[U-Boot] [PATCH v4] sun8i: h3: Add support for the Beelink-x2 STB
The Beelink X2 is an STB based on the Allwinner H3 SoC with a uSD slot, 2 USB ports( 1 * USB-2 Host, 1 USB OTG), a 10/100M ethernet port using the SoC's integrated PHY, Wifi via an sdio wifi chip, HDMI, an IR receiver, a dual colour LED and an optical S/PDIF connector.
Signed-off-by: Marcus Cooper codekipper@gmail.com --- Changes in v4: - updated dts to reflex current linux kernel status
Changes in v3: - Removed incorrect commit author - Included v1-v2 change info
Changes in v2: - updated dts to reflex current linux kernel status --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun8i-h3-beelink-x2.dts | 216 +++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/beelink_x2_defconfig | 19 +++ 4 files changed, 241 insertions(+) create mode 100644 arch/arm/dts/sun8i-h3-beelink-x2.dts create mode 100644 configs/beelink_x2_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 83058c4452..716108dd2e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -472,6 +472,7 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h2-plus-orangepi-r1.dtb \ sun8i-h2-plus-orangepi-zero.dtb \ sun8i-h3-bananapi-m2-plus.dtb \ + sun8i-h3-beelink-x2.dtb \ sun8i-h3-libretech-all-h3-cc.dtb \ sun8i-h3-nanopi-m1.dtb \ sun8i-h3-nanopi-m1-plus.dtb \ diff --git a/arch/arm/dts/sun8i-h3-beelink-x2.dts b/arch/arm/dts/sun8i-h3-beelink-x2.dts new file mode 100644 index 0000000000..25540b7694 --- /dev/null +++ b/arch/arm/dts/sun8i-h3-beelink-x2.dts @@ -0,0 +1,216 @@ +/* + * Copyright (C) 2017 Marcus Cooper codekipper@gmail.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-h3.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + model = "Beelink X2"; + compatible = "roofull,beelink-x2", "allwinner,sun8i-h3"; + + aliases { + serial0 = &uart0; + ethernet0 = &emac; + ethernet1 = &sdiowifi; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + blue { + label = "beelink-x2:blue:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */ + default-state = "on"; + }; + + red { + label = "beelink-x2:red:standby"; + gpios = <&pio 0 15 GPIO_ACTIVE_HIGH>; /* PA15 */ + }; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */ + }; + + sound_spdif { + compatible = "simple-audio-card"; + simple-audio-card,name = "On-board SPDIF"; + + simple-audio-card,cpu { + sound-dai = <&spdif>; + }; + + simple-audio-card,codec { + sound-dai = <&spdif_out>; + }; + }; + + spdif_out: spdif-out { + #sound-dai-cells = <0>; + compatible = "linux,spdif-dit"; + }; +}; + +&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&emac { + phy-handle = <&int_mii_phy>; + phy-mode = "mii"; + allwinner,leds-active-low; + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&ir { + pinctrl-names = "default"; + pinctrl-0 = <&ir_pins_a>; + status = "okay"; +}; + +&mmc0 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + status = "okay"; +}; + +&mmc1 { + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + non-removable; + status = "okay"; + + /* + * Explicitly define the sdio device, so that we can add an ethernet + * alias for it (which e.g. makes u-boot set a mac-address). + */ + sdiowifi: sdio_wifi@1 { + reg = <1>; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_8bit_pins>; + vmmc-supply = <®_vcc3v3>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +®_usb0_vbus { + gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */ + status = "okay"; +}; + +&spdif { + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx_pins_a>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + /* USB VBUS is always on except for the OTG port */ + status = "okay"; + usb0_id_det-gpios = <&pio 0 7 GPIO_ACTIVE_HIGH>; /* PA07 */ + usb0_vbus-supply = <®_usb0_vbus>; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index bdd1854197..28f2bece40 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -172,6 +172,11 @@ S: Maintained F: configs/beelink_gs1_defconfig F: arch/arm/dts/sun50i-h6-beelink-gs1.dts
+BEELINK X2 BOARD +M: Marcus Cooper codekipper@gmail.com +S: Maintained +F: configs/beelink_x2_defconfig + COLOMBUS BOARD M: Maxime Ripard maxime.ripard@bootlin.com S: Maintained diff --git a/configs/beelink_x2_defconfig b/configs/beelink_x2_defconfig new file mode 100644 index 0000000000..6508e470a0 --- /dev/null +++ b/configs/beelink_x2_defconfig @@ -0,0 +1,19 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN8I_H3=y +CONFIG_DRAM_CLK=624 +CONFIG_DRAM_ZQ=3881979 +CONFIG_DRAM_ODT_EN=y +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-beelink-x2" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y +CONFIG_SY8106A_POWER=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
Hi!
Dne nedelja, 26. maj 2019 ob 08:28:41 CEST je codekipper@gmail.com napisal(a):
Changes in v4:
Changes in v3:
Changes in v2:
- sun8i-h3-beelink-x2.dtb \ sun8i-h3-libretech-all-h3-cc.dtb \ sun8i-h3-nanopi-m1.dtb \ sun8i-h3-nanopi-m1-plus.dtb \
- Copyright (C) 2017 Marcus Cooper codekipper@gmail.com
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- model = "Beelink X2";
- compatible = "roofull,beelink-x2", "allwinner,sun8i-h3";
- aliases {
serial0 = &uart0;
ethernet0 = &emac;
- chosen {
- connector {
type = "a";
port {
- leds {
blue {
PL10 */
red {
- wifi_pwrseq: wifi_pwrseq {
- sound_spdif {
- spdif_out: spdif-out {
+&de {
- status = "okay";
+&ehci0 {
- status = "okay";
+&ehci1 {
- status = "okay";
+&emac {
- phy-handle = <&int_mii_phy>;
- phy-mode = "mii";
- allwinner,leds-active-low;
- status = "okay";
+&hdmi {
- status = "okay";
+&hdmi_out {
- hdmi_out_con: endpoint {
+&ir {
- pinctrl-names = "default";
- pinctrl-0 = <&ir_pins_a>;
- status = "okay";
+&mmc0 {
- vmmc-supply = <®_vcc3v3>;
- bus-width = <4>;
- cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */
- status = "okay";
+&mmc1 {
- bus-width = <4>;
- non-removable;
- status = "okay";
- sdiowifi: sdio_wifi@1 {
reg = <1>;
+&mmc2 {
- pinctrl-0 = <&mmc2_8bit_pins>;
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+®_usb0_vbus {
- gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */
- status = "okay";
+&spdif {
- pinctrl-0 = <&spdif_tx_pins_a>;
- status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_pins_a>;
- status = "okay";
+&usb_otg {
- dr_mode = "otg";
- status = "okay";
+&usbphy {
- /* USB VBUS is always on except for the OTG port */
- status = "okay";
- usb0_id_det-gpios = <&pio 0 7 GPIO_ACTIVE_HIGH>; /* PA07 */
- usb0_vbus-supply = <®_usb0_vbus>;
Android on my Beelink X2 box sets DRAM clock to 576 MHz, did you check yours?
I'm pretty sure that my Beelink X2 doesn't have SY8106A regulator. In fact, it doesn't have any regulator for CPU voltage (it's fixed). I think you should drop this and CONFIG_SPL_I2C_SUPPORT line from defconfig.
I know there are at least two models of Beelink X2 (different wifi), but I think both are missing CPU regulator.
Best regards, Jernej
On Sun, 26 May 2019 at 08:42, Jernej Škrabec jernej.skrabec@gmail.com wrote:
Hi!
Changes in v4:
Changes in v3:
Changes in v2:
- whole.
conditions:
aliases {
serial0 = &uart0;
ethernet0 = &emac;
chosen {
connector {
type = "a";
port {
leds {
blue {
PL10 */
red {
sound_spdif {
+&de {
status = "okay";
+&ehci0 {
status = "okay";
+&ehci1 {
status = "okay";
+&emac {
phy-mode = "mii";
status = "okay";
+&hdmi {
status = "okay";
+&hdmi_out {
+&ir {
status = "okay";
+&mmc0 {
bus-width = <4>;
status = "okay";
+&mmc1 {
bus-width = <4>;
non-removable;
status = "okay";
reg = <1>;
+&mmc2 {
bus-width = <8>;
non-removable;
cap-mmc-hw-reset;
status = "okay";
+&ohci0 {
status = "okay";
+&ohci1 {
status = "okay";
+®_usb0_vbus {
status = "okay";
+&spdif {
status = "okay";
+&uart0 {
status = "okay";
+&usb_otg {
dr_mode = "otg";
status = "okay";
+&usbphy {
status = "okay";
ACK thanks, CK
Hi!
Changes in v4:
Changes in v3:
Changes in v2:
- whole.
conditions:
- aliases {
serial0 = &uart0;
ethernet0 = &emac;
- chosen {
- connector {
type = "a";
port {
- leds {
blue {
PL10 */
red {
- sound_spdif {
+&de {
- status = "okay";
+&ehci0 {
- status = "okay";
+&ehci1 {
- status = "okay";
+&emac {
- phy-mode = "mii";
- status = "okay";
+&hdmi {
- status = "okay";
+&hdmi_out {
+&ir {
- status = "okay";
+&mmc0 {
- bus-width = <4>;
- status = "okay";
+&mmc1 {
- bus-width = <4>;
- non-removable;
- status = "okay";
reg = <1>;
+&mmc2 {
- bus-width = <8>;
- non-removable;
- cap-mmc-hw-reset;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+®_usb0_vbus {
- status = "okay";
+&spdif {
- status = "okay";
+&uart0 {
- status = "okay";
+&usb_otg {
- dr_mode = "otg";
- status = "okay";
+&usbphy {
- status = "okay";
I think you should add: CONFIG_SPL_TEXT_BASE=0x60
due to following commit: http://git.denx.de/?p=u-boot/u-boot-sunxi.git;a=commit;h=f89d6133ee
On Sun, 26 May 2019 at 14:13, Jernej Škrabec jernej.skrabec@gmail.com wrote:
Hi!
Changes in v4:
Changes in v3:
Changes in v2:
- whole.
conditions:
aliases {
serial0 = &uart0;
ethernet0 = &emac;
chosen {
connector {
type = "a";
port {
leds {
blue {
PL10 */
red {
sound_spdif {
+&de {
status = "okay";
+&ehci0 {
status = "okay";
+&ehci1 {
status = "okay";
+&emac {
phy-mode = "mii";
status = "okay";
+&hdmi {
status = "okay";
+&hdmi_out {
+&ir {
status = "okay";
+&mmc0 {
bus-width = <4>;
status = "okay";
+&mmc1 {
bus-width = <4>;
non-removable;
status = "okay";
reg = <1>;
+&mmc2 {
bus-width = <8>;
non-removable;
cap-mmc-hw-reset;
status = "okay";
+&ohci0 {
status = "okay";
+&ohci1 {
status = "okay";
+®_usb0_vbus {
status = "okay";
+&spdif {
status = "okay";
+&uart0 {
status = "okay";
+&usb_otg {
dr_mode = "otg";
status = "okay";
+&usbphy {
status = "okay";
ACK, arrgghh I thought the sunxi-next branch was misbehaving. Now boots ontop of master, CK
Hi!
Changes in v4:
Changes in v3:
Changes in v2:
- whole.
conditions:
aliases {
serial0 = &uart0;
ethernet0 = &emac;
chosen {
connector {
type = "a";
port {
leds {
blue {
PL10 */
red {
sound_spdif {
+&de {
status = "okay";
+&ehci0 {
status = "okay";
+&ehci1 {
status = "okay";
+&emac {
phy-mode = "mii";
status = "okay";
+&hdmi {
status = "okay";
+&hdmi_out {
+&ir {
status = "okay";
+&mmc0 {
bus-width = <4>;
status = "okay";
+&mmc1 {
bus-width = <4>;
non-removable;
status = "okay";
reg = <1>;
+&mmc2 {
bus-width = <8>;
non-removable;
cap-mmc-hw-reset;
status = "okay";
+&ohci0 {
status = "okay";
+&ohci1 {
status = "okay";
+®_usb0_vbus {
status = "okay";
+&spdif {
status = "okay";
+&uart0 {
status = "okay";
+&usb_otg {
dr_mode = "otg";
status = "okay";
+&usbphy {
status = "okay";
Can we make that a default in Kconfig instead of having to put it in pretty much every defconfig?
Maxime
-- Maxime Ripard, Bootlin Embedded Linux and Kernel engineering https://bootlin.com
Code Kipper
Jernej Škrabec
Maxime Ripard
