[U-Boot] adding NAND support for omap4 (based on pandaboard)
Hello all, (cc Pekon - my efforts are based on his earlier commit)
My firm is developing an omap4-based board with NAND memory as a boot option. For the most part it's identical to the pandaboard (OMAP4460) without most of the peripheral interfaces. After a recent commit which generalized the omap NAND driver, I began the task of porting it to my board. With some trial-and-error, I was able to get the main u-boot image built, but am facing errors during SPL compilation.
To explain my problem, I've taken the latest uboot mainline code and have made edits so as to get NAND working on a pandaboard (it's not possible schematically, but does demonstrate my compilation problem). Hopefully, this will help get the drivers working for the omap4 SoC as well.
My build steps are like this;
make distclean make omap4_panda_config make
Here are the 6 steps/changes I made to the source code (working off uboot mainline ).
1. Added NAND as a configuration option in boards.cfg by changing this line,
Active arm armv7 omap4 ti panda omap4_panda - Sricharan R < r.sricharan@ti.com>
to this,
Active arm armv7 omap4 ti panda omap4_panda omap4_panda:NAND Sricharan R r.sricharan@ti.com
2. Added NAND support in omap4_common.h configuration file as below (Just copied the lines from am335x_evm.h
diff --git a/include/configs/omap4_common.h b/include/configs/omap4_common.h index ea56eeb..49d5d8a 100644 --- a/include/configs/omap4_common.h +++ b/include/configs/omap4_common.h @@ -154,4 +154,49 @@ #define CONFIG_SPL_DISPLAY_PRINT #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds"
+#ifdef CONFIG_NAND +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_NAND_OMAP_ELM +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#endif + +/* NAND support */ +#ifdef CONFIG_NAND +#define CONFIG_CMD_NAND +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 +#if !defined(CONFIG_SPI_BOOT) && !defined(CONFIG_NOR_BOOT) +#define MTDIDS_DEFAULT "nand0=omap2-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:128k(SPL)," \ + "128k(SPL.backup1)," \ + "128k(SPL.backup2)," \ + "128k(SPL.backup3),1792k(u-boot)," \ + "128k(u-boot-spl-os)," \ + "128k(u-boot-env),5m(kernel),-(rootfs)" +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#endif +#endif + #endif /* __CONFIG_OMAP4_COMMON_H */
3. Edited omap4_panda.h to prevent a compilation error (The ENV gets setup as NAND thanks to earlier change);
diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 6820e42..d356cfd 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -45,8 +45,10 @@ /* GPIO */ #define CONFIG_CMD_GPIO
+#ifndef CONFIG_NAND /* ENV related config options */ #define CONFIG_ENV_IS_NOWHERE +#endif
#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
4. Copied over 2 header files from arch-omap3 to arch-omap4 (since they are from the same processor family, I'm hoping it will work)
cp arch/arm/include/asm/arch-omap3/mem.h
arch/arm/include/asm/arch-omap4/mem.h
cp arch/arm/include/asm/arch-omap3/omap_gpmc.h
arch/arm/include/asm/arch-omap4/omap_gpmc.h
5. Edited cpu.h to add a few structure members needed for BCH error correction (compiler complains they are missing otherwise);
diff --git a/arch/arm/include/asm/arch-omap4/cpu.h b/arch/arm/include/asm/arch-omap4/cpu.h index 545d9d9..9e389ba 100644 --- a/arch/arm/include/asm/arch-omap4/cpu.h +++ b/arch/arm/include/asm/arch-omap4/cpu.h @@ -28,6 +28,10 @@ struct gpmc_cs { u8 res[8]; /* blow up to 0x30 byte */ };
+struct bch_res_0_3 { + u32 bch_result_x[4]; +}; + struct gpmc { u8 res1[0x10]; u32 sysconfig; /* 0x10 */ @@ -35,7 +39,7 @@ struct gpmc { u32 irqstatus; /* 0x18 */ u32 irqenable; /* 0x1C */ u8 res3[0x20]; - u32 timeout_control; /* 0x40 */ + u32 timeout_control; /* 0x40 */ u8 res4[0xC]; u32 config; /* 0x50 */ u32 status; /* 0x54 */ @@ -54,6 +58,8 @@ struct gpmc { u32 ecc7_result; /* 0x218 */ u32 ecc8_result; /* 0x21C */ u32 ecc9_result; /* 0x220 */ + u8 res7[0x1C]; /* fill up to 0x240 */ + struct bch_res_0_3 bch_result_0_3[7]; /* 0x240 */ };
/* Used for board specific gpmc initialization */
6. Adding a #define in omap.h to allow NAND driver to compile (The value of ELM_BASE was copied over from arch/arm/include/asm/arch-am33xx/hardware.h)
diff --git a/arch/arm/include/asm/arch-omap4/omap.h b/arch/arm/include/asm/arch-omap4/omap.h index e35f51c..770a18c 100644 --- a/arch/arm/include/asm/arch-omap4/omap.h +++ b/arch/arm/include/asm/arch-omap4/omap.h @@ -63,6 +63,9 @@ /* GPMC */ #define OMAP44XX_GPMC_BASE 0x50000000
+/* BCH Error Location Module */ +#define ELM_BASE 0x48080000 + /* * Hardware Register Details */
With the above, I'm able to compile u-boot.img, but am having trouble with the SPL. Here's where the build fails,
/home/abraham/SPACE/BISQUARE/source/uboot_update/gcc-SourceryCodeBenchLite-arm/bin/arm-none-linux-gnueabi-gcc -E -g -Os -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -D__KERNEL__ -ffunction-sections -fdata-sections -DCONFIG_SYS_TEXT_BASE=0x80800000 -DCONFIG_SPL_BUILD -I/home/abraham/SPACE/uboot_panda_NAND/include -I/home/abraham/SPACE/uboot_panda_NAND/arch/arm/include -fno-builtin -ffreestanding -nostdinc -isystem /home/abraham/SPACE/BISQUARE/source/uboot_update/gcc-SourceryCodeBenchLite-arm/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/include -pipe -DCONFIG_ARM -D__ARM__ -mthumb -mthumb-interwork -mabi=aapcs-linux -march=armv7-a -include /home/abraham/SPACE/uboot_panda_NAND/include/u-boot/u-boot.lds.h -include /home/abraham/SPACE/uboot_panda_NAND/include/config.h -DCPUDIR=arch/arm/cpu/armv7 -I/home/abraham/SPACE/uboot_panda_NAND/spl/. -ansi -D__ASSEMBLY__ -P - < /home/abraham/SPACE/uboot_panda_NAND/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
/home/abraham/SPACE/uboot_panda_NAND/spl/u-boot-spl.lds
cd /home/abraham/SPACE/uboot_panda_NAND/spl/ && /home/abraham/SPACE/BISQUARE/source/uboot_update/gcc-SourceryCodeBenchLite-arm/bin/arm-none-linux-gnueabi-ld -T /home/abraham/SPACE/uboot_panda_NAND/spl/u-boot-spl.lds --gc-sections --gc-sections -Bstatic -Ttext 0x40304350 arch/arm/cpu/armv7/start.o --start-group arch/arm/cpu/armv7/built-in.o arch/arm/cpu/armv7/omap4/built-in.o arch/arm/cpu/built-in.o arch/arm/lib/built-in.o board/ti/panda/built-in.o common/built-in.o common/spl/built-in.o disk/built-in.o drivers/gpio/built-in.o drivers/i2c/built-in.o drivers/mmc/built-in.o drivers/mtd/nand/built-in.o drivers/serial/built-in.o fs/built-in.o lib/built-in.o --end-group /home/abraham/SPACE/uboot_panda_NAND/spl/arch/arm/lib/eabi_compat.o -L /home/abraham/SPACE/BISQUARE/source/uboot_update/gcc-SourceryCodeBenchLite-arm/bin/../lib/gcc/arm-none-linux-gnueabi/4.7.3/thumb2 -lgcc -Map u-boot-spl.map -o u-boot-spl arch/arm/cpu/armv7/built-in.o: In function `spl_board_init': /home/abraham/SPACE/uboot_panda_NAND/arch/arm/cpu/armv7/omap-common/boot-common.c:75: undefined reference to `gpmc_init' drivers/mtd/nand/built-in.o: In function `omap_nand_hwcontrol': /home/abraham/SPACE/uboot_panda_NAND/drivers/mtd/nand/omap_gpmc.c:52: undefined reference to `gpmc_cfg' drivers/mtd/nand/built-in.o: In function `omap_spl_dev_ready': /home/abraham/SPACE/uboot_panda_NAND/drivers/mtd/nand/omap_gpmc.c:60: undefined reference to `gpmc_cfg' drivers/mtd/nand/built-in.o: In function `omap_enable_ecc_bch': /home/abraham/SPACE/uboot_panda_NAND/drivers/mtd/nand/omap_gpmc.c:362: undefined reference to `gpmc_cfg' drivers/mtd/nand/built-in.o: In function `omap_calculate_ecc_bch': /home/abraham/SPACE/uboot_panda_NAND/drivers/mtd/nand/omap_gpmc.c:479: undefined reference to `gpmc_cfg' drivers/mtd/nand/built-in.o: In function `board_nand_init': /home/abraham/SPACE/uboot_panda_NAND/drivers/mtd/nand/omap_gpmc.c:1027: undefined reference to `gpmc_cfg' make[1]: *** [/home/abraham/SPACE/uboot_panda_NAND/spl/u-boot-spl] Error 1 make[1]: Leaving directory `/home/abraham/SPACE/uboot_panda_NAND/spl' make: *** [spl/u-boot-spl.bin] Error 2
Any suggestions on how I could fix this? I can't seem to figure out how SPL is built and am not sure where to start. Assuming that we can solve this issue, I can submit a proper patch after running it on real hardware (which should arrive in about 2 - 4 weeks).
Puzzled, Abraham V.
From: Abraham V. [mailto:abraham.varricatt@vvdntech.com]
- Added NAND as a configuration option in boards.cfg
Yes this is correct ..
- Added NAND support in omap4_common.h configuration file
as below (Just copied the lines from am335x_evm.h --- a/include/configs/omap4_common.h +++ b/include/configs/omap4_common.h
These changes look ok..
- Edited omap4_panda.h to prevent a compilation error
This should be in include/configs/omap4_common.h itself #if defined(CONFIG_NAND) #undef CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_IS_IN_NAND #endif
- Copied over 2 header files from arch-omap3 to arch-omap4
(since they are from the same processor family, I'm hoping it will work) cp arch/arm/include/asm/arch-omap3/mem.h \
I'm about to send the patch for fixing this.. However you can proceed Like this for now..
This should not be required if you pull in my below patch-set http://lists.denx.de/pipermail/u-boot/2013-November/167696.html
- Edited cpu.h to add a few structure members needed
Again, this should not be required if you pull in patch mentioned above
- Adding a #define in omap.h to allow NAND driver to compile
Please double check the OMAP4 TRM, ELM_BASE shouldn't change though.
Please pull in my above patch-set mentioned above, and it should Solve this compilation issue.. The patch is compile clean as tested with ./MAKEALL -s omap4
Plz pull the patch mentioned above, and much of things should be cleaned up http://lists.denx.de/pipermail/u-boot/2013-November/167696.html
Thanks..
Puzzled,
?? why ?? Its ok, you will figure the solution :-) (Also plz send plain text emails on u-boot maillist, no HTML please).
with regards, pekon
Thank you for the reply Pekon, but sadly even after applying your patch the earlier compile issue is still present. Starting from a copy of mainline u-boot source code here are the minimal steps required to reproduce the issue.
1. Apply following patches,
http://lists.denx.de/pipermail/u-boot/2013-November/167697.html http://lists.denx.de/pipermail/u-boot/2013-November/167698.html http://lists.denx.de/pipermail/u-boot/2013-November/167700.html http://lists.denx.de/pipermail/u-boot/2013-November/167699.html http://lists.denx.de/pipermail/u-boot/2013-November/167701.html
After this is done compiling for all the omap4 boards happens without issue (example output below).
./MAKEALL -s omap4
Configuring for omap4_panda board... text data bss dec hex filename 193830 9970 305496 509296 7c570 ./u-boot 32923 2200 197972 233095 38e87 ./spl/u-boot-spl Configuring for omap4_sdp4430 board... text data bss dec hex filename 154677 9800 214704 379181 5c92d ./u-boot 32378 2200 197972 232550 38c66 ./spl/u-boot-spl
--------------------- SUMMARY ---------------------------- Boards compiled: 2 ----------------------------------------------------------
2. Since we're interested in bundling in NAND support for the pandaboard, please apply the following patch (pass on NAND as a compilation parameter),
diff --git a/boards.cfg b/boards.cfg index e742746..7bad4a0 100644 --- a/boards.cfg +++ b/boards.cfg @@ -334,7 +334,7 @@ Active arm armv7 omap3 ti evm Active arm armv7 omap3 ti evm omap3_evm_quick_nand - Active arm armv7 omap3 ti sdp3430 omap3_sdp3430 - Active arm armv7 omap3 timll devkit8000 devkit8000 - -Active arm armv7 omap4 ti panda omap4_panda - +Active arm armv7 omap4 ti panda omap4_panda omap4_panda:NAND Active arm armv7 omap4 ti sdp4430 omap4_sdp4430 - Active arm armv7 omap5 ti dra7xx dra7xx_evm dra7xx_evm:CONS_INDEX=1 Active arm armv7 omap5 ti dra7xx dra7xx_evm_uart3 dra7xx_evm:CONS_INDEX=3,S
3. Compiling for omap4 boards now gives an error about "asm/arch/mem.h" missing. A simple work-around is to copy over the file from the omap3 directory (command below)
cp arch/arm/include/asm/arch-omap3/mem.h arch/arm/include/asm/arch-omap4/mem.h
4. At this point we'll get some complaints about missing static definitions, so apply the following patch to add them in the common configuration file;
diff --git a/include/configs/omap4_common.h b/include/configs/omap4_common.h index ea56eeb..80f5d03 100644 --- a/include/configs/omap4_common.h +++ b/include/configs/omap4_common.h @@ -154,4 +154,49 @@ #define CONFIG_SPL_DISPLAY_PRINT #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds"
+#ifdef CONFIG_NAND +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_NAND_OMAP_ELM +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#endif + +/* NAND support */ +#ifdef CONFIG_NAND +#define CONFIG_CMD_NAND +#if !defined(CONFIG_SPI_BOOT) && !defined(CONFIG_NOR_BOOT) +#define MTDIDS_DEFAULT "nand0=omap2-nand.0" +#define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:128k(SPL)," \ + "128k(SPL.backup1)," \ + "128k(SPL.backup2)," \ + "128k(SPL.backup3),1792k(u-boot)," \ + "128k(u-boot-spl-os)," \ + "128k(u-boot-env),5m(kernel),-(rootfs)" +#undef CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#endif +#endif + #endif /* __CONFIG_OMAP4_COMMON_H */
The following edit is also needed in the panda configuration file (it won't work from the common file as the panda configuration will over-ride it)
5. Now, we get a complaint about a missing "hardware.h". Only ELM_BASE is used from there, so I created the header file with that sole entry as follows
echo "#define ELM_BASE 0x48078000" > arch/arm/include/asm/arch-omap4/hardware.h
(I updated the value for ELM_BASE from the public OMAP4460 manual, page 310 - it looks different from that used on the am335)
And at this point, I encounter the same error I mentioned last time (output below). Quite frankly, I'm stuck on how to proceed. I *suspect* that the SPL build has some extra configuration file where I need to mention the NAND support, but am not sure where to look. :(
make -s omap4_panda
Configuring for omap4_panda - Board: omap4_panda, Options: NAND Image Name: U-Boot 2014.01-rc1-dirty for pan Created: Fri Nov 29 16:48:34 2013 Image Type: ARM U-Boot Firmware (uncompressed) Data Size: 260136 Bytes = 254.04 kB = 0.25 MB Load Address: 80800000 Entry Point: 00000000 arch/arm/cpu/armv7/built-in.o: In function `spl_board_init': /home/abraham/SPACE/patch_uboot_panda/arch/arm/cpu/armv7/omap-common/boot-common.c:75: undefined reference to `gpmc_init' drivers/mtd/nand/built-in.o: In function `omap_nand_hwcontrol': /home/abraham/SPACE/patch_uboot_panda/drivers/mtd/nand/omap_gpmc.c:51: undefined reference to `gpmc_cfg' drivers/mtd/nand/built-in.o: In function `omap_spl_dev_ready': /home/abraham/SPACE/patch_uboot_panda/drivers/mtd/nand/omap_gpmc.c:59: undefined reference to `gpmc_cfg' drivers/mtd/nand/built-in.o: In function `omap_enable_ecc_bch': /home/abraham/SPACE/patch_uboot_panda/drivers/mtd/nand/omap_gpmc.c:361: undefined reference to `gpmc_cfg' drivers/mtd/nand/built-in.o: In function `omap_calculate_ecc_bch': /home/abraham/SPACE/patch_uboot_panda/drivers/mtd/nand/omap_gpmc.c:478: undefined reference to `gpmc_cfg' drivers/mtd/nand/built-in.o: In function `board_nand_init': /home/abraham/SPACE/patch_uboot_panda/drivers/mtd/nand/omap_gpmc.c:1026: undefined reference to `gpmc_cfg' make[2]: *** [/home/abraham/SPACE/patch_uboot_panda/spl/u-boot-spl] Error 1 make[1]: *** [spl/u-boot-spl.bin] Error 2 make: *** [omap4_panda] Error 2
Help?
-Abraham
PS: Sorry about the HTML in my last reply. Hope this is better?
Hello Pekon,
An addendum to my last mail; I tried digging into the build mechanism and finally got the system to build without errors with the following patch,
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 4d3a165..5eeecce 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -22,8 +22,6 @@ obj-y += boot-common.o obj-y += lowlevel_init.o endif
-ifndef CONFIG_SPL_BUILD ifneq ($(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),) obj-y += mem-common.o endif -endif
The way I understood the compiler error, it was due to a missing gpmc_init() function. Which, in the case of the OMAP4 and OMAP5 series appears to be defined in the "arch/arm/cpu/armv7/omap-common/mem-common.c" file.
For reasons I do not understand, this has been left aside for the SPL (or MLO ?) builds. Any idea why this is so? What might be the after-affects of enabling it (like I'm doing)?
Way I see the OMAP4 processor, if you want NAND support, you'll need GPMC enabled too.
-Abraham
Abraham V.
Gupta, Pekon
