[U-Boot] [PATCH] config_distro_bootcmd: Init IDE devices
IDE devices are no longer automatically probed by u-boot, so it should be done by the distro boot command before attempting to boot from IDE (just like scsi and nvme)
Signed-off-by: Joshua Watt JPEWhacker@gmail.com --- include/config_distro_bootcmd.h | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 4993303f4d..26e61ef196 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -229,10 +229,23 @@ #endif
#ifdef CONFIG_IDE -#define BOOTENV_SHARED_IDE BOOTENV_SHARED_BLKDEV(ide) +#define BOOTENV_RUN_IDE_INIT "run ide_init; " +#define BOOTENV_SET_IDE_NEED_INIT "setenv ide_need_init; " +#define BOOTENV_SHARED_IDE \ + "ide_init=" \ + "if ${ide_need_init}; then " \ + "setenv ide_need_init false; " \ + "ide reset; " \ + "fi\0" \ + \ + "ide_boot=" \ + BOOTENV_RUN_IDE_INIT \ + BOOTENV_SHARED_BLKDEV_BODY(ide) #define BOOTENV_DEV_IDE BOOTENV_DEV_BLKDEV #define BOOTENV_DEV_NAME_IDE BOOTENV_DEV_NAME_BLKDEV #else +#define BOOTENV_RUN_IDE_INIT +#define BOOTENV_SET_IDE_NEED_INIT #define BOOTENV_SHARED_IDE #define BOOTENV_DEV_IDE \ BOOT_TARGET_DEVICES_references_IDE_without_CONFIG_IDE @@ -451,6 +464,7 @@ \ "distro_bootcmd=" BOOTENV_SET_SCSI_NEED_INIT \ BOOTENV_SET_NVME_NEED_INIT \ + BOOTENV_SET_IDE_NEED_INIT \ "for target in ${boot_targets}; do " \ "run bootcmd_${target}; " \ "done\0"
Joshua Watt
