[U-Boot] [PATCH] arm: ls1021a: Add timer_init() in board_init_f for SPL
I2C is used to access DDR SPD in the DDR initialization for SPL. In i2c_write process, get_timer() will be called. In board_init_f for SPL, timer_init() is not called before. The system counter is not enabled and the counter frequency is not set to 12.5MHz in SPL. The parameters for do_div() are zero too.
It could not be found until CONFIG_USE_PRIVATE_LIBGCC is enabled in default. When CONFIG_USE_PRIVATE_LIBGCC is enabled, U-Boot will use its own set of libgcc functions. As the parameters for do_div() are zero, __div0 will be called. Then the processor will stay in an endless loop after calling hang().
This patch will add timer_init() in board_init_f for SPL and fix a series of issues it caused.
Signed-off-by: Alison Wang alison.wang@nxp.com --- board/freescale/ls1021aqds/ls1021aqds.c | 1 + board/freescale/ls1021atwr/ls1021atwr.c | 1 + 2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index c828dac..c08be1e 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -244,6 +244,7 @@ void board_init_f(ulong dummy) if (major == SOC_MAJOR_VER_1_0) out_le32(&cci->ctrl_ord, CCI400_CTRLORD_TERM_BARRIER);
+ timer_init(); dram_init();
/* Allow OCRAM access permission as R/W */ diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index dcd6d93..beb82ce 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -467,6 +467,7 @@ void board_init_f(ulong dummy)
preloader_console_init();
This set is applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Alison Wang
York Sun
