[PATCH] efi_loader: fix CapsuleMax variable reporting
Currently the code that adds the CapsuleMax variable is under a Kconfig named 'EFI_HAVE_CAPSULE_UPDATE. Git history only shows a single occurrence of that. The IS_ENABLED should be checking for EFI_HAVE_CAPSULE_SUPPORT
Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_setup.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index e00005bc3830..0a7b608ba960 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -128,7 +128,7 @@ static efi_status_t efi_init_capsule(void) { efi_status_t ret = EFI_SUCCESS;
- if (IS_ENABLED(CONFIG_EFI_HAVE_CAPSULE_UPDATE)) { + if (IS_ENABLED(CONFIG_EFI_HAVE_CAPSULE_SUPPORT)) { ret = efi_set_variable_int(u"CapsuleMax", &efi_guid_capsule_report, EFI_VARIABLE_READ_ONLY | -- 2.38.1
Ilias Apalodimas
