[PATCH 1/1] test: NULL dereference in test-uclass
If a test-uclass device is probed outside a test, uts is not defined. Avoid a NULL dereference in this case.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- test/dm/test-uclass.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/test/dm/test-uclass.c b/test/dm/test-uclass.c index 067701734a..d2d1e0f190 100644 --- a/test/dm/test-uclass.c +++ b/test/dm/test-uclass.c @@ -32,6 +32,9 @@ static int test_post_bind(struct udevice *dev) struct unit_test_state *uts = test_get_state(); struct dm_test_perdev_uc_pdata *uc_pdata;
+ if (!uts) + return 0; + dm_testdrv_op_count[DM_TEST_OP_POST_BIND]++; ut_assert(!device_active(dev));
@@ -57,6 +60,9 @@ static int test_pre_probe(struct udevice *dev) test-uclass.cstruct dm_test_uclass_perdev_priv *priv = dev_get_uclass_priv(dev); struct unit_test_state *uts = test_get_state();
+ if (!uts) + return 0; + dm_testdrv_op_count[DM_TEST_OP_PRE_PROBE]++; ut_assert(priv); ut_assert(device_active(dev)); @@ -70,6 +76,9 @@ static int test_post_probe(struct udevice *dev) struct udevice *prev = list_entry(dev->uclass_node.prev, struct udevice, uclass_node);
+ if (!uts) + return 0; + struct dm_test_uclass_perdev_priv *priv = dev_get_uclass_priv(dev); struct uclass *uc = dev->uclass;
@@ -103,6 +112,9 @@ static int test_init(struct uclass *uc) { struct unit_test_state *uts = test_get_state();
+ if (!uts) + return 0; + dm_testdrv_op_count[DM_TEST_OP_INIT]++; ut_assert(uclass_get_priv(uc));
-- 2.30.2
Hi Heinrich,
I am missing the motivation for this patch. In what situation does this occur?
