[U-Boot] [PATCH] board: engicam: spl: match icore-mipi fit-config
Match imx6q-icore-mipi and imx6dl-icore-mipi dtb in board_fit_config_name_match.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/engicam/common/spl.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/engicam/common/spl.c b/board/engicam/common/spl.c index 470d96aaed..1a1fe6c66a 100644 --- a/board/engicam/common/spl.c +++ b/board/engicam/common/spl.c @@ -43,10 +43,14 @@ int board_fit_config_name_match(const char *name) return 0; else if (is_mx6dq() && !strcmp(name, "imx6q-icore-rqs")) return 0; + else if (is_mx6dq() && !strcmp(name, "imx6q-icore-mipi")) + return 0; else if ((is_mx6dl() || is_mx6solo()) && !strcmp(name, "imx6dl-icore")) return 0; else if ((is_mx6dl() || is_mx6solo()) && !strcmp(name, "imx6dl-icore-rqs")) return 0; + else if ((is_mx6dl() || is_mx6solo()) && !strcmp(name, "imx6dl-icore-mipi")) + return 0; else return -1; }
Best regards, Stefano Babic
Jagan Teki
Stefano Babic
