[PATCH] arm64: Remove CONFIG_SYS_FULL_VA macro
All configurations have been removed in 2016 by commit 7985cdf74b28 ("arm64: Remove non-full-va map code").
include/configs/s32v234evb.h | 4 ---- scripts/config_whitelist.txt | 1 - 2 files changed, 5 deletions(-)
diff --git a/include/configs/s32v234evb.h b/include/configs/s32v234evb.h index 5c6692c1999c..3db3d4884f75 100644 --- a/include/configs/s32v234evb.h +++ b/include/configs/s32v234evb.h @@ -34,10 +34,6 @@
#define CONFIG_SKIP_LOWLEVEL_INIT
-/* Config CACHE */ - -#define CONFIG_SYS_FULL_VA - /* Enable passing of ATAGs */ #define CONFIG_CMDLINE_TAG
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b023806efc2f..0e6de885bcf2 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2657,7 +2657,6 @@ CONFIG_SYS_FTSDMC021_CR2 CONFIG_SYS_FTSDMC021_TP1 CONFIG_SYS_FTSDMC021_TP2 CONFIG_SYS_FTSMC020_CONFIGS -CONFIG_SYS_FULL_VA CONFIG_SYS_GAFR0_L_VAL CONFIG_SYS_GAFR0_U_VAL CONFIG_SYS_GAFR1_L_VAL
Michal Simek
