[U-Boot] [PATCH v3] sf: Minor cleanups
- Add spaces, tabs - Commenting. - Rearrange code. - Add static qualifier for missing func. - Remove memory_map from ramtron.c - Ramtron: spi_flash_internal.h -> sf_internal.h
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v3: - Remove exctra added "update.txt" file Changes for v2: - Ramtron: spi_flash_internal.h -> sf_internal.h
drivers/mtd/spi/ramtron.c | 4 +--- drivers/mtd/spi/sf_internal.h | 8 ++++---- drivers/mtd/spi/sf_probe.c | 7 ++++--- include/spi.h | 22 +++++++++++----------- include/spi_flash.h | 4 ++-- 5 files changed, 22 insertions(+), 23 deletions(-)
diff --git a/drivers/mtd/spi/ramtron.c b/drivers/mtd/spi/ramtron.c index c9701d0..7367e7a 100644 --- a/drivers/mtd/spi/ramtron.c +++ b/drivers/mtd/spi/ramtron.c @@ -36,7 +36,7 @@ #include <common.h> #include <malloc.h> #include <spi_flash.h> -#include "spi_flash_internal.h" +#include "sf_internal.h"
/* * Properties of supported FRAMs @@ -383,8 +383,6 @@ struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, printf("SF: Detected %s with page size ", flash->name); print_size(flash->sector_size, ", total "); print_size(flash->size, ""); - if (flash->memory_map) - printf(", mapped at %p", flash->memory_map); puts("\n");
spi_release_bus(spi); diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 29a14f4..12d02f9 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -13,7 +13,7 @@ #define SPI_FLASH_16MB_BOUN 0x1000000
/* SECT flags */ -#define SECT_4K (1 << 1) +#define SECT_4K (1 << 1) #define SECT_32K (1 << 2) #define E_FSR (1 << 3)
@@ -29,8 +29,8 @@ #define CMD_WRITE_DISABLE 0x04 #define CMD_READ_STATUS 0x05 #define CMD_WRITE_ENABLE 0x06 -#define CMD_READ_CONFIG 0x35 -#define CMD_FLAG_STATUS 0x70 +#define CMD_READ_CONFIG 0x35 +#define CMD_FLAG_STATUS 0x70
/* Read commands */ #define CMD_READ_ARRAY_SLOW 0x03 @@ -57,7 +57,7 @@ /* SST specific */ #ifdef CONFIG_SPI_FLASH_SST # define SST_WP 0x01 /* Supports AAI word program */ -# define CMD_SST_BP 0x02 /* Byte Program */ +# define CMD_SST_BP 0x02 /* Byte Program */ # define CMD_SST_AAI_WP 0xAD /* Auto Address Incr Word Program */
int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 6aa7086..4251b1b 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -152,7 +152,8 @@ static const struct spi_flash_params spi_flash_params_table[] = { */ };
-struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, u8 *idcode) +static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, + u8 *idcode) { const struct spi_flash_params *params; struct spi_flash *flash; @@ -189,6 +190,7 @@ struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, u8 *idcode)
flash->spi = spi; flash->name = params->name; + flash->memory_map = spi->memory_map;
/* Assign spi_flash ops */ flash->write = spi_flash_cmd_write_ops; @@ -203,7 +205,6 @@ struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, u8 *idcode) flash->page_size = (ext_jedec == 0x4d00) ? 512 : 256; flash->sector_size = params->sector_size; flash->size = flash->sector_size * params->nr_sectors; - flash->memory_map = spi->memory_map;
/* Compute erase sector and command */ if (params->flags & SECT_4K) { @@ -224,8 +225,8 @@ struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, u8 *idcode) flash->poll_cmd = CMD_FLAG_STATUS; #endif
+ /* Configure the BAR - discover bank cmds and read current bank */ #ifdef CONFIG_SPI_FLASH_BAR - /* Configure the BAR - discover bank cmds and read current bank */ u8 curr_bank = 0; if (flash->size > SPI_FLASH_16MB_BOUN) { flash->bank_read_cmd = (idcode[0] == 0x01) ? diff --git a/include/spi.h b/include/spi.h index c2086fc..5164d43 100644 --- a/include/spi.h +++ b/include/spi.h @@ -25,24 +25,24 @@ #define SPI_PREAMBLE 0x80 /* Skip preamble bytes */
/* SPI transfer flags */ -#define SPI_XFER_BEGIN 0x01 /* Assert CS before transfer */ -#define SPI_XFER_END 0x02 /* Deassert CS after transfer */ -#define SPI_XFER_MMAP 0x08 /* Memory Mapped start */ -#define SPI_XFER_MMAP_END 0x10 /* Memory Mapped End */ +#define SPI_XFER_BEGIN 0x01 /* Assert CS before transfer */ +#define SPI_XFER_END 0x02 /* Deassert CS after transfer */ +#define SPI_XFER_MMAP 0x08 /* Memory Mapped start */ +#define SPI_XFER_MMAP_END 0x10 /* Memory Mapped End */
/* Header byte that marks the start of the message */ -#define SPI_PREAMBLE_END_BYTE 0xec +#define SPI_PREAMBLE_END_BYTE 0xec
/** - * struct spi_slave: Representation of a SPI slave, - * i.e. what we're communicating with. + * struct spi_slave - Representation of a SPI slave * * Drivers are expected to extend this with controller-specific data. * - * bus: ID of the bus that the slave is attached to. - * cs: ID of the chip select connected to the slave. - * max_write_size: If non-zero, the maximum number of bytes which can - * be written at once, excluding command bytes. + * @bus: ID of the bus that the slave is attached to. + * @cs: ID of the chip select connected to the slave. + * @max_write_size: If non-zero, the maximum number of bytes which can + * be written at once, excluding command bytes. + * @memory_map: Address of read-only SPI flash access. */ struct spi_slave { unsigned int bus; diff --git a/include/spi_flash.h b/include/spi_flash.h index b7cce12..1ff5af4 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -27,13 +27,13 @@ * @size: Total flash size * @page_size: Write (page) size * @sector_size: Sector size - * @erase_size: Erase size + * @erase_size: Erase size * @bank_read_cmd: Bank read cmd * @bank_write_cmd: Bank write cmd * @bank_curr: Current flash bank * @poll_cmd: Poll cmd - for flash erase/program * @erase_cmd: Erase cmd 4K, 32K, 64K - * @memory_map: Address of read-only SPI flash access + * @memory_map: Address of read-only SPI flash access * @read: Flash read ops: Read len bytes at offset into buf * Supported cmds: Fast Array Read * @write: Flash write ops: Write len bytes from buf into offeset
Applied to u-boot-spi/master
-- Thanks, Jagan.
On Mon, Oct 7, 2013 at 7:47 PM, Jagannadha Sutradharudu Teki jagannadha.sutradharudu-teki@xilinx.com wrote:
- Add spaces, tabs
- Commenting.
- Rearrange code.
- Properties of supported FRAMs
printf(", mapped at %p", flash->memory_map); puts("\n"); spi_release_bus(spi);
u8 *idcode)
flash->memory_map = spi->memory_map; /* Assign spi_flash ops */ flash->write = spi_flash_cmd_write_ops;
flash->memory_map = spi->memory_map; /* Compute erase sector and command */ if (params->flags & SECT_4K) {
- struct spi_slave: Representation of a SPI slave,
- struct spi_slave - Representation of a SPI slave
- Drivers are expected to extend this with controller-specific data.
- bus: ID of the bus that the slave is attached to.
- cs: ID of the chip select connected to the slave.
- max_write_size: If non-zero, the maximum number of bytes which can
- @bus: ID of the bus that the slave is attached to.
- @cs: ID of the chip select connected to the slave.
- @max_write_size: If non-zero, the maximum number of bytes which can
- @memory_map: Address of read-only SPI flash access.
- @size: Total flash size
- @page_size: Write (page) size
- @sector_size: Sector size
- @erase_size: Erase size
- @bank_read_cmd: Bank read cmd
- @bank_write_cmd: Bank write cmd
- @bank_curr: Current flash bank
- @poll_cmd: Poll cmd - for flash erase/program
- @erase_cmd: Erase cmd 4K, 32K, 64K
- @read: Flash read ops: Read len bytes at offset into buf
- @write: Flash write ops: Write len bytes from buf into offeset
-- 1.8.3
Jagan Teki
