[U-Boot] [PATCH v2] microblaze: Do not call timer init that early
Timer needs to be converted to DM but as of now it can't be called so early because intc controller is not ready. Call it later in board_r.c. Before this patch timer_init is called twice which is wrong. The patch is blocking initialization before relocation.
Changes in v2: - Do not add new ifdef to board_f and use GD_FLG_RELOC instead - reported-by sjg - Change commit message
arch/microblaze/cpu/timer.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/microblaze/cpu/timer.c b/arch/microblaze/cpu/timer.c index ef229023bf08..58e5c3075085 100644 --- a/arch/microblaze/cpu/timer.c +++ b/arch/microblaze/cpu/timer.c @@ -51,6 +51,10 @@ int timer_init (void)
debug("TIMER: Initialization\n");
+ /* Do not init before relocation */ + if (!(gd->flags & GD_FLG_RELOC)) + return 0; + node = fdt_node_offset_by_compatible(blob, node, "xlnx,xps-timer-1.00.a"); if (node != -1) {
Changes in v2:
Michal Simek
