[U-Boot] [PATCH] AT91SAM9XE add embedded flash support
Add support for the embedded flash in the AT91SAM9XE128/256/512 SoCs: - Environment can be put into that flash - U-Boot can be in that flash - Commands "cp" and "protect" are supported
Signed-off-by: Reinhard Meyer reinhard.meyer@emk-elektronik.de --- arch/arm/cpu/arm926ejs/at91/Makefile | 1 + arch/arm/cpu/arm926ejs/at91/eflash.c | 277 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-at91/at91_dbu.h | 41 ++++ arch/arm/include/asm/arch-at91/at91_eefc.h | 51 +++++ 4 files changed, 370 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/at91/eflash.c create mode 100644 arch/arm/include/asm/arch-at91/at91_dbu.h create mode 100644 arch/arm/include/asm/arch-at91/at91_eefc.h
diff --git a/arch/arm/cpu/arm926ejs/at91/Makefile b/arch/arm/cpu/arm926ejs/at91/Makefile index 4f467be..def3980 100644 --- a/arch/arm/cpu/arm926ejs/at91/Makefile +++ b/arch/arm/cpu/arm926ejs/at91/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_AT91SAM9263) += at91sam9263_devices.o COBJS-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o COBJS-$(CONFIG_AT91SAM9M10G45) += at91sam9m10g45_devices.o COBJS-$(CONFIG_AT91SAM9G45) += at91sam9m10g45_devices.o +COBJS-$(CONFIG_AT91_EFLASH) += eflash.o COBJS-$(CONFIG_AT91_LED) += led.o COBJS-y += clock.o COBJS-y += cpu.o diff --git a/arch/arm/cpu/arm926ejs/at91/eflash.c b/arch/arm/cpu/arm926ejs/at91/eflash.c new file mode 100644 index 0000000..83dce7d --- /dev/null +++ b/arch/arm/cpu/arm926ejs/at91/eflash.c @@ -0,0 +1,277 @@ +/* + * (C) Copyright 2010 + * Reinhard Meyer, EMK Elektronik, reinhard.meyer@emk-elektronik.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +/* + * this driver supports the enhanced embedded flash in the Atmel + * AT91SAM9XE devices with the following geometry: + * + * AT91SAM9XE128: 1 plane of 8 regions of 32 pages (total 256 pages) + * AT91SAM9XE256: 1 plane of 16 regions of 32 pages (total 512 pages) + * AT91SAM9XE512: 1 plane of 32 regions of 32 pages (total 1024 pages) + * (the exact geometry is read from the flash at runtime, so any + * future devices should already be covered) + * + * Regions can be write/erase protected. + * Whole (!) pages can be individually written with erase on the fly. + * Writing partial pages will corrupt the rest of the page. + * + * The flash is presented to u-boot with each region being a sector, + * having the following effects: + * Each sector can be hardware protected (protect on/off). + * Each page in a sector can be rewritten anytime. + * Since pages are erased when written, the "erase" does nothing. + * The first "CONFIG_EFLASH_PROTSECTORS" cannot be unprotected + * by u-Boot commands. + * + * Note: Redundant environment will not work in this flash since + * it does use partial page writes. Make sure the environent spans + * whole pages! + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <asm/arch/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_eefc.h> +#include <asm/arch/at91_dbu.h> + +/* checks to detect configuration errors */ +#if CONFIG_SYS_MAX_FLASH_BANKS!=1 +#error eflash: this driver can only handle 1 bank +#endif + +/*#define DEBUG_FLASH*/ + +#ifdef DEBUG_FLASH +#define DEBUGF(fmt,args...) printf("eflash: "fmt ,##args) +#else +#define DEBUGF(fmt,args...) +#endif + +/* global structure */ +flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; +static u32 pagesize; + +unsigned long flash_init (void) +{ + at91_eefc_t *eefc = (at91_eefc_t *) 0xfffffa00; + at91_dbu_t *dbu = (at91_dbu_t *) 0xfffff200; + u32 id, size, nplanes, planesize, nlocks; + u32 addr, i, tmp=0; + +#ifdef DEBUG_FLASH + puts("eflash: init\n"); +#endif + + flash_info[0].flash_id = FLASH_UNKNOWN; + + /* check if its an AT91ARM9XE SoC */ + if ((readl(&dbu->cidr) & AT91_DBU_CID_ARCH_MASK) != AT91_DBU_CID_ARCH_9XExx) { +#ifdef DEBUG_FLASH + puts("eflash: not an AT91SAM9XE\n"); +#endif + return 0; + } + + /* now query the eflash for its structure */ + writel(AT91_EEFC_FCR_KEY | AT91_EEFC_FCR_FCMD_GETD, &eefc->fcr); + while ((readl(&eefc->fsr) & AT91_EEFC_FSR_FRDY) == 0) + ; + id = readl(&eefc->frr); /* word 0 */ + size = readl(&eefc->frr); /* word 1 */ + pagesize = readl(&eefc->frr); /* word 2 */ + nplanes = readl(&eefc->frr); /* word 3 */ + planesize = readl(&eefc->frr); /* word 4 */ + DEBUGF("id=%08x size=%u pagesize=%u planes=%u planesize=%u\n", + id, size, pagesize, nplanes, planesize); + for (i=1; i<nplanes; i++) { + tmp = readl(&eefc->frr); /* words 5..4+nplanes-1 */ + }; + nlocks = readl(&eefc->frr); /* word 4+nplanes */ + DEBUGF("nlocks=%u\n", nlocks); + /* since we are going to use the lock regions as sectors, check count */ + if (nlocks > CONFIG_SYS_MAX_FLASH_SECT) { + printf("eflash: number of lock regions(%u) "\ + "> CONFIG_SYS_MAX_FLASH_SECT. reducing...\n", + nlocks); + nlocks = CONFIG_SYS_MAX_FLASH_SECT; + } + flash_info[0].size = size; + flash_info[0].sector_count = nlocks; + flash_info[0].flash_id = id; + + addr = AT91SAM9XE_FLASH_BASE; + for (i=0; i<nlocks; i++) { + tmp = readl(&eefc->frr); /* words 4+nplanes+1.. */ + flash_info[0].start[i] = addr; + flash_info[0].protect[i] = 0; + addr += tmp; + }; + + /* now read the protection information for all regions */ + writel(AT91_EEFC_FCR_KEY | AT91_EEFC_FCR_FCMD_GLB, &eefc->fcr); + while ((readl(&eefc->fsr) & AT91_EEFC_FSR_FRDY) == 0) + ; + for (i=0; i<flash_info[0].sector_count; i++) { + if (i%32 == 0) + tmp = readl(&eefc->frr); + flash_info[0].protect[i] = (tmp >> (i%32)) & 1; +#if defined(CONFIG_EFLASH_PROTSECTORS) + if (i < CONFIG_EFLASH_PROTSECTORS) + flash_info[0].protect[i] = 1; +#endif + } + + return size; +} + +void flash_print_info (flash_info_t *info) +{ + int i; + + puts("AT91SAM9XE embedded flash\n"); + if (info->size >= (1 << 20)) { + i = 20; + } else { + i = 10; + } + printf(" Size: %ld %cB in %d Sectors\n", + info->size >> i, + (i == 20) ? 'M' : 'k', + info->sector_count); + + printf(" Sector Start Addresses:"); + for (i=0; i<info->sector_count; ++i) { + if ((i % 5) == 0) + printf("\n "); + printf(" %08lX%s", + info->start[i], + info->protect[i] ? " (RO)" : " " + ); + } + printf ("\n"); + return; +} + +int flash_real_protect (flash_info_t *info, long sector, int prot) +{ + at91_eefc_t *eefc = (at91_eefc_t *) 0xfffffa00; + u32 pagenum = (info->start[sector]-AT91SAM9XE_FLASH_BASE)/pagesize; + u32 i, tmp=0; + + DEBUGF("protect sector=%ld prot=%d\n", sector, prot); + +#if defined(CONFIG_EFLASH_PROTSECTORS) + if (sector < CONFIG_EFLASH_PROTSECTORS) { + if (!prot) { + printf("eflash: sector %lu cannot be unprotected\n", + sector); + } + return 1; /* return anyway, caller does not care for result */ + } +#endif + if (prot) { + writel(AT91_EEFC_FCR_KEY | AT91_EEFC_FCR_FCMD_SLB | + (pagenum << AT91_EEFC_FCR_FARG_SHIFT), &eefc->fcr); + } else { + writel(AT91_EEFC_FCR_KEY | AT91_EEFC_FCR_FCMD_CLB | + (pagenum << AT91_EEFC_FCR_FARG_SHIFT), &eefc->fcr); + } + while ((readl(&eefc->fsr) & AT91_EEFC_FSR_FRDY) == 0) + ; + /* now read the protection information for all regions */ + writel(AT91_EEFC_FCR_KEY | AT91_EEFC_FCR_FCMD_GLB, &eefc->fcr); + while ((readl(&eefc->fsr) & AT91_EEFC_FSR_FRDY) == 0) + ; + for (i=0; i<info->sector_count; i++) { + if (i%32 == 0) + tmp = readl(&eefc->frr); + info->protect[i] = (tmp >> (i%32)) & 1; + } + return 0; +} + +static u32 erase_write_page (u32 pagenum) +{ + at91_eefc_t *eefc = (at91_eefc_t *) 0xfffffa00; + + DEBUGF("erase+write page=%u\n", pagenum); + + /* give erase and write page command */ + writel(AT91_EEFC_FCR_KEY | AT91_EEFC_FCR_FCMD_EWP | + (pagenum << AT91_EEFC_FCR_FARG_SHIFT), &eefc->fcr); + while ((readl(&eefc->fsr) & AT91_EEFC_FSR_FRDY) == 0) + ; + /* return status */ + return readl(&eefc->fsr) + & (AT91_EEFC_FSR_FCMDE | AT91_EEFC_FSR_FLOCKE); +} + +int flash_erase (flash_info_t *info, int s_first, int s_last) +{ + DEBUGF("erase first=%d last=%d\n", s_first, s_last); + return 0; +} + +/* + * Copy memory to flash, returns: + * 0 - OK + * 1 - write timeout + */ + +int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) +{ + u32 pagenum; + u32 *src32, *dst32; + u32 i; + + DEBUGF("write src=%08lx addr=%08lx cnt=%lx\n", + (ulong)src, addr, cnt); + + /* REQUIRE addr to be on a page start, abort if not */ + if (addr % pagesize) { + printf ("eflash: start %08lx is not on page start\n"\ + " write aborted\n", addr); + return 1; + } + + /* now start copying data */ + pagenum = (addr-AT91SAM9XE_FLASH_BASE)/pagesize; + src32 = (u32 *) src; + dst32 = (u32 *) addr; + while (cnt > 0) { + i = pagesize / 4; + /* fill page buffer */ + while (i--) + *dst32++ = *src32++; + /* write page */ + if (erase_write_page(pagenum)) + return 1; + pagenum++; + if (cnt > pagesize) + cnt -= pagesize; + else + cnt = 0; + } + return 0; +} + diff --git a/arch/arm/include/asm/arch-at91/at91_dbu.h b/arch/arm/include/asm/arch-at91/at91_dbu.h new file mode 100644 index 0000000..669d933 --- /dev/null +++ b/arch/arm/include/asm/arch-at91/at91_dbu.h @@ -0,0 +1,41 @@ +/* + * Copyright (C) 2010 + * Reinhard Meyer, reinhard.meyer@emk-elektronik.de + * + * Debug Unit + * Based on AT91SAM9XE datasheet + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91_DBU_H +#define AT91_DBU_H + +#ifndef __ASSEMBLY__ + +typedef struct at91_dbu { + u32 cr; /* Control Register WO */ + u32 mr; /* Mode Register RW */ + u32 ier; /* Interrupt Enable Register WO */ + u32 idr; /* Interrupt Disable Register WO */ + u32 imr; /* Interrupt Mask Register RO */ + u32 sr; /* Status Register RO */ + u32 rhr; /* Receive Holding Register RO */ + u32 thr; /* Transmit Holding Register WO */ + u32 brgr; /* Baud Rate Generator Register RW */ + u32 res1[7];/* 0x0024 - 0x003C Reserved */ + u32 cidr; /* Chip ID Register RO */ + u32 exid; /* Chip ID Extension Register RO */ + u32 fnr; /* Force NTRST Register RW */ +} at91_dbu_t; + +#endif /* __ASSEMBLY__ */ + +#define AT91_DBU_CID_ARCH_MASK 0x0ff00000 +#define AT91_DBU_CID_ARCH_9xx 0x01900000 +#define AT91_DBU_CID_ARCH_9XExx 0x02900000 + +#endif diff --git a/arch/arm/include/asm/arch-at91/at91_eefc.h b/arch/arm/include/asm/arch-at91/at91_eefc.h new file mode 100644 index 0000000..9bb3ea2 --- /dev/null +++ b/arch/arm/include/asm/arch-at91/at91_eefc.h @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2010 + * Reinhard Meyer, reinhard.meyer@emk-elektronik.de + * + * Enhanced Embedded Flash Controller + * Based on AT91SAM9XE datasheet + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91_EEFC_H +#define AT91_EEFC_H + +#ifndef __ASSEMBLY__ + +typedef struct at91_eefc { + u32 fmr; /* Flash Mode Register RW */ + u32 fcr; /* Flash Command Register WO */ + u32 fsr; /* Flash Status Register RO */ + u32 frr; /* Flash Result Register RO */ +} at91_eefc_t; + +#endif /* __ASSEMBLY__ */ + +#define AT91_EEFC_FMR_FWS_MASK 0x00000f00 +#define AT91_EEFC_FMR_FRDY_BIT 0x00000001 + +#define AT91_EEFC_FCR_KEY 0x5a000000 +#define AT91_EEFC_FCR_FARG_MASK 0x00ffff00 +#define AT91_EEFC_FCR_FARG_SHIFT 8 +#define AT91_EEFC_FCR_FCMD_GETD 0x0 +#define AT91_EEFC_FCR_FCMD_WP 0x1 +#define AT91_EEFC_FCR_FCMD_WPL 0x2 +#define AT91_EEFC_FCR_FCMD_EWP 0x3 +#define AT91_EEFC_FCR_FCMD_EWPL 0x4 +#define AT91_EEFC_FCR_FCMD_EA 0x5 +#define AT91_EEFC_FCR_FCMD_SLB 0x8 +#define AT91_EEFC_FCR_FCMD_CLB 0x9 +#define AT91_EEFC_FCR_FCMD_GLB 0xA +#define AT91_EEFC_FCR_FCMD_SGPB 0xB +#define AT91_EEFC_FCR_FCMD_CGPB 0xC +#define AT91_EEFC_FCR_FCMD_GGPB 0xD + +#define AT91_EEFC_FSR_FRDY 1 +#define AT91_EEFC_FSR_FCMDE 2 +#define AT91_EEFC_FSR_FLOCKE 4 + +#endif
Sorry, Thunderbird had me there again. When the compose window is too narrow for the insterted Text, it will wrap text during insertion, even if wrapping is switched off generally! Disregard this patch. A new one is sent already.
Reinhard
