", - &len); - if (range) { - len /= sizeof(u32); - for (i = 0; i < len; i += 6) { - u32 mux_reg = fdt32_to_cpu(range[i+0]); - u32 conf_reg = fdt32_to_cpu(range[i+1]); - /* mux PAD_CSI0_DATA_EN to GPIO */ - if (is_cpu_type(MXC_CPU_MX6Q) && - mux_reg == 0x260 && - conf_reg == 0x630) - range[i+3] = cpu_to_fdt32(0x5); - else if (!is_cpu_type(MXC_CPU_MX6Q) && - mux_reg == 0x08c && - conf_reg == 0x3a0) - range[i+3] = cpu_to_fdt32(0x5); - } - fdt_setprop_inplace(blob, i, "fsl,pins", range, - len); - } - - /* set BT656 video format */ - ft_sethdmiinfmt(blob, "yuv422bt656"); - } - - /* GW551x-C adds WDOG1_B external reset */ - if (rev < 'C') - ft_board_wdog_fixup(blob, WDOG1_ADDR); - break; - case GW5901: - case GW5902: - /* GW5901/GW5901 revB adds WDOG1_B as an external reset */ - if (rev < 'B') - ft_board_wdog_fixup(blob, WDOG1_ADDR); - break; - } + /* early board/revision ft fixups */ + ft_early_fixup(blob, board_type);
/* Configure DIO */ for (i = 0; i < gpio_cfg[board_type].dio_num; i++) { @@ -1201,15 +1056,6 @@ int ft_board_setup(void *blob, struct bd_info *bd) } }
- /* remove no-1-8-v if UHS-I support is present */ - if (gpio_cfg[board_type].usd_vsel) { - debug("Enabling UHS-I support\n"); - i = fdt_node_offset_by_compat_reg(blob, "fsl,imx6q-usdhc", - USDHC3_ADDR); - if (i) - fdt_delprop(blob, i, "no-1-8-v"); - } - #if defined(CONFIG_CMD_PCI) if (!env_get("nopcifixup")) ft_board_pci_fixup(blob, bd); diff --git a/board/gateworks/gw_ventana/gw_ventana_spl.c b/board/gateworks/gw_ventana/gw_ventana_spl.c index a4f64395a1..5a69aff671 100644 --- a/board/gateworks/gw_ventana/gw_ventana_spl.c +++ b/board/gateworks/gw_ventana/gw_ventana_spl.c @@ -729,10 +729,10 @@ void board_boot_order(u32 *spl_boot_list)
/* called from board_init_r after gd setup if CONFIG_SPL_BOARD_INIT defined */ /* its our chance to print info about boot device */ +static int board_type; void spl_board_init(void) { u32 boot_device; - int board_type;
/* determine boot device from SRC_SBMR1 (BOOT_CFG[4:1]) or SRC_GPR9 */ boot_device = spl_boot_device(); @@ -785,3 +785,8 @@ int spl_start_uboot(void) return ret; } #endif + +void spl_perform_fixups(struct spl_image_info *spl_image) +{ + ft_early_fixup(spl_image->fdt_addr, board_type); +}
NAND fdt fixups can be performed without knowing if NAND is present.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 11 ----------- board/gateworks/gw_ventana/common.h | 1 - board/gateworks/gw_ventana/gw_ventana.c | 10 ++++------ 3 files changed, 4 insertions(+), 18 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index f9ee167458..328fdd3b29 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -989,7 +989,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .gps_shdn = IMX_GPIO_NR(1, 2), .vidin_en = IMX_GPIO_NR(5, 20), .wdis = IMX_GPIO_NR(7, 12), - .nand = true, },
/* GW52xx */ @@ -1014,7 +1013,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .rs232_en = GP_RS232_EN, .vsel_pin = IMX_GPIO_NR(6, 14), .mmc_cd = IMX_GPIO_NR(7, 0), - .nand = true, },
/* GW53xx */ @@ -1038,7 +1036,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .rs232_en = GP_RS232_EN, .vsel_pin = IMX_GPIO_NR(6, 14), .mmc_cd = IMX_GPIO_NR(7, 0), - .nand = true, },
/* GW54xx */ @@ -1064,7 +1061,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .rs232_en = GP_RS232_EN, .vsel_pin = IMX_GPIO_NR(6, 14), .mmc_cd = IMX_GPIO_NR(7, 0), - .nand = true, },
/* GW551x */ @@ -1078,7 +1074,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { }, .pcie_rst = IMX_GPIO_NR(1, 0), .wdis = IMX_GPIO_NR(7, 12), - .nand = true, },
/* GW552x */ @@ -1096,7 +1091,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .usb_sel = IMX_GPIO_NR(1, 7), .wdis = IMX_GPIO_NR(7, 12), .msata_en = GP_MSATA_SEL, - .nand = true, },
/* GW553x */ @@ -1114,7 +1108,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .wdis = IMX_GPIO_NR(7, 12), .vsel_pin = IMX_GPIO_NR(6, 14), .mmc_cd = IMX_GPIO_NR(7, 0), - .nand = true, },
/* GW560x */ @@ -1146,7 +1139,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { IMX_GPIO_NR(4, 15), }, .pcie_rst = IMX_GPIO_NR(1, 29), - .nand = true, },
/* GW5902 */ @@ -1159,7 +1151,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { }, .pcie_rst = IMX_GPIO_NR(1, 0), .rs232_en = GP_RS232_EN, - .nand = true, },
/* GW5903 */ @@ -1216,7 +1207,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .usb_sel = IMX_GPIO_NR(1, 7), .wdis = IMX_GPIO_NR(7, 12), .msata_en = GP_MSATA_SEL, - .nand = true, },
/* GW5907 */ @@ -1231,7 +1221,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { }, .pcie_rst = IMX_GPIO_NR(1, 0), .wdis = IMX_GPIO_NR(7, 12), - .nand = true, },
/* GW5908 */ diff --git a/board/gateworks/gw_ventana/common.h b/board/gateworks/gw_ventana/common.h index 8f226d109b..4b2aaf0fda 100644 --- a/board/gateworks/gw_ventana/common.h +++ b/board/gateworks/gw_ventana/common.h @@ -78,7 +78,6 @@ struct ventana { int mmc_cd; /* various features */ bool usd_vsel; - bool nand; };
extern struct ventana gpio_cfg[GW_UNKNOWN]; diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 7f43e1b620..77a2f2ca4b 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -981,7 +981,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) { struct ventana_board_info *info = &ventana_info; struct ventana_eeprom_config *cfg; - static const struct node_info nodes[] = { + static const struct node_info nand_nodes[] = { { "sst,w25q256", MTD_DEV_TYPE_NOR, }, /* SPI flash */ { "fsl,imx6q-gpmi-nand", MTD_DEV_TYPE_NAND, }, /* NAND flash */ }; @@ -1003,11 +1003,9 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; }
- if (gpio_cfg[board_type].nand) { - /* Update partition nodes using info from mtdparts env var */ - puts(" Updating MTD partitions...\n"); - fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); - } + /* Update MTD partition nodes using info from mtdparts env var */ + puts(" Updating MTD partitions...\n"); + fdt_fixup_mtdparts(blob, nand_nodes, ARRAY_SIZE(nand_nodes));
/* Update display timings from display env var */ if (display) {
Use device-tree LED config instead of hard-coded board-specific config.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 149 ---------------------------- board/gateworks/gw_ventana/common.h | 1 - configs/gwventana_emmc_defconfig | 3 + configs/gwventana_gw5904_defconfig | 3 + configs/gwventana_nand_defconfig | 3 + 5 files changed, 9 insertions(+), 150 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 328fdd3b29..729f612f81 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -178,10 +178,6 @@ void setup_ventana_i2c(int i2c) * Baseboard specific GPIO */ static iomux_v3_cfg_t const gw51xx_gpio_pads[] = { - /* PANLEDG# */ - IOMUX_PADS(PAD_KEY_COL0__GPIO4_IO06 | DIO_PAD_CFG), - /* PANLEDR# */ - IOMUX_PADS(PAD_KEY_ROW0__GPIO4_IO07 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ @@ -204,18 +200,12 @@ static iomux_v3_cfg_t const gw52xx_gpio_pads[] = { IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), /* MSATA_EN */ IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), - /* PANLEDG# */ - IOMUX_PADS(PAD_KEY_COL0__GPIO4_IO06 | DIO_PAD_CFG), - /* PANLEDR# */ - IOMUX_PADS(PAD_KEY_ROW0__GPIO4_IO07 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ IOMUX_PADS(PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(IRQ_PAD_CTRL)), /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* GPS_SHDN */ IOMUX_PADS(PAD_ENET_RXD0__GPIO1_IO27 | DIO_PAD_CFG), /* USBOTG_SEL */ @@ -243,12 +233,6 @@ static iomux_v3_cfg_t const gw53xx_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* USB_HUBRST# */ IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), - /* PANLEDG# */ - IOMUX_PADS(PAD_KEY_COL0__GPIO4_IO06 | DIO_PAD_CFG), - /* PANLEDR# */ - IOMUX_PADS(PAD_KEY_ROW0__GPIO4_IO07 | DIO_PAD_CFG), - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ @@ -276,12 +260,6 @@ static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), - /* PANLEDG# */ - IOMUX_PADS(PAD_KEY_COL0__GPIO4_IO06 | DIO_PAD_CFG), - /* PANLEDR# */ - IOMUX_PADS(PAD_KEY_ROW0__GPIO4_IO07 | DIO_PAD_CFG), - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* USB_HUBRST# */ IOMUX_PADS(PAD_SD1_DAT0__GPIO1_IO16 | DIO_PAD_CFG), /* MIPI_DIO */ @@ -307,8 +285,6 @@ static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { static iomux_v3_cfg_t const gw551x_gpio_pads[] = { /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), - /* PANLED# */ - IOMUX_PADS(PAD_KEY_ROW0__GPIO4_IO07 | DIO_PAD_CFG), /* PCI_RST# */ IOMUX_PADS(PAD_GPIO_0__GPIO1_IO00 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ @@ -322,12 +298,6 @@ static iomux_v3_cfg_t const gw552x_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_7__GPIO1_IO07 | DIO_PAD_CFG), /* USB_HUBRST# */ IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), - /* PANLEDG# */ - IOMUX_PADS(PAD_KEY_COL0__GPIO4_IO06 | DIO_PAD_CFG), - /* PANLEDR# */ - IOMUX_PADS(PAD_KEY_ROW0__GPIO4_IO07 | DIO_PAD_CFG), - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* PCI_RST# */ IOMUX_PADS(PAD_ENET_TXD1__GPIO1_IO29 | DIO_PAD_CFG), /* MX6_DIO[4:9] */ @@ -348,10 +318,6 @@ static iomux_v3_cfg_t const gw552x_gpio_pads[] = { static iomux_v3_cfg_t const gw553x_gpio_pads[] = { /* SD3_VSELECT */ IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | DIO_PAD_CFG), - /* PANLEDG# */ - IOMUX_PADS(PAD_KEY_COL2__GPIO4_IO10 | DIO_PAD_CFG), - /* PANLEDR# */ - IOMUX_PADS(PAD_KEY_ROW2__GPIO4_IO11 | DIO_PAD_CFG), /* VID_PWR */ IOMUX_PADS(PAD_CSI0_DATA_EN__GPIO5_IO20 | DIO_PAD_CFG), /* PCI_RST# */ @@ -367,12 +333,6 @@ static iomux_v3_cfg_t const gw560x_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* USB_HUBRST# */ IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), - /* PANLEDG# */ - IOMUX_PADS(PAD_KEY_COL0__GPIO4_IO06 | DIO_PAD_CFG), - /* PANLEDR# */ - IOMUX_PADS(PAD_KEY_ROW0__GPIO4_IO07 | DIO_PAD_CFG), - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ @@ -394,8 +354,6 @@ static iomux_v3_cfg_t const gw560x_gpio_pads[] = { };
static iomux_v3_cfg_t const gw5901_gpio_pads[] = { - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* ETH1_EN */ IOMUX_PADS(PAD_GPIO_1__GPIO1_IO01 | DIO_PAD_CFG), /* CAN_STBY */ @@ -418,8 +376,6 @@ static iomux_v3_cfg_t const gw5901_gpio_pads[] = { };
static iomux_v3_cfg_t const gw5902_gpio_pads[] = { - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* CAN1_STBY */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* CAN2_STBY */ @@ -459,8 +415,6 @@ static iomux_v3_cfg_t const gw5903_gpio_pads[] = { IOMUX_PADS(PAD_DISP0_DAT23__GPIO5_IO17 | DIO_PAD_CFG), /* UART1_TEN# */ IOMUX_PADS(PAD_CSI0_DAT12__GPIO5_IO30 | DIO_PAD_CFG), - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | DIO_PAD_CFG), /* LVDS_BKLEN # */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), /* RGMII_PDWN# */ @@ -474,12 +428,6 @@ static iomux_v3_cfg_t const gw5903_gpio_pads[] = { static iomux_v3_cfg_t const gw5904_gpio_pads[] = { /* USB_HUBRST# */ IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), - /* PANLEDG# */ - IOMUX_PADS(PAD_KEY_COL0__GPIO4_IO06 | DIO_PAD_CFG), - /* PANLEDR# */ - IOMUX_PADS(PAD_KEY_ROW0__GPIO4_IO07 | DIO_PAD_CFG), - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ @@ -511,8 +459,6 @@ static iomux_v3_cfg_t const gw5904_gpio_pads[] = { static iomux_v3_cfg_t const gw5905_gpio_pads[] = { /* EMMY_PDN# */ IOMUX_PADS(PAD_NANDF_D3__GPIO2_IO03 | DIO_PAD_CFG), - /* MX6_LOCLED# */ - IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | DIO_PAD_CFG), /* MIPI_RST */ IOMUX_PADS(PAD_SD2_DAT0__GPIO1_IO15 | DIO_PAD_CFG), /* MIPI_PWDN */ @@ -527,12 +473,6 @@ static iomux_v3_cfg_t const gw5905_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_18__GPIO7_IO13 | DIO_PAD_CFG), /* SPK_SHDN# */ IOMUX_PADS(PAD_GPIO_19__GPIO4_IO05 | DIO_PAD_CFG), - /* LOCLED# */ - IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | DIO_PAD_CFG), - /* FLASH LED1 */ - IOMUX_PADS(PAD_DISP0_DAT11__GPIO5_IO05 | DIO_PAD_CFG), - /* FLASH LED2 */ - IOMUX_PADS(PAD_DISP0_DAT12__GPIO5_IO06 | DIO_PAD_CFG), /* DECT_RST# */ IOMUX_PADS(PAD_DISP0_DAT20__GPIO5_IO14 | DIO_PAD_CFG), /* USBH1_PEN (EHCI) */ @@ -959,11 +899,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw54xx_gpio_pads)/2, .dio_cfg = gw54xx_dio, .dio_num = ARRAY_SIZE(gw54xx_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 10), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(4, 7), .mezz_irq = IMX_GPIO_NR(4, 9), @@ -979,10 +914,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw51xx_gpio_pads)/2, .dio_cfg = gw51xx_dio, .dio_num = ARRAY_SIZE(gw51xx_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 10), - }, .pcie_rst = IMX_GPIO_NR(1, 0), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), @@ -997,11 +928,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw52xx_gpio_pads)/2, .dio_cfg = gw52xx_dio, .dio_num = ARRAY_SIZE(gw52xx_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 7), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), @@ -1021,11 +947,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw53xx_gpio_pads)/2, .dio_cfg = gw53xx_dio, .dio_num = ARRAY_SIZE(gw53xx_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 7), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), @@ -1044,11 +965,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw54xx_gpio_pads)/2, .dio_cfg = gw54xx_dio, .dio_num = ARRAY_SIZE(gw54xx_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 7), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), @@ -1069,9 +985,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw551x_gpio_pads)/2, .dio_cfg = gw551x_dio, .dio_num = ARRAY_SIZE(gw551x_dio), - .leds = { - IMX_GPIO_NR(4, 7), - }, .pcie_rst = IMX_GPIO_NR(1, 0), .wdis = IMX_GPIO_NR(7, 12), }, @@ -1082,11 +995,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw552x_gpio_pads)/2, .dio_cfg = gw552x_dio, .dio_num = ARRAY_SIZE(gw552x_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 7), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 29), .usb_sel = IMX_GPIO_NR(1, 7), .wdis = IMX_GPIO_NR(7, 12), @@ -1099,10 +1007,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw553x_gpio_pads)/2, .dio_cfg = gw553x_dio, .dio_num = ARRAY_SIZE(gw553x_dio), - .leds = { - IMX_GPIO_NR(4, 10), - IMX_GPIO_NR(4, 11), - }, .pcie_rst = IMX_GPIO_NR(1, 0), .vidin_en = IMX_GPIO_NR(5, 20), .wdis = IMX_GPIO_NR(7, 12), @@ -1116,11 +1020,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw560x_gpio_pads)/2, .dio_cfg = gw560x_dio, .dio_num = ARRAY_SIZE(gw560x_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 7), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(4, 31), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), @@ -1135,9 +1034,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .gpio_pads = gw5901_gpio_pads, .num_pads = ARRAY_SIZE(gw5901_gpio_pads)/2, .dio_cfg = gw5901_dio, - .leds = { - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 29), },
@@ -1146,9 +1042,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .gpio_pads = gw5902_gpio_pads, .num_pads = ARRAY_SIZE(gw5902_gpio_pads)/2, .dio_cfg = gw5902_dio, - .leds = { - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 0), .rs232_en = GP_RS232_EN, }, @@ -1159,9 +1052,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw5903_gpio_pads)/2, .dio_cfg = gw5903_dio, .dio_num = ARRAY_SIZE(gw5903_dio), - .leds = { - IMX_GPIO_NR(6, 14), - }, .mmc_cd = IMX_GPIO_NR(6, 11), },
@@ -1171,11 +1061,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw5904_gpio_pads)/2, .dio_cfg = gw5904_dio, .dio_num = ARRAY_SIZE(gw5904_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 7), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 0), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), @@ -1185,9 +1070,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { { .gpio_pads = gw5905_gpio_pads, .num_pads = ARRAY_SIZE(gw5905_gpio_pads)/2, - .leds = { - IMX_GPIO_NR(6, 14), - }, .pcie_rst = IMX_GPIO_NR(7, 11), .wdis = IMX_GPIO_NR(7, 13), }, @@ -1198,11 +1080,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw552x_gpio_pads)/2, .dio_cfg = gw5906_dio, .dio_num = ARRAY_SIZE(gw5906_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 7), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 29), .usb_sel = IMX_GPIO_NR(1, 7), .wdis = IMX_GPIO_NR(7, 12), @@ -1215,10 +1092,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw51xx_gpio_pads)/2, .dio_cfg = gw51xx_dio, .dio_num = ARRAY_SIZE(gw51xx_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 10), - }, .pcie_rst = IMX_GPIO_NR(1, 0), .wdis = IMX_GPIO_NR(7, 12), }, @@ -1229,11 +1102,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw53xx_gpio_pads)/2, .dio_cfg = gw53xx_dio, .dio_num = ARRAY_SIZE(gw53xx_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 7), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), @@ -1250,11 +1118,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw5904_gpio_pads)/2, .dio_cfg = gw5904_dio, .dio_num = ARRAY_SIZE(gw5904_dio), - .leds = { - IMX_GPIO_NR(4, 6), - IMX_GPIO_NR(4, 7), - IMX_GPIO_NR(4, 15), - }, .pcie_rst = IMX_GPIO_NR(1, 0), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), @@ -1269,8 +1132,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { gpio_direction_input(gpio); void setup_iomux_gpio(int board, struct ventana_board_info *info) { - int i; - if (board >= GW_UNKNOWN) return;
@@ -1292,16 +1153,6 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) gpio_request(gpio_cfg[board].pcie_rst, "pci_rst#"); gpio_direction_output(gpio_cfg[board].pcie_rst, 0);
- /* turn off (active-high) user LED's */ - for (i = 0; i < ARRAY_SIZE(gpio_cfg[board].leds); i++) { - char name[16]; - if (gpio_cfg[board].leds[i]) { - sprintf(name, "led_user%d", i); - gpio_request(gpio_cfg[board].leds[i], name); - gpio_direction_output(gpio_cfg[board].leds[i], 1); - } - } - /* MSATA Enable - default to PCI */ if (gpio_cfg[board].msata_en) { gpio_request(gpio_cfg[board].msata_en, "msata_en"); diff --git a/board/gateworks/gw_ventana/common.h b/board/gateworks/gw_ventana/common.h index 4b2aaf0fda..3e67d469dd 100644 --- a/board/gateworks/gw_ventana/common.h +++ b/board/gateworks/gw_ventana/common.h @@ -61,7 +61,6 @@ struct ventana { struct dio_cfg *dio_cfg; int dio_num; /* various gpios (0 if non-existent) */ - int leds[3]; int pcie_rst; int mezz_pwren; int mezz_irq; diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 2fa30d470a..d3f0a0ec2d 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -80,6 +80,9 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 5b75fca9f2..c65c751da6 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -80,6 +80,9 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 16c0374804..78609c34ce 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -82,6 +82,9 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y
The USB HUB reset is handled via dt now.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 729f612f81..3f85fc6915 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -231,8 +231,6 @@ static iomux_v3_cfg_t const gw53xx_gpio_pads[] = { IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), - /* USB_HUBRST# */ - IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ @@ -260,8 +258,6 @@ static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), - /* USB_HUBRST# */ - IOMUX_PADS(PAD_SD1_DAT0__GPIO1_IO16 | DIO_PAD_CFG), /* MIPI_DIO */ IOMUX_PADS(PAD_SD1_DAT3__GPIO1_IO21 | DIO_PAD_CFG), /* RS485_EN */ @@ -296,8 +292,6 @@ static iomux_v3_cfg_t const gw552x_gpio_pads[] = { IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* USBOTG_SEL */ IOMUX_PADS(PAD_GPIO_7__GPIO1_IO07 | DIO_PAD_CFG), - /* USB_HUBRST# */ - IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), /* PCI_RST# */ IOMUX_PADS(PAD_ENET_TXD1__GPIO1_IO29 | DIO_PAD_CFG), /* MX6_DIO[4:9] */ @@ -331,8 +325,6 @@ static iomux_v3_cfg_t const gw560x_gpio_pads[] = { IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), - /* USB_HUBRST# */ - IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ @@ -426,8 +418,6 @@ static iomux_v3_cfg_t const gw5903_gpio_pads[] = { };
static iomux_v3_cfg_t const gw5904_gpio_pads[] = { - /* USB_HUBRST# */ - IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */
The Gateworks Ventana boards have always had usb0=usbh1 and usb1=usbotg because OTG is often subloaded on these boards and a bit in the EEPROM which flagging that OTG is subloaded is used to remove the dt node via the alias.
U-Boot DM_USB UMS requires the usb0 alias be assigned to the usbotg so fix the usb0 alias in order for UMS to work.
Fixes 72c46327f03f: ("imx: ventana: enable dm support for USB")
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/dts/imx6qdl-gw51xx.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw52xx.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw53xx.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw54xx.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw551x.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw552x.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw553x.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw560x.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw5904.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw5907.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw5912.dtsi | 4 ++-- arch/arm/dts/imx6qdl-gw5913.dtsi | 4 ++-- 12 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/arch/arm/dts/imx6qdl-gw51xx.dtsi b/arch/arm/dts/imx6qdl-gw51xx.dtsi index 7e28463084..76a41d563c 100644 --- a/arch/arm/dts/imx6qdl-gw51xx.dtsi +++ b/arch/arm/dts/imx6qdl-gw51xx.dtsi @@ -13,8 +13,8 @@ led0 = &led0; led1 = &led1; nand = &gpmi; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw52xx.dtsi b/arch/arm/dts/imx6qdl-gw52xx.dtsi index f1d9ba1fac..31a059f26b 100644 --- a/arch/arm/dts/imx6qdl-gw52xx.dtsi +++ b/arch/arm/dts/imx6qdl-gw52xx.dtsi @@ -16,8 +16,8 @@ mmc0 = &usdhc3; nand = &gpmi; ssi0 = &ssi1; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw53xx.dtsi b/arch/arm/dts/imx6qdl-gw53xx.dtsi index 172a45ba17..904b228306 100644 --- a/arch/arm/dts/imx6qdl-gw53xx.dtsi +++ b/arch/arm/dts/imx6qdl-gw53xx.dtsi @@ -16,8 +16,8 @@ mmc0 = &usdhc3; nand = &gpmi; ssi0 = &ssi1; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw54xx.dtsi b/arch/arm/dts/imx6qdl-gw54xx.dtsi index e09fad6068..95939cf277 100644 --- a/arch/arm/dts/imx6qdl-gw54xx.dtsi +++ b/arch/arm/dts/imx6qdl-gw54xx.dtsi @@ -17,8 +17,8 @@ mmc0 = &usdhc3; nand = &gpmi; ssi0 = &ssi1; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw551x.dtsi b/arch/arm/dts/imx6qdl-gw551x.dtsi index 1bb586cbd5..c0ffea16d8 100644 --- a/arch/arm/dts/imx6qdl-gw551x.dtsi +++ b/arch/arm/dts/imx6qdl-gw551x.dtsi @@ -57,8 +57,8 @@ led0 = &led0; nand = &gpmi; ssi0 = &ssi1; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw552x.dtsi b/arch/arm/dts/imx6qdl-gw552x.dtsi index 7935b10eab..f6742e5131 100644 --- a/arch/arm/dts/imx6qdl-gw552x.dtsi +++ b/arch/arm/dts/imx6qdl-gw552x.dtsi @@ -14,8 +14,8 @@ led1 = &led1; led2 = &led2; nand = &gpmi; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw553x.dtsi b/arch/arm/dts/imx6qdl-gw553x.dtsi index b6965f25da..e21f068bec 100644 --- a/arch/arm/dts/imx6qdl-gw553x.dtsi +++ b/arch/arm/dts/imx6qdl-gw553x.dtsi @@ -55,8 +55,8 @@ led0 = &led0; led1 = &led1; nand = &gpmi; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw560x.dtsi b/arch/arm/dts/imx6qdl-gw560x.dtsi index bfe65fd3c0..5da19756e0 100644 --- a/arch/arm/dts/imx6qdl-gw560x.dtsi +++ b/arch/arm/dts/imx6qdl-gw560x.dtsi @@ -58,8 +58,8 @@ mmc0 = &usdhc2; mmc1 = &usdhc3; ssi0 = &ssi1; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw5904.dtsi b/arch/arm/dts/imx6qdl-gw5904.dtsi index 9adbd728dc..b5ed2d83c1 100644 --- a/arch/arm/dts/imx6qdl-gw5904.dtsi +++ b/arch/arm/dts/imx6qdl-gw5904.dtsi @@ -56,8 +56,8 @@ led1 = &led1; led2 = &led2; mmc0 = &usdhc3; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw5907.dtsi b/arch/arm/dts/imx6qdl-gw5907.dtsi index 58f73a141e..a36b6e7048 100644 --- a/arch/arm/dts/imx6qdl-gw5907.dtsi +++ b/arch/arm/dts/imx6qdl-gw5907.dtsi @@ -13,8 +13,8 @@ led0 = &led0; led1 = &led1; nand = &gpmi; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw5912.dtsi b/arch/arm/dts/imx6qdl-gw5912.dtsi index 88234a6f13..2537288627 100644 --- a/arch/arm/dts/imx6qdl-gw5912.dtsi +++ b/arch/arm/dts/imx6qdl-gw5912.dtsi @@ -15,8 +15,8 @@ led2 = &led2; mmc0 = &usdhc3; nand = &gpmi; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen { diff --git a/arch/arm/dts/imx6qdl-gw5913.dtsi b/arch/arm/dts/imx6qdl-gw5913.dtsi index f4c2b2189f..c2c1c2b160 100644 --- a/arch/arm/dts/imx6qdl-gw5913.dtsi +++ b/arch/arm/dts/imx6qdl-gw5913.dtsi @@ -13,8 +13,8 @@ led0 = &led0; led1 = &led1; nand = &gpmi; - usb0 = &usbh1; - usb1 = &usbotg; + usb0 = &usbotg; + usb1 = &usbh1; };
chosen {
PCIe reset configuration is handled via dt now.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 49 ------------------------- board/gateworks/gw_ventana/common.h | 1 - board/gateworks/gw_ventana/gw_ventana.c | 12 ------ 3 files changed, 62 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 3f85fc6915..c1a4f8d277 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -187,8 +187,6 @@ static iomux_v3_cfg_t const gw51xx_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* VID_PWR */ IOMUX_PADS(PAD_CSI0_DATA_EN__GPIO5_IO20 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_GPIO_0__GPIO1_IO00 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), }; @@ -212,10 +210,6 @@ static iomux_v3_cfg_t const gw52xx_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* VID_PWR */ IOMUX_PADS(PAD_EIM_D31__GPIO3_IO31 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_ENET_TXD1__GPIO1_IO29 | DIO_PAD_CFG), - /* PCI_RST# (GW522x) */ - IOMUX_PADS(PAD_EIM_D23__GPIO3_IO23 | DIO_PAD_CFG), /* RS485_EN */ IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ @@ -241,8 +235,6 @@ static iomux_v3_cfg_t const gw53xx_gpio_pads[] = { IOMUX_PADS(PAD_ENET_RXD0__GPIO1_IO27 | DIO_PAD_CFG), /* VID_EN */ IOMUX_PADS(PAD_EIM_D31__GPIO3_IO31 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_ENET_TXD1__GPIO1_IO29 | DIO_PAD_CFG), /* RS485_EN */ IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ @@ -268,8 +260,6 @@ static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { IOMUX_PADS(PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(IRQ_PAD_CTRL)), /* DIOI2C_DIS# */ IOMUX_PADS(PAD_GPIO_19__GPIO4_IO05 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_ENET_TXD1__GPIO1_IO29 | DIO_PAD_CFG), /* VID_EN */ IOMUX_PADS(PAD_EIM_D31__GPIO3_IO31 | DIO_PAD_CFG), /* RS485_EN */ @@ -281,8 +271,6 @@ static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { static iomux_v3_cfg_t const gw551x_gpio_pads[] = { /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_GPIO_0__GPIO1_IO00 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), }; @@ -292,8 +280,6 @@ static iomux_v3_cfg_t const gw552x_gpio_pads[] = { IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* USBOTG_SEL */ IOMUX_PADS(PAD_GPIO_7__GPIO1_IO07 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_ENET_TXD1__GPIO1_IO29 | DIO_PAD_CFG), /* MX6_DIO[4:9] */ IOMUX_PADS(PAD_CSI0_PIXCLK__GPIO5_IO18 | DIO_PAD_CFG), IOMUX_PADS(PAD_CSI0_DATA_EN__GPIO5_IO20 | DIO_PAD_CFG), @@ -314,8 +300,6 @@ static iomux_v3_cfg_t const gw553x_gpio_pads[] = { IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | DIO_PAD_CFG), /* VID_PWR */ IOMUX_PADS(PAD_CSI0_DATA_EN__GPIO5_IO20 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_GPIO_0__GPIO1_IO00 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), }; @@ -333,8 +317,6 @@ static iomux_v3_cfg_t const gw560x_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_19__GPIO4_IO05 | DIO_PAD_CFG), /* VID_EN */ IOMUX_PADS(PAD_EIM_D31__GPIO3_IO31 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_DISP0_DAT10__GPIO4_IO31 | DIO_PAD_CFG), /* RS485_EN */ IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ @@ -350,8 +332,6 @@ static iomux_v3_cfg_t const gw5901_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_1__GPIO1_IO01 | DIO_PAD_CFG), /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_ENET_TXD1__GPIO1_IO29 | DIO_PAD_CFG), /* PMIC reset */ IOMUX_PADS(PAD_DISP0_DAT8__WDOG1_B | DIO_PAD_CFG), /* COM_CFGA/B/C/D */ @@ -374,8 +354,6 @@ static iomux_v3_cfg_t const gw5902_gpio_pads[] = { IOMUX_PADS(PAD_SD3_CLK__GPIO7_IO03 | DIO_PAD_CFG), /* UART1_EN# */ IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_GPIO_0__GPIO1_IO00 | DIO_PAD_CFG), /* 5V_UVLO */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), /* ETI_IRQ# */ @@ -455,8 +433,6 @@ static iomux_v3_cfg_t const gw5905_gpio_pads[] = { IOMUX_PADS(PAD_SD2_DAT1__GPIO1_IO14 | DIO_PAD_CFG), /* USBEHCI_SEL */ IOMUX_PADS(PAD_GPIO_7__GPIO1_IO07 | DIO_PAD_CFG), - /* PCI_RST# */ - IOMUX_PADS(PAD_GPIO_16__GPIO7_IO11 | DIO_PAD_CFG), /* LVDS_BKLEN # */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ @@ -889,7 +865,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw54xx_gpio_pads)/2, .dio_cfg = gw54xx_dio, .dio_num = ARRAY_SIZE(gw54xx_dio), - .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(4, 7), .mezz_irq = IMX_GPIO_NR(4, 9), .rs485en = IMX_GPIO_NR(3, 24), @@ -904,7 +879,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw51xx_gpio_pads)/2, .dio_cfg = gw51xx_dio, .dio_num = ARRAY_SIZE(gw51xx_dio), - .pcie_rst = IMX_GPIO_NR(1, 0), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .gps_shdn = IMX_GPIO_NR(1, 2), @@ -918,7 +892,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw52xx_gpio_pads)/2, .dio_cfg = gw52xx_dio, .dio_num = ARRAY_SIZE(gw52xx_dio), - .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .gps_shdn = IMX_GPIO_NR(1, 27), @@ -937,7 +910,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw53xx_gpio_pads)/2, .dio_cfg = gw53xx_dio, .dio_num = ARRAY_SIZE(gw53xx_dio), - .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .gps_shdn = IMX_GPIO_NR(1, 27), @@ -955,7 +927,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw54xx_gpio_pads)/2, .dio_cfg = gw54xx_dio, .dio_num = ARRAY_SIZE(gw54xx_dio), - .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .rs485en = IMX_GPIO_NR(7, 1), @@ -975,7 +946,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw551x_gpio_pads)/2, .dio_cfg = gw551x_dio, .dio_num = ARRAY_SIZE(gw551x_dio), - .pcie_rst = IMX_GPIO_NR(1, 0), .wdis = IMX_GPIO_NR(7, 12), },
@@ -985,7 +955,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw552x_gpio_pads)/2, .dio_cfg = gw552x_dio, .dio_num = ARRAY_SIZE(gw552x_dio), - .pcie_rst = IMX_GPIO_NR(1, 29), .usb_sel = IMX_GPIO_NR(1, 7), .wdis = IMX_GPIO_NR(7, 12), .msata_en = GP_MSATA_SEL, @@ -997,7 +966,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw553x_gpio_pads)/2, .dio_cfg = gw553x_dio, .dio_num = ARRAY_SIZE(gw553x_dio), - .pcie_rst = IMX_GPIO_NR(1, 0), .vidin_en = IMX_GPIO_NR(5, 20), .wdis = IMX_GPIO_NR(7, 12), .vsel_pin = IMX_GPIO_NR(6, 14), @@ -1010,7 +978,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw560x_gpio_pads)/2, .dio_cfg = gw560x_dio, .dio_num = ARRAY_SIZE(gw560x_dio), - .pcie_rst = IMX_GPIO_NR(4, 31), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .rs232_en = GP_RS232_EN, @@ -1024,7 +991,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .gpio_pads = gw5901_gpio_pads, .num_pads = ARRAY_SIZE(gw5901_gpio_pads)/2, .dio_cfg = gw5901_dio, - .pcie_rst = IMX_GPIO_NR(1, 29), },
/* GW5902 */ @@ -1032,7 +998,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .gpio_pads = gw5902_gpio_pads, .num_pads = ARRAY_SIZE(gw5902_gpio_pads)/2, .dio_cfg = gw5902_dio, - .pcie_rst = IMX_GPIO_NR(1, 0), .rs232_en = GP_RS232_EN, },
@@ -1051,7 +1016,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw5904_gpio_pads)/2, .dio_cfg = gw5904_dio, .dio_num = ARRAY_SIZE(gw5904_dio), - .pcie_rst = IMX_GPIO_NR(1, 0), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), }, @@ -1060,7 +1024,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { { .gpio_pads = gw5905_gpio_pads, .num_pads = ARRAY_SIZE(gw5905_gpio_pads)/2, - .pcie_rst = IMX_GPIO_NR(7, 11), .wdis = IMX_GPIO_NR(7, 13), },
@@ -1070,7 +1033,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw552x_gpio_pads)/2, .dio_cfg = gw5906_dio, .dio_num = ARRAY_SIZE(gw5906_dio), - .pcie_rst = IMX_GPIO_NR(1, 29), .usb_sel = IMX_GPIO_NR(1, 7), .wdis = IMX_GPIO_NR(7, 12), .msata_en = GP_MSATA_SEL, @@ -1082,7 +1044,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw51xx_gpio_pads)/2, .dio_cfg = gw51xx_dio, .dio_num = ARRAY_SIZE(gw51xx_dio), - .pcie_rst = IMX_GPIO_NR(1, 0), .wdis = IMX_GPIO_NR(7, 12), },
@@ -1092,7 +1053,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw53xx_gpio_pads)/2, .dio_cfg = gw53xx_dio, .dio_num = ARRAY_SIZE(gw53xx_dio), - .pcie_rst = IMX_GPIO_NR(1, 29), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .gps_shdn = IMX_GPIO_NR(1, 27), @@ -1108,7 +1068,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw5904_gpio_pads)/2, .dio_cfg = gw5904_dio, .dio_num = ARRAY_SIZE(gw5904_dio), - .pcie_rst = IMX_GPIO_NR(1, 0), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), }, @@ -1135,14 +1094,6 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) gpio_direction_output(gpio_cfg[board].rs232_en, 0); }
- /* GW522x Uses GPIO3_IO23 for PCIE_RST# */ - if (board == GW52xx && info->model[4] == '2') - gpio_cfg[board].pcie_rst = IMX_GPIO_NR(3, 23); - - /* assert PCI_RST# */ - gpio_request(gpio_cfg[board].pcie_rst, "pci_rst#"); - gpio_direction_output(gpio_cfg[board].pcie_rst, 0); - /* MSATA Enable - default to PCI */ if (gpio_cfg[board].msata_en) { gpio_request(gpio_cfg[board].msata_en, "msata_en"); diff --git a/board/gateworks/gw_ventana/common.h b/board/gateworks/gw_ventana/common.h index 3e67d469dd..35a5c86e81 100644 --- a/board/gateworks/gw_ventana/common.h +++ b/board/gateworks/gw_ventana/common.h @@ -61,7 +61,6 @@ struct ventana { struct dio_cfg *dio_cfg; int dio_num; /* various gpios (0 if non-existent) */ - int pcie_rst; int mezz_pwren; int mezz_irq; int rs485en; diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 77a2f2ca4b..0d9e7b682a 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -372,18 +372,6 @@ int power_init_board(void) return 0; }
-int imx6_pcie_toggle_reset(struct gpio_desc *gpio, bool active_high) -{ - if (board_type < GW_UNKNOWN) { - uint pin = gpio_cfg[board_type].pcie_rst; - gpio_request(pin, "pci_rst#"); - gpio_direction_output(pin, 0); - mdelay(50); - gpio_direction_output(pin, 1); - } - return 0; -} - /* * Most Ventana boards have a PLX PEX860x PCIe switch onboard and use its * GPIO's as PERST# signals for its downstream ports - configure the GPIO's
pinmux is now done via dt. Add missing OTG_OC pinmux for boards that use it.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/dts/imx6qdl-gw51xx.dtsi | 1 + arch/arm/dts/imx6qdl-gw52xx.dtsi | 1 + arch/arm/dts/imx6qdl-gw54xx.dtsi | 1 + arch/arm/dts/imx6qdl-gw553x.dtsi | 1 + board/gateworks/gw_ventana/common.c | 7 ------- 5 files changed, 4 insertions(+), 7 deletions(-)
diff --git a/arch/arm/dts/imx6qdl-gw51xx.dtsi b/arch/arm/dts/imx6qdl-gw51xx.dtsi index 76a41d563c..812acf7ab8 100644 --- a/arch/arm/dts/imx6qdl-gw51xx.dtsi +++ b/arch/arm/dts/imx6qdl-gw51xx.dtsi @@ -629,6 +629,7 @@ fsl,pins = < MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x17059 MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x1b0b0 /* OTG_PWR_EN */ + MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x17059 >; };
diff --git a/arch/arm/dts/imx6qdl-gw52xx.dtsi b/arch/arm/dts/imx6qdl-gw52xx.dtsi index 31a059f26b..81a9ce38b9 100644 --- a/arch/arm/dts/imx6qdl-gw52xx.dtsi +++ b/arch/arm/dts/imx6qdl-gw52xx.dtsi @@ -734,6 +734,7 @@ fsl,pins = < MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x17059 MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x1b0b0 /* OTG_PWR_EN */ + MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x17059 >; };
diff --git a/arch/arm/dts/imx6qdl-gw54xx.dtsi b/arch/arm/dts/imx6qdl-gw54xx.dtsi index 95939cf277..ffed4fb550 100644 --- a/arch/arm/dts/imx6qdl-gw54xx.dtsi +++ b/arch/arm/dts/imx6qdl-gw54xx.dtsi @@ -819,6 +819,7 @@ fsl,pins = < MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x17059 MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x1b0b0 /* PWR_EN */ + MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x17059 >; };
diff --git a/arch/arm/dts/imx6qdl-gw553x.dtsi b/arch/arm/dts/imx6qdl-gw553x.dtsi index e21f068bec..b15c281852 100644 --- a/arch/arm/dts/imx6qdl-gw553x.dtsi +++ b/arch/arm/dts/imx6qdl-gw553x.dtsi @@ -688,6 +688,7 @@ fsl,pins = < MX6QDL_PAD_GPIO_1__USB_OTG_ID 0x17059 MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x1b0b0 /* OTG_PWR_EN */ + MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x17059 >; };
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index c1a4f8d277..1dead66517 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -182,7 +182,6 @@ static iomux_v3_cfg_t const gw51xx_gpio_pads[] = { IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ IOMUX_PADS(PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(IRQ_PAD_CTRL)), - /* GPS_SHDN */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* VID_PWR */ @@ -321,8 +320,6 @@ static iomux_v3_cfg_t const gw560x_gpio_pads[] = { IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), - /* USBH2_PEN (OTG) */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* 12V0_PWR_EN */ IOMUX_PADS(PAD_DISP0_DAT5__GPIO4_IO26 | DIO_PAD_CFG), }; @@ -360,8 +357,6 @@ static iomux_v3_cfg_t const gw5902_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_5__GPIO1_IO05 | DIO_PAD_CFG), /* DIO_IRQ# */ IOMUX_PADS(PAD_GPIO_7__GPIO1_IO07 | DIO_PAD_CFG), - /* USBOTG_PEN */ - IOMUX_PADS(PAD_EIM_D23__GPIO3_IO23 | DIO_PAD_CFG), };
static iomux_v3_cfg_t const gw5903_gpio_pads[] = { @@ -375,8 +370,6 @@ static iomux_v3_cfg_t const gw5903_gpio_pads[] = { IOMUX_PADS(PAD_NANDF_D4__GPIO2_IO04 | DIO_PAD_CFG), /* USBH1_PEN (EHCI) */ IOMUX_PADS(PAD_EIM_D31__GPIO3_IO31 | DIO_PAD_CFG), - /* USBH2_PEN (OTG) */ - IOMUX_PADS(PAD_KEY_ROW4__GPIO4_IO15 | DIO_PAD_CFG), /* USBDPC_PEN */ IOMUX_PADS(PAD_KEY_ROW0__GPIO4_IO07 | DIO_PAD_CFG), /* TOUCH_RST */
Analog video codec enable is configured in kernel dt.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 25 ------------------------- board/gateworks/gw_ventana/common.h | 1 - 2 files changed, 26 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 1dead66517..719357f128 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -184,8 +184,6 @@ static iomux_v3_cfg_t const gw51xx_gpio_pads[] = { IOMUX_PADS(PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(IRQ_PAD_CTRL)), /* GPS_SHDN */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), - /* VID_PWR */ - IOMUX_PADS(PAD_CSI0_DATA_EN__GPIO5_IO20 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), }; @@ -207,8 +205,6 @@ static iomux_v3_cfg_t const gw52xx_gpio_pads[] = { IOMUX_PADS(PAD_ENET_RXD0__GPIO1_IO27 | DIO_PAD_CFG), /* USBOTG_SEL */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), - /* VID_PWR */ - IOMUX_PADS(PAD_EIM_D31__GPIO3_IO31 | DIO_PAD_CFG), /* RS485_EN */ IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ @@ -232,8 +228,6 @@ static iomux_v3_cfg_t const gw53xx_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_19__GPIO4_IO05 | DIO_PAD_CFG), /* GPS_SHDN */ IOMUX_PADS(PAD_ENET_RXD0__GPIO1_IO27 | DIO_PAD_CFG), - /* VID_EN */ - IOMUX_PADS(PAD_EIM_D31__GPIO3_IO31 | DIO_PAD_CFG), /* RS485_EN */ IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ @@ -259,8 +253,6 @@ static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { IOMUX_PADS(PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(IRQ_PAD_CTRL)), /* DIOI2C_DIS# */ IOMUX_PADS(PAD_GPIO_19__GPIO4_IO05 | DIO_PAD_CFG), - /* VID_EN */ - IOMUX_PADS(PAD_EIM_D31__GPIO3_IO31 | DIO_PAD_CFG), /* RS485_EN */ IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ @@ -297,8 +289,6 @@ static iomux_v3_cfg_t const gw552x_gpio_pads[] = { static iomux_v3_cfg_t const gw553x_gpio_pads[] = { /* SD3_VSELECT */ IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | DIO_PAD_CFG), - /* VID_PWR */ - IOMUX_PADS(PAD_CSI0_DATA_EN__GPIO5_IO20 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), }; @@ -314,8 +304,6 @@ static iomux_v3_cfg_t const gw560x_gpio_pads[] = { IOMUX_PADS(PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(IRQ_PAD_CTRL)), /* DIOI2C_DIS# */ IOMUX_PADS(PAD_GPIO_19__GPIO4_IO05 | DIO_PAD_CFG), - /* VID_EN */ - IOMUX_PADS(PAD_EIM_D31__GPIO3_IO31 | DIO_PAD_CFG), /* RS485_EN */ IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ @@ -875,7 +863,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .gps_shdn = IMX_GPIO_NR(1, 2), - .vidin_en = IMX_GPIO_NR(5, 20), .wdis = IMX_GPIO_NR(7, 12), },
@@ -888,7 +875,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .gps_shdn = IMX_GPIO_NR(1, 27), - .vidin_en = IMX_GPIO_NR(3, 31), .usb_sel = IMX_GPIO_NR(1, 2), .wdis = IMX_GPIO_NR(7, 12), .msata_en = GP_MSATA_SEL, @@ -906,7 +892,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .gps_shdn = IMX_GPIO_NR(1, 27), - .vidin_en = IMX_GPIO_NR(3, 31), .wdis = IMX_GPIO_NR(7, 12), .msata_en = GP_MSATA_SEL, .rs232_en = GP_RS232_EN, @@ -923,7 +908,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .rs485en = IMX_GPIO_NR(7, 1), - .vidin_en = IMX_GPIO_NR(3, 31), .dioi2c_en = IMX_GPIO_NR(4, 5), .pcie_sson = IMX_GPIO_NR(1, 20), .wdis = IMX_GPIO_NR(5, 17), @@ -959,7 +943,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw553x_gpio_pads)/2, .dio_cfg = gw553x_dio, .dio_num = ARRAY_SIZE(gw553x_dio), - .vidin_en = IMX_GPIO_NR(5, 20), .wdis = IMX_GPIO_NR(7, 12), .vsel_pin = IMX_GPIO_NR(6, 14), .mmc_cd = IMX_GPIO_NR(7, 0), @@ -974,7 +957,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .rs232_en = GP_RS232_EN, - .vidin_en = IMX_GPIO_NR(3, 31), .wdis = IMX_GPIO_NR(7, 12), .mmc_cd = IMX_GPIO_NR(7, 0), }, @@ -1049,7 +1031,6 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), .gps_shdn = IMX_GPIO_NR(1, 27), - .vidin_en = IMX_GPIO_NR(3, 31), .wdis = IMX_GPIO_NR(7, 12), .msata_en = GP_MSATA_SEL, .rs232_en = GP_RS232_EN, @@ -1115,12 +1096,6 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) gpio_direction_output(gpio_cfg[board].gps_shdn, 1); }
- /* Analog video codec power enable */ - if (gpio_cfg[board].vidin_en) { - gpio_request(gpio_cfg[board].vidin_en, "anavidin_en"); - gpio_direction_output(gpio_cfg[board].vidin_en, 1); - } - /* DIOI2C_DIS# */ if (gpio_cfg[board].dioi2c_en) { gpio_request(gpio_cfg[board].dioi2c_en, "dioi2c_dis#"); diff --git a/board/gateworks/gw_ventana/common.h b/board/gateworks/gw_ventana/common.h index 35a5c86e81..edfb065f6a 100644 --- a/board/gateworks/gw_ventana/common.h +++ b/board/gateworks/gw_ventana/common.h @@ -65,7 +65,6 @@ struct ventana { int mezz_irq; int rs485en; int gps_shdn; - int vidin_en; int dioi2c_en; int pcie_sson; int usb_sel;
Flexcan pinmux is configured in kernel dt.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 21 --------------------- 1 file changed, 21 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 719357f128..f7819f841c 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -199,8 +199,6 @@ static iomux_v3_cfg_t const gw52xx_gpio_pads[] = { IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ IOMUX_PADS(PAD_EIM_A20__GPIO2_IO18 | MUX_PAD_CTRL(IRQ_PAD_CTRL)), - /* CAN_STBY */ - IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), /* GPS_SHDN */ IOMUX_PADS(PAD_ENET_RXD0__GPIO1_IO27 | DIO_PAD_CFG), /* USBOTG_SEL */ @@ -218,8 +216,6 @@ static iomux_v3_cfg_t const gw53xx_gpio_pads[] = { IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), /* MSATA_EN */ IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), - /* CAN_STBY */ - IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ @@ -241,8 +237,6 @@ static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), /* MSATA_EN */ IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), - /* CAN_STBY */ - IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* MIPI_DIO */ IOMUX_PADS(PAD_SD1_DAT3__GPIO1_IO21 | DIO_PAD_CFG), /* RS485_EN */ @@ -260,8 +254,6 @@ static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { };
static iomux_v3_cfg_t const gw551x_gpio_pads[] = { - /* CAN_STBY */ - IOMUX_PADS(PAD_GPIO_9__GPIO1_IO09 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), }; @@ -296,8 +288,6 @@ static iomux_v3_cfg_t const gw553x_gpio_pads[] = { static iomux_v3_cfg_t const gw560x_gpio_pads[] = { /* RS232_EN# */ IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), - /* CAN_STBY */ - IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* IOEXP_PWREN# */ IOMUX_PADS(PAD_EIM_A19__GPIO2_IO19 | DIO_PAD_CFG), /* IOEXP_IRQ# */ @@ -315,8 +305,6 @@ static iomux_v3_cfg_t const gw560x_gpio_pads[] = { static iomux_v3_cfg_t const gw5901_gpio_pads[] = { /* ETH1_EN */ IOMUX_PADS(PAD_GPIO_1__GPIO1_IO01 | DIO_PAD_CFG), - /* CAN_STBY */ - IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* PMIC reset */ IOMUX_PADS(PAD_DISP0_DAT8__WDOG1_B | DIO_PAD_CFG), /* COM_CFGA/B/C/D */ @@ -333,10 +321,6 @@ static iomux_v3_cfg_t const gw5901_gpio_pads[] = { };
static iomux_v3_cfg_t const gw5902_gpio_pads[] = { - /* CAN1_STBY */ - IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), - /* CAN2_STBY */ - IOMUX_PADS(PAD_SD3_CLK__GPIO7_IO03 | DIO_PAD_CFG), /* UART1_EN# */ IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), /* 5V_UVLO */ @@ -1139,12 +1123,7 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) gpio_request(IMX_GPIO_NR(4, 26), "12p0_en"); gpio_direction_output(IMX_GPIO_NR(4, 26), 1); break; - case GW5901: - SETUP_GPIO_OUTPUT(IMX_GPIO_NR(1, 2), "can_stby", 0); - break; case GW5902: - SETUP_GPIO_OUTPUT(IMX_GPIO_NR(1, 2), "can1_stby", 0); - SETUP_GPIO_OUTPUT(IMX_GPIO_NR(7, 3), "can2_stby", 0); SETUP_GPIO_OUTPUT(IMX_GPIO_NR(7, 12), "5P0V_EN", 1); break; case GW5903:
Use dt-bindings for GSC hwmon devices.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gsc.c | 172 ++++++++++++++++++++----------- 1 file changed, 113 insertions(+), 59 deletions(-)
diff --git a/board/gateworks/gw_ventana/gsc.c b/board/gateworks/gw_ventana/gsc.c index ffed6b5fc8..443ecea572 100644 --- a/board/gateworks/gw_ventana/gsc.c +++ b/board/gateworks/gw_ventana/gsc.c @@ -15,10 +15,13 @@ #include <linux/ctype.h>
#include <asm/arch/sys_proto.h> +#include <asm/global_data.h>
#include "ventana_eeprom.h" #include "gsc.h"
+DECLARE_GLOBAL_DATA_PTR; + /* * The Gateworks System Controller will fail to ACK a master transaction if * it is busy, which can occur during its 1HZ timer tick while reading ADC's. @@ -65,24 +68,116 @@ int gsc_i2c_write(uchar chip, uint addr, int alen, uchar *buf, int len) return ret; }
-static void read_hwmon(const char *name, uint reg, uint size) +int gsc_get_board_temp(void) { - unsigned char buf[3]; - uint ui; + const void *fdt = gd->fdt_blob; + int node, reg, mode, val; + const char *label; + u8 buf[2]; + int ret;
- printf("%-8s:", name); - memset(buf, 0, sizeof(buf)); - if (gsc_i2c_read(GSC_HWMON_ADDR, reg, 1, buf, size)) { - puts("fRD\n"); - } else { - ui = buf[0] | (buf[1]<<8) | (buf[2]<<16); - if (size == 2 && ui > 0x8000) - ui -= 0xffff; - if (ui == 0xffffff) - puts("invalid\n"); - else - printf("%d\n", ui); + node = fdt_node_offset_by_compatible(fdt, -1, "gw,gsc-adc"); + if (node <= 0) + return node; + i2c_set_bus_num(0); + + /* iterate over hwmon nodes */ + node = fdt_first_subnode(fdt, node); + while (node > 0) { + reg = fdtdec_get_int(fdt, node, "reg", -1); + mode = fdtdec_get_int(fdt, node, "gw,mode", -1); + label = fdt_stringlist_get(fdt, node, "label", 0, NULL); + + if ((reg == -1) || (mode == -1) || !label) { + printf("invalid dt:%s\n", fdt_get_name(fdt, node, NULL)); + continue; + } + + if ((mode != 0) || strcmp(label, "temp")) + continue; + + memset(buf, 0, sizeof(buf)); + ret = gsc_i2c_read(GSC_HWMON_ADDR, reg, 1, buf, sizeof(buf)); + val = buf[0] | buf[1] << 8; + if (val >= 0) { + if (val > 0x8000) + val -= 0xffff; + return val; + } + node = fdt_next_subnode(fdt, node); } + + return 0; +} + +/* display hardware monitor ADC channels */ +int gsc_hwmon(void) +{ + const void *fdt = gd->fdt_blob; + int node, reg, mode, len, val, offset; + const char *label; + u8 buf[2]; + int ret; + + node = fdt_node_offset_by_compatible(fdt, -1, "gw,gsc-adc"); + if (node <= 0) + return node; + i2c_set_bus_num(0); + + /* iterate over hwmon nodes */ + node = fdt_first_subnode(fdt, node); + while (node > 0) { + reg = fdtdec_get_int(fdt, node, "reg", -1); + mode = fdtdec_get_int(fdt, node, "gw,mode", -1); + offset = fdtdec_get_int(fdt, node, "gw,voltage-offset-microvolt", 0); + label = fdt_stringlist_get(fdt, node, "label", 0, NULL); + + if ((reg == -1) || (mode == -1) || !label) + printf("invalid dt:%s\n", fdt_get_name(fdt, node, NULL)); + + memset(buf, 0, sizeof(buf)); + ret = gsc_i2c_read(GSC_HWMON_ADDR, reg, 1, buf, sizeof(buf)); + val = buf[0] | buf[1] << 8; + if (val >= 0) { + const u32 *div; + int r[2]; + + switch (mode) { + case 0: /* temperature (C*10) */ + if (val > 0x8000) + val -= 0xffff; + printf("%-8s: %d.%ldC\n", label, val / 10, abs(val % 10)); + break; + case 1: /* prescaled voltage */ + if (val != 0xffff) + printf("%-8s: %d.%03dV\n", label, val / 1000, val % 1000); + break; + case 2: /* scaled based on ref volt and resolution */ + val *= 2500; + val /= 1 << 12; + + /* apply pre-scaler voltage divider */ + div = fdt_getprop(fdt, node, "gw,voltage-divider-ohms", &len); + if (div && (len == sizeof(uint32_t) * 2)) { + r[0] = fdt32_to_cpu(div[0]); + r[1] = fdt32_to_cpu(div[1]); + if (r[0] && r[1]) { + val *= (r[0] + r[1]); + val /= r[1]; + } + } + + /* adjust by offset */ + val += (offset / 1000); + + printf("%-8s: %d.%03dV\n", label, val / 1000, val % 1000); + break; + } + } + node = fdt_next_subnode(fdt, node); + } + + return 0; }
int gsc_info(int verbose) @@ -103,54 +198,13 @@ int gsc_info(int verbose) gsc_i2c_write(GSC_SC_ADDR, GSC_SC_STATUS, 1, &buf[GSC_SC_STATUS], 1); } - if (!gsc_i2c_read(GSC_HWMON_ADDR, GSC_HWMON_TEMP, 1, buf, 2)) { - int ui = buf[0] | buf[1]<<8; - if (ui > 0x8000) - ui -= 0xffff; - printf(" board temp at %dC", ui / 10); - } + printf(" board temp at %dC", gsc_get_board_temp() / 10); puts("\n"); if (!verbose) return CMD_RET_SUCCESS;
- read_hwmon("Temp", GSC_HWMON_TEMP, 2); - read_hwmon("VIN", GSC_HWMON_VIN, 3); - read_hwmon("VBATT", GSC_HWMON_VBATT, 3); - read_hwmon("VDD_3P3", GSC_HWMON_VDD_3P3, 3); - read_hwmon("VDD_ARM", GSC_HWMON_VDD_CORE, 3); - read_hwmon("VDD_SOC", GSC_HWMON_VDD_SOC, 3); - read_hwmon("VDD_HIGH", GSC_HWMON_VDD_HIGH, 3); - read_hwmon("VDD_DDR", GSC_HWMON_VDD_DDR, 3); - read_hwmon("VDD_5P0", GSC_HWMON_VDD_5P0, 3); - if (strncasecmp((const char*) ventana_info.model, "GW553", 5)) - read_hwmon("VDD_2P5", GSC_HWMON_VDD_2P5, 3); - read_hwmon("VDD_1P8", GSC_HWMON_VDD_1P8, 3); - read_hwmon("VDD_IO2", GSC_HWMON_VDD_IO2, 3); - switch (ventana_info.model[3]) { - case '1': /* GW51xx */ - read_hwmon("VDD_IO3", GSC_HWMON_VDD_IO4, 3); /* -C rev */ - break; - case '2': /* GW52xx */ - break; - case '3': /* GW53xx */ - read_hwmon("VDD_IO4", GSC_HWMON_VDD_IO4, 3); /* -C rev */ - read_hwmon("VDD_GPS", GSC_HWMON_VDD_IO3, 3); - break; - case '4': /* GW54xx */ - read_hwmon("VDD_IO3", GSC_HWMON_VDD_IO4, 3); /* -C rev */ - read_hwmon("VDD_GPS", GSC_HWMON_VDD_IO3, 3); - break; - case '5': /* GW55xx */ - break; - case '6': /* GW560x */ - read_hwmon("VDD_IO4", GSC_HWMON_VDD_IO4, 3); - read_hwmon("VDD_GPS", GSC_HWMON_VDD_IO3, 3); - break; - case '9': /* GW590x */ - read_hwmon("AMONBMON", GSC_HWMON_VDD_IO3, 3); - read_hwmon("BAT_VOLT", GSC_HWMON_VDD_EXT, 3); - read_hwmon("BAT_TEMP", GSC_HWMON_VDD_IO4, 2); - } + gsc_hwmon(); + return 0; }
The GW5910 is a Single Board Computer based on the NXP i.MX6Q/DL SoC with the following features: - DDR3 DRAM - NAND FLASH (256MiB or 2048MiB) - microSD socket - Gateworks System Periperhal Controller - front panel LED's - front panel pushbutton - RS232 connector (2x UARTs) - Digital I/O connector (I2C/GPIO) - SPI connector - u-blox Zoe-M8Q GPS - LIS2DE12 Accellerometer - TI CC1352 ARM Cortex-M4 multiprotocol sub-1GHz / 2.4GHz wireless MCU - On-board brcmfmac WiFi and BT module - RGMII RJ45 GbE - 1x MiniPCIe socket with PCIe/USB 2.0 - 1x MiniPCIe socket with USB 2.0 and nanoSIM socket - Passive PoE and wide-range DC power supply
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 47 +++++++++++++++++++++ board/gateworks/gw_ventana/eeprom.c | 2 + board/gateworks/gw_ventana/ventana_eeprom.h | 1 + 3 files changed, 50 insertions(+)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index f7819f841c..270c4cf3a3 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -19,6 +19,7 @@ #include <power/pmic.h> #include <power/ltc3676_pmic.h> #include <power/pfuze100_pmic.h> +#include <power/mp5416.h>
#include "common.h"
@@ -420,6 +421,19 @@ static iomux_v3_cfg_t const gw5905_gpio_pads[] = { IOMUX_PADS(PAD_KEY_COL0__GPIO4_IO06 | DIO_PAD_CFG), };
+static iomux_v3_cfg_t const gw5910_gpio_pads[] = { + /* SD3_VSELECT */ + IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | DIO_PAD_CFG), + /* RS232_EN# */ + IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), + /* RF_RESET# */ + IOMUX_PADS(PAD_GPIO_7__GPIO1_IO07 | DIO_PAD_CFG), + /* RF_BOOT */ + IOMUX_PADS(PAD_GPIO_8__GPIO1_IO08 | DIO_PAD_CFG), + /* PCIESKT_WDIS# */ + IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), +}; + /* Digital I/O */ struct dio_cfg gw51xx_dio[] = { { @@ -1029,6 +1043,18 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), }, + + /* GW5910 */ + { + .gpio_pads = gw5910_gpio_pads, + .num_pads = ARRAY_SIZE(gw5910_gpio_pads) / 2, + .dio_cfg = gw52xx_dio, + .dio_num = ARRAY_SIZE(gw52xx_dio), + .wdis = IMX_GPIO_NR(7, 12), + .rs232_en = GP_RS232_EN, + .vsel_pin = IMX_GPIO_NR(6, 14), + .mmc_cd = IMX_GPIO_NR(7, 0), + }, };
#define SETUP_GPIO_OUTPUT(gpio, name, level) \ @@ -1181,6 +1207,11 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) */ SETUP_GPIO_OUTPUT(IMX_GPIO_NR(4, 8), "touch_rst", 1); break; + case GW5910: + /* CC1352 */ + SETUP_GPIO_OUTPUT(IMX_GPIO_NR(1, 7), "rf_reset#", 1); + SETUP_GPIO_OUTPUT(IMX_GPIO_NR(1, 8), "rf_boot", 1); + break; } }
@@ -1423,6 +1454,21 @@ void setup_pmic(void) pmic_reg_write(p, LTC3676_BUCK3, 0xc0); pmic_reg_write(p, LTC3676_BUCK4, 0xc0); } + + /* configure MP5416 PMIC */ + else if (!i2c_probe(0x69)) { + puts("PMIC: MP5416\n"); + switch (board) { + case GW5910: + /* SW1: VDD_ARM 1.2V -> (1.275 to 1.475) */ + reg = MP5416_VSET_EN | MP5416_VSET_SW1_SVAL(1475000); + i2c_write(0x69, MP5416_VSET_SW1, 1, (uint8_t *)®, 1); + /* SW4: VDD_SOC 1.2V -> (1.350 to 1.475) */ + reg = MP5416_VSET_EN | MP5416_VSET_SW4_SVAL(1475000); + i2c_write(0x69, MP5416_VSET_SW4, 1, (uint8_t *)®, 1); + break; + } + } }
#include <fdt_support.h> @@ -1570,6 +1616,7 @@ int board_mmc_init(struct bd_info *bis) case GW53xx: case GW54xx: case GW553x: + case GW5910: /* usdhc3: 4bit microSD */ SETUP_IOMUX_PADS(usdhc3_pads); usdhc_cfg[0].esdhc_base = USDHC3_BASE_ADDR; diff --git a/board/gateworks/gw_ventana/eeprom.c b/board/gateworks/gw_ventana/eeprom.c index b9862c7dfc..1e48141160 100644 --- a/board/gateworks/gw_ventana/eeprom.c +++ b/board/gateworks/gw_ventana/eeprom.c @@ -124,6 +124,8 @@ read_eeprom(int bus, struct ventana_board_info *info) type = GW5908; else if (info->model[4] == '0' && info->model[5] == '9') type = GW5909; + else if (info->model[4] == '1' && info->model[5] == '0') + type = GW5910; break; default: printf("EEPROM: Unknown model in EEPROM: %s\n", info->model); diff --git a/board/gateworks/gw_ventana/ventana_eeprom.h b/board/gateworks/gw_ventana/ventana_eeprom.h index 4fa085b320..7c01e9edb4 100644 --- a/board/gateworks/gw_ventana/ventana_eeprom.h +++ b/board/gateworks/gw_ventana/ventana_eeprom.h @@ -121,6 +121,7 @@ enum { GW5907, GW5908, GW5909, + GW5910, GW_UNKNOWN, GW_BADCRC, };
The GW5912 is a Single Board Computer based on the NXP i.MX6Q/DL SoC with the following features: - DDR3 DRAM - NAND FLASH (256MiB or 2048MiB) - microSD socket - Gateworks System Periperhal Controller - front panel LED's - front panel pushbutton - RS232 connector (2x UARTs) - CAN/RS485 connector - Digital I/O connector (I2C/GPIO) - SPI connector - u-blox Zoe-M8Q GPS - LIS2DE12 Accellerometer - 1x FEC GbE RJ45 with 802.3at Active PoE - 1x PCI GbE RJ45 with Passive PoE - 5x MiniPCIe socket with PCIe/USB 2.0 - 1x MiniPCIe socket with PCIe/USB 2.0 and SIM socket - Aux power input with wide-range DC power supply
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 30 ++++++++++++++++++++- board/gateworks/gw_ventana/eeprom.c | 2 ++ board/gateworks/gw_ventana/ventana_eeprom.h | 1 + 3 files changed, 32 insertions(+), 1 deletion(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 270c4cf3a3..3a0b18672f 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -434,6 +434,15 @@ static iomux_v3_cfg_t const gw5910_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), };
+static iomux_v3_cfg_t const gw5912_gpio_pads[] = { + /* SD3_VSELECT */ + IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | DIO_PAD_CFG), + /* RS232_EN# */ + IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), + /* PCIESKT_WDIS# */ + IOMUX_PADS(PAD_GPIO_0__GPIO1_IO00 | DIO_PAD_CFG), +}; + /* Digital I/O */ struct dio_cfg gw51xx_dio[] = { { @@ -850,6 +859,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .dioi2c_en = IMX_GPIO_NR(4, 5), .pcie_sson = IMX_GPIO_NR(1, 20), .mmc_cd = IMX_GPIO_NR(7, 0), + .wdis = -1, },
/* GW51xx */ @@ -964,6 +974,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .gpio_pads = gw5901_gpio_pads, .num_pads = ARRAY_SIZE(gw5901_gpio_pads)/2, .dio_cfg = gw5901_dio, + .wdis = -1, },
/* GW5902 */ @@ -972,6 +983,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .num_pads = ARRAY_SIZE(gw5902_gpio_pads)/2, .dio_cfg = gw5902_dio, .rs232_en = GP_RS232_EN, + .wdis = -1, },
/* GW5903 */ @@ -981,6 +993,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .dio_cfg = gw5903_dio, .dio_num = ARRAY_SIZE(gw5903_dio), .mmc_cd = IMX_GPIO_NR(6, 11), + .wdis = -1, },
/* GW5904 */ @@ -991,6 +1004,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .dio_num = ARRAY_SIZE(gw5904_dio), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), + .wdis = -1, },
/* GW5905 */ @@ -1042,6 +1056,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .dio_num = ARRAY_SIZE(gw5904_dio), .mezz_pwren = IMX_GPIO_NR(2, 19), .mezz_irq = IMX_GPIO_NR(2, 18), + .wdis = -1, },
/* GW5910 */ @@ -1055,6 +1070,18 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .vsel_pin = IMX_GPIO_NR(6, 14), .mmc_cd = IMX_GPIO_NR(7, 0), }, + + /* GW5912 */ + { + .gpio_pads = gw5912_gpio_pads, + .num_pads = ARRAY_SIZE(gw5912_gpio_pads) / 2, + .dio_cfg = gw54xx_dio, + .dio_num = ARRAY_SIZE(gw54xx_dio), + .wdis = IMX_GPIO_NR(1, 0), + .rs232_en = GP_RS232_EN, + .vsel_pin = IMX_GPIO_NR(6, 14), + .mmc_cd = IMX_GPIO_NR(7, 0), + }, };
#define SETUP_GPIO_OUTPUT(gpio, name, level) \ @@ -1125,7 +1152,7 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) }
/* PCISKT_WDIS# (Wireless disable GPIO to miniPCIe sockets) */ - if (gpio_cfg[board].wdis) { + if (gpio_cfg[board].wdis != -1) { gpio_request(gpio_cfg[board].wdis, "wlan_dis"); gpio_direction_output(gpio_cfg[board].wdis, 1); } @@ -1617,6 +1644,7 @@ int board_mmc_init(struct bd_info *bis) case GW54xx: case GW553x: case GW5910: + case GW5912: /* usdhc3: 4bit microSD */ SETUP_IOMUX_PADS(usdhc3_pads); usdhc_cfg[0].esdhc_base = USDHC3_BASE_ADDR; diff --git a/board/gateworks/gw_ventana/eeprom.c b/board/gateworks/gw_ventana/eeprom.c index 1e48141160..a4f3065c7d 100644 --- a/board/gateworks/gw_ventana/eeprom.c +++ b/board/gateworks/gw_ventana/eeprom.c @@ -126,6 +126,8 @@ read_eeprom(int bus, struct ventana_board_info *info) type = GW5909; else if (info->model[4] == '1' && info->model[5] == '0') type = GW5910; + else if (info->model[4] == '1' && info->model[5] == '2') + type = GW5912; break; default: printf("EEPROM: Unknown model in EEPROM: %s\n", info->model); diff --git a/board/gateworks/gw_ventana/ventana_eeprom.h b/board/gateworks/gw_ventana/ventana_eeprom.h index 7c01e9edb4..9cac4a769c 100644 --- a/board/gateworks/gw_ventana/ventana_eeprom.h +++ b/board/gateworks/gw_ventana/ventana_eeprom.h @@ -122,6 +122,7 @@ enum { GW5908, GW5909, GW5910, + GW5912, GW_UNKNOWN, GW_BADCRC, };
The GW5913 is a Single Board Computer based on the NXP i.MX6Q/DL SoC with the following features: - DDR3 DRAM - NAND FLASH (256MiB or 2048MiB) - Gateworks System Periperhal Controller - front panel LED's - front panel pushbutton - Digital I/O connector (I2C/GPIO/UART) - u-blox Zoe-M8Q GPS - 1x RJ45 GbE - 1x MiniPCIe socket with PCIe USB 2.0 and nanoSIM socket - Passive PoE and wide-range DC power supply
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 54 +++++++++++++++++++++ board/gateworks/gw_ventana/eeprom.c | 2 + board/gateworks/gw_ventana/ventana_eeprom.h | 1 + 3 files changed, 57 insertions(+)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 3a0b18672f..a4c2f5549f 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -843,6 +843,51 @@ struct dio_cfg gw5906_dio[] = { }, };
+struct dio_cfg gw5913_dio[] = { + { + { IOMUX_PADS(PAD_SD1_DAT0__GPIO1_IO16) }, + IMX_GPIO_NR(1, 16), + { 0, 0 }, + 0 + }, + { + { IOMUX_PADS(PAD_SD1_DAT2__GPIO1_IO19) }, + IMX_GPIO_NR(1, 19), + { IOMUX_PADS(PAD_SD1_DAT2__PWM2_OUT) }, + 2 + }, + { + { IOMUX_PADS(PAD_SD1_DAT1__GPIO1_IO17) }, + IMX_GPIO_NR(1, 17), + { IOMUX_PADS(PAD_SD1_DAT1__PWM3_OUT) }, + 3 + }, + { + { IOMUX_PADS(PAD_SD1_CMD__GPIO1_IO18) }, + IMX_GPIO_NR(1, 18), + { IOMUX_PADS(PAD_SD1_CMD__PWM4_OUT) }, + 4 + }, + { + { IOMUX_PADS(PAD_SD2_DAT0__GPIO1_IO15) }, + IMX_GPIO_NR(1, 15), + { 0, 0 }, + 0 + }, + { + { IOMUX_PADS(PAD_SD2_DAT1__GPIO1_IO14) }, + IMX_GPIO_NR(1, 14), + { 0, 0 }, + 0 + }, + { + { IOMUX_PADS(PAD_GPIO_19__GPIO4_IO05) }, + IMX_GPIO_NR(4, 5), + { 0, 0 }, + 0 + }, +}; + /* * Board Specific GPIO */ @@ -1082,6 +1127,15 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .vsel_pin = IMX_GPIO_NR(6, 14), .mmc_cd = IMX_GPIO_NR(7, 0), }, + + /* GW5913 */ + { + .gpio_pads = gw5912_gpio_pads, + .num_pads = ARRAY_SIZE(gw5912_gpio_pads) / 2, + .dio_cfg = gw5913_dio, + .dio_num = ARRAY_SIZE(gw5913_dio), + .wdis = IMX_GPIO_NR(1, 0), + }, };
#define SETUP_GPIO_OUTPUT(gpio, name, level) \ diff --git a/board/gateworks/gw_ventana/eeprom.c b/board/gateworks/gw_ventana/eeprom.c index a4f3065c7d..d21aa3c38f 100644 --- a/board/gateworks/gw_ventana/eeprom.c +++ b/board/gateworks/gw_ventana/eeprom.c @@ -128,6 +128,8 @@ read_eeprom(int bus, struct ventana_board_info *info) type = GW5910; else if (info->model[4] == '1' && info->model[5] == '2') type = GW5912; + else if (info->model[4] == '1' && info->model[5] == '3') + type = GW5913; break; default: printf("EEPROM: Unknown model in EEPROM: %s\n", info->model); diff --git a/board/gateworks/gw_ventana/ventana_eeprom.h b/board/gateworks/gw_ventana/ventana_eeprom.h index 9cac4a769c..2d5c27261e 100644 --- a/board/gateworks/gw_ventana/ventana_eeprom.h +++ b/board/gateworks/gw_ventana/ventana_eeprom.h @@ -123,6 +123,7 @@ enum { GW5909, GW5910, GW5912, + GW5913, GW_UNKNOWN, GW_BADCRC, };
The GW53xx-G revision has the foolowing changes: - replaces the EOL GbE PHY with an updated part (requires an enable pin) - replaces the EOL analog video decoder with an updated part (requires dt prop) - add power control to miniPCIe socket
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index a4c2f5549f..65e4de1dee 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -229,6 +229,10 @@ static iomux_v3_cfg_t const gw53xx_gpio_pads[] = { IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), + /* J6_PWREN */ + IOMUX_PADS(PAD_EIM_DA15__GPIO3_IO15 | DIO_PAD_CFG), + /* PCIEGBE_EN */ + IOMUX_PADS(PAD_EIM_DA14__GPIO3_IO14 | DIO_PAD_CFG), };
static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { @@ -1226,6 +1230,12 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info)
/* Anything else board specific */ switch(board) { + case GW53xx: + gpio_request(IMX_GPIO_NR(3, 15), "j6_pwren"); + gpio_direction_output(IMX_GPIO_NR(3, 15), 1); + gpio_request(IMX_GPIO_NR(3, 14), "gbe_en"); + gpio_direction_output(IMX_GPIO_NR(3, 14), 1); + break; case GW560x: gpio_request(IMX_GPIO_NR(4, 26), "12p0_en"); gpio_direction_output(IMX_GPIO_NR(4, 26), 1); @@ -1645,6 +1655,15 @@ void ft_early_fixup(void *blob, int board_type) /* GW53xx-E adds WDOG1_B external reset */ if (rev < 'E') ft_board_wdog_fixup(blob, WDOG1_ADDR); + + /* GW53xx-G has an adv7280 instead of an adv7180 */ + else if (rev > 'F') { + i = fdt_node_offset_by_compatible(blob, -1, "adi,adv7180"); + if (i) { + fdt_setprop_string(blob, i, "compatible", "adi,adv7280"); + fdt_setprop_empty(blob, i, "adv,force-bt656-4"); + } + } break;
case GW54xx:
The GW54xx-G revision has the foolowing changes: - replaces the EOL GbE PHY with an updated part (requires an enable pin) - replaces the EOL analog video decoder with an updated part (requires dt prop) - add power control to miniPCIe socket
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 65e4de1dee..9e53765ef5 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -256,6 +256,10 @@ static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { IOMUX_PADS(PAD_SD3_DAT4__GPIO7_IO01 | DIO_PAD_CFG), /* PCIESKT_WDIS# */ IOMUX_PADS(PAD_DISP0_DAT23__GPIO5_IO17 | DIO_PAD_CFG), + /* J7_PWREN */ + IOMUX_PADS(PAD_EIM_DA15__GPIO3_IO15 | DIO_PAD_CFG), + /* PCIEGBE_EN */ + IOMUX_PADS(PAD_EIM_DA14__GPIO3_IO14 | DIO_PAD_CFG), };
static iomux_v3_cfg_t const gw551x_gpio_pads[] = { @@ -1236,6 +1240,12 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) gpio_request(IMX_GPIO_NR(3, 14), "gbe_en"); gpio_direction_output(IMX_GPIO_NR(3, 14), 1); break; + case GW54xx: + gpio_request(IMX_GPIO_NR(3, 15), "j7_pwren"); + gpio_direction_output(IMX_GPIO_NR(3, 15), 1); + gpio_request(IMX_GPIO_NR(3, 14), "gbe_en"); + gpio_direction_output(IMX_GPIO_NR(3, 14), 1); + break; case GW560x: gpio_request(IMX_GPIO_NR(4, 26), "12p0_en"); gpio_direction_output(IMX_GPIO_NR(4, 26), 1); @@ -1677,6 +1687,15 @@ void ft_early_fixup(void *blob, int board_type) /* GW54xx-E adds WDOG2_B external reset */ if (rev < 'E') ft_board_wdog_fixup(blob, WDOG2_ADDR); + + /* GW54xx-G has an adv7280 instead of an adv7180 */ + else if (rev > 'F') { + i = fdt_node_offset_by_compatible(blob, -1, "adi,adv7180"); + if (i) { + fdt_setprop_string(blob, i, "compatible", "adi,adv7280"); + fdt_setprop_empty(blob, i, "adv,force-bt656-4"); + } + } break;
case GW551x:
Tim Harvey
