[U-Boot] [BUG] test_avb_persistent_values() fails
Hello Igor,
when I run `make tests` with current origin/master commit a69120a0d7c8d4044cdaceea9eb03913ba4e49c7 I get an error. I think your submitted this test recently: commit fc1fe01b08ce ("avb: add support for named persistent values")
u_boot_console = <u_boot_console_sandbox.ConsoleSandbox object at 0x7ff056222cd0>
@pytest.mark.buildconfigspec('cmd_avb') @pytest.mark.buildconfigspec('optee_ta_avb') def test_avb_persistent_values(u_boot_console): """Test reading/writing persistent storage to avb """
response = u_boot_console.run_command('avb init %s' % str(mmc_dev)) assert response == ''
response = u_boot_console.run_command('avb write_pvalue test value_value') assert response == 'Wrote 12 bytes'
response = u_boot_console.run_command('avb read_pvalue test 12')
assert response == 'Read 12 bytes, value = value_value'
E AssertionError: assert 'Read 12 byte...alue_value/XU' == 'Read 12 bytes...= value_value' E - Read 12 bytes, value = value_value/XU E ? --- E + Read 12 bytes, value = value_value
test/py/tests/test_avb.py:134: AssertionError
Best regards
Heinrich
On Tue, Apr 30, 2019, 23:14 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hello Igor,
@pytest.mark.buildconfigspec('cmd_avb') @pytest.mark.buildconfigspec('optee_ta_avb') def test_avb_persistent_values(u_boot_console): """Test reading/writing persistent storage to avb """ response = u_boot_console.run_command('avb init %s' %
Best regards
Heinrich
Hi Heinrich,
Thanks for reporting this. Interesting, that when I sent v5 everything was ok (where I addressed an issue reported by Tom, actually I played a lot with `make tests` and all tests were passing successfully) and the only thing I did in v6 - adding R-b tag(v5 was posted ~3 month ago, so I assume something probably was changed in py/tests).
Unfortunately I am AFK till Sunday, will look into this ASAP(Monday morning).
Regards, Igor
On Tue, Apr 30, 2019 at 11:14 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hello Igor,
@pytest.mark.buildconfigspec('cmd_avb') @pytest.mark.buildconfigspec('optee_ta_avb') def test_avb_persistent_values(u_boot_console): """Test reading/writing persistent storage to avb """ response = u_boot_console.run_command('avb init %s' % str(mmc_dev)) assert response == '' response = u_boot_console.run_command('avb write_pvalue test
Best regards
Heinrich
Hi Heinrich,
Just posted the fix [1].
[1]: https://patchwork.ozlabs.org/patch/1095734/
Thanks
Igor Opaniuk
