[U-Boot] [PATCH v3] arm: Kirkwood: add SYSRSTn Duration Counter Support
This feature can be used to trigger special command "sysrstcmd" using reset key long press event and environment variable "sysrstdelay" is set (useful for reset to factory or manufacturing mode execution)
Kirkwood SoC implements a hardware-based SYSRSTn duration counter. When SYSRSTn is asserted low, a SYSRSTn duration counter is running. The counter value is stored in the SYSRSTn Length Counter Register The counter is based on the 25-MHz reference clock (40ns) It is a 29-bit counter, yielding a maximum counting duration of 2^29/25 MHz (21.4 seconds). When the counter reach its maximum value, it remains at this value until counter reset is triggered by setting bit 31 of KW_REG_SYSRST_CNT
Implementation: Upon long reset assertion (> ${sysrstdelay} in secs) sysrstcmd will be executed if pre-defined in environment variables. This feature will be disabled if "sysrstdelay" variable is unset.
for-ex. setenv sysrst_cmd "echo starting factory reset; nand erase 0xa0000 0x20000; echo finish ed sysrst command;" will erase particular nand sector if triggered by this event
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- Change log: v2: updated as per review feedback for v1 bug fix in the previous post (V2) fixed
v2 repost: I am sorry for previous post v2, pls ignore it, this is the right patch for the same
v3: updated as per review feedback for v2 all possible messages termed as debug
cpu/arm926ejs/kirkwood/cpu.c | 75 +++++++++++++++++++++++++++++++++++ include/asm-arm/arch-kirkwood/cpu.h | 2 + 2 files changed, 77 insertions(+), 0 deletions(-)
diff --git a/cpu/arm926ejs/kirkwood/cpu.c b/cpu/arm926ejs/kirkwood/cpu.c index 795a739..3b978e2 100644 --- a/cpu/arm926ejs/kirkwood/cpu.c +++ b/cpu/arm926ejs/kirkwood/cpu.c @@ -195,6 +195,78 @@ int kw_config_mpp(u32 mpp0_7, u32 mpp8_15, u32 mpp16_23, u32 mpp24_31, return 0; }
+/* + * SYSRSTn Duration Counter Support + * + * Kirkwood SoC implements a hardware-based SYSRSTn duration counter. + * When SYSRSTn is asserted low, a SYSRSTn duration counter is running. + * The SYSRSTn duration counter is useful for implementing a manufacturer + * or factory reset. Upon a long reset assertion that is greater than a + * pre-configured environment variable value for sysrstdelay, + * The counter value is stored in the SYSRSTn Length Counter Register + * The counter is based on the 25-MHz reference clock (40ns) + * It is a 29-bit counter, yielding a maximum counting duration of + * 2^29/25 MHz (21.4 seconds). When the counter reach its maximum value, + * it remains at this value until counter reset is triggered by setting + * bit 31 of KW_REG_SYSRST_CNT + */ +static void kw_sysrst_action(void) +{ + int ret; + char *s = getenv("sysrstcmd"); + + if (!s) { + debug("Error.. %s failed, check sysrstcmd\n", + __FUNCTION__); + return; + } + + debug("Starting %s process...\n", __FUNCTION__); +#if !defined(CONFIG_SYS_HUSH_PARSER) + ret = run_command (s, 0); +#else + ret = parse_string_outer(s, FLAG_PARSE_SEMICOLON + | FLAG_EXIT_FROM_LOOP); +#endif + if (ret < 0) + debug("Error.. %s failed\n", __FUNCTION__); + else + debug("%s process finished\n", __FUNCTION__); +} + +static void kw_sysrst_check(void) +{ + u32 sysrst_cnt, sysrst_dly; + char *s; + + /* + * no action if sysrstdelay environment variable is not defined + */ + s = getenv("sysrstdelay"); + if (s == NULL) + return; + + /* read sysrstdelay value */ + sysrst_dly = (u32) simple_strtoul(s, NULL, 10); + + /* read SysRst Length counter register (bits 28:0) */ + sysrst_cnt = (0x1fffffff & readl(KW_REG_SYSRST_CNT)); + debug("H/w Rst hold time: %d.%d secs\n", + sysrst_cnt / SYSRST_CNT_1SEC_VAL, + sysrst_cnt % SYSRST_CNT_1SEC_VAL); + + /* clear the counter for next valid read*/ + writel(1 << 31, KW_REG_SYSRST_CNT); + + /* + * sysrst_action: + * if H/w Reset key is pressed and hold for time + * more than sysrst_dly in seconds + */ + if (sysrst_cnt >= SYSRST_CNT_1SEC_VAL * sysrst_dly) + kw_sysrst_action(); +} + #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { @@ -298,6 +370,9 @@ int arch_misc_init(void) temp = get_cr(); set_cr(temp & ~CR_V);
+ /* checks and execute resset to factory event */ + kw_sysrst_check(); + return 0; } #endif /* CONFIG_ARCH_MISC_INIT */ diff --git a/include/asm-arm/arch-kirkwood/cpu.h b/include/asm-arm/arch-kirkwood/cpu.h index d1440af..b3022a3 100644 --- a/include/asm-arm/arch-kirkwood/cpu.h +++ b/include/asm-arm/arch-kirkwood/cpu.h @@ -36,6 +36,8 @@ ((_x ? KW_EGIGA0_BASE : KW_EGIGA1_BASE) + 0x44c)
#define KW_REG_DEVICE_ID (KW_MPP_BASE + 0x34) +#define KW_REG_SYSRST_CNT (KW_MPP_BASE + 0x50) +#define SYSRST_CNT_1SEC_VAL (25*1000000) #define KW_REG_MPP_OUT_DRV_REG (KW_MPP_BASE + 0xE0)
enum memory_bank {
-----Original Message----- From: Prafulla Wadaskar [mailto:prafulla@marvell.com] Sent: Thursday, August 20, 2009 8:59 PM To: u-boot@lists.denx.de Cc: Prabhanjan Sarnaik; Ronen Shitrit; Ashish Karkare; Prafulla Wadaskar Subject: [PATCH v3] arm: Kirkwood: add SYSRSTn Duration Counter Support
Ping... I could not see the reference for this post on http://lists.denx.de/pipermail/u-boot/2009-August/date.html Pls suggest If I need to repost this patch
Regards.. Prafulla . .
- SYSRSTn Duration Counter Support
- Kirkwood SoC implements a hardware-based SYSRSTn duration counter.
- When SYSRSTn is asserted low, a SYSRSTn duration counter
is running.
- The SYSRSTn duration counter is useful for implementing a
manufacturer
- or factory reset. Upon a long reset assertion that is
greater than a
- pre-configured environment variable value for sysrstdelay,
- The counter value is stored in the SYSRSTn Length Counter Register
- The counter is based on the 25-MHz reference clock (40ns)
- It is a 29-bit counter, yielding a maximum counting duration of
- 2^29/25 MHz (21.4 seconds). When the counter reach its
maximum value,
- it remains at this value until counter reset is triggered
by setting
- bit 31 of KW_REG_SYSRST_CNT
- int ret;
- char *s = getenv("sysrstcmd");
- if (!s) {
__FUNCTION__);
return;
- debug("Starting %s process...\n", __FUNCTION__);
- ret = run_command (s, 0);
+#else
- ret = parse_string_outer(s, FLAG_PARSE_SEMICOLON
- if (ret < 0)
- else
- u32 sysrst_cnt, sysrst_dly;
- char *s;
- s = getenv("sysrstdelay");
- if (s == NULL)
return;
- /* read sysrstdelay value */
- sysrst_dly = (u32) simple_strtoul(s, NULL, 10);
- /* read SysRst Length counter register (bits 28:0) */
- sysrst_cnt = (0x1fffffff & readl(KW_REG_SYSRST_CNT));
- debug("H/w Rst hold time: %d.%d secs\n",
- /* clear the counter for next valid read*/
- writel(1 << 31, KW_REG_SYSRST_CNT);
* sysrst_action:
- if (sysrst_cnt >= SYSRST_CNT_1SEC_VAL * sysrst_dly)
kw_sysrst_action();
- /* checks and execute resset to factory event */
- kw_sysrst_check();
enum memory_bank {
1.5.3.3
Applied to u-boot-arm
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
Prafulla Wadaskar
