[U-Boot] [GIT PULL] u-boot-mips/master
Hi Tom,
please pull the last batch of MIPS updates, thanks.
The following changes since commit e4a94ce4ac77396b181663c0493c50bc2d5b9143:
Merge git://git.denx.de/u-boot-dm (2016-05-27 20:34:12 -0400)
git://git.denx.de/u-boot-mips.git master
for you to fetch changes up to f1b65c98b0a134ce92c38141b917fd3a210ee535:
mips: ath79: ap143: Reset ethernet on boot (2016-05-31 10:17:54 +0200)
---------------------------------------------------------------- Daniel Schwierzeck (4): MIPS: provide a default u-boot-spl.lds MIPS: add tune for MIPS 34kc MIPS: remove dead code from asm/u-boot-mips.h MIPS: malta: add defconfigs for MIPS64
Marek Vasut (1): net: Add ag7xxx driver for Atheros MIPS
Paul Burton (8): MIPS: Use CPHYSADDR to implement mips32 virt_to_phys net: pcnet: Stop converting kseg1->kseg0 addresses net: pcnet: Make 64 bit safe net: pcnet: Fix init on big endian 64 bit malta: Allow MIPS64 builds MIPS: Move cache sizes to Kconfig MIPS: Split I & D cache line size config MIPS: Abstract cache op loops with a macro
Wills Wang (6): mips: ath79: Rename get_bootstrap into ath79_get_bootstrap mips: ath79: ap121: Enable ethernet mips: ath79: Use 8MB flash profile for mtd partition by default mips: ath79: Add support for ungating USB and ethernet on qca953x mips: ath79: Use AR933X_PLL_SWITCH_CLOCK_CONTROL_REG macro define mips: ath79: ap143: Reset ethernet on boot
arch/mips/Kconfig | 40 +++++ arch/mips/Makefile | 1 + arch/mips/config.mk | 5 +- arch/mips/cpu/u-boot-spl.lds | 90 ++++++++++++ arch/mips/dts/ap121.dts | 5 + arch/mips/dts/ar933x.dtsi | 4 +- arch/mips/include/asm/cache.h | 7 + arch/mips/include/asm/io.h | 5 +- arch/mips/include/asm/u-boot-mips.h | 21 +-- arch/mips/lib/cache.c | 79 +++------- arch/mips/lib/cache_init.S | 10 +- arch/mips/mach-ath79/ar933x/clk.c | 4 +- arch/mips/mach-ath79/ar933x/ddr.c | 4 +- arch/mips/mach-ath79/ar934x/clk.c | 6 +- arch/mips/mach-ath79/ar934x/ddr.c | 4 +- arch/mips/mach-ath79/include/mach/ar71xx_regs.h | 1 + arch/mips/mach-ath79/include/mach/ath79.h | 1 + arch/mips/mach-ath79/include/mach/reset.h | 14 -- arch/mips/mach-ath79/qca953x/clk.c | 4 +- arch/mips/mach-ath79/qca953x/ddr.c | 4 +- arch/mips/mach-ath79/reset.c | 54 ++++++- board/dbau1x00/Kconfig | 12 ++ board/imgtec/malta/Kconfig | 3 +- board/imgtec/malta/lowlevel_init.S | 13 +- board/micronas/vct/Kconfig | 12 ++ board/pb1x00/Kconfig | 12 ++ board/qca/ap121/Kconfig | 12 ++ board/qca/ap121/ap121.c | 2 + board/qca/ap143/Kconfig | 12 ++ board/qca/ap143/ap143.c | 2 + board/qemu-mips/Kconfig | 12 ++ board/tplink/wdr4300/Kconfig | 12 ++ configs/ap121_defconfig | 9 +- configs/malta64_defconfig | 16 ++ configs/malta64el_defconfig | 17 +++ drivers/net/Kconfig | 9 ++ drivers/net/Makefile | 1 + drivers/net/ag7xxx.c | 980 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/pcnet.c | 39 +++-- include/configs/ap121.h | 9 +- include/configs/ap143.h | 11 +- include/configs/dbau1x00.h | 7 - include/configs/malta.h | 18 ++- include/configs/pb1x00.h | 6 - include/configs/pic32mzdask.h | 1 - include/configs/qemu-mips.h | 7 - include/configs/qemu-mips64.h | 7 - include/configs/tplink_wdr4300.h | 5 - include/configs/vct.h | 7 - 49 files changed, 1412 insertions(+), 204 deletions(-) create mode 100644 arch/mips/cpu/u-boot-spl.lds delete mode 100644 arch/mips/mach-ath79/include/mach/reset.h create mode 100644 configs/malta64_defconfig create mode 100644 configs/malta64el_defconfig create mode 100644 drivers/net/ag7xxx.c
On Tue, May 31, 2016 at 11:36:46AM +0200, Daniel Schwierzeck wrote:
Hi Tom,
Daniel Schwierzeck
