[U-Boot] [PATCH] powerpc/corenet: Add workaround for ELBC multi-bit ECC error
NAND operations in condition like below will result ELBC internal multi-bit ECC error, DCFG will send this error to MPIC to report it as an error interrupt (Interrupt 0), which causes call trace in kernel, so software should disable the DCFG not to send the ELBC ECC error by setting bit 15 in the register at DCSRBASE + 0x0002_0520. This won't inhibit the reporting of LTESR[PAR]. This workaround is enabled on P2041/P3041/P50x0.
steps to reproduce the issue: 1. power cycle the board 2. use following command to do NAND test: flashcp -v file-jffs2 /dev/mtdx
The 'mtdx' should be a NAND partition, the file 'file-jffs2' should be page aligned.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- Sorry! I have to resent since I still cannot find the patch in patch work.
arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 10 ++++++++++ arch/powerpc/include/asm/config_mpc85xx.h | 4 ++++ 3 files changed, 17 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 5d72f4c..671c205 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -227,6 +227,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_NMG_LBC103 puts("Work-around for Erratum NMG_LBC103 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ELBC_MULTIBIT_ECC + puts("Work-around for Erratum ELBC MULTIBIT ECC enabled\n"); +#endif #ifdef CONFIG_SYS_FSL_ERRATUM_NMG_ETSEC129 if ((SVR_MAJ(svr) == 1) || IS_SVR_REV(svr, 2, 0)) puts("Work-around for Erratum NMG ETSEC129 enabled\n"); diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index de9d916..c43be5e 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -592,6 +592,16 @@ skip_l2: } } #endif +#ifdef CONFIG_SYS_FSL_ELBC_MULTIBIT_ECC + /* + * On P2041/P3041/P50x0, NAND operations will result internal multi-bit + * ECC error, which causes call trace in kernel, so software should + * disable the ECC error reported from eLBC by setting bit 15 in + * the register at DCSRBASE + 0x0002_0520. + */ +#define DCFG_ECC (CONFIG_SYS_DCSRBAR + 0x20520) + setbits_be32((void *)DCFG_ECC, 1 << (31 - 15)); +#endif
#ifdef CONFIG_SYS_LBC_LCRR /* diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index d57c178..926316d 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -345,6 +345,7 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000 #define CONFIG_SYS_FSL_ERRATUM_SRIO_A004034 #define CONFIG_SYS_FSL_ERRATUM_A004849 +#define CONFIG_SYS_FSL_ELBC_MULTIBIT_ECC
#elif defined(CONFIG_PPC_P3041) #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 @@ -377,6 +378,7 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000 #define CONFIG_SYS_FSL_ERRATUM_SRIO_A004034 #define CONFIG_SYS_FSL_ERRATUM_A004849 +#define CONFIG_SYS_FSL_ELBC_MULTIBIT_ECC
#elif defined(CONFIG_PPC_P4080) /* also supports P4040 */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 @@ -451,6 +453,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A004510_SVR_REV 0x10 #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xc0000000 #define CONFIG_SYS_FSL_ERRATUM_SRIO_A004034 +#define CONFIG_SYS_FSL_ELBC_MULTIBIT_ECC
#elif defined(CONFIG_PPC_P5040) #define CONFIG_SYS_PPC64 @@ -480,6 +483,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A004510 #define CONFIG_SYS_FSL_ERRATUM_A004510_SVR_REV 0x10 #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000 +#define CONFIG_SYS_FSL_ELBC_MULTIBIT_ECC
#elif defined(CONFIG_BSC9131) #define CONFIG_MAX_CPUS 1
Shaohui Xie
