[U-Boot] [PATCH] ARM: Kirkwood: fix IDE configuration on LaCie boards
On the LaCie boards netspace_max_v2 and net2big_v2, two internal hard drives are available. Additionally on the d2net_v2 board, an extra hard drive can be plugged via eSATA.
This patch updates CONFIG_SYS_IDE_MAXBUS and CONFIG_SYS_IDE_MAXDEVICE accordingly for this boards.
Signed-off-by: Simon Guinot simon.guinot@sequanux.org --- include/configs/lacie_kw.h | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 7f63ae0d2228..53957acd37d6 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -97,12 +97,8 @@ /* Remove or override few declarations from mv-common.h */ #undef CONFIG_RBTREE #undef CONFIG_ENV_SPI_MAX_HZ -#undef CONFIG_SYS_IDE_MAXBUS -#undef CONFIG_SYS_IDE_MAXDEVICE #undef CONFIG_SYS_PROMPT #define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */ -#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 1 #if defined(CONFIG_D2NET_V2) #define CONFIG_SYS_PROMPT "d2v2> " #elif defined(CONFIG_NET2BIG_V2) @@ -132,6 +128,11 @@ #if defined(CONFIG_NETSPACE_MAX_V2) || defined(CONFIG_D2NET_V2) || \ defined(CONFIG_NET2BIG_V2) #define CONFIG_SYS_ATA_IDE1_OFFSET MV_SATA_PORT1_OFFSET +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_IDE_MAXDEVICE 2 +#else +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 #endif #endif /* CONFIG_MVSATA_IDE */
Signed-off-by: Simon Guinot simon.guinot@sequanux.org --- include/configs/lacie_kw.h | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
Changes for v2: - Restore the undef CONFIG_SYS_IDE_MAXBUS and CONFIG_SYS_IDE_MAXDEVICE. It is needed to avoid symbol redefinition warnings at build time.
diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 7f63ae0d2228..7f878b713afa 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -101,8 +101,6 @@ #undef CONFIG_SYS_IDE_MAXDEVICE #undef CONFIG_SYS_PROMPT #define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */ -#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 1 #if defined(CONFIG_D2NET_V2) #define CONFIG_SYS_PROMPT "d2v2> " #elif defined(CONFIG_NET2BIG_V2) @@ -132,6 +130,11 @@ #if defined(CONFIG_NETSPACE_MAX_V2) || defined(CONFIG_D2NET_V2) || \ defined(CONFIG_NET2BIG_V2) #define CONFIG_SYS_ATA_IDE1_OFFSET MV_SATA_PORT1_OFFSET +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_IDE_MAXDEVICE 2 +#else +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 #endif #endif /* CONFIG_MVSATA_IDE */
Hi Luka and Prafulla,
Please, consider to apply this patch.
Thanks,
Simon
Changes for v2:
-- 2.1.4
Simon Guinot
Simon Guinot
