[U-Boot] [PATCH v3 3/6] arm64: mvebu: pinctrl: Add pin control driver for A8K family
Add a DM port of Marvell pin control driver. The A8K SoC family contains several silicone dies interconnected in a single package. Every die is normally equipped with its own pin controller unit. There are 2 pin controllers in A70x0 SoC and 3 in A80x0 SoC.
Changes for v3: - Extend the Kconfig help for pin control driver
Signed-off-by: Konstantin Porotchkin kostap@marvell.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Nadav Haklai nadavh@marvell.com Cc: Neta Zur Hershkovits neta@marvell.com Cc: Omri Itach omrii@marvell.com Cc: Igal Liberman igall@marvell.com Cc: Haim Boot hayim@marvell.com Cc: Hanna Hawa hannah@marvell.com --- arch/arm/include/asm/arch-armada8k/soc-info.h | 17 ++ .../pinctrl/marvell,armada-apn806-pinctrl.txt | 25 ++ .../pinctrl/marvell,armada-cp110-pinctrl.txt | 270 +++++++++++++++++++++ .../pinctrl/marvell,mvebu-pinctrl.txt | 113 +++++++++ drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/mvebu/Kconfig | 16 ++ drivers/pinctrl/mvebu/Makefile | 7 + drivers/pinctrl/mvebu/pinctrl-mvebu.c | 179 ++++++++++++++ drivers/pinctrl/mvebu/pinctrl-mvebu.h | 31 +++ 10 files changed, 660 insertions(+) create mode 100644 arch/arm/include/asm/arch-armada8k/soc-info.h create mode 100644 doc/device-tree-bindings/pinctrl/marvell,armada-apn806-pinctrl.txt create mode 100644 doc/device-tree-bindings/pinctrl/marvell,armada-cp110-pinctrl.txt create mode 100644 doc/device-tree-bindings/pinctrl/marvell,mvebu-pinctrl.txt create mode 100644 drivers/pinctrl/mvebu/Kconfig create mode 100644 drivers/pinctrl/mvebu/Makefile create mode 100644 drivers/pinctrl/mvebu/pinctrl-mvebu.c create mode 100644 drivers/pinctrl/mvebu/pinctrl-mvebu.h
diff --git a/arch/arm/include/asm/arch-armada8k/soc-info.h b/arch/arm/include/asm/arch-armada8k/soc-info.h new file mode 100644 index 0000000..bae3995 --- /dev/null +++ b/arch/arm/include/asm/arch-armada8k/soc-info.h @@ -0,0 +1,17 @@ +/* + * Copyright (C) 2016 Marvell International Ltd. + * + * SPDX-License-Identifier: GPL-2.0 + * https://spdx.org/licenses + */ + +#ifndef _SOC_INFO_H_ +#define _SOC_INFO_H_ + +/* Pin Ctrl driver definitions */ +#define BITS_PER_PIN 4 +#define PIN_FUNC_MASK ((1 << BITS_PER_PIN) - 1) +#define PIN_REG_SHIFT 3 +#define PIN_FIELD_MASK ((1 << PIN_REG_SHIFT) - 1) + +#endif /* _SOC_INFO_H_ */ diff --git a/doc/device-tree-bindings/pinctrl/marvell,armada-apn806-pinctrl.txt b/doc/device-tree-bindings/pinctrl/marvell,armada-apn806-pinctrl.txt new file mode 100644 index 0000000..51f2f2c --- /dev/null +++ b/doc/device-tree-bindings/pinctrl/marvell,armada-apn806-pinctrl.txt @@ -0,0 +1,25 @@ + Functions of Armada APN806 pin controller + Function 0x0 for any MPP ID activates GPIO pin mode +---------------------------------------------------------------------- +MPP# 0x1 0x2 0x3 0x4 +---------------------------------------------------------------------- +0 SDIO_CLK - SPI0_CLK - +1 SDIO_CMD - SPI0_MISO - +2 SDIO_D[0] - SPI0_MOSI - +3 SDIO_D[1] - SPI0_CS0n - +4 SDIO_D[2] - I2C0_SDA SPI0_CS1n +5 SDIO_D[3] - I2C0_SCK - +6 SDIO_DS - - - +7 SDIO_D[4] - UART1_RXD - +8 SDIO_D[5] - UART1_TXD - +9 SDIO_D[6] - SPI0_CS1n - +10 SDIO_D[7] - - - +11 - - UART0_TXD - +12 SDIO_CARD_PW_OFF SDIO_HW_RST - - +13 - - - - +14 - - - - +15 - - - - +16 - - - - +17 - - - - +18 - - - - +19 - - UART0_RXD - diff --git a/doc/device-tree-bindings/pinctrl/marvell,armada-cp110-pinctrl.txt b/doc/device-tree-bindings/pinctrl/marvell,armada-cp110-pinctrl.txt new file mode 100644 index 0000000..3adcf3a --- /dev/null +++ b/doc/device-tree-bindings/pinctrl/marvell,armada-cp110-pinctrl.txt @@ -0,0 +1,270 @@ + Functions of Armada CP110 pin controller + Function 0x0 for any MPP ID activates GPIO pin mode + Function 0xc for any MPP ID activates DEBUG_BUS pin mode +------------------------------------------------------------------------------- +MPP# 0x1 0x2 0x3 0x4 +------------------------------------------------------------------------------- +0 DEV_ALE[1] AU_I2SMCLK GE0_RXD[3] TDM_PCLK +1 DEV_ALE[0] AU_I2SDO_SPDIFO GE0_RXD[2] TDM_DRX +2 DEV_AD[15] AU_I2SEXTCLK GE0_RXD[1] TDM_DTX +3 DEV_AD[14] AU_I2SLRCLK GE0_RXD[0] TDM_FSYNC +4 DEV_AD[13] AU_I2SBCLK GE0_RXCTL TDM_RSTn +5 DEV_AD[12] AU_I2SDI GE0_RXCLK TDM_INTn +6 DEV_AD[11] - GE0_TXD[3] SPI0_CSn[2] +7 DEV_AD[10] - GE0_TXD[2] SPI0_CSn[1] +8 DEV_AD[9] - GE0_TXD[1] SPI0_CSn[0] +9 DEV_AD[8] - GE0_TXD[0] SPI0_MOSI +10 DEV_READYn - GE0_TXCTL SPI0_MISO +11 DEV_WEn[1] - GE0_TXCLKOUT SPI0_CLK +12 DEV_CLK_OUT NF_RBn[1] SPI1_CSn[1] GE0_RXCLK +13 DEV_BURSTn NF_RBn[0] SPI1_MISO GE0_RXCTL +14 DEV_BOOTCSn DEV_CSn[0] SPI1_CSn[0] SPI0_CSn[3] +15 DEV_AD[7] - SPI1_MOSI - +16 DEV_AD[6] - SPI1_CLK - +17 DEV_AD[5] - - GE0_TXD[3] +18 DEV_AD[4] - - GE0_TXD[2] +19 DEV_AD[3] - - GE0_TXD[1] +20 DEV_AD[2] - - GE0_TXD[0] +21 DEV_AD[1] - - GE0_TXCTL +22 DEV_AD[0] - - GE0_TXCLKOUT +23 DEV_A[1] - - - +24 DEV_A[0] - - - +25 DEV_OEn - - - - +26 DEV_WEn[0] - - - +27 DEV_CSn[0] SPI1_MISO MSS_GPIO[4] GE0_RXD[3] +28 DEV_CSn[1] SPI1_CSn[0] MSS_GPIO[5] GE0_RXD[2] +29 DEV_CSn[2] SPI1_MOSI MSS_GPIO[6] GE0_RXD[1] +30 DEV_CSn[3] SPI1_CLK MSS_GPIO[7] GE0_RXD[0] +31 DEV_A[2] - MSS_GPIO[4] - +32 MII_COL MII_TXERR MSS_SPI_MISO TDM_DRX +33 MII_TXCLK SDIO_PWR1[0] MSS_SPI_CSn TDM_FSYNC +34 MII_RXERR SDIO_PWR1[1] MSS_SPI_MOSI TDM_DTX +35 SATA1_PRESENT_ACTIVEn TWSI1_SDA MSS_SPI_CLK TDM_PCLK +36 SYNCE2_CLK TWSI1_SCK PTP_CLK SYNCE1_CLK +37 UART2_RXD TWSI0_SCK PTP_PCLK_OUT TDM_INTn +38 UART2_TXD TWSI0_SDA PTP_PULSE TDM_RSTn +39 SDIO_WR_PROTECT - - AU_I2SBCLK PTP_CLK +40 SDIO_PWR1[1] SYNCE1_CLK MSS_TWSI_SDA AU_I2SDO_SPDIFO +41 SDIO_PWR1[0] SDIO_BUS_PWR MSS_TWSI_SCK AU_I2SLRCLK +42 SDIO_V18_EN SDIO_WR_PROTECT SYNCE2_CLK AU_I2SMCLK +43 SDIO_CARD_DETECT - SYNCE1_CLK AU_I2SEXTCLK +44 GE1_TXD[2] - - - +45 GE1_TXD[3] - - - +46 GE1_TXD[1] - - - +47 GE1_TXD[0] - - - +48 GE1_TXCTL_MII_TXEN - - - +49 GE1_TXCLKOUT MII_CRS - - +50 GE1_RXCLK MSS_TWSI_SDA - - +51 GE1_RXD[0] MSS_TWSI_SCK - - +52 GE1_RXD[1] SYNCE1_CLK - SYNCE2_CLK +53 GE1_RXD[2] - PTP_CLK - +54 GE1_RXD[3] SYNCE2_CLK PTP_PCLK_OUT SYNCE1_CLK +55 GE1_RXCTL_MII_RXDV - PTP_PULSE - +56 - - - TDM_DRX +57 - MSS_TWSI_SDA PTP_PCLK_OUT TDM_INTn +58 - MSS_TWSI_SCK PTP_CLK TDM_RSTn +59 MSS_GPIO[7] SYNCE2_CLK - TDM_FSYNC +60 MSS_GPIO[6] - PTP_PULSE TDM_DTX +61 MSS_GPIO[5] - PTP_CLK TDM_PCLK +62 MSS_GPIO[4] SYNCE1_CLK PTP_PCLK_OUT - + +------------------------------------------------------------------------------- +MPP# 0x5 0x6 0x7 +------------------------------------------------------------------------------- +0 - PTP_PULSE MSS_TWSI_SDA +1 - PTP_CLK MSS_TWSI_SCK +2 MSS_UART_RXD PTP_PCLK_OUT TWSI1_SCK +3 MSS_UART_TXD PCIe_RSTOUTn TWSI1_SDA +4 MSS_UART_RXD UART1_CTS PCIe0_CLKREQ +5 MSS_UART_TXD UART1_RTS PCIe1_CLKREQ +6 AU_I2SEXTCLK SATA1_PRESENT_ACTIVEn PCIe2_CLKREQ +7 SPI1_CSn[1] SATA0_PRESENT_ACTIVEn LED_DATA +8 SPI1_CSn[0] UART0_CTS LED_STB +9 SPI1_MOSI - PCIe_RSTOUTn +10 SPI1_MISO UART0_CTS SATA1_PRESENT_ACTIVEn +11 SPI1_CLK UART0_RTS LED_CLK +12 - - - +13 - - - +14 AU_I2SEXTCLK SPI0_MISO SATA0_PRESENT_ACTIVEn +15 - SPI0_MOSI - +16 - - - +17 - - - +18 - - - +19 - - - +20 - - - +21 - - - +22 - - - +23 AU_I2SMCLK - - +24 AU_I2SLRCLK - - +25 AU_I2SDO_SPDIFO - - +26 AU_I2SBCLK - - +27 SPI0_CSn[4] - - +28 SPI0_CSn[5] PCIe2_CLKREQ PTP_PULSE +29 SPI0_CSn[6] PCIe1_CLKREQ PTP_CLK +30 SPI0_CSn[7] PCIe0_CLKREQ PTP_PCLK_OUT +31 - PCIe_RSTOUTn - +32 AU_I2SEXTCLK AU_I2SDI GE_MDIO +33 AU_I2SMCLK SDIO_BUS_PWR - +34 AU_I2SLRCLK SDIO_WR_PROTECT GE_MDC +35 AU_I2SDO_SPDIFO SDIO_CARD_DETECT XG_MDIO +36 AU_I2SBCLK SATA0_PRESENT_ACTIVEn XG_MDC +37 MSS_TWSI_SCK SATA1_PRESENT_ACTIVEn GE_MDC +38 MSS_TWSI_SDA SATA0_PRESENT_ACTIVEn GE_MDIO +39 SPI0_CSn[1] - - +40 PTP_PCLK_OUT SPI0_CLK UART1_TXD +41 PTP_PULSE SPI0_MOSI UART1_RXD +42 MSS_UART_TXD SPI0_MISO UART1_CTS +43 MSS_UART_RXD SPI0_CSn[0] UART1_RTS +44 - - UART0_RTS +45 - - UART0_TXD +46 - - UART1_RTS +47 SPI1_CLK - UART1_TXD +48 SPI1_MOSI - - +49 SPI1_MISO - UART1_RXD +50 SPI1_CSn[0] UART2_TXD UART0_RXD +51 SPI1_CSn[1] UART2_RXD UART0_CTS +52 SPI1_CSn[2] - UART1_CTS +53 SPI1_CSn[3] - UART1_RXD +54 - - - +55 - - - +56 AU_I2SDO_SPDIFO SPI0_CLK UART1_RXD +57 AU_I2SBCLK SPI0_MOSI UART1_TXD +58 AU_I2SDI SPI0_MISO UART1_CTS +59 AU_I2SLRCLK SPI0_CSn[0] UART0_CTS +60 AU_I2SMCLK SPI0_CSn[1] UART0_RTS +61 AU_I2SEXTCLK SPI0_CSn[2] UART0_TXD +62 SATA1_PRESENT_ACTIVEn SPI0_CSn[3] UART0_RXD + +------------------------------------------------------------------------------- +MPP# 0x8 0x9 0xA +------------------------------------------------------------------------------- +0 UART0_RXD SATA0_PRESENT_ACTIVEn GE_MDIO +1 UART0_TXD SATA1_PRESENT_ACTIVEn GE_MDC +2 UART1_RXD SATA0_PRESENT_ACTIVEn XG_MDC +3 UART1_TXD SATA1_PRESENT_ACTIVEn XG_MDIO +4 UART3_RXD - GE_MDC +5 UART3_TXD - GE_MDIO +6 UART0_RXD PTP_PULSE - +7 UART0_TXD PTP_CLK - +8 UART2_RXD PTP_PCLK_OUT SYNCE1_CLK +9 - - SYNCE2_CLK +10 - - - +11 UART2_TXD SATA0_PRESENT_ACTIVEn - +12 - - - +13 MSS_SPI_MISO - - +14 MSS_SPI_CSn - - +15 MSS_SPI_MOSI - - +16 MSS_SPI_CLK - - +17 - - - +18 - - - +19 - - - +20 - - - +21 - - - +22 - - - +23 - - - +24 - - - +25 - - - +26 - - - +27 GE_MDIO SATA0_PRESENT_ACTIVEn UART0_RTS +28 GE_MDC SATA1_PRESENT_ACTIVEn UART0_CTS +29 MSS_TWSI_SDA SATA0_PRESENT_ACTIVEn UART0_RXD +30 MSS_TWSI_SCK SATA1_PRESENT_ACTIVEn UART0_TXD +31 GE_MDC - - +32 SDIO_V18_EN PCIe1_CLKREQ MSS_GPIO[0] +33 XG_MDIO PCIe2_CLKREQ MSS_GPIO[1] +34 - PCIe0_CLKREQ MSS_GPIO[2] +35 GE_MDIO PCIe_RSTOUTn MSS_GPIO[3] +36 GE_MDC PCIe2_CLKREQ MSS_GPIO[5] +37 XG_MDC PCIe1_CLKREQ MSS_GPIO[6] +38 XG_MDIO AU_I2SEXTCLK MSS_GPIO[7] +39 SATA1_PRESENT_ACTIVEn MSS_GPIO[0] +40 GE_MDIO SATA0_PRESENT_ACTIVEn MSS_GPIO[1] +41 GE_MDC SATA1_PRESENT_ACTIVEn MSS_GPIO[2] +42 XG_MDC SATA0_PRESENT_ACTIVEn MSS_GPIO[4] +43 XG_MDIO SATA1_PRESENT_ACTIVEn MSS_GPIO[5] +44 - - - +45 - PCIe_RSTOUTn - +46 - - - +47 GE_MDC CLKOUT - +48 XG_MDC - - +49 GE_MDIO PCIe0_CLKREQ SDIO_V18_EN +50 XG_MDIO - SDIO_PWR1[1] +51 - - SDIO_PWR1[0] +52 LED_CLK PCIe_RSTOUTn PCIe0_CLKREQ +53 LED_STB - - +54 LED_DATA - SDIO_HW_RST +55 - - SDIO_LED +56 - SATA1_PRESENT_ACTIVEn - +57 - SATA0_PRESENT_ACTIVEn - +58 LED_CLK - - +59 LED_STB UART1_TXD - +60 LED_DATA UART1_RXD - +61 UART2_TXD SATA1_PRESENT_ACTIVEn GE_MDIO +62 UART2_RXD SATA0_PRESENT_ACTIVEn GE_MDC + +------------------------------------------------------------------------------- +MPP# 0xB 0xD 0xE +------------------------------------------------------------------------------- +0 - - - +1 - - - +2 - - - +3 - - - +4 - - - +5 - - - +6 - - - +7 - - - +8 - - - +9 - - - +10 - - - +11 - CLKOUT_MPP_11 - +12 - - - +13 - - - +14 - - - +15 PTP_PULSE_CP2CP SAR_IN[5] - +16 - SAR_IN[3] - +17 - SAR_IN[6] - +18 PTP_CLK_CP2CP SAR_IN[11] - +19 WAKEUP_OUT_CP2CP SAR_IN[7] - +20 - SAR_IN[9] - +21 SEI_IN_CP2CP SAR_IN[8] - +22 WAKEUP_IN_CP2CP SAR_IN[10] - +23 LINK_RD_IN_CP2CP SAR_IN[4] - +24 - - - +25 - CLKOUT_MPP_25 - +26 - SAR_IN[0] - +27 REI_IN_CP2CP SAR_IN[1] - +28 LED_DATA SAR_IN[2] - +29 LED_STB AVS_FB_IN_CP2CP - +30 LED_CLK SAR_IN[13] - +31 - - - +32 - SAR_CP2CP_OUT[0] - +33 - SAR_CP2CP_OUT[1] - +34 - SAR_CP2CP_OUT[2] - +35 - SAR_CP2CP_OUT[3] - +36 - CLKIN - +37 LINK_RD_OUT_CP2CP SAR_CP2CP_OUT[4] - +38 PTP_PULSE_CP2CP SAR_CP2CP_OUT[5] - +39 - AVS_FB_OUT_CP2CP - +40 - - - +41 REI_OUT_CP2CP - - +42 - SAR_CP2CP_OUT[9] - +43 WAKEUP_OUT_CP2CP SAR_CP2CP_OUT[10] - +44 PTP_CLK_CP2CP SAR_CP2CP_OUT[11] - +45 - SAR_CP2CP_OUT[6] - +46 - SAR_CP2CP_OUT[13] - +47 - - - +48 WAKEUP_IN_CP2CP SAR_CP2CP_OUT[7] - +49 SEI_OUT_CP2CP SAR_CP2CP_OUT[8] - +50 - - - +51 - - - +52 - - - +53 SDIO_LED - - +54 SDIO_WR_PROTECT - - +55 SDIO_CARD_DETECT - - +56 - - SDIO0_CLK +57 - - SDIO0_CMD +58 - - SDIO0_D[0] +59 - - SDIO0_D[1] +60 - - SDIO0_D[2] +61 - - SDIO0_D[3] +62 - - - diff --git a/doc/device-tree-bindings/pinctrl/marvell,mvebu-pinctrl.txt b/doc/device-tree-bindings/pinctrl/marvell,mvebu-pinctrl.txt new file mode 100644 index 0000000..0973db8 --- /dev/null +++ b/doc/device-tree-bindings/pinctrl/marvell,mvebu-pinctrl.txt @@ -0,0 +1,113 @@ +The pinctrl driver enables Marvell Armada 8K SoCs to configure the multi-purpose +pins (mpp) to a specific function. +A Marvell SoC pin configuration node is a node of a group of pins which can +be used for a specific device or function. Each node requires one or more +mpp pins or group of pins and a mpp function common to all pins. + +Required properties for the pinctrl driver: +- compatible: "marvell,mvebu-pinctrl", + "marvell,armada-ap806-pinctrl", + "marvell,a70x0-pinctrl", + "marvell,a80x0-cp0-pinctrl", + "marvell,a80x0-cp1-pinctrl" +- bank-name: A string defining the pinc controller bank name +- reg: A pair of values defining the pin controller base address + and the address space +- pin-count: Numeric value defining the amount of multi purpose pins + included in this bank +- max-func: Numeric value defining the maximum function value for + pins in this bank +- pin-func: Array of pin function values for every pin in the bank. + When the function value for a specific pin equal 0xFF, + the pin configuration is skipped and a default function + value is used for this pin. + +The A8K is a hybrid SoC that contains several silicon dies interconnected in +a single package. Each such die may have a separate pin controller. + +Example: +/ { + ap806 { + config-space { + pinctl: pinctl@6F4000 { + compatible = "marvell,mvebu-pinctrl", + "marvell,armada-ap806-pinctrl"; + bank-name ="apn-806"; + reg = <0x6F4000 0x10>; + pin-count = <20>; + max-func = <3>; + /* MPP Bus: + SPI0 [0-3] + I2C0 [4-5] + UART0 [11,19] + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 3 3 3 3 3 3 0 0 0 0 + 0 3 0 0 0 0 0 0 0 3>; + }; + }; + }; + + cp110-master { + config-space { + cpm_pinctl: pinctl@44000 { + compatible = "marvell,mvebu-pinctrl", + "marvell,a70x0-pinctrl", + "marvell,a80x0-cp0-pinctrl"; + bank-name ="cp0-110"; + reg = <0x440000 0x20>; + pin-count = <63>; + max-func = <0xf>; + /* MPP Bus: + [0-31] = 0xff: Keep default CP0_shared_pins: + [11] CLKOUT_MPP_11 (out) + [23] LINK_RD_IN_CP2CP (in) + [25] CLKOUT_MPP_25 (out) + [29] AVS_FB_IN_CP2CP (in) + [32,34] SMI + [31] GPIO: push button/Wake + [35-36] GPIO + [37-38] I2C + [40-41] SATA[0/1]_PRESENT_ACTIVEn + [42-43] XSMI + [44-55] RGMII1 + [56-62] SD + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0 7 0 7 0 0 2 2 0 + 0 0 8 8 1 1 1 1 1 1 + 1 1 1 1 1 1 0xE 0xE 0xE 0xE + 0xE 0xE 0xE>; + }; + }; + }; + + cp110-slave { + config-space { + cps_pinctl: pinctl@44000 { + compatible = "marvell,mvebu-pinctrl", + "marvell,a80x0-cp1-pinctrl"; + bank-name ="cp1-110"; + reg = <0x440000 0x20>; + pin-count = <63>; + max-func = <0xf>; + /* MPP Bus: + [0-11] RGMII0 + [27,31] GE_MDIO/MDC + [32-62] = 0xff: Keep default CP1_shared_pins: + */ + /* 0 1 2 3 4 5 6 7 8 9 */ + pin-func = < 0x3 0x3 0x3 0x3 0x3 0x3 0x3 0x3 0x3 0x3 + 0x3 0x3 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0x8 0xff 0xff + 0xff 0x8 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff + 0xff 0xff 0xff>; + }; + }; + }; +} diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 12be3cf..efcb4c0 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -181,5 +181,6 @@ source "drivers/pinctrl/meson/Kconfig" source "drivers/pinctrl/nxp/Kconfig" source "drivers/pinctrl/uniphier/Kconfig" source "drivers/pinctrl/exynos/Kconfig" +source "drivers/pinctrl/mvebu/Kconfig"
endmenu diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index f28b5c1..512112a 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_PINCTRL_UNIPHIER) += uniphier/ obj-$(CONFIG_PIC32_PINCTRL) += pinctrl_pic32.o obj-$(CONFIG_PINCTRL_EXYNOS) += exynos/ obj-$(CONFIG_PINCTRL_MESON) += meson/ +obj-$(CONFIG_PINCTRL_MVEBU) += mvebu/ diff --git a/drivers/pinctrl/mvebu/Kconfig b/drivers/pinctrl/mvebu/Kconfig new file mode 100644 index 0000000..39946a2 --- /dev/null +++ b/drivers/pinctrl/mvebu/Kconfig @@ -0,0 +1,16 @@ +config PINCTRL_MVEBU + depends on ARCH_MVEBU + bool + default y + help + Support pin multiplexing and pin configuration control on + Marvell's Armada-8K SoC. The pin control driver allows setting + the pin mode (function) according to DTS configuration for every + multi-purpose pin (MPP) that is connected to the SoC pin controllers, + which are located on AP (north bridge with CPU cluster) or CP + (south bridge with mode IO). + For details about available pin function please refer to the + documentation included in device-tree-binding/pinctrl folder. + The driver allows all-pins configuration upon pin controller device + probe and setting specific pin functions for enabling some interface + functionality, for instance UART, SPI. I2C, etc. diff --git a/drivers/pinctrl/mvebu/Makefile b/drivers/pinctrl/mvebu/Makefile new file mode 100644 index 0000000..f4f7864 --- /dev/null +++ b/drivers/pinctrl/mvebu/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2016 Marvell International Ltd. +# +# SPDX-License-Identifier: GPL-2.0 +# https://spdx.org/licenses + +obj-$(CONFIG_PINCTRL_MVEBU) += pinctrl-mvebu.o diff --git a/drivers/pinctrl/mvebu/pinctrl-mvebu.c b/drivers/pinctrl/mvebu/pinctrl-mvebu.c new file mode 100644 index 0000000..b077639 --- /dev/null +++ b/drivers/pinctrl/mvebu/pinctrl-mvebu.c @@ -0,0 +1,179 @@ +/* + * Copyright (C) 2016 Marvell International Ltd. + * + * SPDX-License-Identifier: GPL-2.0 + * https://spdx.org/licenses + */ + +#include <common.h> +#include <config.h> +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <dm/root.h> +#include <asm/system.h> +#include <asm/io.h> +#include <asm/arch-armada8k/soc-info.h> +#include "pinctrl-mvebu.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * mvebu_pinctrl_set_state: configure pin functions. + * @dev: the pinctrl device to be configured. + * @config: the state to be configured. + * @return: 0 in success + */ +int mvebu_pinctrl_set_state(struct udevice *dev, struct udevice *config) +{ + const void *blob = gd->fdt_blob; + int node = config->of_offset; + struct mvebu_pinctrl_priv *priv; + u32 pin_arr[MVEBU_MAX_PINS_PER_BANK]; + u32 function; + int i, pin_count; + + priv = dev_get_priv(dev); + + pin_count = fdtdec_get_int_array_count(blob, node, + "marvell,pins", + pin_arr, + MVEBU_MAX_PINS_PER_BANK); + if (pin_count <= 0) { + debug("Failed reading pins array for pinconfig %s (%d)\n", + config->name, pin_count); + return -EINVAL; + } + + function = fdtdec_get_int(blob, node, "marvell,function", 0xff); + + for (i = 0; i < pin_count; i++) { + int reg_offset; + int field_offset; + int pin = pin_arr[i]; + + if (function > priv->max_func) { + debug("Illegal function %d for pinconfig %s\n", + function, config->name); + return -EINVAL; + } + + /* Calculate register address and bit in register */ + reg_offset = priv->reg_direction * 4 * + (pin >> (PIN_REG_SHIFT)); + field_offset = (BITS_PER_PIN) * (pin & PIN_FIELD_MASK); + + clrsetbits_le32(priv->base_reg + reg_offset, + PIN_FUNC_MASK << field_offset, + (function & PIN_FUNC_MASK) << field_offset); + } + + return 0; +} + +/* + * mvebu_pinctrl_set_state_all: configure the entire bank pin functions. + * @dev: the pinctrl device to be configured. + * @config: the state to be configured. + * @return: 0 in success + */ +static int mvebu_pinctrl_set_state_all(struct udevice *dev, + struct udevice *config) +{ + const void *blob = gd->fdt_blob; + int node = config->of_offset; + struct mvebu_pinctrl_priv *priv; + u32 func_arr[MVEBU_MAX_PINS_PER_BANK]; + int pin, err; + + priv = dev_get_priv(dev); + + err = fdtdec_get_int_array(blob, node, "pin-func", + func_arr, priv->pin_cnt); + if (err) { + debug("Failed reading pin functions for bank %s\n", + priv->bank_name); + return -EINVAL; + } + + for (pin = 0; pin < priv->pin_cnt; pin++) { + int reg_offset; + int field_offset; + u32 func = func_arr[pin]; + + /* Bypass pins with function 0xFF */ + if (func == 0xff) { + debug("Warning: pin %d value is not modified ", pin); + debug("(kept as default)\n"); + continue; + } else if (func > priv->max_func) { + debug("Illegal function %d for pin %d\n", func, pin); + return -EINVAL; + } + + /* Calculate register address and bit in register */ + reg_offset = priv->reg_direction * 4 * + (pin >> (PIN_REG_SHIFT)); + field_offset = (BITS_PER_PIN) * (pin & PIN_FIELD_MASK); + + clrsetbits_le32(priv->base_reg + reg_offset, + PIN_FUNC_MASK << field_offset, + (func & PIN_FUNC_MASK) << field_offset); + } + + return 0; +} + +int mvebu_pinctl_probe(struct udevice *dev) +{ + const void *blob = gd->fdt_blob; + int node = dev->of_offset; + struct mvebu_pinctrl_priv *priv; + + priv = dev_get_priv(dev); + if (!priv) { + debug("%s: Failed to get private\n", __func__); + return -EINVAL; + } + + priv->base_reg = dev_get_addr_ptr(dev); + if (priv->base_reg == (void *)FDT_ADDR_T_NONE) { + debug("%s: Failed to get base address\n", __func__); + return -EINVAL; + } + + priv->pin_cnt = fdtdec_get_int(blob, node, "pin-count", + MVEBU_MAX_PINS_PER_BANK); + priv->max_func = fdtdec_get_int(blob, node, "max-func", + MVEBU_MAX_FUNC); + priv->bank_name = fdt_getprop(blob, node, "bank-name", NULL); + + priv->reg_direction = 1; + if (fdtdec_get_bool(blob, node, "reverse-reg")) + priv->reg_direction = -1; + + return mvebu_pinctrl_set_state_all(dev, dev); +} + +static struct pinctrl_ops mvebu_pinctrl_ops = { + .set_state = mvebu_pinctrl_set_state +}; + +static const struct udevice_id mvebu_pinctrl_ids[] = { + { .compatible = "marvell,mvebu-pinctrl" }, + { .compatible = "marvell,armada-ap806-pinctrl" }, + { .compatible = "marvell,a70x0-pinctrl" }, + { .compatible = "marvell,a80x0-cp0-pinctrl" }, + { .compatible = "marvell,a80x0-cp1-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(pinctrl_mvebu) = { + .name = "mvebu_pinctrl", + .id = UCLASS_PINCTRL, + .of_match = mvebu_pinctrl_ids, + .priv_auto_alloc_size = sizeof(struct mvebu_pinctrl_priv), + .ops = &mvebu_pinctrl_ops, + .probe = mvebu_pinctl_probe +}; diff --git a/drivers/pinctrl/mvebu/pinctrl-mvebu.h b/drivers/pinctrl/mvebu/pinctrl-mvebu.h new file mode 100644 index 0000000..1a1d3ef --- /dev/null +++ b/drivers/pinctrl/mvebu/pinctrl-mvebu.h @@ -0,0 +1,31 @@ +/* + * Copyright (C) 2016 Marvell International Ltd. + * + * SPDX-License-Identifier: GPL-2.0 + * https://spdx.org/licenses + */ + + #ifndef __PINCTRL_MVEBU_H_ + #define __PINCTRL_MVEBU_H_ + + #define MVEBU_MAX_PINCTL_BANKS 4 + #define MVEBU_MAX_PINS_PER_BANK 100 + #define MVEBU_MAX_FUNC 0xF + +/* + * struct mvebu_pin_bank_data: mvebu-pinctrl bank data + * @base_reg: controller base address for this bank + * @pin_cnt: number of pins included in this bank + * @max_func: maximum configurable function value for pins in this bank + * @reg_direction: + * @bank_name: the pin's bank name + */ +struct mvebu_pinctrl_priv { + void *base_reg; + uint pin_cnt; + uint max_func; + int reg_direction; + const char *bank_name; +}; + +#endif /* __PINCTRL_MVEBU_H_ */
Changes for v3:
I think I already reviewed this, but just in case:
Hello, Simon,
Thank you very much for your review. Yes, this patch was only adding some help to Kconfig (as you requested), no other changes from the previous version. I have to re-send the entire series one more time for moving the change log from commit messages to comment sections. Some changes will be done on other patches, but this one will remain the same as v3.
Best Regards Kosta ________________________________________ From: sjg@google.com sjg@google.com on behalf of Simon Glass sjg@chromium.org Sent: Wednesday, December 7, 2016 05:47 To: Kostya Porotchkin Cc: U-Boot Mailing List; Stefan Roese; Nadav Haklai; Neta Zur Hershkovits; Omri Itach; Igal Liberman; Haim Boot; Hanna Hawa Subject: Re: [PATCH v3 3/6] arm64: mvebu: pinctrl: Add pin control driver for A8K family
---------------------------------------------------------------------- On 5 December 2016 at 05:16, kostap@marvell.com wrote:
Changes for v3:
On 7 December 2016 at 03:03, Kostya Porotchkin kostap@marvell.com wrote:
Hello, Simon,
OK, please add my review tag for anything I have reviewed, when you resend it. It saves me needing to review again.
Thanks, Simon
kostap@marvell.com
Kostya Porotchkin
