[PATCH 1/1] rockchip: Fix incorrect constant name in RAM init code
A condition in the rk3399 RAM initialization code used the old CONFIG_RAM_RK3399_LPDDR4 constant name. This commit changes the condition to use the correct CONFIG_RAM_ROCKCHIP_LPDDR4 constant. --- drivers/ram/rockchip/sdram_rk3399.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index b1fea04e84..963a05c244 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -2954,7 +2954,7 @@ static int sdram_init(struct dram_info *dram, params->ch[ch].cap_info.rank = rank; }
-#if defined(CONFIG_RAM_RK3399_LPDDR4) +#if defined(CONFIG_RAM_ROCKCHIP_LPDDR4) /* LPDDR4 needs to be trained at 400MHz */ lpddr4_set_rate(dram, params, 0); params->base.ddr_freq = dfs_cfgs_lpddr4[0].base.ddr_freq / MHz;
David Sebek
